  4. Power_switch.state - no change state - EzloPlus - Msr v. 21351-a3aef - Synology Docker
22 Posts 2 Posters 6.8k Views 2 Watching
  • N Offline
    N Offline
    I divide in two posts the log :
    [latest-21353]2021-12-19T23:08:39.981Z <Structure:INFO> Starting controller EzloController#ezlo
    [latest-21353]2021-12-19T23:08:39.995Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
    [latest-21353]2021-12-19T23:08:39.997Z <EzloController:ERR> EzloController#ezlo implementation data references undefined capability power_sensor#electric_meter_watt
    [latest-21353]2021-12-19T23:08:39.998Z <EzloController:ERR> EzloController#ezlo implementation data references undefined capability energy_sensor#electric_meter_kwh
    [latest-21353]2021-12-19T23:08:39.999Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
    [latest-21353]2021-12-19T23:08:40.000Z <Structure:INFO> Starting controller OWMWeatherController#weather
    [latest-21353]2021-12-19T23:08:40.028Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-21353]2021-12-19T23:08:40.030Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-21353]2021-12-19T23:08:40.058Z <EzloController:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
    [latest-21353]2021-12-19T23:08:40.065Z <app:INFO> Structure running; pausing for controllers' initial ready
    [latest-21353]2021-12-19T23:08:40.163Z <VeraController:WARN> VeraController#vera ignoring geotag ([Object]{ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": ", "color": "006e45", "latitude": "43.79130238128065", "longitude": "11.251052767038345", "name": "", "status": --null-- } ] }) for user 1520131, user not in user list
    [latest-21353]2021-12-19T23:08:40.203Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://10.0.4.119:17000)
    [latest-21353]2021-12-19T23:08:40.204Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
    [latest-21353]2021-12-19T23:08:40.272Z <EzloController:INFO> EzloController#ezlo hub "90000464" is h2.1 (undefined) firmware "2.0.23.1817.1"
    [latest-21353]2021-12-19T23:08:40.315Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
    [latest-21353]2021-12-19T23:08:40.317Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
    [latest-21353]2021-12-19T23:08:40.596Z <VeraController:NOTICE> Controller VeraController#vera is now online.
    [latest-21353]2021-12-19T23:08:41.069Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0982" (Entity#ezlo>device_613e2959129e2912114c0982); has [Array][ "613e2959129e2912114c0983", "basic", "613e2959129e2912114c0984", "battery", "613e2959129e2912114c0985", "tampering_cover_alarm", "613e2959129e2912114c0986", "acceleration_x_axis", "613e2959129e2912114c0987", "acceleration_y_axis", "613e2959129e2912114c0988", "acceleration_z_axis", "613e2959129e2912114c0989", "motion", "613e2959129e2912114c098a", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.071Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0982" (Entity#ezlo>device_613e2959129e2912114c0982); has [Array][ "613e2959129e2912114c0983", "basic", "613e2959129e2912114c0984", "battery", "613e2959129e2912114c0985", "tampering_cover_alarm", "613e2959129e2912114c0986", "acceleration_x_axis", "613e2959129e2912114c0987", "acceleration_y_axis", "613e2959129e2912114c0988", "acceleration_z_axis", "613e2959129e2912114c0989", "motion", "613e2959129e2912114c098a", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.074Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c098d" (Entity#ezlo>device_613e2959129e2912114c098d); has [Array][ "613e2959129e2912114c098e", "temp" ]
    [latest-21353]2021-12-19T23:08:41.074Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c098d" (Entity#ezlo>device_613e2959129e2912114c098d); has [Array][ "613e2959129e2912114c098e", "temp" ]
    [latest-21353]2021-12-19T23:08:41.076Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c098f" (Entity#ezlo>device_613e2959129e2912114c098f); has [Array][ "613e2959129e2912114c0990", "lux" ]
    [latest-21353]2021-12-19T23:08:41.076Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c098f" (Entity#ezlo>device_613e2959129e2912114c098f); has [Array][ "613e2959129e2912114c0990", "lux" ]
    [latest-21353]2021-12-19T23:08:41.078Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
    [latest-21353]2021-12-19T23:08:41.078Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c0991" (Entity#ezlo>device_613e2959129e2912114c0991); has [Array][ "613e2959129e2912114c0992", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.079Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0991" (Entity#ezlo>device_613e2959129e2912114c0991); has [Array][ "613e2959129e2912114c0992", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.094Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d55129e29124dfcd782" (Entity#ezlo>device_61425d55129e29124dfcd782); has [Array][ "61425d55129e29124dfcd783", "basic", "61425d56129e29124dfcd784", "battery", "61425d56129e29124dfcd785", "tampering_cover_alarm", "61425d56129e29124dfcd786", "acceleration_x_axis", "61425d56129e29124dfcd787", "acceleration_y_axis", "61425d56129e29124dfcd788", "acceleration_z_axis", "61425d56129e29124dfcd789", "motion", "61425d56129e29124dfcd78a", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.095Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
    [latest-21353]2021-12-19T23:08:41.096Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78b" (Entity#ezlo>device_61425d56129e29124dfcd78b); has [Array][ "61425d56129e29124dfcd78c", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.096Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78b" (Entity#ezlo>device_61425d56129e29124dfcd78b); has [Array][ "61425d56129e29124dfcd78c", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.097Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78d" (Entity#ezlo>device_61425d56129e29124dfcd78d); has [Array][ "61425d56129e29124dfcd78e", "temp" ]
    [latest-21353]2021-12-19T23:08:41.097Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78d" (Entity#ezlo>device_61425d56129e29124dfcd78d); has [Array][ "61425d56129e29124dfcd78e", "temp" ]
    [latest-21353]2021-12-19T23:08:41.098Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78f" (Entity#ezlo>device_61425d56129e29124dfcd78f); has [Array][ "61425d56129e29124dfcd790", "lux" ]
    [latest-21353]2021-12-19T23:08:41.099Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78f" (Entity#ezlo>device_61425d56129e29124dfcd78f); has [Array][ "61425d56129e29124dfcd790", "lux" ]
    [latest-21353]2021-12-19T23:08:41.106Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c693129e29124dfcd7a7" (Entity#ezlo>device_6145c693129e29124dfcd7a7); has [Array][ "6145c693129e29124dfcd7a8", "basic", "6145c693129e29124dfcd7a9", "battery", "6145c693129e29124dfcd7aa", "tampering_cover_alarm", "6145c693129e29124dfcd7ab", "acceleration_x_axis", "6145c693129e29124dfcd7ac", "acceleration_y_axis", "6145c694129e29124dfcd7ad", "acceleration_z_axis", "6145c694129e29124dfcd7ae", "motion", "6145c694129e29124dfcd7af", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.107Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c693129e29124dfcd7a7" (Entity#ezlo>device_6145c693129e29124dfcd7a7); has [Array][ "6145c693129e29124dfcd7a8", "basic", "6145c693129e29124dfcd7a9", "battery", "6145c693129e29124dfcd7aa", "tampering_cover_alarm", "6145c693129e29124dfcd7ab", "acceleration_x_axis", "6145c693129e29124dfcd7ac", "acceleration_y_axis", "6145c694129e29124dfcd7ad", "acceleration_z_axis", "6145c694129e29124dfcd7ae", "motion", "6145c694129e29124dfcd7af", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.108Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b0" (Entity#ezlo>device_6145c694129e29124dfcd7b0); has [Array][ "6145c694129e29124dfcd7b1", "temp" ]
    [latest-21353]2021-12-19T23:08:41.109Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b0" (Entity#ezlo>device_6145c694129e29124dfcd7b0); has [Array][ "6145c694129e29124dfcd7b1", "temp" ]
    [latest-21353]2021-12-19T23:08:41.110Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b2" (Entity#ezlo>device_6145c694129e29124dfcd7b2); has [Array][ "6145c694129e29124dfcd7b3", "lux" ]
    [latest-21353]2021-12-19T23:08:41.111Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b2" (Entity#ezlo>device_6145c694129e29124dfcd7b2); has [Array][ "6145c694129e29124dfcd7b3", "lux" ]
    [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
    [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b4" (Entity#ezlo>device_6145c694129e29124dfcd7b4); has [Array][ "6145c694129e29124dfcd7b5", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b4" (Entity#ezlo>device_6145c694129e29124dfcd7b4); has [Array][ "6145c694129e29124dfcd7b5", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.113Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7ba" (Entity#ezlo>device_6145c7ca129e29124dfcd7ba); has [Array][ "6145c7ca129e29124dfcd7bb", "basic", "6145c7ca129e29124dfcd7bc", "battery", "6145c7ca129e29124dfcd7bd", "motion", "6145c7ca129e29124dfcd7be", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.114Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7ba" (Entity#ezlo>device_6145c7ca129e29124dfcd7ba); has [Array][ "6145c7ca129e29124dfcd7bb", "basic", "6145c7ca129e29124dfcd7bc", "battery", "6145c7ca129e29124dfcd7bd", "motion", "6145c7ca129e29124dfcd7be", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.115Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c7ca129e29124dfcd7bf" (Entity#ezlo>device_6145c7ca129e29124dfcd7bf); has [Array][ "6145c7ca129e29124dfcd7c0", "lux" ]
    [latest-21353]2021-12-19T23:08:41.115Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7bf" (Entity#ezlo>device_6145c7ca129e29124dfcd7bf); has [Array][ "6145c7ca129e29124dfcd7c0", "lux" ]
    [latest-21353]2021-12-19T23:08:41.116Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c7ca129e29124dfcd7c1" (Entity#ezlo>device_6145c7ca129e29124dfcd7c1); has [Array][ "6145c7ca129e29124dfcd7c2", "temp" ]
    [latest-21353]2021-12-19T23:08:41.116Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7c1" (Entity#ezlo>device_6145c7ca129e29124dfcd7c1); has [Array][ "6145c7ca129e29124dfcd7c2", "temp" ]
    [latest-21353]2021-12-19T23:08:41.124Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd805" (Entity#ezlo>device_614755cd129e29124dfcd805); has [Array][ "614755cd129e29124dfcd806", "basic", "614755cd129e29124dfcd807", "battery", "614755cd129e29124dfcd808", "tampering_cover_alarm", "614755cd129e29124dfcd809", "acceleration_x_axis", "614755cd129e29124dfcd80a", "acceleration_y_axis", "614755cd129e29124dfcd80b", "acceleration_z_axis", "614755cd129e29124dfcd80c", "motion", "614755cd129e29124dfcd80d", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.125Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd805" (Entity#ezlo>device_614755cd129e29124dfcd805); has [Array][ "614755cd129e29124dfcd806", "basic", "614755cd129e29124dfcd807", "battery", "614755cd129e29124dfcd808", "tampering_cover_alarm", "614755cd129e29124dfcd809", "acceleration_x_axis", "614755cd129e29124dfcd80a", "acceleration_y_axis", "614755cd129e29124dfcd80b", "acceleration_z_axis", "614755cd129e29124dfcd80c", "motion", "614755cd129e29124dfcd80d", "security_threat" ]
    [latest-21353]2021-12-19T23:08:41.126Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755cd129e29124dfcd80e" (Entity#ezlo>device_614755cd129e29124dfcd80e); has [Array][ "614755ce129e29124dfcd80f", "temp" ]
    [latest-21353]2021-12-19T23:08:41.126Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd80e" (Entity#ezlo>device_614755cd129e29124dfcd80e); has [Array][ "614755ce129e29124dfcd80f", "temp" ]
    [latest-21353]2021-12-19T23:08:41.127Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755ce129e29124dfcd810" (Entity#ezlo>device_614755ce129e29124dfcd810); has [Array][ "614755ce129e29124dfcd811", "lux" ]
    [latest-21353]2021-12-19T23:08:41.127Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755ce129e29124dfcd810" (Entity#ezlo>device_614755ce129e29124dfcd810); has [Array][ "614755ce129e29124dfcd811", "lux" ]
    [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
    [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755ce129e29124dfcd812" (Entity#ezlo>device_614755ce129e29124dfcd812); has [Array][ "614755ce129e29124dfcd813", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755ce129e29124dfcd812" (Entity#ezlo>device_614755ce129e29124dfcd812); has [Array][ "614755ce129e29124dfcd813", "seismic_intensity" ]
    [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.133Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.135Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.138Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.145Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.145Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
    [latest-21353]2021-12-19T23:08:41.146Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
    • N Offline
      N Offline
      [latest-21353]2021-12-19T23:08:41.146Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.147Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.147Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.148Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.148Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.149Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.149Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.150Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.150Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.151Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.151Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.152Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.152Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.154Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.156Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.158Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.161Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.173Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198168b129e2918c5ce97bc" (Entity#ezlo>device_6198168b129e2918c5ce97bc); has [Array][ "6198168b129e2918c5ce97bd", "dimmer", "6198168b129e2918c5ce97be", "dimmer_up", "6198168b129e2918c5ce97bf", "dimmer_down", "6198168b129e2918c5ce97c0", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.174Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619816bb129e2918c5ce97c1" (Entity#ezlo>device_619816bb129e2918c5ce97c1); has [Array][ "619816bb129e2918c5ce97c2", "dimmer", "619816bb129e2918c5ce97c3", "dimmer_up", "619816bc129e2918c5ce97c4", "dimmer_down", "619816bc129e2918c5ce97c5", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.175Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198173f129e2918c5ce97c6" (Entity#ezlo>device_6198173f129e2918c5ce97c6); has [Array][ "6198173f129e2918c5ce97c7", "dimmer", "6198173f129e2918c5ce97c8", "dimmer_up", "6198173f129e2918c5ce97c9", "dimmer_down", "6198173f129e2918c5ce97ca", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.176Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "61981760129e2918c5ce97cb" (Entity#ezlo>device_61981760129e2918c5ce97cb); has [Array][ "61981760129e2918c5ce97cc", "dimmer", "61981760129e2918c5ce97cd", "dimmer_up", "61981760129e2918c5ce97ce", "dimmer_down", "61981760129e2918c5ce97cf", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.177Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "61981770129e2918c5ce97d0" (Entity#ezlo>device_61981770129e2918c5ce97d0); has [Array][ "61981770129e2918c5ce97d1", "dimmer", "61981770129e2918c5ce97d2", "dimmer_up", "61981770129e2918c5ce97d3", "dimmer_down", "61981770129e2918c5ce97d4", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.178Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198177e129e2918c5ce97d5" (Entity#ezlo>device_6198177e129e2918c5ce97d5); has [Array][ "6198177e129e2918c5ce97d6", "dimmer", "6198177e129e2918c5ce97d7", "dimmer_up", "6198177e129e2918c5ce97d8", "dimmer_down", "6198177e129e2918c5ce97d9", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.179Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198178b129e2918c5ce97da" (Entity#ezlo>device_6198178b129e2918c5ce97da); has [Array][ "6198178b129e2918c5ce97db", "dimmer", "6198178b129e2918c5ce97dc", "dimmer_up", "6198178b129e2918c5ce97dd", "dimmer_down", "6198178b129e2918c5ce97de", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.183Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198179b129e2918c5ce97df" (Entity#ezlo>device_6198179b129e2918c5ce97df); has [Array][ "6198179b129e2918c5ce97e0", "dimmer", "6198179b129e2918c5ce97e1", "dimmer_up", "6198179b129e2918c5ce97e2", "dimmer_down", "6198179b129e2918c5ce97e3", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.184Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817a6129e2918c5ce97e4" (Entity#ezlo>device_619817a6129e2918c5ce97e4); has [Array][ "619817a6129e2918c5ce97e5", "dimmer", "619817a7129e2918c5ce97e6", "dimmer_up", "619817a7129e2918c5ce97e7", "dimmer_down", "619817a7129e2918c5ce97e8", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.185Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817b2129e2918c5ce97e9" (Entity#ezlo>device_619817b2129e2918c5ce97e9); has [Array][ "619817b2129e2918c5ce97ea", "dimmer", "619817b3129e2918c5ce97eb", "dimmer_up", "619817b3129e2918c5ce97ec", "dimmer_down", "619817b3129e2918c5ce97ed", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.186Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817c2129e2918c5ce97ee" (Entity#ezlo>device_619817c2129e2918c5ce97ee); has [Array][ "619817c3129e2918c5ce97ef", "dimmer", "619817c3129e2918c5ce97f0", "dimmer_up", "619817c3129e2918c5ce97f1", "dimmer_down", "619817c3129e2918c5ce97f2", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.187Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817d0129e2918c5ce97f3" (Entity#ezlo>device_619817d0129e2918c5ce97f3); has [Array][ "619817d0129e2918c5ce97f4", "dimmer", "619817d0129e2918c5ce97f5", "dimmer_up", "619817d0129e2918c5ce97f6", "dimmer_down", "619817d0129e2918c5ce97f7", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.190Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817de129e2918c5ce97f8" (Entity#ezlo>device_619817de129e2918c5ce97f8); has [Array][ "619817de129e2918c5ce97f9", "dimmer", "619817de129e2918c5ce97fa", "dimmer_up", "619817de129e2918c5ce97fb", "dimmer_down", "619817de129e2918c5ce97fc", "dimmer_stop" ]
      [latest-21353]2021-12-19T23:08:41.192Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=door_lock cap keypad
      [latest-21353]2021-12-19T23:08:41.196Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e89442e" (Entity#ezlo>device_619903e9129e29123e89442e); has [Array][ "619903e9129e29123e89442f", "basic", "619903e9129e29123e894430", "battery", "619903e9129e29123e894431", "tampering_cover_alarm", "619903e9129e29123e894432", "battery_maintenance_state", "619903e9129e29123e894433", "dw_state", "619903e9129e29123e894434", "security_threat" ]
      [latest-21353]2021-12-19T23:08:41.198Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "619903e9129e29123e894437" (Entity#ezlo>device_619903e9129e29123e894437); has [Array][ "619903ea129e29123e894438", "heat_alarm", "619903ea129e29123e894439", "security_threat" ]
      [latest-21353]2021-12-19T23:08:41.198Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e894437" (Entity#ezlo>device_619903e9129e29123e894437); has [Array][ "619903ea129e29123e894438", "heat_alarm", "619903ea129e29123e894439", "security_threat" ]
      [latest-21353]2021-12-19T23:08:41.200Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "619903ea129e29123e89443a" (Entity#ezlo>device_619903ea129e29123e89443a); has [Array][ "619903ea129e29123e89443b", "temp" ]
      [latest-21353]2021-12-19T23:08:41.200Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903ea129e29123e89443a" (Entity#ezlo>device_619903ea129e29123e89443a); has [Array][ "619903ea129e29123e89443b", "temp" ]
      [latest-21353]2021-12-19T23:08:41.239Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 1034ms
      -ZWaveJS-UI 11.22.3
      -Update 16/08/2026
        OK. Those are benign, but I'd still like to try and clean them up. There are devices listed that aren't in the previous upload you gave me, so can I ask that you use that upload link previously sent (in DM to you here) and upload the latest [data--see edit below] file from your logs directory? That will tell me what the devices are reporting more clearly.
        Edit: the file is now called ezlo_inventory.json for the latest version.
        • N Offline
          N Offline
          Hi, the file it is uploaded.
          -ZWaveJS-UI 11.22.3
          -Update 16/08/2026
          • N Offline
            N Offline
            If can help, today I added another zwave device "Widom Smart Plug" https://www.widom.it/wp-content/uploads/2019/08/Widom-Smart-Plug_EN_20190404_0.pdf
            At the moment it is ON and in Entities power.switch_state is FALSE
            energy_sensor.units="kilo_watt_hour"
            energy_sensor.value=0.0230000000447035
            power_sensor.units="watt"
            power_sensor.value=36.7000007629395
            power_switch.state=false
            x_ezlo_device.battery_powered=false
            x_ezlo_device.category="switch"
            x_ezlo_device.manufacturer="Unknown"
            x_ezlo_device.model="Unknown"
            x_ezlo_device.parent=""
            x_ezlo_device.reachable=true
            x_ezlo_device.ready=true
            x_ezlo_device.room="613e2037129e2912114c093e"
            x_ezlo_device.status="idle"
            x_ezlo_device.subcategory="interior_plugin"
            x_ezlo_device.type_id="329_4628_1792"
            x_ezlo_item.electric_meter_kwh=0.0230000000447035
            x_ezlo_item.electric_meter_volt=230.399993896484
            x_ezlo_item.electric_meter_watt=36.7000007629395
            x_ezlo_item.meter_reset=0
            x_ezlo_item.switch=false
            x_ezlo_object.id="61c18f96129e291255528096"
            zwave_device.capabilities=null
            zwave_device.failed=false
            zwave_device.manufacturer_info=["Unknown","Unknown",null]
            zwave_device.node_id=60
            Capabilities: energy_sensor, power_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
            Actions: power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
            -ZWaveJS-UI 11.22.3
            -Update 16/08/2026
              OK. If you would please, upload your ezlo_inventory.json file again.
              I would also note that the switch item (seen in raw form in x_ezlo_item.switch) also says false, so check in the (Vera/Ezlo) mobile app what it reports for state. It's not relevant what state the switch is physically in, only what state the hub thinks its in. If they don't agree, neither will Reactor.
              • N Offline
                N Offline
                Hi, checking Ezlo app and the device is also in OFF state on Dashboard. So the problem is not Reactor but Ezlo.
                -ZWaveJS-UI 11.22.3
                -Update 16/08/2026
                  OK. New data maps with no further changes to previous work, so I'm going to go ahead and build. Watch for the update announcement in that topic.
                  • N Offline
                    N Offline
                    Hi and Happy New Year!
                    Trying a new test between MSR capability vs. Ezlo attribute and they show different. At the moment all devices are ON in the room:
                    -ZWaveJS-UI 11.22.3
                    -Update 16/08/2026
                      Any errors in the log? You know you always need to look there whenever things don't seem right, yes?
                      Also, I would do a hard-refresh of the browser and open that page again. I have seen it get out of sync once in a while but I haven't been able to figure out why as yet.
                      • N Offline
                        N Offline
                        Updating to the last version, and doing a hard-refresh (F5) on the page, comparing the two images: now there are two devices ON
                        ![alt text](b4a4f3cc-d2d2-4512-b8b0-eea49f845e70-image.png image url)
                        I will try to close the brower and to erase data on the browser.
                        -ZWaveJS-UI 11.22.3
                        -Update 16/08/2026
                        • N Offline
                          N Offline
                          Now seems ok, no error in the log. It was related to Google Chrome. Thanks!
                          ![alt text](28e558ac-598b-4063-b0f7-eb96de2f993c-image.png image url)
                          -ZWaveJS-UI 11.22.3
                          -Update 16/08/2026
                            Not so sure... try changing the switch state of one of them (toggle one of them manually), see if both attributes follow... I'm guessing they'll diverge...
                            • N Offline
                              N Offline
                              eheh, I was hoping to go happy to sleep 🙂 Yes, they diverge:
                              ![alt text](c32f3243-5ef7-48d4-a5e9-ef1b5d72df08-image.png image url)
                              -ZWaveJS-UI 11.22.3
                              -Update 16/08/2026
                              • N Offline
                                N Offline
                                what I can notice in "Entities" is that at the moment this device is OFF, but dimmer_level is =1
                                L Bulb Spot Widom Dimmer
                                ezlo>device_61475325129e29124dfcd7e6
                                2:16:40 AM
                                dimming.level=1
                                dimming.step=0.1
                                dimming.undefined=0
                                energy_sensor.undefined="KWh"
                                energy_sensor.units="KWh"
                                energy_sensor.value=0.994000017642975
                                power_sensor.undefined="W"
                                power_sensor.units="W"
                                power_sensor.value=7.96000003814697
                                power_switch.state=true
                                power_switch.undefined=false
                                x_ezlo_device.category="dimmable_light"
                                x_ezlo_device.room="613e2024129e2912114c093b"
                                x_ezlo_device.subcategory="dimmable_in_wall"
                                x_ezlo_device.type_id="329_4628_2560"
                                x_ezlo_item.dimmer=0
                                x_ezlo_item.dimmer_down=0
                                x_ezlo_item.dimmer_stop=0
                                x_ezlo_item.dimmer_up=0
                                x_ezlo_item.electric_meter_kwh=0.996999979019165
                                x_ezlo_item.electric_meter_watt=0
                                x_ezlo_object.id="61475325129e29124dfcd7e6"
                                zwave_device.node_id=38
                                Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                                Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
                                or this other one, dimmer level diverge from msr to ezlo
                                K Bulb Domitech
                                ezlo>device_61423589129e29124dfcd756
                                2:30:41 AM
                                dimming.level=0
                                dimming.step=0.1
                                dimming.undefined=0.25
                                power_switch.undefined=true
                                x_ezlo_device.manufacturer="Domitech"
                                x_ezlo_device.model="ZE27EU"
                                x_ezlo_device.room="613e2020129e2912114c093a"
                                x_ezlo_device.subcategory="dimmable_bulb"
                                x_ezlo_device.type_id="526_19522_12596"
                                x_ezlo_item.dimmer=25
                                x_ezlo_item.switch=true
                                x_ezlo_object.id="61423589129e29124dfcd756"
                                zwave_device.manufacturer_info=["Domitech","ZE27EU",null]
                                zwave_device.node_id=26
                                Capabilities: dimming, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                                -ZWaveJS-UI 11.22.3
                                -Update 16/08/2026
                                  The real give-away there is the power_switch.undefined attribute in the list. I can reproduce the issue. I won't be able to roll a fix tonight, but I'll have something out tomorrow.
                                  • N Offline
                                    N Offline
                                    Hi, it seems working ok. Thanks! If you need more infos to test, just tell me how I can produce them.
                                    L Bulb FibaroDimmer2
                                    ezlo>device_61425874129e29124dfcd75e
                                    0.65
                                    7:30:07 PM
                                    dimming.level=0.65
                                    dimming.step=0.1
                                    energy_sensor.value=11.3400001525879
                                    power_sensor.value=6.90000009536743
                                    x_ezlo_device.manufacturer="Fibaro"
                                    x_ezlo_device.model="FGD-212"
                                    x_ezlo_device.type_id="271_258_4096"
                                    x_ezlo_item.dimmer=65
                                    x_ezlo_item.electric_meter_kwh=11.3400001525879
                                    x_ezlo_item.electric_meter_watt=6.90000009536743
                                    x_ezlo_item.hw_state="hardware_failure"
                                    x_ezlo_item.load_error_state="unknown"
                                    x_ezlo_item.over_current_state="unknown"
                                    x_ezlo_item.over_load_state="unknown"
                                    x_ezlo_item.power_surge_state="no_surge"
                                    x_ezlo_item.voltage_drop_drift_state="unknown"
                                    x_ezlo_object.id="61425874129e29124dfcd75e"
                                    zwave_device.manufacturer_info=["Fibaro","FGD-212",null]
                                    zwave_device.node_id=27
                                    another
                                    K Bulb Domitech
                                    0.65
                                    7:35:42 PM
                                    dimming.level=0.65
                                    dimming.step=0.1
                                    another
                                    H Bulb Widom dimmer
                                    ezlo>device_6147578c129e29124dfcd814
                                    7:36:56 PM
                                    dimming.level=1
                                    dimming.step=0.1
                                    energy_sensor.value=0.651000022888184
                                    power_sensor.value=2.47000002861023
                                    x_ezlo_device.room="613e2012129e2912114c0938"
                                    x_ezlo_item.dimmer=100
                                    x_ezlo_item.electric_meter_kwh=0.651000022888184
                                    x_ezlo_item.electric_meter_watt=2.47000002861023
                                    x_ezlo_object.id="6147578c129e29124dfcd814"
                                    zwave_device.node_id=41
                                    -ZWaveJS-UI 11.22.3
                                    -Update 16/08/2026
                                      146.9k
