  4. Power_switch.state - no change state - EzloPlus - Msr v. 21351-a3aef - Synology Docker
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
22 Posts 2 Posters 7.4k Views 2 Watching
    OK. If you would please, upload your ezlo_inventory.json file again.
    I would also note that the switch item (seen in raw form in x_ezlo_item.switch) also says false, so check in the (Vera/Ezlo) mobile app what it reports for state. It's not relevant what state the switch is physically in, only what state the hub thinks its in. If they don't agree, neither will Reactor.
    • N Offline
      N Offline
      Hi, checking Ezlo app and the device is also in OFF state on Dashboard. So the problem is not Reactor but Ezlo.
      -Docker on Synology NAS
      -HASS Docker 2026.8.1
      -ZWaveJS-UI 11.22.3
      -Update 16/08/2026
        OK. New data maps with no further changes to previous work, so I'm going to go ahead and build. Watch for the update announcement in that topic.
        • N Offline
          N Offline
          Hi and Happy New Year!
          Trying a new test between MSR capability vs. Ezlo attribute and they show different. At the moment all devices are ON in the room:
          -ZWaveJS-UI 11.22.3
          -Update 16/08/2026
            Any errors in the log? You know you always need to look there whenever things don't seem right, yes?
            Also, I would do a hard-refresh of the browser and open that page again. I have seen it get out of sync once in a while but I haven't been able to figure out why as yet.
            • N Offline
              N Offline
              Updating to the last version, and doing a hard-refresh (F5) on the page, comparing the two images: now there are two devices ON
              ![alt text](b4a4f3cc-d2d2-4512-b8b0-eea49f845e70-image.png image url)
              I will try to close the brower and to erase data on the browser.
              -ZWaveJS-UI 11.22.3
              -Update 16/08/2026
              • N Offline
                N Offline
                Now seems ok, no error in the log. It was related to Google Chrome. Thanks!
                ![alt text](28e558ac-598b-4063-b0f7-eb96de2f993c-image.png image url)
                -ZWaveJS-UI 11.22.3
                -Update 16/08/2026
                  Not so sure... try changing the switch state of one of them (toggle one of them manually), see if both attributes follow... I'm guessing they'll diverge...
                  • N Offline
                    N Offline
                    eheh, I was hoping to go happy to sleep 🙂 Yes, they diverge:
                    ![alt text](c32f3243-5ef7-48d4-a5e9-ef1b5d72df08-image.png image url)
                    -ZWaveJS-UI 11.22.3
                    -Update 16/08/2026
                    • N Offline
                      N Offline
                      what I can notice in "Entities" is that at the moment this device is OFF, but dimmer_level is =1
                      L Bulb Spot Widom Dimmer
                      ezlo>device_61475325129e29124dfcd7e6
                      2:16:40 AM
                      dimming.level=1
                      dimming.step=0.1
                      dimming.undefined=0
                      energy_sensor.undefined="KWh"
                      energy_sensor.units="KWh"
                      energy_sensor.value=0.994000017642975
                      power_sensor.undefined="W"
                      power_sensor.units="W"
                      power_sensor.value=7.96000003814697
                      power_switch.state=true
                      power_switch.undefined=false
                      x_ezlo_device.battery_powered=false
                      x_ezlo_device.category="dimmable_light"
                      x_ezlo_device.manufacturer="Unknown"
                      x_ezlo_device.model="Unknown"
                      x_ezlo_device.parent=""
                      x_ezlo_device.reachable=true
                      x_ezlo_device.ready=true
                      x_ezlo_device.room="613e2024129e2912114c093b"
                      x_ezlo_device.status="idle"
                      x_ezlo_device.subcategory="dimmable_in_wall"
                      x_ezlo_device.type_id="329_4628_2560"
                      x_ezlo_item.dimmer=0
                      x_ezlo_item.dimmer_down=0
                      x_ezlo_item.dimmer_stop=0
                      x_ezlo_item.dimmer_up=0
                      x_ezlo_item.electric_meter_kwh=0.996999979019165
                      x_ezlo_item.electric_meter_watt=0
                      x_ezlo_item.meter_reset=0
                      x_ezlo_item.switch=false
                      x_ezlo_object.id="61475325129e29124dfcd7e6"
                      zwave_device.capabilities=null
                      zwave_device.failed=false
                      zwave_device.manufacturer_info=["Unknown","Unknown",null]
                      zwave_device.node_id=38
                      Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                      Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
                      or this other one, dimmer level diverge from msr to ezlo
                      K Bulb Domitech
                      ezlo>device_61423589129e29124dfcd756
                      2:30:41 AM
                      dimming.level=0
                      dimming.step=0.1
                      dimming.undefined=0.25
                      power_switch.state=false
                      power_switch.undefined=true
                      x_ezlo_device.manufacturer="Domitech"
                      x_ezlo_device.model="ZE27EU"
                      x_ezlo_device.room="613e2020129e2912114c093a"
                      x_ezlo_device.subcategory="dimmable_bulb"
                      x_ezlo_device.type_id="526_19522_12596"
                      x_ezlo_item.dimmer=25
                      x_ezlo_item.switch=true
                      x_ezlo_object.id="61423589129e29124dfcd756"
                      zwave_device.manufacturer_info=["Domitech","ZE27EU",null]
                      zwave_device.node_id=26
                      Capabilities: dimming, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                      -ZWaveJS-UI 11.22.3
                      -Update 16/08/2026
                        The real give-away there is the power_switch.undefined attribute in the list. I can reproduce the issue. I won't be able to roll a fix tonight, but I'll have something out tomorrow.
                        • N Offline
                          N Offline
                          Hi, it seems working ok. Thanks! If you need more infos to test, just tell me how I can produce them.
                          L Bulb FibaroDimmer2
                          ezlo>device_61425874129e29124dfcd75e
                          0.65
                          7:30:07 PM
                          dimming.level=0.65
                          dimming.step=0.1
                          energy_sensor.value=11.3400001525879
                          power_sensor.value=6.90000009536743
                          x_ezlo_device.manufacturer="Fibaro"
                          x_ezlo_device.model="FGD-212"
                          x_ezlo_device.type_id="271_258_4096"
                          x_ezlo_item.dimmer=65
                          x_ezlo_item.electric_meter_kwh=11.3400001525879
                          x_ezlo_item.electric_meter_watt=6.90000009536743
                          x_ezlo_item.hw_state="hardware_failure"
                          x_ezlo_item.load_error_state="unknown"
                          x_ezlo_item.over_current_state="unknown"
                          x_ezlo_item.over_load_state="unknown"
                          x_ezlo_item.power_surge_state="no_surge"
                          x_ezlo_item.voltage_drop_drift_state="unknown"
                          x_ezlo_object.id="61425874129e29124dfcd75e"
                          zwave_device.manufacturer_info=["Fibaro","FGD-212",null]
                          zwave_device.node_id=27
                          another
                          K Bulb Domitech
                          0.65
                          7:35:42 PM
                          dimming.level=0.65
                          dimming.step=0.1
                          another
                          H Bulb Widom dimmer
                          ezlo>device_6147578c129e29124dfcd814
                          7:36:56 PM
                          dimming.level=1
                          dimming.step=0.1
                          energy_sensor.value=0.651000022888184
                          power_sensor.value=2.47000002861023
                          x_ezlo_device.room="613e2012129e2912114c0938"
                          x_ezlo_item.dimmer=100
                          x_ezlo_item.electric_meter_kwh=0.651000022888184
                          x_ezlo_item.electric_meter_watt=2.47000002861023
                          x_ezlo_object.id="6147578c129e29124dfcd814"
                          zwave_device.node_id=41
                          -ZWaveJS-UI 11.22.3
                          -Update 16/08/2026
                            164.2k
