Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
Alexa TTS is sloooooooow
@rafale77 said in Alexa TTS is sloooooooow:
If you haven't changed anything in your setup, I am guessing it is some random lag in the cloud? I don't believe you want me to get on my soap box and recommend my local approach...
Nope, that's good :). That was my feeling as well, but to be clear this is NOT Alexa executing commands, that's still real quick. This is only TTS via Alexa. Which makes it a little more confusing.
However, does Google home do local TTS as well?
Google?? Nahh nothing will really be local with Google. It goes against their personal data collection business model. Our data on their cloud is their primary source of revenue. My approach to TTS has been to use the "say" command built in macOS from my desktop and sends it to my sonos speakers. I run a little node.js server which offers an http API which openLuup uses as I wrote a tiny function in the startup lua. It works without the hands (I mean the internet) and is instantaneous.
@toggledbits , any chance at all that MSR could one day gain a TTS-like facility on board? At least to the point that MP3 files could be stored in /storage/tts awaiting a "Play" command of some sort. I'm sure doing literal TTS locally is too big an ask, but gosh... what wouldn't we all give to gain at least some freedom from the cloud-based likes of Azure, Alexa, etc.
Actually I somewhat did this for myself watching traffic going through my local DNS (pihole) and firewall. I started doing this because of the recent QNAP ransomware attacks leading me to deploy more drastic DPI and IPS reporting. Boy, Android is nasty... The amount of data and frequency of calling home is amazing. I ended taking down wifi on my oven (which runs android) and my one android tablet (alexa/echo) which was the most unreliable piece of hardware I had. I also notice a similar behavior on iOS devices but unlike Android, you could disable it. Most of the data is about location on iOS. They data packets are much smaller and are much less frequent. Disabling them means disabling some services. Apple uses your data for relative localization: devices scan for one another MAC addresses over BT and wifi and they keep a registry of it on their cloud. This way based on triangulation of what devices one given device sees, it is able to better estimate its location even without GPS as it uses the other device's GPS. I think Google does the same but more frequently and collects a lot more data while preventing you from disabling. Honestly the data was too much for me to figure out what it was for Android.
I also have relatives who work in marketing companies who freaked me out when they told me what data they have access to from Google... Just piecing things together and is a bit of a leap since I don't have any Google home device. I had some nest ones though which moved to very restrictive cloud only API when they got bought by Google and lead me to get rid of them.Edit: Someone in Ireland has done a much deeper study on the topic than I:
The only thing I would add is that I think the author missed a setting in iOS which I found to completely disable all data sending. Also note the attitude of Google towards the whole thing is pretty comical but at the same time it is all very understandable since it is their business model to collect and sell data since they do not sell their OS and don't make a profit on the devices they sell. They make profit on their true products... our data.
Now Amazon is (was?) different. They are actually selling products and making a profit from them, not so much from the smart devices but more from the echo/eco system to get us to shop on their sites. It is a different business model. How long before it changes? I don't know. At least the example of how they handled the Philips hue API drastically from Google is a sign that they are not as laser focused on forcing a cloud approach.
@therealdb said in Alexa TTS is sloooooooow:
@catmanv2 yep, same for me yesterday. Today it seems to be back to normal latency.
Mine's been like this for some time. Just checking again and the same 10 second delay somewhere
try to update the .sh script. They released a new version yesterday, and they specifically changed the TTS part. It's working good for me, even if they removed announcements, it's still working with announcements for me
Do you have a link perchance? I can't find anything newer than Jan..
Cheers
@catmanv2 https://github.com/thorsten-gehrig/alexa-remote-control
My thanks, as ever
And as anticipated, my system remains completely silent. I did update the .SH file just now to v.0.18, but no change.
However, I am noticing some (potential) weirdness in Vera Log which perhaps are not anomalies, but I'm pasting below just in case. I just leave VeraAlexa in 'Debug' mode all the time now. The command I had issued (from MSR) was:
luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e textcommand:'tune in wwoz' -d 'Living Room'"}, 366)
Log contained the following, and I'm wondering why, for starters, most (not all) of my Echo devices are listed twice? why the response from .SH is ""? why the
setVar
/Devices
line references a device other thanLiving Room
? whyLatestResponse
appears empty? etc.:08 05/29/21 9:40:44.577 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x70dc2520> 08 05/29/21 9:40:44.577 JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e textcommand:'tune in wwoz' -d 'Living Room'"}, 366) <0x70dc2520> 08 05/29/21 9:40:44.577 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=0 <0x70dc2520> 08 05/29/21 9:40:44.577 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x70dc2520> 08 05/29/21 9:40:44.578 JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x70dc2520> 08 05/29/21 9:40:44.578 JobHandler_LuaUPnP::HandleActionRequest argument _r=1622299244559 <0x70dc2520> 08 05/29/21 9:40:44.578 JobHandler_LuaUPnP::HandleActionRequest device: 366 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: RunCommand <0x70dc2520> 08 05/29/21 9:40:44.579 JobHandler_LuaUPnP::HandleActionRequest argument Command=-e textcommand:'tune in wwoz' -d 'Living Room' <0x70dc2520> 50 05/29/21 9:40:44.580 luup_log:366: VeraAlexa[0.97@366](setVar@120):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",366) old value "" <0x70dc2520> 50 05/29/21 9:40:44.581 luup_log:366: VeraAlexa[0.97@366](runCommand@395):Executing command [runCommand]: "-e textcommand:'tune in wwoz' -d 'Living Room'" <0x70dc2520> 50 05/29/21 9:40:44.601 luup_log:366: VeraAlexa[0.97@366](setVar@120):setVar("urn:micasaverde-com:serviceId:HaDevice1","CommFailure","0",366) old value "0" <0x70dc2520> 50 05/29/21 9:40:44.602 luup_log:366: VeraAlexa[0.97@366](setVar@120):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","LatestResponse","",366) old value "" <0x70dc2520> 50 05/29/21 9:40:44.603 luup_log:366: VeraAlexa[0.97@366](@308):Response from Alexa.sh: "" <0x70dc2520> 50 05/29/21 9:40:44.622 luup_log:366: VeraAlexa[0.97@366](setVar@120):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","Devices","Anne's Alexa Apps, false,2f69293cc2c749f6854ad6c5b41aef43,MSHOP\ Kitchen, true,F00718703203T4,ECHO\ Yoga Room, true,90LF1071750H8V,ECHO\ Hall Bathroom, true,90LF1071750H7N,ECHO\ Everywhere, true,56c846877e416eaa3425d163619011,WHA\ Downstairs, false,095239c8124c46834ded97b5c947b7,THIRD_PARTY_AVS_MEDIA_DISPLAY\ Master Bedroom, true,70RR138143018W,ROOK\ Workshop, true,90LF1071750H4G,ECHO\ Guest Room, false,90U50991541T31,ECHO\ Alexa App for PC, false,0CE90F27F69FFF703570DE6C20E7BA,REAVER\ Fire Tablet, true,W0TC039353F2SX,TABLET\ Libra's Sonos Beam, true,89f9dcc0ab4085bcb59494f81c3726,THIRD_PARTY_AVS_SONOS_BOOTLEG\ Living Room, true,48978706f5459f890ef0ec5aa9fce9,THIRD_PARTY_AVS_MEDIA_DISPLAY\ Libra's Ezlo Voi, false,eea63a85e2419498871004faca7e4d,UNKNOWN\ This Device, true,60b747dc4ce292626be49b7c3d41,VOX\ Libra's Alexa Apps, false,56FEC32487,AMAZONMOBILEMUSIC_ANDROID\ ",366) old value "Anne's Alexa Apps, false,69293cc2c749f6854ad6c5b41aef43,MSHOP\ Kitchen, true,F00718703203T4,ECHO\ Yoga Room, true,90LF1071750H8V,ECHO\ Hall Bathroom, true,90LF1071750H7N,ECHO\ Everywhere, true,56c846877e416eaa3425d163619011,WHA\ Downstairs, false,095239c8124c46834ded97b5c947b7,THIRD_PARTY_AVS_MEDIA_DISPLAY\ Master Bedroom, true,70RR138143018W,ROOK\ Workshop, true,90LF1071750H4G,ECHO\ Guest Room, false,90U50991541T31,ECHO\ Alexa App for PC, false,0CE90F27F69FFF703570DE6C20E7BA,REAVER\ Fire Tablet, true,W0TC039353F2SX,TABLET\ Libra's Sonos Beam, true,89f9dcc0ab4085bcb59494f81c3726,THIRD_PARTY_AVS_SONOS_BOOTLEG\ Living Room, true,48978706f5459f890ef0ec5aa9fce9,THIRD_PARTY_AVS_MEDIA_DISPLAY\ Libra's Ezlo Voi, false,eea63ae2419498871004faca7e4d,UNKNOWN\ This Device, true,60b747dc4ce292626be49b7c3d41,VOX\ Libra's Alexa Apps, false,56FEC32487,AMAZONMOBILEMUSIC_ANDROID\ " <0x70dc2520> 08 05/29/21 9:40:58.658 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunLua <0x6d5c2520> 08 05/29/21 9:40:58.658 JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1","RunCommand",{Command="-e weather -d 'Living Room'"}, 366) <0x6d5c2520> 08 05/29/21 9:40:58.658 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=0 <0x6d5c2520> 08 05/29/21 9:40:58.659 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x6d5c2520> 08 05/29/21 9:40:58.659 JobHandler_LuaUPnP::HandleActionRequest argument action=RunLua <0x6d5c2520> 08 05/29/21 9:40:58.659 JobHandler_LuaUPnP::HandleActionRequest argument _r=1622299258640 <0x6d5c2520> 08 05/29/21 9:40:58.660 JobHandler_LuaUPnP::HandleActionRequest device: 366 service: urn:bochicchio-com:serviceId:VeraAlexa1 action: RunCommand <0x6d5c2520> 08 05/29/21 9:40:58.660 JobHandler_LuaUPnP::HandleActionRequest argument Command=-e weather -d 'Living Room' <0x6d5c2520> 50 05/29/21 9:40:58.661 luup_log:366: VeraAlexa[0.97@366](setVar@120):setVar("urn:bochicchio-com:serviceId:VeraAlexa1","OneTimePassCode","",366) old value "" <0x6d5c2520> 50 05/29/21 9:40:58.662 luup_log:366: VeraAlexa[0.97@366](runCommand@395):Executing command [runCommand]: "-e weather -d 'Living Room'" <0x6d5c2520>
NOTE: All names and S/N's redacted for privacy (so may appear inconsistent in listing)
@catmanv2 said in Alexa TTS is sloooooooow:
This is the LuaUPnP.log yes?
Yes. I get a very verbose response set like that in Vera's LuaUPnP Log every time I attempt one of the Lua commands I use for testing. Some worked with previous revisions, others not, but right now ... literally nothing works for me.
I'm wondering if maybe I have too many Alexa devices defined in my account... or something else unique to "me" that's causing VeraAlexa to choke.
Whenever I update any component of the VeraAlexa plug-in (whether through WinSCP or by dragging files into App > Develop), I always set "Configured" back to
and restart Vera, so things have a chance to settle. The cookie is safely there, and "Configured" always sets to1
without any trouble.It's as if the plug-in wants to work, but simply doesn't, for me.
@librasun are you on Vera or OpenLuup?
What's in your .alexa.devicelist.all? If you've got duplicate entries it's probably worth deleting it and letting it re-create.
I've just realised my 'new' Echo is not listed, but it's in the guess bedroom so doesn't get used.
To answer your question, I inspected the contents of my .alexa.devicelist.json file (I see no 'all' file like you mentioned), and found -- after putting it through a JSON Pretty Print converter and filtering for accountName -- just a single copy of each device on my account.
Egads, though, the file is 931 lines long, lol!
If you're suggesting I delete that file, I'm game, but am generally loath to take stabs in the dark like that until I have more data.
AFAIK you should have:
.alexa.devicelist.txt
.alexa.cookie
.alexa.devicelist.jsonI think the lack of some or more of these could be part of your issue. Are you on Vera still? I forget
Totally get what you mean about deleting stuff. I tend to rename ;). My understanding is they should be created automagically.
Yep, am still on Vera Plus. I'll do the rename you suggest IF I can find the .all file in question. Weird that I haven't seen it yet in WinSCP (which is definitely showing me any hidden/system files).
When I do a search for alexa starting at Vera's root directory, here are the results (am I seeing duplicates?):
/etc/cmh-ludl/L_AmazonAlexaHelper.lua.lzo /storage/cmh-ludl/L_AmazonAlexaHelper.lua.lzo /etc/cmh-ludl/alexa.png.lzo /etc/cmh-ludl/D_VeraAlexa1.xml.lzo /etc/cmh-ludl/I_VeraAlexa1.xml.lzo /etc/cmh-ludl/L_VeraAlexa1.lua.lzo /etc/cmh-ludl/S_VeraAlexa1.xml.lzo /storage/cmh-ludl/alexa.png.lzo /storage/cmh-ludl/D_VeraAlexa1.xml.lzo /storage/cmh-ludl/I_VeraAlexa1.xml.lzo /storage/cmh-ludl/L_VeraAlexa1.lua.lzo /storage/cmh-ludl/S_VeraAlexa1.xml.lzo /storage/alexa/.alexa.cookie /storage/alexa/.alexa.devicelist.json /storage/alexa/alexa_remote_control.sh.old /storage/alexa/alexa_remote_control.sh /storage/alexa/.alexa.cmd /storage/alexa/.alexa.volume.4256c846877e416eaa3425d163619011 /storage/alexa/.alexa.volume.90F00718703203T4 /storage/alexa/.alexa.volume.d889f9dcc0ab4085bcb59494f81c3726 /storage/alexa/.alexa.volume.eb48978706f5459f890ef0ec5aa9fce9 /storage/alexa/.alexa.volume.G070RR138143018W /storage/alexa/.alexa.volume.G090LF1071750H4G /storage/alexa/.alexa.volume.G090LF1071750H7N /storage/alexa/.alexa.volume.G090LF1071750H8V /storage/alexa/.alexa.volume.G0W0TC039353F2SX
