  4. Power_switch.state - no change state - EzloPlus - Msr v. 21351-a3aef - Synology Docker
22 Posts 2 Posters 6.8k Views 2 Watching
  • N Offline
    N Offline
    Hi, checking Ezlo app and the device is also in OFF state on Dashboard. So the problem is not Reactor but Ezlo.
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
      OK. New data maps with no further changes to previous work, so I'm going to go ahead and build. Watch for the update announcement in that topic.
      • N Offline
        N Offline
        Hi and Happy New Year!
        Trying a new test between MSR capability vs. Ezlo attribute and they show different. At the moment all devices are ON in the room:
        -ZWaveJS-UI 11.22.3
        -Update 16/08/2026
          Any errors in the log? You know you always need to look there whenever things don't seem right, yes?
          Also, I would do a hard-refresh of the browser and open that page again. I have seen it get out of sync once in a while but I haven't been able to figure out why as yet.
          • N Offline
            N Offline
            Updating to the last version, and doing a hard-refresh (F5) on the page, comparing the two images: now there are two devices ON
            ![alt text](b4a4f3cc-d2d2-4512-b8b0-eea49f845e70-image.png image url)
            I will try to close the brower and to erase data on the browser.
            -ZWaveJS-UI 11.22.3
            -Update 16/08/2026
            • N Offline
              N Offline
              Now seems ok, no error in the log. It was related to Google Chrome. Thanks!
              ![alt text](28e558ac-598b-4063-b0f7-eb96de2f993c-image.png image url)
              -ZWaveJS-UI 11.22.3
              -Update 16/08/2026
                Not so sure... try changing the switch state of one of them (toggle one of them manually), see if both attributes follow... I'm guessing they'll diverge...
                • N Offline
                  N Offline
                  eheh, I was hoping to go happy to sleep 🙂 Yes, they diverge:
                  ![alt text](c32f3243-5ef7-48d4-a5e9-ef1b5d72df08-image.png image url)
                  -ZWaveJS-UI 11.22.3
                  -Update 16/08/2026
                  • N Offline
                    N Offline
                    what I can notice in "Entities" is that at the moment this device is OFF, but dimmer_level is =1
                    L Bulb Spot Widom Dimmer
                    ezlo>device_61475325129e29124dfcd7e6
                    2:16:40 AM
                    dimming.level=1
                    dimming.step=0.1
                    dimming.undefined=0
                    energy_sensor.undefined="KWh"
                    energy_sensor.units="KWh"
                    energy_sensor.value=0.994000017642975
                    power_sensor.undefined="W"
                    power_sensor.units="W"
                    power_sensor.value=7.96000003814697
                    power_switch.state=true
                    power_switch.undefined=false
                    x_ezlo_device.battery_powered=false
                    x_ezlo_device.category="dimmable_light"
                    x_ezlo_device.manufacturer="Unknown"
                    x_ezlo_device.model="Unknown"
                    x_ezlo_device.parent=""
                    x_ezlo_device.reachable=true
                    x_ezlo_device.ready=true
                    x_ezlo_device.room="613e2024129e2912114c093b"
                    x_ezlo_device.status="idle"
                    x_ezlo_device.subcategory="dimmable_in_wall"
                    x_ezlo_device.type_id="329_4628_2560"
                    x_ezlo_item.dimmer=0
                    x_ezlo_item.dimmer_down=0
                    x_ezlo_item.dimmer_stop=0
                    x_ezlo_item.dimmer_up=0
                    x_ezlo_item.electric_meter_kwh=0.996999979019165
                    x_ezlo_item.electric_meter_watt=0
                    x_ezlo_item.meter_reset=0
                    x_ezlo_item.switch=false
                    x_ezlo_object.id="61475325129e29124dfcd7e6"
                    zwave_device.capabilities=null
                    zwave_device.failed=false
                    zwave_device.manufacturer_info=["Unknown","Unknown",null]
                    zwave_device.node_id=38
                    Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                    Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
                    or this other one, dimmer level diverge from msr to ezlo
                    K Bulb Domitech
                    ezlo>device_61423589129e29124dfcd756
                    2:30:41 AM
                    dimming.level=0
                    dimming.step=0.1
                    dimming.undefined=0.25
                    power_switch.state=false
                    power_switch.undefined=true
                    x_ezlo_device.manufacturer="Domitech"
                    x_ezlo_device.model="ZE27EU"
                    x_ezlo_device.room="613e2020129e2912114c093a"
                    x_ezlo_device.subcategory="dimmable_bulb"
                    x_ezlo_device.type_id="526_19522_12596"
                    x_ezlo_item.dimmer=25
                    x_ezlo_item.switch=true
                    x_ezlo_object.id="61423589129e29124dfcd756"
                    zwave_device.manufacturer_info=["Domitech","ZE27EU",null]
                    zwave_device.node_id=26
                    Capabilities: dimming, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                    -ZWaveJS-UI 11.22.3
                    -Update 16/08/2026
                      The real give-away there is the power_switch.undefined attribute in the list. I can reproduce the issue. I won't be able to roll a fix tonight, but I'll have something out tomorrow.
                      • N Offline
                        N Offline
                        Hi, it seems working ok. Thanks! If you need more infos to test, just tell me how I can produce them.
                        L Bulb FibaroDimmer2
                        ezlo>device_61425874129e29124dfcd75e
                        0.65
                        7:30:07 PM
                        dimming.level=0.65
                        dimming.step=0.1
                        energy_sensor.value=11.3400001525879
                        power_sensor.value=6.90000009536743
                        x_ezlo_device.manufacturer="Fibaro"
                        x_ezlo_device.model="FGD-212"
                        x_ezlo_device.type_id="271_258_4096"
                        x_ezlo_item.dimmer=65
                        x_ezlo_item.electric_meter_kwh=11.3400001525879
                        x_ezlo_item.electric_meter_watt=6.90000009536743
                        x_ezlo_item.hw_state="hardware_failure"
                        x_ezlo_item.load_error_state="unknown"
                        x_ezlo_item.over_current_state="unknown"
                        x_ezlo_item.over_load_state="unknown"
                        x_ezlo_item.power_surge_state="no_surge"
                        x_ezlo_item.voltage_drop_drift_state="unknown"
                        x_ezlo_object.id="61425874129e29124dfcd75e"
                        zwave_device.manufacturer_info=["Fibaro","FGD-212",null]
                        zwave_device.node_id=27
                        another
                        K Bulb Domitech
                        0.65
                        7:35:42 PM
                        dimming.level=0.65
                        dimming.step=0.1
                        another
                        H Bulb Widom dimmer
                        ezlo>device_6147578c129e29124dfcd814
                        7:36:56 PM
                        dimming.level=1
                        dimming.step=0.1
                        energy_sensor.value=0.651000022888184
                        power_sensor.value=2.47000002861023
                        x_ezlo_device.room="613e2012129e2912114c0938"
                        x_ezlo_item.dimmer=100
                        x_ezlo_item.electric_meter_kwh=0.651000022888184
                        x_ezlo_item.electric_meter_watt=2.47000002861023
                        x_ezlo_object.id="6147578c129e29124dfcd814"
                        zwave_device.node_id=41
                        -ZWaveJS-UI 11.22.3
                        -Update 16/08/2026
                          146.9k
