  4. Change in Plans (Don't Panic)
30 Posts 15 Posters 11.8k Views 14 Watching
    Thanks to all who have replied/volunteered. Variety of devices is key, so anything and everything is helpful. As you may have seen in these forums, even several months into fairly stable integrations for the other hubs, devices keep popping up with little exceptions or gaps in completion. More data is better is less. All of the interfaces drop files in the logs folder at the moment that I can use for fairly good diagnostics and forensics, so that theme will continue and get some embellishments for eZLO.
    I expect the first wave of testing will just be "look and see"... do the devices come in as correct MSR entities, do they have their correct attributes, and are they correctly identified and, where appropriate, assigned sensible system capabilities (in addition to extension capabilities of the x_ezlo_etc variety). Startup configuration is also always a first-level challenge, and in this case, we'll have two different options: secured access (login through eZLO's cloud to get a local access token), and unsecured access (secured access can be disabled on the hub, eliminating the need for cloud login/token requests to get local access to the hub). Login + attributes will enable all of the rule/condition capabilities automatically. The second wave will follow immediately (as in with the next breath) to see that actions work and to what extent they need extension or repair, and that completes reactions. Things converged pretty quickly with the other three interfaces, so I'm hopeful this can be highly functional in short order.
      I have a VeraPlus (daily driver), another VeraPlus (used/spare), an eZLO Atom 2.0 (unused), Vera Edge running the LInux f/w (unused), an eZLO Plus (beta testing / unused) and an old Vera 1 (connected / idle) divided among two different residences.
      @toggledbits , surely others have made a similar offer by now, so I presume you are "set" for want of controllers -- but IF you require any of these for use in-house, just ask and I'll happily ship/donate.
      Likewise, IF you need me to test some particular thing out from my side (Synology NAS > Docker > MSR > hub(s)), also just ask. Who knows, it might be the first/last thing I ever do with eZLO hardware, which otherwise is going in the trash at some point.
      Glad you made this decision; I was concerned that you might inadvertently wind up with spare time on your hands. Oh, and THANK YOU for so thoughtfully grandfathering those who've toiled in the trenches alongside you lo these many weeks and months. For that you will not be sorry.
      • Libra
        • Libra
        @librasun I actually have a pretty big fist full of controllers myself. It's not really controllers I'm wanting for, it's devices and environments. The more hands this touches that aren't mine, the more things break, and the better things get for it. Hold on to them!
        @librasun said in Change in Plans (Don't Panic):
        I absolutely doubt most users of the Atom or PlugHub would be a user of MSR (except in some fringe cases, like for an out-building). But those eZLO Plus's (in full or prototype/skeletal form) could be useful. They seem to have a similar architecture to the Raspberry Pi 4. Maybe once I get the ZWaveJS interface fleshed out (that's also been in the works), I can just publish an MSR replacement firmware for the Plus hardware. You know, for science. 😉
        cw-kidC K 2 Replies Last reply
          @toggledbits said in Change in Plans (Don't Panic):
          😳 So would it also act as a Z-Wave radio?
          Or would you still need another second hub like Vera or the Ezlo or Hubitat etc, to act as the Z-Wave controller?
            ZWaveJS would just talk to the on-board ZWave chip (via a serial/USB interface). Vera works the same way. So, yes, it would function as the ZWave radio in addition to being the rules engine.
            cw-kidC therealdbT 2 Replies Last reply
              So an all in one controller then!
              Might have to get my hands on another Ezlo Plus hub, so I can test both setups, native Ezlo or MSR with Z-Wave JS.
                Looking forward to this, so I could add openluup to the mix and call it a day 🤣
                  I have a plus, but not many devices on it. I use it for broad link as i could not get the broadlink2 plugin working on openloop. will to test though. Like the idea of Zwavejs, love science.
                  • F Offline
                    I have as many before me, a Ezlo Plus laying around, and collecting dust. I've been waiting for a good reason to use it. When I got the Ezlo Plus, and I heard of the new Z-wave standard with better range I went really hopeful. Combined with MSR it looked like a winning concept. But the lack of stabilty, a working UI, and non-beta made me loose interest. If I can contribute in any way, I'd be honoured.
                      While I think a complete replacement firmware would be a fun exercise (and very possibly useful), we already have shown with openLuup and MSR that a Vera on its own is pretty stable in a reduced role as a ZWave radio and little else. So far my testing with the eZLO hub is yielding similar results, with the added benefit that it's demonstrably more stable when ZWave devices become unreachable (the Achilles Heel of current Vera firmware). I suspect we'll find that MSR running on a Pi, NAS, or other host against an eZLO hub still on its native firmware gives almost all of the benefits, without the need to replace the firmware on the hub itself. It will be fun to try it both ways, but I suspect that the simplest solution is going to be the best. And it will be here in a few days, where figuring out the firmware replacement will likely take a good bit more effort (and so is not really a goal, currently, just more of an experiment for a future weekend).
                      • wmarcolinW Offline
                        I have already commented on the other forum that my VeraPlus was saved from an incinerator or the tires of my car a few times, thanks to Reactor, and gained new life with MSR, so Patrick you know that you have in my person a collaborator (with limitations of technical knowledge), but a person who likes to explore and especially give suggestions that help users.
                        But, in my humble opinion, I will not make the mistake of buying an eZLO, I am seriously considering investing now in a Hubitat because I am tired of my VeraPlus being incompatible with any ZegBee or other devices with S2. The eZLO developers should follow the same line of not listening to the 3PP, the independent developers, and go back to repeating Vera's mistakes in my opinion.
                        This way I recognize your huge effort for the HA community, I am sure you have done a lot but in this new eZLO endeavor I will not be able to help, count me full on MSR for VeraPlus and Hubitat.
                          My unwillingness to base my own HA on eZLO is what delayed this eventuality, so I completely understand. There's a community that needs this, though, and they are my community from the Vera days. While we may be of the same mind with respect to the future, it's clear that a great many people are still clinging to hope. If they want to stay and wait it out (now nearly three years in the making and not near completion, IMO), at least I can throw them a lifeline to make straddling the Vera-eZLO divide less painful.
                            #22
                            I have to say my Ezlo Plus is extremely fast as far a Z-Wave communications are concerned. I don't have many Z-Wave devices directly paired to the Ezlo hub yet, but the ones that are, are very quick !
                            I setup a Z-wave door contact sensor on a walk in cupboard door and a Z-Wave light bulb and two scenes created on the Ezlo Plus, one for open and one for close.
                            The bulb turns on instantly and I mean instantly as soon as I open the door even just a little bit when it breaks the door contacts connection.
                            Yes the Ezlo software is still very lacking and buggy and all still being developed.
                            But we have MSR support coming for Ezlo hubs soon and Bill the Home Remote dashboard app developer told me only yesterday he is still planning to support Ezlo hubs and it will hopefully happen this summer. So with MSR and Home Remote what other interfaces do you need?
                            The Ezlo hub can act just as a Z-Wave radio as my Vera Plus does now today.
                            I am in no rush to replace my production Vera Plus but I will likely one day migrate all the devices to the Ezlo hub, especially if it works also well with Zigbee 3.0 devices, which Vera hubs do not.
                            PablaP 1 Reply Last reply
                              @cw-kid The only thing Ezlo is missing is proper plugins, I use plugins for my car, A/V amps, harmony hub etc these will likely never make it to the Ezlo platform. Otherwise with MSR + Ezlo its not a bad set up
                                #24
                                Yeah that is true.
                                I use the Harmony plugin as well.
                                And I'm still upset with Logitech..
                                  Yeah that is true.
                                  @cw-kid Why? I'm going to have to replace my aging Harmony one soon, and no idea what with....
                                    Exactly replace it with what?
                                    I've used Harmony remotes for longer than I can remember.
                                    The Elite is the best remote they ever made.
                                      @cw-kid Oh! I see. That's why.
                                      Personally I loved my Pronto. Was so easy to get codes on.
                                        Yes Philips Pronto another great dead product.
                                          Everyone, I've had a change in thinking.
                                          As many of you know, I had decided to not build an MSR interface for eZLO's new controllers, for multiple reasons, not the least of which was that I had chosen not to use an eZLO hub in my future HA. I am currently straddling three hubs: Vera, Home Assistant, and Hubitat. I am actually very much enjoying the flexibility this has provided. But these three hubs are enough for the moment, and when the venerable Vera Plus on which my house has operated since 2017 dies, I will likely just move the rest of my ZWave devices to the other hubs and reduce by one.
                                          Another reason for my previous decision was the risk of fluidity/instability in the eZLO APIs. Since this is first generation work, and even now as they approach the three-year mark on development and are still in "beta" with much functionality still incomplete or missing altogether (plugin UI framework?... anyone? anyone?), it stands to reason that, like all projects in this phase in particular, choices are made that need to be revisited. To be fair, Hass and Hubitat are not immune from this either, even as much more mature products with greater market penetration. In any case, I've demurred because of the high perceived risk of change and breakage, and didn't want to put myself (again) on the critical path of my own user base waiting for me to catch up. I accept now, however, that events like this are just part and parcel of the environment in which I've chosen to work. As I said, if it's not eZLO changing something, it's going to be Hass, or something else. I haven't had a breaking change hit from the Hubitat side yet, but it's probably just a matter of time. Just as I seek to improve my work, they must seek to improve theirs.
                                          The upshot is that I've decided to write an eZLO interface, and I've been working on that for a few days and now have a working prototype running. It works with the few devices I have available for it, and there's a lot that's assumed and untested about all the others. Think back to March, when MSR was first released -- the process of going through and stabilizing these interfaces under all the different external conditions, with devices in your environments that I don't, and sometimes cannot, have -- it takes time. Drilling out all of the details of device behaviors and data, and how each hub handles them differently, takes time. But it's going to be a reality. Aside from this, reading the other forums makes me realize just how much this is needed, if only because there appears as yet to be no articulated concrete plan (e.g. words beyond a promise with no date) to support easy migration from a Vera to an eZLO. MSR touts itself as a tool to assist such migrations between hubs. An eZLO interface must exist.
                                          To set expectations: you'll see the first version of this interface in a build in the next couple of weeks. It will be an add-in. Like MSR itself, I will be limiting the initial audience, and those of you that participate in the early use and testing will be asked to provide lots of diagnostics and feedback (so please don't ask/participate if you're not willing and able to put in the time). It's brand new, unfinished work; there will be lots of bugs, and lots of holes, and it's going to take a lot to get them all squashed and filled, respectively.
                                          Based on what I've learned so far from this project, I also want to forewarn you that it may include access to my cloud infrastructure for automatic logging (to make our mutual efforts to examine problems easier and faster), at least during the early stages. At the moment, MSR has no hard Internet-access dependencies, so this is a change for this interface work.
                                          Also, I probably will ultimately be charging a modest monthly or annual subscription for the eZLO interface, which is a change from policy and practice to date. The amount of effort the project has demanded and can demand in future makes it necessary that I consider a business model. I know that gives some pause, but it should also give you confidence that I am thinking of a long-term future. But, those of you who, as of this writing, hold active accounts on the MSR bug tracker and have participated so valuably in the testing and improvement of MSR, are grand-fathered in to a perpetual (personal/non-commercial use) license to MSR and this interface (no fees, at least for what parts are produced by my hand; I cannot control what others may choose to do if/when third party development takes root). I am considering extending that benefit to everyone who has donated to my projects from the start to date; that is, including those who supported Reactor for Vera, without which MSR would never had been born.
                                          I can probably predict from these forums and others who the active eZLO users are going to be, but if you want to work with me on it, please let me know by reply here. I will be relying on you heavily, because I am not going to be a big consumer of the hub, so a lot of the work will require data collected from you and your hub and investigative work on that evidence, rather than first-hand experience and witnessed events in my own environment. But I'm confident it will work, as much gets done this way already, and investing in more and deeper troubleshooting tools is always a good investment.
                                          Thanks to all of you who have supported this project. Onward...
                                          parkercP Offline
                                          parkercP Offline
                                          parkerc
                                          No… don’t say that ! (Don’t jinx it !!)
                                          While i didn’t think it would get much better than my Vera 3 (way back when) I’d be sad to see my VeraPlus go…
                                            154.9k
