Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Urgent Help MSR stopped running
OK these are the latest entries in the syslog to do with reactor
Mar 18 22:07:48 HP-Thin01 node[522]: NODE_PATH /home/stuart/reactor Mar 18 22:07:48 HP-Thin01 node[522]: FileLogStream { type: 'file', name: 'reactor.log', maxsize: 2, keep: 5 } Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.123Z <app:null> Reactor latest-22069-ebeefad starting on v16.13.1 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.126Z <app:INFO> Process ID 522; platform linux/x64 #1 SMP Debian 4.19.208-1 (2021-09-29); locale en_GB.UTF-8 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.127Z <app:INFO> Basedir /home/stuart/reactor; data in /home/stuart/reactor/storage Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.128Z <app:INFO> NODE_PATH=/home/stuart/reactor Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.135Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.195Z <app:INFO> Loaded locale en-US Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.223Z <Capabilities:null> Module Capabilities v21333 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.354Z <Plugin:null> Module Plugin v21186 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.369Z <TimerBroker:null> Module TimerBroker v21333 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.381Z <default:INFO> Module Entity v22042 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.391Z <Controller:null> Module Controller v22003 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.392Z <default:null> Module Structure v22047 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.413Z <default:null> Module Ruleset v21096 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.414Z <default:null> Module Rulesets v21096 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.433Z <GlobalExpression:null> Module GlobalExpression v21333 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.474Z <Predicate:null> Module Predicate v22067 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.484Z <AlertManager:null> Module AlertManager v21355 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.490Z <default:null> Module Rule v22043 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.500Z <GlobalReaction:null> Module GlobalReaction v21333 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.504Z <default:null> Module Engine v22053 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.505Z <default:null> Module httpapi v22021 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.510Z <default:null> Module httpproxy v21333 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.554Z <default:null> Module wsapi v21334 Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.558Z <app:NOTICE> Starting Structure... ar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.558Z <app:NOTICE> Starting Structure... Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.567Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input Mar 18 22:07:48 HP-Thin01 node[522]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input Mar 18 22:07:48 HP-Thin01 node[522]: at JSON.parse (<anonymous>) Mar 18 22:07:48 HP-Thin01 node[522]: at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47) Mar 18 22:07:48 HP-Thin01 node[522]: at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51) Mar 18 22:07:48 HP-Thin01 node[522]: at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631) Mar 18 22:07:48 HP-Thin01 node[522]: at Object.<anonymous> (/home/stuart/reactor/app.js:288:80) Mar 18 22:07:48 HP-Thin01 node[522]: at Module._compile (node:internal/modules/cjs/loader:1101:14) Mar 18 22:07:48 HP-Thin01 node[522]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) Mar 18 22:07:48 HP-Thin01 node[522]: at Module.load (node:internal/modules/cjs/loader:981:32) Mar 18 22:07:48 HP-Thin01 node[522]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) Mar 18 22:07:48 HP-Thin01 node[522]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) Mar 18 22:07:48 HP-Thin01 node[522]: SyntaxError: Unexpected end of JSON input Mar 18 22:07:48 HP-Thin01 node[522]: at JSON.parse (<anonymous>) Mar 18 22:07:48 HP-Thin01 node[522]: at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47) Mar 18 22:07:48 HP-Thin01 node[522]: at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51) Mar 18 22:07:48 HP-Thin01 node[522]: at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631) Mar 18 22:07:48 HP-Thin01 node[522]: at Object.<anonymous> (/home/stuart/reactor/app.js:288:80) Mar 18 22:07:48 HP-Thin01 node[522]: at Module._compile (node:internal/modules/cjs/loader:1101:14) Mar 18 22:07:48 HP-Thin01 node[522]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) Mar 18 22:07:48 HP-Thin01 node[522]: at Module.load (node:internal/modules/cjs/loader:981:32) Mar 18 22:07:48 HP-Thin01 node[522]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) Mar 18 22:07:48 HP-Thin01 node[522]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) Mar 18 22:07:48 HP-Thin01 node[522]: Promise { Mar 18 22:07:48 HP-Thin01 node[522]: <rejected> SyntaxError: Unexpected end of JSON input Mar 18 22:07:48 HP-Thin01 node[522]: at JSON.parse (<anonymous>) Mar 18 22:07:48 HP-Thin01 node[522]: at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47) Mar 18 22:07:48 HP-Thin01 node[522]: at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51) Mar 18 22:07:48 HP-Thin01 node[522]: at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631) Mar 18 22:07:48 HP-Thin01 node[522]: at Object.<anonymous> (/home/stuart/reactor/app.js:288:80) Mar 18 22:07:48 HP-Thin01 node[522]: at Module._compile (node:internal/modules/cjs/loader:1101:14) Mar 18 22:07:48 HP-Thin01 node[522]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) Mar 18 22:07:48 HP-Thin01 node[522]: at Module.load (node:internal/modules/cjs/loader:981:32) Mar 18 22:07:48 HP-Thin01 node[522]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) Mar 18 22:07:48 HP-Thin01 node[522]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) Mar 18 22:07:48 HP-Thin01 node[522]: } Mar 18 22:07:48 HP-Thin01 node[522]: Trace Mar 18 22:07:48 HP-Thin01 node[522]: at process.<anonymous> (/home/stuart/reactor/app.js:271:162) Mar 18 22:07:48 HP-Thin01 node[522]: at process.emit (node:events:390:28) Mar 18 22:07:48 HP-Thin01 node[522]: at process.emit (node:domain:475:12) Mar 18 22:07:48 HP-Thin01 node[522]: at emit (node:internal/process/promises:136:22) Mar 18 22:07:48 HP-Thin01 node[522]: at processPromiseRejections (node:internal/process/promises:242:25) Mar 18 22:07:48 HP-Thin01 node[522]: at processTicksAndRejections (node:internal/process/task_queues:97:32) Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Please refer to the console log for trace Mar 18 22:07:48 HP-Thin01 systemd[1]: reactor.service: Succeeded.
Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.048Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input Mar 18 22:05:28 HP-Thin01 node[402]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input Mar 18 22:05:28 HP-Thin01 node[402]: at JSON.parse (<anonymous>) Mar 18 22:05:28 HP-Thin01 node[402]: at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47) Mar 18 22:05:28 HP-Thin01 node[402]: at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51) Mar 18 22:05:28 HP-Thin01 node[402]: at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631) Mar 18 22:05:28 HP-Thin01 node[402]: at Object.<anonymous> (/home/stuart/reactor/app.js:288:80) Mar 18 22:05:28 HP-Thin01 node[402]: at Module._compile (node:internal/modules/cjs/loader:1101:14) Mar 18 22:05:28 HP-Thin01 node[402]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) Mar 18 22:05:28 HP-Thin01 node[402]: at Module.load (node:internal/modules/cjs/loader:981:32) Mar 18 22:05:28 HP-Thin01 node[402]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) Mar 18 22:05:28 HP-Thin01 node[402]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) Mar 18 22:05:28 HP-Thin01 node[402]: SyntaxError: Unexpected end of JSON input Mar 18 22:05:28 HP-Thin01 node[402]: at JSON.parse (<anonymous>) Mar 18 22:05:28 HP-Thin01 node[402]: at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47) Mar 18 22:05:28 HP-Thin01 node[402]: at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51) Mar 18 22:05:28 HP-Thin01 node[402]: at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631) Mar 18 22:05:28 HP-Thin01 node[402]: at Object.<anonymous> (/home/stuart/reactor/app.js:288:80) Mar 18 22:05:28 HP-Thin01 node[402]: at Module._compile (node:internal/modules/cjs/loader:1101:14) Mar 18 22:05:28 HP-Thin01 node[402]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) Mar 18 22:05:28 HP-Thin01 node[402]: at Module.load (node:internal/modules/cjs/loader:981:32) Mar 18 22:05:28 HP-Thin01 node[402]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) Mar 18 22:05:28 HP-Thin01 node[402]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) Mar 18 22:05:28 HP-Thin01 node[402]: Promise { Mar 18 22:05:28 HP-Thin01 node[402]: <rejected> SyntaxError: Unexpected end of JSON input Mar 18 22:05:28 HP-Thin01 node[402]: at JSON.parse (<anonymous>) Mar 18 22:05:28 HP-Thin01 node[402]: at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47) Mar 18 22:05:28 HP-Thin01 node[402]: at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51) Mar 18 22:05:28 HP-Thin01 node[402]: at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631) Mar 18 22:05:28 HP-Thin01 node[402]: at Object.<anonymous> (/home/stuart/reactor/app.js:288:80) Mar 18 22:05:28 HP-Thin01 node[402]: at Module._compile (node:internal/modules/cjs/loader:1101:14) Mar 18 22:05:28 HP-Thin01 node[402]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) Mar 18 22:05:28 HP-Thin01 node[402]: at Module.load (node:internal/modules/cjs/loader:981:32) Mar 18 22:05:28 HP-Thin01 node[402]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) Mar 18 22:05:28 HP-Thin01 node[402]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) Mar 18 22:05:28 HP-Thin01 node[402]: } Mar 18 22:05:28 HP-Thin01 node[402]: Trace Mar 18 22:05:28 HP-Thin01 node[402]: at process.<anonymous> (/home/stuart/reactor/app.js:271:162) Mar 18 22:05:28 HP-Thin01 node[402]: at process.emit (node:events:390:28) Mar 18 22:05:28 HP-Thin01 node[402]: at process.emit (node:domain:475:12) Mar 18 22:05:28 HP-Thin01 node[402]: at emit (node:internal/process/promises:136:22) Mar 18 22:05:28 HP-Thin01 node[402]: at processPromiseRejections (node:internal/process/promises:242:25) Mar 18 22:05:28 HP-Thin01 node[402]: at processTicksAndRejections (node:internal/process/task_queues:97:32) Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.097Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
The disk going full has resulted in the corruption of your storage folder. You will need to restore a backup.
@cw-kid it's the folder called
storage
in your Reactor folder. -
Is that the folder with the rulesets in it ?
I have a backup of all the folders and files, but it's not very recent.Hope I am not going to lose the more recent changes to the rules.
That's good sleuthing and good work. Yes, the
states
folder gets most of the I/O. If it looks like everything else is intact, that's fine. Rules and rule sets would only be damaged if you happened to edit them during the time the disk was full.On the Reactor master device, there are flags for warning you when disk space is becoming limited; rules with notifications may be a good idea, to avoid future unpleasant surprises.
I am assuming I have had a lucky escape here then, all my rules look to be present still, I am assuming "States" is just that as the name suggests the current state of the rules and that they will rebuild and repopulate themselves.
I didn't have any auto backup in place as not really sure how to do that in Linux command line, so I was just now and again manually copying the entire contents of the /reactor folder down on to my PC.
All correct.
In Entities under Reactor System I have all this information
reactor_system.alert_count=0 reactor_system.alert_last=1647657325518 reactor_system.alert_severity=null reactor_system.alerts=[] reactor_system.arch="x64" reactor_system.hostname="HP-Thin01" reactor_system.internet_ok=null reactor_system.platform="linux" reactor_system.reactor_memory_used=138702848 reactor_system.reactor_uptime=1082 reactor_system.system_load=[0.13,0.15,0.11] reactor_system.system_memory_free=2020356096 reactor_system.system_memory_size=3537993728 reactor_system.system_uptime=17002.98 reactor_system.volume_critical_reactor_base=false reactor_system.volume_critical_reactor_data=false reactor_system.volume_critical_reactor_logs=false reactor_system.volume_reactor_base=[5390756,13825496,0.389,"/home/stuart/reactor"] reactor_system.volume_reactor_data=[5390756,13825496,0.389,"/home/stuart/reactor/storage"] reactor_system.volume_reactor_logs=[5390756,13825496,0.389,"/home/stuart/reactor/logs"] sys_system.state=true Capabilities: reactor_system, sys_system Actions: reactor_system.clear_alert, reactor_system.clear_alerts, sys_system.restart
Memory free is that disk or RAM ?
Losing state will cause rules to possibly run unexpectedly. For example, say you had a rule that triggers between sunrise and sunset. If state was lost due to disk full corruption such as this in mid-day, discarding the state at restart will cause the rule to have no state, therefore think it has a transition into the sunrise (triggered) period and fire. This may or may not be a desirable side-effect, depending entirely on how the user determines the rules to work, and I cannot predetermine whether re-running a rule would have side-effects in the user environment or not. Since this can occur unattended (such as while on vacation or at a remote vacation home), it's potentially very troublesome and should at least be corrected with the full awareness of the user, as you have in this case.
My number one recommendation is that you manage filesystem space well on the system. This is always an issue on all systems, and in Linux/Unix systems in particular, processes can die (due to errors) and files can become (logically) corrupt due to disk full conditions. It is something that needs to be managed. In your case, I would remember what log files were deleted, and investigate why those were so large and not being rotated and expired or archived. In your case, it appears you have a single root volume with everything on it. That means any subsystem running on the box can potentially fill the filesystem and cause other applications to misbehave. Best practices for system management often call for segmenting files/directories out. It is not uncommon, for example, to have
/var
,/usr
and/home
all on separate filesystems, that any one of them filling (/var
often has this issue because it holds system logs and other fast-changing files) would not result in other files in the other directories to become corrupt or truncated. Taking this to an extreme, but if hardening Reactor is mission-critical to you, it is possible to create a small volume and mount it as/var/reactor
at boot time, and use that as the home for thestorage
directory (andconfig
, but not Reactor'slogs
), thereby isolating and protecting Reactor's storage from everything else. This is all Linux system management stuff, so not really appropriate to deep dive into, but if you're going to use and maintain these systems as part of your infrastructure, well worth spending the time to learn. A must really, because when it goes wrong, and it will go wrong, your fluency in system management will directly determine the time it takes to recover, and how well (or not) you recover.I can take more mitigating steps to harden startup, and I will definitely do that. I will also see about adding Status page alerts for disk space problems. The way Reactor works, if the disk space problem is mitigated before a restart of Reactor (i.e. while Reactor is running), Reactor will (eventually) rewrite the files with state (which is cached in RAM during operation) -- at shutdown, Reactor writes the RAM state back to disk as a final assurance that they are in sync, just for this reason. But I cannot protect those files from every eventuality, and every other subsystem on the machine works pretty much the same way (rebooting after fixing a no-space condition is always recommended, because many daemons will just die when they can't write a file).
And as I've said again and again and again, please read the documentation and look at your log files. If you see something in the log files that points to obvious issue, handle it. If you don't know how to handle it, post the log file snippet and remember that context is vital, so posting 2-3 lines of a log file may provide little or no useful information (even when the error contains module names and line numbers); it often takes a dozen or more lines of context prior to really interpret how the system got to the crash point, so you must post a least a dozen or more lines prior to any error message you are inquiring about. Fortunately in this case, it was pretty obvious.
Pardon errors. Tapping this out on a bluetooth keyboard and over my home VPN on sketchy Internet made this a bit of a chore. Onward.
