Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
[Solved] Issue with Tasmota sensors and MQTTController later than 22024
I made custom templates because I never got the default to work and I wanted a init on restarts of MSR.
My templates is based on what was in the default templates when I created them and then it was not mandatory to declare payload as JSON, it may have changed and I might have missed that release note so I tried declaring a JSON payload in my templates but made no difference.
I'm now running default template for tasmota temperature sensor with log level 6 and all that is set from SENSOR topic istemperature_sensor.units
log with version 22024
[latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:242> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-02T19:02:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.8},"TempUnit":"C"} [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:270> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:5:MQTTController.js:500> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-02T19:02:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.8},"TempUnit":"C"} [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "expr": "payload[source]?.Temperature" }, "temperature_sensor.units": { "expr": "payload.TempUnit" } } [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:589> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.value=3.8 [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:589> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C
log with 22086.
[latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"} [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"} [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } } [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:5:MQTTController.js:604> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C
long snippet from that time with 22086.
[latest-22080]2022-04-02T17:14:19.496Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_active_power/state/value_sensor {"value":167,"units":"W"} [latest-22080]2022-04-02T17:14:19.496Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_active_power/state/string_sensor {"value":"167"} [latest-22080]2022-04-02T17:14:19.496Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_active_power/value "167" [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/input_power, payload=[Buffer]197 [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_input_power/value "197" [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_active_power/state/value_sensor {"value":167,"units":"W"} [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_active_power/state/string_sensor {"value":"167"} [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/active_power, payload=[Buffer]0.167 [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/Watts, payload=[Buffer]167 [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_active_power/value "167" [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_efficiency [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_efficiency [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_efficiency/state/value_sensor {"value":84.9,"units":"%"} [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_efficiency/state/string_sensor {"value":"84.9"} [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_efficiency/value "84.9" [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_efficiency/state/value_sensor {"value":84.9,"units":"%"} [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_pv_1_voltage [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_pv_1_voltage [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_1_voltage/state/value_sensor {"value":302.2,"units":"V"} [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_1_voltage/state/string_sensor {"value":"302.2"} [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_pv_1_voltage/value "302.2" [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_efficiency/state/string_sensor {"value":"84.9"} [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/efficiency, payload=[Buffer]84.9 [latest-22080]2022-04-02T17:14:19.501Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_efficiency/value "84.9" [latest-22080]2022-04-02T17:14:19.501Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_1_voltage/state/value_sensor {"value":302.2,"units":"V"} [latest-22080]2022-04-02T17:14:19.501Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_1_voltage/state/string_sensor {"value":"302.2"} [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/pv_1_voltage, payload=[Buffer]302.2 [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_1_voltage/value "302.2" [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_pv_2_voltage [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_pv_2_voltage [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_2_voltage/state/value_sensor {"value":302.2,"units":"V"} [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_2_voltage/state/string_sensor {"value":"302.2"} [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_pv_2_voltage/value "302.2" [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_2_voltage/state/value_sensor {"value":302.2,"units":"V"} [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_2_voltage/state/string_sensor {"value":"302.2"} [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_pv_4_current [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_pv_4_current [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_4_current/state/value_sensor {"value":0.57,"units":"A"} [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_4_current/state/string_sensor {"value":"0.57"} [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_pv_4_current/value "0.57" [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/pv_2_voltage, payload=[Buffer]302.2 [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_2_voltage/value "302.2" [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_4_current/state/value_sensor {"value":0.57,"units":"A"} [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_4_current/state/string_sensor {"value":"0.57"} [latest-22080]2022-04-02T17:14:19.505Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/pv_4_current, payload=[Buffer]0.57 [latest-22080]2022-04-02T17:14:19.505Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_4_current/value "0.57" [latest-22080]2022-04-02T17:14:20.716Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_import/state, payload=[Buffer]40140.484 [latest-22080]2022-04-02T17:14:20.752Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_export/state, payload=[Buffer]5946.984 [latest-22080]2022-04-02T17:14:20.753Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_import/state, payload=[Buffer]325.049 [latest-22080]2022-04-02T17:14:20.753Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_export/state, payload=[Buffer]3259.873 [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import/state, payload=[Buffer]5.574 [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import, payload=[Buffer]5.574 [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/Watts, payload=[Buffer]5574 [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use, payload=[Buffer]5.741 [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use_own, payload=[Buffer]0.167 [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.755Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.755Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export/state, payload=[Buffer]0.749 [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export, payload=[Buffer]0.749 [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_1/state, payload=[Buffer]0.525 [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_1, payload=[Buffer]0.525 [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_1/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.757Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_2/state, payload=[Buffer]3.819 [latest-22080]2022-04-02T17:14:20.757Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_2/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_3/state, payload=[Buffer]1.218 [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_3, payload=[Buffer]1.218 [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_3/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_1/state, payload=[Buffer]0.441 [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_import_phase_1, payload=[Buffer]0.441 [latest-22080]2022-04-02T17:14:20.759Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_1/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.759Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_2/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.759Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_2/state, payload=[Buffer]0.528 [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_2, payload=[Buffer]0.528 [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_3/state, payload=[Buffer]0.000 [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_3/state, payload=[Buffer]0.654 [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_3, payload=[Buffer]0.654 [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_1/state, payload=[Buffer]235.500 [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_1, payload=[Buffer]235.5 [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_2/state, payload=[Buffer]232.900 [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_2, payload=[Buffer]232.9 [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_3/state, payload=[Buffer]235.600 [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_3, payload=[Buffer]235.6 [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_1/state, payload=[Buffer]2.900 [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_1, payload=[Buffer]2.9 [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_2/state, payload=[Buffer]16.600 [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.800 [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_3, payload=[Buffer]5.8 [latest-22080]2022-04-02T17:14:21.909Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/STATE, payload=[Buffer]{"Time":"2022-04-02T19:14:21","Uptime":"54T18:23:25","UptimeSec":4731805,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":92,"POWER":"ON","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":4,"Downtime":"0T00:00:19"}} [latest-22080]2022-04-02T17:14:21.909Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648919661 [latest-22080]2022-04-02T17:14:21.909Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/HaDevice1/LastUpdate, payload=[Buffer]1648919661 [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-02T19:14:21","Uptime":"54T18:23:25","UptimeSec":4731805,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":92,"POWER":"ON","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":4,"Downtime":"0T00:00:19"}} [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/UptimeSec, payload=[Buffer]4731805 [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-02T19:14:21 [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Wifi/RSSI, payload=[Buffer]58 [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Wifi/Signal, payload=[Buffer]-71 [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Uptime, payload=[Buffer]54T18:23:25 [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"} [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"} [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } } [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:5:MQTTController.js:604> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"} [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"Var1":"3.4"} [latest-22080]2022-04-02T17:14:22.210Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"WebSend":"Done"} [latest-22080]2022-04-02T17:14:22.211Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/10086/TemperatureSensor1/CurrentTemperature, payload=[Buffer]3.4 [latest-22080]2022-04-02T17:14:22.211Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/5/VeraBridge1/LastUpdate, payload=[Buffer]1648919662 [latest-22080]2022-04-02T17:14:26.644Z <wsapi:INFO> client "192.168.1.238#1" closed, code=1001, reason= [latest-22080]2022-04-02T17:14:27.081Z <wsapi:INFO> wsapi: connection from "192.168.1.238"
@crille said in Issue with Tasmota sensors and MQTTController later than 22024:
I have to confess that's a bit disappointing, because if nobody tells me something doesn't work, I may never know to fix it. I rely on everyone to be ears, eyes, and hands because even if I had every device and could test every thing, the chances of me using things in the same ways, and in all of the possible ways, that people can and do are slim to non-existent. You're saying versions before 22024 are working for you, and today is 22092, 68 days later. That's a bummer.
But back to the technical side, you don't need to make your own template just to have an init. You can just add your init to your entity configuration. All that
uses_template
does is merge the referenced template into the entity config, with priority given to config (that is, if you haveinit
in your config and there's aninit
in the template, your config will prevail). I will make this more clear in the docs.And, that init really shouldn't be necessary if your Tasmota has the retain flag set for those messages -- MQTTController would get the message with last state when it subscribes after it connects. At least, that would be the case for a compliant broker (I have no idea what you're using as a broker).
Log snippets are helpful. I think I spotted an issue. Let me set up a test case and run your messages through statically, and see if I'm right, and if I am, what I can do about it. Stay tuned!
Yes, sorry for not being persistent with my issue on this, we kind of touched it before here but obviously it worked for you and no one else had issues so I made it work for me.
I first noticed my current issue in 22029 (mentioned in MantisBT #0000303, not related to this, as “other issues”) and haven’t had the time to mess with a stable setup to report the errors since. My apologies!
Better late than never I’m doing my part now when life allows the time for fun stuff like this
I believe openLuup MQTT broker supports the retain flag now and will configure my devices to apply it, if not I will move them to my Mosquitto broker when I have the time.
Thank you for your patience and support!
@crille I'm sorry you've had to live with it this long. Let's get it straightened out.
New build 22092 of MQTTController is available for download/install. Let's see if that gets things rolling (your template or the included one, either way, but it will require
json_payload: true
where JSON is used). -
OK, new tests done.
This is done with 22092 with log level 6.
reactor.yaml
"pooltemp": name: "Pooltemp" topic: "Pooltemp" source: "DS18B20" uses_template: tasmota_sensor_temperature
as you can see it's using included default template
tasmota_sensor_temperature: type: ValueSensor capabilities: [temperature_sensor] primary_attribute: temperature_sensor.value events: "tele/%topic%/SENSOR": "temperature_sensor.value": json_payload: true if_expr: '! isnull( payload?[ source ?? "Global" ] )' expr: 'payload[ source ?? "Global" ]?.Temperature' "temperature_sensor.units": json_payload: true if_expr: '! isnull( payload?.TempUnit )' expr: payload.TempUnit
I've set
SensorRetain 1
in Tasmota and the value is now retained in openLuup
log after restart of MSR
[latest-22080]2022-04-03T13:06:19.815Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.800 [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Växthuset/SENSOR, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to esp32 [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for esp32: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>esp32: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } } [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to flora1 [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for flora1: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>flora1: [Object]{ "temperature_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Temperature" }, "temperature_sensor.units": "C", "humidity_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Moisture" }, "humidity_sensor.units": "%", "light_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Illuminance" }, "light_sensor.units": "lux", "value_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Fertility" }, "value_sensor.units": "µS/cm" } [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Växthuset/SENSOR on flora1: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} at _run (/home/homebridge/reactor/common/lexp.js:1431:31) at /home/homebridge/reactor/common/lexp.js:1512:33 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1511:28) at _run (/home/homebridge/reactor/common/lexp.js:1414:33) at /home/homebridge/reactor/common/lexp.js:1265:29 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1264:28) at Object.run (/home/homebridge/reactor/common/lexp.js:1645:22) at MQTTController.handle_event (/home/homebridge/reactor/ext/MQTTController/MQTTController.js:567:44) [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to flora2 [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for flora2: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>flora2: [Object]{ "temperature_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Temperature" }, "temperature_sensor.units": "C", "humidity_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Moisture" }, "humidity_sensor.units": "%", "light_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Illuminance" }, "light_sensor.units": "lux", "value_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Fertility" }, "value_sensor.units": "µS/cm" } [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Växthuset/SENSOR on flora2: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} at _run (/home/homebridge/reactor/common/lexp.js:1431:31) at /home/homebridge/reactor/common/lexp.js:1512:33 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1511:28) at _run (/home/homebridge/reactor/common/lexp.js:1414:33) at /home/homebridge/reactor/common/lexp.js:1265:29 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1264:28) at Object.run (/home/homebridge/reactor/common/lexp.js:1645:22) at MQTTController.handle_event (/home/homebridge/reactor/ext/MQTTController/MQTTController.js:567:44) [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648991187 [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/HaDevice1/LastUpdate, payload=[Buffer]1648991187 [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Växthuset/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}} [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Växthuset/Time, payload=[Buffer]2022-04-03T15:06:27 [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/Illuminance, payload=[Buffer]547 [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/RSSI, payload=[Buffer]-97 [latest-22080]2022-04-03T13:06:27.254Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/Temperature, payload=[Buffer]10.5 [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/STATE, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Uptime":"55T14:15:31","UptimeSec":4803331,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":93,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":4,"Downtime":"0T00:00:19"}} [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648991188 [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/HaDevice1/LastUpdate, payload=[Buffer]1648991188 [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Uptime":"55T14:15:31","UptimeSec":4803331,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":93,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":4,"Downtime":"0T00:00:19"}} [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/UptimeSec, payload=[Buffer]4803331 [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-03T15:06:27 [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Uptime, payload=[Buffer]55T14:15:31 [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"} [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"} [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } } [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:5:MQTTController.js:604> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"} [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/DS18B20/Temperature, payload=[Buffer]8.8 [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-03T15:06:28 [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"Var1":"8.8"} [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching stat/Pooltemp/RESULT to dräneringspump [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling stat/Pooltemp/RESULT for dräneringspump: {"Var1":"8.8"} [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>dräneringspump: [Object]{ "power_switch.state": { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" } } [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"} [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"} ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"} at _run (/home/homebridge/reactor/common/lexp.js:1431:31) at /home/homebridge/reactor/common/lexp.js:1512:33 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1511:28) at _run (/home/homebridge/reactor/common/lexp.js:1414:33) at /home/homebridge/reactor/common/lexp.js:1265:29 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1264:28) at Object.run (/home/homebridge/reactor/common/lexp.js:1645:22) at MQTTController.handle_event (/home/homebridge/reactor/ext/MQTTController/MQTTController.js:567:44) [latest-22080]2022-04-03T13:06:28.733Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/10086/TemperatureSensor1/CurrentTemperature, payload=[Buffer]8.6 [latest-22080]2022-04-03T13:06:28.733Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/5/VeraBridge1/LastUpdate, payload=[Buffer]1648991188 [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"WebSend":"Done"} [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching stat/Pooltemp/RESULT to dräneringspump [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling stat/Pooltemp/RESULT for dräneringspump: {"WebSend":"Done"} [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>dräneringspump: [Object]{ "power_switch.state": { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" } } [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"} [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"} ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"} at _run (/home/homebridge/reactor/common/lexp.js:1431:31) at /home/homebridge/reactor/common/lexp.js:1512:33 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1511:28) at _run (/home/homebridge/reactor/common/lexp.js:1414:33) at /home/homebridge/reactor/common/lexp.js:1265:29 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1264:28) at Object.run (/home/homebridge/reactor/common/lexp.js:1645:22) at MQTTController.handle_event (/home/homebridge/reactor/ext/MQTTController/MQTTController.js:567:44) [latest-22080]2022-04-03T13:06:29.774Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_import/state, payload=[Buffer]40196.133 [latest-22080]2022-04-03T13:06:29.804Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_export/state, payload=[Buffer]5955.417 [latest-22080]2022-04-03T13:06:29.804Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_import/state, payload=[Buffer]325.054 [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_export/state, payload=[Buffer]3266.027 [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import/state, payload=[Buffer]4.250 [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import, payload=[Buffer]4.250 [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/Watts, payload=[Buffer]4250 [latest-22080]2022-04-03T13:06:29.806Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use, payload=[Buffer]7.933 [latest-22080]2022-04-03T13:06:29.806Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export/state, payload=[Buffer]0.589 [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export, payload=[Buffer]0.589 [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_1/state, payload=[Buffer]0.652 [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_1, payload=[Buffer]0.652 [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_1/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_2/state, payload=[Buffer]2.673 [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_2, payload=[Buffer]2.673 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_2/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_3/state, payload=[Buffer]0.844 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_3, payload=[Buffer]0.844 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_3/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_1/state, payload=[Buffer]0.954 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_import_phase_1, payload=[Buffer]0.954 [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_1/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_2/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_2/state, payload=[Buffer]0.432 [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_2, payload=[Buffer]0.432 [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_3/state, payload=[Buffer]0.000 [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_3/state, payload=[Buffer]1.118 [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_3, payload=[Buffer]1.118 [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_1/state, payload=[Buffer]232.900 [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_1, payload=[Buffer]232.9 [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_2/state, payload=[Buffer]231.200 [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_2, payload=[Buffer]231.2 [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_3/state, payload=[Buffer]233.800 [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_3, payload=[Buffer]233.8 [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_1/state, payload=[Buffer]4.900 [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_1, payload=[Buffer]4.9 [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_2/state, payload=[Buffer]11.700 [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_2, payload=[Buffer]11.7 [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.900 [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_3, payload=[Buffer]5.9 [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_input_power [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_input_power [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_input_power/state/value_sensor {"value":3647,"units":"W"}
Can you confirm in the startup messages that MQTTController is version 22092? The messages are not consistent with what should be seen in the new version.
This is from 22024
[latest-22080]2022-04-03T14:52:25.150Z <SystemController:null> Module SystemController v22080 [latest-22080]2022-04-03T14:52:25.151Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController) [latest-22080]2022-04-03T14:52:25.152Z <MQTTController:null> Module MQTTController v22009 [latest-22080]2022-04-03T14:52:25.191Z <MQTTController:INFO> instance topic ident is mqtt
and this is from 22092
[latest-22080]2022-04-03T14:56:46.397Z <SystemController:null> Module SystemController v22080 [latest-22080]2022-04-03T14:56:46.398Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController) [latest-22080]2022-04-03T14:56:46.400Z <MQTTController:null> Module MQTTController v22029 [latest-22080]2022-04-03T14:56:46.437Z <MQTTController:INFO> instance topic ident is mqtt
Line 3 from 22092 says... 22029... dyslexia in version! That's a build error, and a strange coincidence at that.
I just rebuilt the package. Re-download it and run the install again, then try. It should say 22092 at startup.
Yup, now I can confirm it's version 22092
[latest-22080]2022-04-03T15:24:40.904Z <SystemController:null> Module SystemController v22080 [latest-22080]2022-04-03T15:24:40.905Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController) [latest-22080]2022-04-03T15:24:40.906Z <MQTTController:null> Module MQTTController v22092 [latest-22080]2022-04-03T15:24:40.943Z <MQTTController:INFO> instance topic ident is mqtt
AND I now get the value for temperature on the next tele, but not the retained value at startup...?
My custom template using init is also working when JSON payload is declared.Tell me what you need next.
OK. I can see on my Tasmota devices that it doesn't send the retain flag
on
... and I can't find that in Tasmota configuration... seems like a big hole, actually. I assumed that would be somewhere, and I'm disappointed that I'm apparently wrong.So, init will be required. However, your
init
should work with the included template (no need to copy the template to your local config, just put yourinit
afteruses_template
). If that's not working, I'd like to know.EDIT: I found it... it's obscure. In the Tasmota console (it's not in the GUI), you need to type each of:
PowerRetain on SensorRetain on StateRetain on SwitchRetain on
For your temperature sensor,
SensorRetain
may be sufficient, but I don't see why you would not use it for other types as well. -
I've set SensorRetain 1 in Tasmota and the value is now retained in openLuup
Yes, I've done that but the value does not get set when I restart MSR for some reason.
I had to restart my Tasmota device to get it to work, and of course, force state/value changes on the device to get it to send a first message with that flag set.
Here's what my log looks like with Mosquitto broker and the Tasmota device disconnected from power (so unable to publish -- anything Tasmota is therefore retained and sent from the broker):
[###BUILDVERSION###]2022-04-03T17:37:38.285Z <MQTTController:null> Module MQTTController v22092 [###BUILDVERSION###]2022-04-03T17:37:38.323Z <MQTTController:5:Controller.js:90> [MQTTController:constructor] created controller mqtt [###BUILDVERSION###]2022-04-03T17:37:38.323Z <MQTTController:INFO> instance topic ident is mqtt [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity blueiris_cam6_motion [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity blueiris_cam13_motion [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity "75e505_1" [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity "75e505_2" [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.0.66:1883/ [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:5:MQTTController.js:241> MQTTController#mqtt connecting to mqtt://192.168.0.66:1883/ with options [Object]{ "reconnectPeriod": 15000, "clientId": "reactor_drupal_mqtt", "connectTimeout": 10000, "resubscribe": false, "will": { "topic": "reactor/mqtt/LWT", "payload": "offline", "qos": 1, "retain": true, "properties": { "willDelayInterval": 30 } } } [###BUILDVERSION###]2022-04-03T17:37:38.474Z <MQTTController:INFO> connected; opening subscriptions [###BUILDVERSION###]2022-04-03T17:37:38.477Z <MQTTController:INFO> Sending inits and going online! [###BUILDVERSION###]2022-04-03T17:37:38.478Z <MQTTController:NOTICE> Controller MQTTController#mqtt is now online. [###BUILDVERSION###]2022-04-03T17:37:38.488Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling tele/tasmota_75E505/STATE for "75e505_1": {"Time":"2022-04-03T18:32:34","Uptime":"0T00:10:10","UptimeSec":610,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SupremeGarden","BSSId":"44:D9:E7:03:C7:3A","Channel":6,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:04"}} [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_1 power_switch.state=true [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling tele/tasmota_75E505/STATE for "75e505_2": {"Time":"2022-04-03T18:32:34","Uptime":"0T00:10:10","UptimeSec":610,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SupremeGarden","BSSId":"44:D9:E7:03:C7:3A","Channel":6,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:04"}} [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_2 power_switch.state=true [###BUILDVERSION###]2022-04-03T17:37:38.494Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling stat/tasmota_75E505/POWER1 for "75e505_1": ON [###BUILDVERSION###]2022-04-03T17:37:38.494Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_1 power_switch.state=true
You can see on line 10, it says
, and then immediately thereafter it gets the retained messages from the broker. You should be able to confirm similar behavior at log level 5. Given that retain is a new feature for openLuup, I would suggest you confirm it's actually sending the messages; clearly it knows it should, but that doesn't prove it does. -
Yup, that's it. I moved the Tasmota device to Mosquitto and can replicate your log. So with openLuup I have to use
init
as it does not seem to respond with the retained messages at MSR startup.
I will consider moving all my devices to Mosquitto in the future, except for those I need to do Luup calculations and variable sets on virtual devices.Oddly the rebuild seems to resolved most of my problems and I'm now up to date with the MQTTController, which was the main issue. Thank you very much for that!
No worries!
Paging @akbooer.... see the last couple of messages above. Apparently @Crille has some retained messages (they show as retained in the openLuup UI) that are not being sent by openLuup's broker when Reactor subscribes. FYI, Reactor uses a "catch-all" subscription (complete wildcard, i.e.
is the entire subscription request). -
Thanks for the heads up. Clearly something missing here that needs to be investigated.
