Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Power_switch.state - no change state - EzloPlus - Msr v. 21351-a3aef - Synology Docker
Hi, Power Switch and Dimmer don't change state, but seems only for this manifacture that I have:
Widom Dimmer and Double Switch.
On Ezlo plus they change correctly state, but in MSR Entities they are always on power_switch.state=false also If I put them ON with a reaction.EzloPlus - Msr v. 21351-a3aef - Synology Docker
[latest-21351]2021-12-18T15:48:52.612Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:48:52.612Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:49:41.720Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:49:41.720Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:50:22.258Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_61475325129e29124dfcd7e6 [latest-21351]2021-12-18T15:50:22.259Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_61475325129e29124dfcd7e6 ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_61475325129e29124dfcd7e6 at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:51:09.464Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:51:09.465Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:51:09.514Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:51:09.515Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:52:02.630Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:52:02.631Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:52:02.680Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:52:02.681Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:52:51.736Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:52:51.736Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28) [latest-21351]2021-12-18T15:52:51.764Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf [latest-21351]2021-12-18T15:52:51.764Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19) at /opt/reactor/server/lib/EzloController.js:1057:257 at Array.forEach (<anonymous>) at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55) at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815) at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48) at WebSocket.emit (node:events:390:28) at WebSocket.emit (node:domain:475:12) at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20) at Receiver.emit (node:events:390:28)
At the moment the bulb is on, and this is what I see in Entities
dimming.level=0
dimming.step=0.1
energy_sensor.units=null
energy_sensor.value=null
x_ezlo_device.battery_powered=false
x_ezlo_device.category="dimmable_light"
x_ezlo_device.manufacturer="Unknown"
x_ezlo_device.model="Unknown"
x_ezlo_device.parent=""
x_ezlo_device.reachable=true
x_ezlo_device.ready=true
x_ezlo_device.room="613e2012129e2912114c0938"
x_ezlo_device.status="idle"
x_ezlo_device.subcategory="dimmable_in_wall"
x_ezlo_device.type_id="329_4628_2560"
x_ezlo_item.dimmer=0
x_ezlo_item.dimmer_down=0
x_ezlo_item.dimmer_stop=0
x_ezlo_item.dimmer_up=0
x_ezlo_item.electric_meter_kwh=0.492000013589859
x_ezlo_item.electric_meter_watt=0
x_ezlo_item.meter_reset=0
x_ezlo_item.switch=false
x_ezlo_object.id="6147578c129e29124dfcd814"
zwave_device.capabilities=null
zwave_device.failed=false
zwave_device.manufacturer_info=["Unknown","Unknown",null]
zwave_device.node_id=41
Capabilities: dimming, energy_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors -
Thanks for the report and good info. I've posted a blind update 21352. Upgrade your container to that and let's see if those errors go away (spoiler: they should).
Hi, thanks... It is ok for power_switch.state when the bulb is on. This is what I see in entities:
dimming.level=1 dimming.step=0.1 energy_sensor.units=null energy_sensor.value=0.5 power_sensor.units=null power_sensor.value=2.48000001907349 power_switch.state=true x_ezlo_device.battery_powered=false x_ezlo_device.category="dimmable_light" x_ezlo_device.manufacturer="Unknown" x_ezlo_device.model="Unknown" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2012129e2912114c0938" x_ezlo_device.status="idle" x_ezlo_device.subcategory="dimmable_in_wall" x_ezlo_device.type_id="329_4628_2560" x_ezlo_item.dimmer=100 x_ezlo_item.dimmer_down=0 x_ezlo_item.dimmer_stop=0 x_ezlo_item.dimmer_up=0 x_ezlo_item.electric_meter_kwh=0.5 x_ezlo_item.electric_meter_watt=2.48000001907349 x_ezlo_item.meter_reset=0 x_ezlo_item.switch=true x_ezlo_object.id="6147578c129e29124dfcd814" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Unknown","Unknown",null] zwave_device.node_id=41 zwave_device.version_info=null Capabilities: dimming, energy_sensor, power_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
but in log, there is stil this problem:
[latest-21352]2021-12-19T22:26:48.725Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1 [latest-21352]2021-12-19T22:26:48.808Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1 [latest-21352]2021-12-19T22:26:48.830Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1 [latest-21352]2021-12-19T22:27:13.704Z <wsapi:INFO> client "172.18.0.1#3" closed, code=1001, reason= [latest-21352]2021-12-19T22:27:14.191Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1 [latest-21352]2021-12-19T22:27:19.338Z <wsapi:INFO> client "172.18.0.1#1" closed, code=1001, reason= [latest-21352]2021-12-19T22:27:19.749Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1 [latest-21352]2021-12-19T22:27:25.745Z <wsapi:INFO> client "172.18.0.1#2" closed, code=1001, reason= [latest-21352]2021-12-19T22:29:32.187Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.187Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.237Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.237Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.289Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.289Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.389Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:32.389Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:44.819Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:44.820Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null [latest-21352]2021-12-19T22:29:58.871Z <Rule:5:Rule.js:771> Rule#rule-kthqmgb6 vR4 DLT 01 Bulb ID requesting eval; entity-changed from Entity#vera>device_726
OK. That's almost working as it should. At least it's not getting in the way of the state update. One more time... blind build 21353 is now available.
I divide in two posts the log :
[latest-21353]2021-12-19T23:08:39.981Z <Structure:INFO> Starting controller EzloController#ezlo [latest-21353]2021-12-19T23:08:39.995Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking... [latest-21353]2021-12-19T23:08:39.997Z <EzloController:ERR> EzloController#ezlo implementation data references undefined capability power_sensor#electric_meter_watt [latest-21353]2021-12-19T23:08:39.998Z <EzloController:ERR> EzloController#ezlo implementation data references undefined capability energy_sensor#electric_meter_kwh [latest-21353]2021-12-19T23:08:39.999Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled) [latest-21353]2021-12-19T23:08:40.000Z <Structure:INFO> Starting controller OWMWeatherController#weather [latest-21353]2021-12-19T23:08:40.028Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-21353]2021-12-19T23:08:40.030Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online. [latest-21353]2021-12-19T23:08:40.058Z <EzloController:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000 [latest-21353]2021-12-19T23:08:40.065Z <app:INFO> Structure running; pausing for controllers' initial ready [latest-21353]2021-12-19T23:08:40.163Z <VeraController:WARN> VeraController#vera ignoring geotag ([Object]{ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": ", "color": "006e45", "latitude": "43.79130238128065", "longitude": "11.251052767038345", "name": "", "status": --null-- } ] }) for user 1520131, user not in user list [latest-21353]2021-12-19T23:08:40.203Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://10.0.4.119:17000) [latest-21353]2021-12-19T23:08:40.204Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub... [latest-21353]2021-12-19T23:08:40.272Z <EzloController:INFO> EzloController#ezlo hub "90000464" is h2.1 (undefined) firmware "2.0.23.1817.1" [latest-21353]2021-12-19T23:08:40.315Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed [latest-21353]2021-12-19T23:08:40.317Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online. [latest-21353]2021-12-19T23:08:40.596Z <VeraController:NOTICE> Controller VeraController#vera is now online. [latest-21353]2021-12-19T23:08:41.069Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0982" (Entity#ezlo>device_613e2959129e2912114c0982); has [Array][ "613e2959129e2912114c0983", "basic", "613e2959129e2912114c0984", "battery", "613e2959129e2912114c0985", "tampering_cover_alarm", "613e2959129e2912114c0986", "acceleration_x_axis", "613e2959129e2912114c0987", "acceleration_y_axis", "613e2959129e2912114c0988", "acceleration_z_axis", "613e2959129e2912114c0989", "motion", "613e2959129e2912114c098a", "security_threat" ] [latest-21353]2021-12-19T23:08:41.071Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0982" (Entity#ezlo>device_613e2959129e2912114c0982); has [Array][ "613e2959129e2912114c0983", "basic", "613e2959129e2912114c0984", "battery", "613e2959129e2912114c0985", "tampering_cover_alarm", "613e2959129e2912114c0986", "acceleration_x_axis", "613e2959129e2912114c0987", "acceleration_y_axis", "613e2959129e2912114c0988", "acceleration_z_axis", "613e2959129e2912114c0989", "motion", "613e2959129e2912114c098a", "security_threat" ] [latest-21353]2021-12-19T23:08:41.074Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c098d" (Entity#ezlo>device_613e2959129e2912114c098d); has [Array][ "613e2959129e2912114c098e", "temp" ] [latest-21353]2021-12-19T23:08:41.074Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c098d" (Entity#ezlo>device_613e2959129e2912114c098d); has [Array][ "613e2959129e2912114c098e", "temp" ] [latest-21353]2021-12-19T23:08:41.076Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c098f" (Entity#ezlo>device_613e2959129e2912114c098f); has [Array][ "613e2959129e2912114c0990", "lux" ] [latest-21353]2021-12-19T23:08:41.076Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c098f" (Entity#ezlo>device_613e2959129e2912114c098f); has [Array][ "613e2959129e2912114c0990", "lux" ] [latest-21353]2021-12-19T23:08:41.078Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor [latest-21353]2021-12-19T23:08:41.078Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c0991" (Entity#ezlo>device_613e2959129e2912114c0991); has [Array][ "613e2959129e2912114c0992", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.079Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0991" (Entity#ezlo>device_613e2959129e2912114c0991); has [Array][ "613e2959129e2912114c0992", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.094Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d55129e29124dfcd782" (Entity#ezlo>device_61425d55129e29124dfcd782); has [Array][ "61425d55129e29124dfcd783", "basic", "61425d56129e29124dfcd784", "battery", "61425d56129e29124dfcd785", "tampering_cover_alarm", "61425d56129e29124dfcd786", "acceleration_x_axis", "61425d56129e29124dfcd787", "acceleration_y_axis", "61425d56129e29124dfcd788", "acceleration_z_axis", "61425d56129e29124dfcd789", "motion", "61425d56129e29124dfcd78a", "security_threat" ] [latest-21353]2021-12-19T23:08:41.094Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d55129e29124dfcd782" (Entity#ezlo>device_61425d55129e29124dfcd782); has [Array][ "61425d55129e29124dfcd783", "basic", "61425d56129e29124dfcd784", "battery", "61425d56129e29124dfcd785", "tampering_cover_alarm", "61425d56129e29124dfcd786", "acceleration_x_axis", "61425d56129e29124dfcd787", "acceleration_y_axis", "61425d56129e29124dfcd788", "acceleration_z_axis", "61425d56129e29124dfcd789", "motion", "61425d56129e29124dfcd78a", "security_threat" ] [latest-21353]2021-12-19T23:08:41.095Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor [latest-21353]2021-12-19T23:08:41.096Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78b" (Entity#ezlo>device_61425d56129e29124dfcd78b); has [Array][ "61425d56129e29124dfcd78c", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.096Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78b" (Entity#ezlo>device_61425d56129e29124dfcd78b); has [Array][ "61425d56129e29124dfcd78c", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.097Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78d" (Entity#ezlo>device_61425d56129e29124dfcd78d); has [Array][ "61425d56129e29124dfcd78e", "temp" ] [latest-21353]2021-12-19T23:08:41.097Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78d" (Entity#ezlo>device_61425d56129e29124dfcd78d); has [Array][ "61425d56129e29124dfcd78e", "temp" ] [latest-21353]2021-12-19T23:08:41.098Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78f" (Entity#ezlo>device_61425d56129e29124dfcd78f); has [Array][ "61425d56129e29124dfcd790", "lux" ] [latest-21353]2021-12-19T23:08:41.099Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78f" (Entity#ezlo>device_61425d56129e29124dfcd78f); has [Array][ "61425d56129e29124dfcd790", "lux" ] [latest-21353]2021-12-19T23:08:41.106Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c693129e29124dfcd7a7" (Entity#ezlo>device_6145c693129e29124dfcd7a7); has [Array][ "6145c693129e29124dfcd7a8", "basic", "6145c693129e29124dfcd7a9", "battery", "6145c693129e29124dfcd7aa", "tampering_cover_alarm", "6145c693129e29124dfcd7ab", "acceleration_x_axis", "6145c693129e29124dfcd7ac", "acceleration_y_axis", "6145c694129e29124dfcd7ad", "acceleration_z_axis", "6145c694129e29124dfcd7ae", "motion", "6145c694129e29124dfcd7af", "security_threat" ] [latest-21353]2021-12-19T23:08:41.107Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c693129e29124dfcd7a7" (Entity#ezlo>device_6145c693129e29124dfcd7a7); has [Array][ "6145c693129e29124dfcd7a8", "basic", "6145c693129e29124dfcd7a9", "battery", "6145c693129e29124dfcd7aa", "tampering_cover_alarm", "6145c693129e29124dfcd7ab", "acceleration_x_axis", "6145c693129e29124dfcd7ac", "acceleration_y_axis", "6145c694129e29124dfcd7ad", "acceleration_z_axis", "6145c694129e29124dfcd7ae", "motion", "6145c694129e29124dfcd7af", "security_threat" ] [latest-21353]2021-12-19T23:08:41.108Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b0" (Entity#ezlo>device_6145c694129e29124dfcd7b0); has [Array][ "6145c694129e29124dfcd7b1", "temp" ] [latest-21353]2021-12-19T23:08:41.109Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b0" (Entity#ezlo>device_6145c694129e29124dfcd7b0); has [Array][ "6145c694129e29124dfcd7b1", "temp" ] [latest-21353]2021-12-19T23:08:41.110Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b2" (Entity#ezlo>device_6145c694129e29124dfcd7b2); has [Array][ "6145c694129e29124dfcd7b3", "lux" ] [latest-21353]2021-12-19T23:08:41.111Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b2" (Entity#ezlo>device_6145c694129e29124dfcd7b2); has [Array][ "6145c694129e29124dfcd7b3", "lux" ] [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b4" (Entity#ezlo>device_6145c694129e29124dfcd7b4); has [Array][ "6145c694129e29124dfcd7b5", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b4" (Entity#ezlo>device_6145c694129e29124dfcd7b4); has [Array][ "6145c694129e29124dfcd7b5", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.113Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7ba" (Entity#ezlo>device_6145c7ca129e29124dfcd7ba); has [Array][ "6145c7ca129e29124dfcd7bb", "basic", "6145c7ca129e29124dfcd7bc", "battery", "6145c7ca129e29124dfcd7bd", "motion", "6145c7ca129e29124dfcd7be", "security_threat" ] [latest-21353]2021-12-19T23:08:41.114Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7ba" (Entity#ezlo>device_6145c7ca129e29124dfcd7ba); has [Array][ "6145c7ca129e29124dfcd7bb", "basic", "6145c7ca129e29124dfcd7bc", "battery", "6145c7ca129e29124dfcd7bd", "motion", "6145c7ca129e29124dfcd7be", "security_threat" ] [latest-21353]2021-12-19T23:08:41.115Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c7ca129e29124dfcd7bf" (Entity#ezlo>device_6145c7ca129e29124dfcd7bf); has [Array][ "6145c7ca129e29124dfcd7c0", "lux" ] [latest-21353]2021-12-19T23:08:41.115Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7bf" (Entity#ezlo>device_6145c7ca129e29124dfcd7bf); has [Array][ "6145c7ca129e29124dfcd7c0", "lux" ] [latest-21353]2021-12-19T23:08:41.116Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c7ca129e29124dfcd7c1" (Entity#ezlo>device_6145c7ca129e29124dfcd7c1); has [Array][ "6145c7ca129e29124dfcd7c2", "temp" ] [latest-21353]2021-12-19T23:08:41.116Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7c1" (Entity#ezlo>device_6145c7ca129e29124dfcd7c1); has [Array][ "6145c7ca129e29124dfcd7c2", "temp" ] [latest-21353]2021-12-19T23:08:41.124Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd805" (Entity#ezlo>device_614755cd129e29124dfcd805); has [Array][ "614755cd129e29124dfcd806", "basic", "614755cd129e29124dfcd807", "battery", "614755cd129e29124dfcd808", "tampering_cover_alarm", "614755cd129e29124dfcd809", "acceleration_x_axis", "614755cd129e29124dfcd80a", "acceleration_y_axis", "614755cd129e29124dfcd80b", "acceleration_z_axis", "614755cd129e29124dfcd80c", "motion", "614755cd129e29124dfcd80d", "security_threat" ] [latest-21353]2021-12-19T23:08:41.125Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd805" (Entity#ezlo>device_614755cd129e29124dfcd805); has [Array][ "614755cd129e29124dfcd806", "basic", "614755cd129e29124dfcd807", "battery", "614755cd129e29124dfcd808", "tampering_cover_alarm", "614755cd129e29124dfcd809", "acceleration_x_axis", "614755cd129e29124dfcd80a", "acceleration_y_axis", "614755cd129e29124dfcd80b", "acceleration_z_axis", "614755cd129e29124dfcd80c", "motion", "614755cd129e29124dfcd80d", "security_threat" ] [latest-21353]2021-12-19T23:08:41.126Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755cd129e29124dfcd80e" (Entity#ezlo>device_614755cd129e29124dfcd80e); has [Array][ "614755ce129e29124dfcd80f", "temp" ] [latest-21353]2021-12-19T23:08:41.126Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd80e" (Entity#ezlo>device_614755cd129e29124dfcd80e); has [Array][ "614755ce129e29124dfcd80f", "temp" ] [latest-21353]2021-12-19T23:08:41.127Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755ce129e29124dfcd810" (Entity#ezlo>device_614755ce129e29124dfcd810); has [Array][ "614755ce129e29124dfcd811", "lux" ] [latest-21353]2021-12-19T23:08:41.127Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755ce129e29124dfcd810" (Entity#ezlo>device_614755ce129e29124dfcd810); has [Array][ "614755ce129e29124dfcd811", "lux" ] [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755ce129e29124dfcd812" (Entity#ezlo>device_614755ce129e29124dfcd812); has [Array][ "614755ce129e29124dfcd813", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755ce129e29124dfcd812" (Entity#ezlo>device_614755ce129e29124dfcd812); has [Array][ "614755ce129e29124dfcd813", "seismic_intensity" ] [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.133Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.135Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.138Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.145Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.145Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.146Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
[latest-21353]2021-12-19T23:08:41.146Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.147Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.147Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.148Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.148Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.149Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.149Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.150Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.150Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.151Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.151Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.152Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.152Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.154Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.156Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.158Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.161Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.173Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198168b129e2918c5ce97bc" (Entity#ezlo>device_6198168b129e2918c5ce97bc); has [Array][ "6198168b129e2918c5ce97bd", "dimmer", "6198168b129e2918c5ce97be", "dimmer_up", "6198168b129e2918c5ce97bf", "dimmer_down", "6198168b129e2918c5ce97c0", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.174Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619816bb129e2918c5ce97c1" (Entity#ezlo>device_619816bb129e2918c5ce97c1); has [Array][ "619816bb129e2918c5ce97c2", "dimmer", "619816bb129e2918c5ce97c3", "dimmer_up", "619816bc129e2918c5ce97c4", "dimmer_down", "619816bc129e2918c5ce97c5", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.175Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198173f129e2918c5ce97c6" (Entity#ezlo>device_6198173f129e2918c5ce97c6); has [Array][ "6198173f129e2918c5ce97c7", "dimmer", "6198173f129e2918c5ce97c8", "dimmer_up", "6198173f129e2918c5ce97c9", "dimmer_down", "6198173f129e2918c5ce97ca", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.176Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "61981760129e2918c5ce97cb" (Entity#ezlo>device_61981760129e2918c5ce97cb); has [Array][ "61981760129e2918c5ce97cc", "dimmer", "61981760129e2918c5ce97cd", "dimmer_up", "61981760129e2918c5ce97ce", "dimmer_down", "61981760129e2918c5ce97cf", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.177Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "61981770129e2918c5ce97d0" (Entity#ezlo>device_61981770129e2918c5ce97d0); has [Array][ "61981770129e2918c5ce97d1", "dimmer", "61981770129e2918c5ce97d2", "dimmer_up", "61981770129e2918c5ce97d3", "dimmer_down", "61981770129e2918c5ce97d4", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.178Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198177e129e2918c5ce97d5" (Entity#ezlo>device_6198177e129e2918c5ce97d5); has [Array][ "6198177e129e2918c5ce97d6", "dimmer", "6198177e129e2918c5ce97d7", "dimmer_up", "6198177e129e2918c5ce97d8", "dimmer_down", "6198177e129e2918c5ce97d9", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.179Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198178b129e2918c5ce97da" (Entity#ezlo>device_6198178b129e2918c5ce97da); has [Array][ "6198178b129e2918c5ce97db", "dimmer", "6198178b129e2918c5ce97dc", "dimmer_up", "6198178b129e2918c5ce97dd", "dimmer_down", "6198178b129e2918c5ce97de", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.183Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198179b129e2918c5ce97df" (Entity#ezlo>device_6198179b129e2918c5ce97df); has [Array][ "6198179b129e2918c5ce97e0", "dimmer", "6198179b129e2918c5ce97e1", "dimmer_up", "6198179b129e2918c5ce97e2", "dimmer_down", "6198179b129e2918c5ce97e3", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.184Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817a6129e2918c5ce97e4" (Entity#ezlo>device_619817a6129e2918c5ce97e4); has [Array][ "619817a6129e2918c5ce97e5", "dimmer", "619817a7129e2918c5ce97e6", "dimmer_up", "619817a7129e2918c5ce97e7", "dimmer_down", "619817a7129e2918c5ce97e8", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.185Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817b2129e2918c5ce97e9" (Entity#ezlo>device_619817b2129e2918c5ce97e9); has [Array][ "619817b2129e2918c5ce97ea", "dimmer", "619817b3129e2918c5ce97eb", "dimmer_up", "619817b3129e2918c5ce97ec", "dimmer_down", "619817b3129e2918c5ce97ed", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.186Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817c2129e2918c5ce97ee" (Entity#ezlo>device_619817c2129e2918c5ce97ee); has [Array][ "619817c3129e2918c5ce97ef", "dimmer", "619817c3129e2918c5ce97f0", "dimmer_up", "619817c3129e2918c5ce97f1", "dimmer_down", "619817c3129e2918c5ce97f2", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.187Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817d0129e2918c5ce97f3" (Entity#ezlo>device_619817d0129e2918c5ce97f3); has [Array][ "619817d0129e2918c5ce97f4", "dimmer", "619817d0129e2918c5ce97f5", "dimmer_up", "619817d0129e2918c5ce97f6", "dimmer_down", "619817d0129e2918c5ce97f7", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.190Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817de129e2918c5ce97f8" (Entity#ezlo>device_619817de129e2918c5ce97f8); has [Array][ "619817de129e2918c5ce97f9", "dimmer", "619817de129e2918c5ce97fa", "dimmer_up", "619817de129e2918c5ce97fb", "dimmer_down", "619817de129e2918c5ce97fc", "dimmer_stop" ] [latest-21353]2021-12-19T23:08:41.192Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=door_lock cap keypad [latest-21353]2021-12-19T23:08:41.196Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e89442e" (Entity#ezlo>device_619903e9129e29123e89442e); has [Array][ "619903e9129e29123e89442f", "basic", "619903e9129e29123e894430", "battery", "619903e9129e29123e894431", "tampering_cover_alarm", "619903e9129e29123e894432", "battery_maintenance_state", "619903e9129e29123e894433", "dw_state", "619903e9129e29123e894434", "security_threat" ] [latest-21353]2021-12-19T23:08:41.196Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e89442e" (Entity#ezlo>device_619903e9129e29123e89442e); has [Array][ "619903e9129e29123e89442f", "basic", "619903e9129e29123e894430", "battery", "619903e9129e29123e894431", "tampering_cover_alarm", "619903e9129e29123e894432", "battery_maintenance_state", "619903e9129e29123e894433", "dw_state", "619903e9129e29123e894434", "security_threat" ] [latest-21353]2021-12-19T23:08:41.198Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "619903e9129e29123e894437" (Entity#ezlo>device_619903e9129e29123e894437); has [Array][ "619903ea129e29123e894438", "heat_alarm", "619903ea129e29123e894439", "security_threat" ] [latest-21353]2021-12-19T23:08:41.198Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e894437" (Entity#ezlo>device_619903e9129e29123e894437); has [Array][ "619903ea129e29123e894438", "heat_alarm", "619903ea129e29123e894439", "security_threat" ] [latest-21353]2021-12-19T23:08:41.200Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "619903ea129e29123e89443a" (Entity#ezlo>device_619903ea129e29123e89443a); has [Array][ "619903ea129e29123e89443b", "temp" ] [latest-21353]2021-12-19T23:08:41.200Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903ea129e29123e89443a" (Entity#ezlo>device_619903ea129e29123e89443a); has [Array][ "619903ea129e29123e89443b", "temp" ] [latest-21353]2021-12-19T23:08:41.239Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 1034ms
OK. Those are benign, but I'd still like to try and clean them up. There are devices listed that aren't in the previous upload you gave me, so can I ask that you use that upload link previously sent (in DM to you here) and upload the latest [data--see edit below] file from your
logs
directory? That will tell me what the devices are reporting more clearly.Edit: the file is now called
ezlo_inventory.json
for the latest version. -
If can help, today I added another zwave device "Widom Smart Plug" https://www.widom.it/wp-content/uploads/2019/08/Widom-Smart-Plug_EN_20190404_0.pdf
At the moment it is ON and in Entities power.switch_state is FALSEenergy_sensor.units="kilo_watt_hour" energy_sensor.value=0.0230000000447035 power_sensor.units="watt" power_sensor.value=36.7000007629395 power_switch.state=false x_ezlo_device.battery_powered=false x_ezlo_device.category="switch" x_ezlo_device.manufacturer="Unknown" x_ezlo_device.model="Unknown" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2037129e2912114c093e" x_ezlo_device.status="idle" x_ezlo_device.subcategory="interior_plugin" x_ezlo_device.type_id="329_4628_1792" x_ezlo_item.electric_meter_kwh=0.0230000000447035 x_ezlo_item.electric_meter_volt=230.399993896484 x_ezlo_item.electric_meter_watt=36.7000007629395 x_ezlo_item.meter_reset=0 x_ezlo_item.switch=false x_ezlo_object.id="61c18f96129e291255528096" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Unknown","Unknown",null] zwave_device.node_id=60 zwave_device.version_info=null Capabilities: energy_sensor, power_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors ```
OK. If you would please, upload your
ezlo_inventory.json
file again.I would also note that the
switch
item (seen in raw form inx_ezlo_item.switch
) also says false, so check in the (Vera/Ezlo) mobile app what it reports for state. It's not relevant what state the switch is physically in, only what state the hub thinks its in. If they don't agree, neither will Reactor. -
OK. New data maps with no further changes to previous work, so I'm going to go ahead and build. Watch for the update announcement in that topic.
Any errors in the log? You know you always need to look there whenever things don't seem right, yes?
Also, I would do a hard-refresh of the browser and open that page again. I have seen it get out of sync once in a while but I haven't been able to figure out why as yet.
Not so sure... try changing the switch state of one of them (toggle one of them manually), see if both attributes follow... I'm guessing they'll diverge...
what I can notice in "Entities" is that at the moment this device is OFF, but dimmer_level is =1
L Bulb Spot Widom Dimmer ezlo>device_61475325129e29124dfcd7e6 1 2:16:40 AM dimming.level=1 dimming.step=0.1 dimming.undefined=0 energy_sensor.undefined="KWh" energy_sensor.units="KWh" energy_sensor.value=0.994000017642975 power_sensor.undefined="W" power_sensor.units="W" power_sensor.value=7.96000003814697 power_switch.state=true power_switch.undefined=false x_ezlo_device.battery_powered=false x_ezlo_device.category="dimmable_light" x_ezlo_device.manufacturer="Unknown" x_ezlo_device.model="Unknown" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2024129e2912114c093b" x_ezlo_device.status="idle" x_ezlo_device.subcategory="dimmable_in_wall" x_ezlo_device.type_id="329_4628_2560" x_ezlo_item.dimmer=0 x_ezlo_item.dimmer_down=0 x_ezlo_item.dimmer_stop=0 x_ezlo_item.dimmer_up=0 x_ezlo_item.electric_meter_kwh=0.996999979019165 x_ezlo_item.electric_meter_watt=0 x_ezlo_item.meter_reset=0 x_ezlo_item.switch=false x_ezlo_object.id="61475325129e29124dfcd7e6" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Unknown","Unknown",null] zwave_device.node_id=38 zwave_device.version_info=null Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
or this other one, dimmer level diverge from msr to ezlo
K Bulb Domitech ezlo>device_61423589129e29124dfcd756 0 2:30:41 AM dimming.level=0 dimming.step=0.1 dimming.undefined=0.25 power_switch.state=false power_switch.undefined=true x_ezlo_device.battery_powered=false x_ezlo_device.category="dimmable_light" x_ezlo_device.manufacturer="Domitech" x_ezlo_device.model="ZE27EU" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2020129e2912114c093a" x_ezlo_device.status="idle" x_ezlo_device.subcategory="dimmable_bulb" x_ezlo_device.type_id="526_19522_12596" x_ezlo_item.dimmer=25 x_ezlo_item.dimmer_down=0 x_ezlo_item.dimmer_stop=0 x_ezlo_item.dimmer_up=0 x_ezlo_item.switch=true x_ezlo_object.id="61423589129e29124dfcd756" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Domitech","ZE27EU",null] zwave_device.node_id=26 zwave_device.version_info=null Capabilities: dimming, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
