38 Posts 3 Posters 12.0k Views 3 Watching
      Is this bad ?
      EDIT:
                  Ok, so now look at the logs again. Disk space problem hiding others, now you should be able to see them.
                    #22
                    Don't know what's happened now but reactor.service is not even in the list at all anymore.
                    The service file is still in there
                    I'm downloading the syslog again now.
                      #23
                      OK these are the latest entries in the syslog to do with reactor
                      Mar 18 22:07:48 HP-Thin01 node[522]: NODE_PATH /home/stuart/reactor
                      Mar 18 22:07:48 HP-Thin01 node[522]: FileLogStream { type: 'file', name: 'reactor.log', maxsize: 2, keep: 5 }
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.123Z <app:null> Reactor latest-22069-ebeefad starting on v16.13.1
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.126Z <app:INFO> Process ID 522; platform linux/x64 #1 SMP Debian 4.19.208-1 (2021-09-29); locale en_GB.UTF-8
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.127Z <app:INFO> Basedir /home/stuart/reactor; data in /home/stuart/reactor/storage
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.128Z <app:INFO> NODE_PATH=/home/stuart/reactor
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.135Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.195Z <app:INFO> Loaded locale en-US
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.223Z <Capabilities:null> Module Capabilities v21333
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.354Z <Plugin:null> Module Plugin v21186
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.369Z <TimerBroker:null> Module TimerBroker v21333
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.381Z <default:INFO> Module Entity v22042
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.391Z <Controller:null> Module Controller v22003
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.392Z <default:null> Module Structure v22047
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.413Z <default:null> Module Ruleset v21096
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.414Z <default:null> Module Rulesets v21096
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.433Z <GlobalExpression:null> Module GlobalExpression v21333
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.474Z <Predicate:null> Module Predicate v22067
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.484Z <AlertManager:null> Module AlertManager v21355
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.490Z <default:null> Module Rule v22043
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.500Z <GlobalReaction:null> Module GlobalReaction v21333
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.504Z <default:null> Module Engine v22053
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.505Z <default:null> Module httpapi v22021
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.510Z <default:null> Module httpproxy v21333
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.554Z <default:null> Module wsapi v21334
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.558Z <app:NOTICE> Starting Structure...
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.567Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input
                      Mar 18 22:07:48 HP-Thin01 node[522]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at JSON.parse (<anonymous>)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Object.<anonymous> (/home/stuart/reactor/app.js:288:80)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      Mar 18 22:07:48 HP-Thin01 node[522]: SyntaxError: Unexpected end of JSON input
                      Mar 18 22:07:48 HP-Thin01 node[522]: Promise {
                      Mar 18 22:07:48 HP-Thin01 node[522]:   <rejected> SyntaxError: Unexpected end of JSON input
                      Mar 18 22:07:48 HP-Thin01 node[522]: }
                      Mar 18 22:07:48 HP-Thin01 node[522]: Trace
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at process.<anonymous> (/home/stuart/reactor/app.js:271:162)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at process.emit (node:events:390:28)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at process.emit (node:domain:475:12)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at emit (node:internal/process/promises:136:22)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at processPromiseRejections (node:internal/process/promises:242:25)
                      Mar 18 22:07:48 HP-Thin01 node[522]:     at processTicksAndRejections (node:internal/process/task_queues:97:32)
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
                      Mar 18 22:07:48 HP-Thin01 node[522]: [latest-22069]2022-03-18T22:07:48.582Z <app:ERR> Please refer to the console log for trace
                      Mar 18 22:07:48 HP-Thin01 systemd[1]: reactor.service: Succeeded.
                      Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.048Z <IndividualFileStrategy:ERR> [IndividualFileStrategy][IndividualFileStrategy#/home/stuart/reactor/storage] failed to read sys_alerts in /home/stuart/reactor/storage/states/sys_alerts.json: [SyntaxError]SyntaxError: Unexpected end of JSON input
                      Mar 18 22:05:28 HP-Thin01 node[402]: Trapped unhandled Promise rejection SyntaxError: Unexpected end of JSON input
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at JSON.parse (<anonymous>)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at IndividualFileStrategy.getDataObject (/home/stuart/reactor/server/lib/IndividualFileStrategy.js:123:47)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Container.getDataObject (/home/stuart/reactor/server/lib/Container.js:98:51)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Structure.start (/home/stuart/reactor/server/lib/Structure.js:280:631)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Object.<anonymous> (/home/stuart/reactor/app.js:288:80)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      Mar 18 22:05:28 HP-Thin01 node[402]: SyntaxError: Unexpected end of JSON input
                      Mar 18 22:05:28 HP-Thin01 node[402]: Promise {
                      Mar 18 22:05:28 HP-Thin01 node[402]:   <rejected> SyntaxError: Unexpected end of JSON input
                      Mar 18 22:05:28 HP-Thin01 node[402]: }
                      Mar 18 22:05:28 HP-Thin01 node[402]: Trace
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at process.<anonymous> (/home/stuart/reactor/app.js:271:162)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at process.emit (node:events:390:28)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at process.emit (node:domain:475:12)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at emit (node:internal/process/promises:136:22)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at processPromiseRejections (node:internal/process/promises:242:25)
                      Mar 18 22:05:28 HP-Thin01 node[402]:     at processTicksAndRejections (node:internal/process/task_queues:97:32)
                      Mar 18 22:05:28 HP-Thin01 node[402]: [latest-22069]2022-03-18T22:05:28.097Z <app:ERR> Trapped unhandled Promise rejection: [SyntaxError]SyntaxError: Unexpected end of JSON input
                        The disk going full has resulted in the corruption of your storage folder. You will need to restore a backup.
                          What's the storage folder ?
                          The entire reactor folder ?
                            @cw-kid it's the folder called storage in your Reactor folder.
                              Is that the folder with the rulesets in it ?
                              I have a backup of all the folders and files, but it's not very recent.
                              Hope I am not going to lose the more recent changes to the rules.
                                #28
                                Looks like it is
                                So they are all corrupted ?
                                There are hundreds of rules on those folders
                                  #29
                                  Looking in the current storage sub folders the "states" folder has a lot of the files in there are 0kb. But in the other folders like "rules" "rulesets" and "reactions" they still have data it seems and have kb values.
                                    I just deleted all the files in the states folder on the Linux box there was 170 odd files. I then uploaded the files from the backup I had, there were 130 odd files. MSR has now started and loaded in the browser. But I am unsure what I have lost.
                                      That's good sleuthing and good work. Yes, the states folder gets most of the I/O. If it looks like everything else is intact, that's fine. Rules and rule sets would only be damaged if you happened to edit them during the time the disk was full.
                                      On the Reactor master device, there are flags for warning you when disk space is becoming limited; rules with notifications may be a good idea, to avoid future unpleasant surprises.
                                        I am assuming I have had a lucky escape here then, all my rules look to be present still, I am assuming "States" is just that as the name suggests the current state of the rules and that they will rebuild and repopulate themselves.
                                        I didn't have any auto backup in place as not really sure how to do that in Linux command line, so I was just now and again manually copying the entire contents of the /reactor folder down on to my PC.
                                          All correct.
                                            148.3k
