  4. [Solved] Issue with Tasmota sensors and MQTTController later than 22024
Possible feature request?
Copying a global reaction
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
22 Posts 3 Posters 3.7k Views 3 Watching
    MSR: latest-22080-ae7212f bare metal.
    I tried several times to update MQTTController but all my Tasmota sensors shows null and never updates if I go above version 22024 of MQTTController.
    I tried both my own local_mqtt_devices.yaml and the default template but getting these errors in the log for all my sensors after an update.
    [latest-22080]2022-03-30T13:26:02.821Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Pooltemp/SENSOR on pooltemp: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-03-30T15:26:02","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"}
    [latest-22080]2022-03-30T13:26:02.821Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-03-30T15:26:02","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"}
    [latest-22080]2022-03-30T13:26:02.828Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Var1":"3.4"}
    [latest-22080]2022-03-30T13:26:02.828Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Var1":"3.4"}
    [latest-22080]2022-03-30T13:26:03.113Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"}
    [latest-22080]2022-03-30T13:26:03.113Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"}
    The example device is running fine with this config on 22024.
    "pooltemp":
       topic: "Pooltemp"
       source: "DS18B20"
       uses_template: my_tasmota_sensor_temperature
    my_tasmota_sensor_temperature:
      type: ValueSensor
      init:
        - topic: "cmnd/%topic%/STATUS"
          payload: 10
          type: raw
      events:
        "tele/%topic%/SENSOR":
          "temperature_sensor.value":
            expr: 'payload[source]?.Temperature'
          "temperature_sensor.units":
            expr: payload.TempUnit
        "stat/%topic%/STATUS10":
            expr: 'payload.StatusSNS[source]?.Temperature'
            expr: payload.StatusSNS.TempUnit
    Any clues on how I could proceed troubleshooting? and as always, what critical information have I missed in this post? 🙂
      I'm wondering why you made a custom template. Why not use the tasmota_sensor_temperature built-in template?
      On your own template, you're not declaring that the payload is JSON, so it will be unparseable by your expressions as given. So I would try the built-in template first and see if that fixes at least half of the issue (there's no template for your special STATUS10 topic, but you can use the built-in template in mqtt_devices.yaml as a model for the changes you'd likely need to make.
      Upping the log level to 5 or 6 (+restart) is often good before trying again and then posting logs, to increase traceable information. Also, it's really vital that you post a dozen or more lines of log before the error, not just the error. Context is vital in determining what it thinks its doing before the error. The error alone may not tell much (other than that there was an error).
        I made custom templates because I never got the default to work and I wanted a init on restarts of MSR.
        My templates is based on what was in the default templates when I created them and then it was not mandatory to declare payload as JSON, it may have changed and I might have missed that release note so I tried declaring a JSON payload in my templates but made no difference.
        I'm now running default template for tasmota temperature sensor with log level 6 and all that is set from SENSOR topic is temperature_sensor.units
        log with version 22024
        [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:242> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-02T19:02:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.8},"TempUnit":"C"}
        [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:270> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp
        [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:5:MQTTController.js:500> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-02T19:02:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.8},"TempUnit":"C"}
        [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "expr": "payload[source]?.Temperature" }, "temperature_sensor.units": { "expr": "payload.TempUnit" } }
        [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:589> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.value=3.8
        [latest-22080]2022-04-02T17:02:21.892Z <MQTTController:6:MQTTController.js:589> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C
        log with 22086.
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"}
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"}
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } }
        [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:5:MQTTController.js:604> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C
        long snippet from that time with 22086.
        [latest-22080]2022-04-02T17:14:19.496Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_active_power/state/value_sensor {"value":167,"units":"W"}
        [latest-22080]2022-04-02T17:14:19.496Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_active_power/state/string_sensor {"value":"167"}
        [latest-22080]2022-04-02T17:14:19.496Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_active_power/value "167"
        [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/input_power, payload=[Buffer]197
        [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_input_power/value "197"
        [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_active_power/state/value_sensor {"value":167,"units":"W"}
        [latest-22080]2022-04-02T17:14:19.497Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_active_power/state/string_sensor {"value":"167"}
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/active_power, payload=[Buffer]0.167
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/Watts, payload=[Buffer]167
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_active_power/value "167"
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_efficiency
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_efficiency
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_efficiency/state/value_sensor {"value":84.9,"units":"%"}
        [latest-22080]2022-04-02T17:14:19.498Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_efficiency/state/string_sensor {"value":"84.9"}
        [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_efficiency/value "84.9"
        [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_efficiency/state/value_sensor {"value":84.9,"units":"%"}
        [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_pv_1_voltage
        [latest-22080]2022-04-02T17:14:19.499Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_pv_1_voltage
        [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass
        [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_1_voltage/state/value_sensor {"value":302.2,"units":"V"}
        [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_1_voltage/state/string_sensor {"value":"302.2"}
        [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_pv_1_voltage/value "302.2"
        [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_efficiency/state/string_sensor {"value":"84.9"}
        [latest-22080]2022-04-02T17:14:19.500Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/efficiency, payload=[Buffer]84.9
        [latest-22080]2022-04-02T17:14:19.501Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_efficiency/value "84.9"
        [latest-22080]2022-04-02T17:14:19.501Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_1_voltage/state/value_sensor {"value":302.2,"units":"V"}
        [latest-22080]2022-04-02T17:14:19.501Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_1_voltage/state/string_sensor {"value":"302.2"}
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/pv_1_voltage, payload=[Buffer]302.2
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_1_voltage/value "302.2"
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_pv_2_voltage
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_pv_2_voltage
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_2_voltage/state/value_sensor {"value":302.2,"units":"V"}
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_2_voltage/state/string_sensor {"value":"302.2"}
        [latest-22080]2022-04-02T17:14:19.502Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_pv_2_voltage/value "302.2"
        [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_2_voltage/state/value_sensor {"value":302.2,"units":"V"}
        [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_2_voltage/state/string_sensor {"value":"302.2"}
        [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_pv_4_current
        [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_pv_4_current
        [latest-22080]2022-04-02T17:14:19.503Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_4_current/state/value_sensor {"value":0.57,"units":"A"}
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_pv_4_current/state/string_sensor {"value":"0.57"}
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:801> MQTTController#mqtt echo publishing primary attribute topic reactor/mqtt/hass/sensor_pv_4_current/value "0.57"
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/pv_2_voltage, payload=[Buffer]302.2
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_2_voltage/value "302.2"
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_4_current/state/value_sensor {"value":0.57,"units":"A"}
        [latest-22080]2022-04-02T17:14:19.504Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_4_current/state/string_sensor {"value":"0.57"}
        [latest-22080]2022-04-02T17:14:19.505Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/67/EnergyMetering1/pv_4_current, payload=[Buffer]0.57
        [latest-22080]2022-04-02T17:14:19.505Z <MQTTController:6:MQTTController.js:856> MQTTController#mqtt handling incoming reactor/mqtt/hass/sensor_pv_4_current/value "0.57"
        [latest-22080]2022-04-02T17:14:20.716Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_import/state, payload=[Buffer]40140.484
        [latest-22080]2022-04-02T17:14:20.752Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_export/state, payload=[Buffer]5946.984
        [latest-22080]2022-04-02T17:14:20.753Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_import/state, payload=[Buffer]325.049
        [latest-22080]2022-04-02T17:14:20.753Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_export/state, payload=[Buffer]3259.873
        [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import/state, payload=[Buffer]5.574
        [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import, payload=[Buffer]5.574
        [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/Watts, payload=[Buffer]5574
        [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use, payload=[Buffer]5.741
        [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use_own, payload=[Buffer]0.167
        [latest-22080]2022-04-02T17:14:20.754Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.755Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.755Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export/state, payload=[Buffer]0.749
        [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export, payload=[Buffer]0.749
        [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_1/state, payload=[Buffer]0.525
        [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_1, payload=[Buffer]0.525
        [latest-22080]2022-04-02T17:14:20.756Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_1/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.757Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_2/state, payload=[Buffer]3.819
        [latest-22080]2022-04-02T17:14:20.757Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_2/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_3/state, payload=[Buffer]1.218
        [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_3, payload=[Buffer]1.218
        [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_3/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_1/state, payload=[Buffer]0.441
        [latest-22080]2022-04-02T17:14:20.758Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_import_phase_1, payload=[Buffer]0.441
        [latest-22080]2022-04-02T17:14:20.759Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_1/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.759Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_2/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.759Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_2/state, payload=[Buffer]0.528
        [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_2, payload=[Buffer]0.528
        [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_3/state, payload=[Buffer]0.000
        [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_3/state, payload=[Buffer]0.654
        [latest-22080]2022-04-02T17:14:20.760Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_3, payload=[Buffer]0.654
        [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_1/state, payload=[Buffer]235.500
        [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_1, payload=[Buffer]235.5
        [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_2/state, payload=[Buffer]232.900
        [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_2, payload=[Buffer]232.9
        [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_3/state, payload=[Buffer]235.600
        [latest-22080]2022-04-02T17:14:20.761Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_3, payload=[Buffer]235.6
        [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_1/state, payload=[Buffer]2.900
        [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_1, payload=[Buffer]2.9
        [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_2/state, payload=[Buffer]16.600
        [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.800
        [latest-22080]2022-04-02T17:14:20.762Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_3, payload=[Buffer]5.8
        [latest-22080]2022-04-02T17:14:21.909Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/STATE, payload=[Buffer]{"Time":"2022-04-02T19:14:21","Uptime":"54T18:23:25","UptimeSec":4731805,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":92,"POWER":"ON","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":4,"Downtime":"0T00:00:19"}}
        [latest-22080]2022-04-02T17:14:21.909Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648919661
        [latest-22080]2022-04-02T17:14:21.909Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/HaDevice1/LastUpdate, payload=[Buffer]1648919661
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-02T19:14:21","Uptime":"54T18:23:25","UptimeSec":4731805,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":92,"POWER":"ON","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":4,"Downtime":"0T00:00:19"}}
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/UptimeSec, payload=[Buffer]4731805
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-02T19:14:21
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Wifi/RSSI, payload=[Buffer]58
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Wifi/Signal, payload=[Buffer]-71
        [latest-22080]2022-04-02T17:14:21.910Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Uptime, payload=[Buffer]54T18:23:25
        [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-02T19:14:21","DS18B20":{"Id":"02049245CBF4","Temperature":3.4},"TempUnit":"C"}
        [latest-22080]2022-04-02T17:14:21.911Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"Var1":"3.4"}
        [latest-22080]2022-04-02T17:14:22.210Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"WebSend":"Done"}
        [latest-22080]2022-04-02T17:14:22.211Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/10086/TemperatureSensor1/CurrentTemperature, payload=[Buffer]3.4
        [latest-22080]2022-04-02T17:14:22.211Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/5/VeraBridge1/LastUpdate, payload=[Buffer]1648919662
        [latest-22080]2022-04-02T17:14:26.644Z <wsapi:INFO> client "192.168.1.238#1" closed, code=1001, reason=
        [latest-22080]2022-04-02T17:14:27.081Z <wsapi:INFO> wsapi: connection from "192.168.1.238"
          log with 22086.
          @crille said in Issue with Tasmota sensors and MQTTController later than 22024:
          I have to confess that's a bit disappointing, because if nobody tells me something doesn't work, I may never know to fix it. I rely on everyone to be ears, eyes, and hands because even if I had every device and could test every thing, the chances of me using things in the same ways, and in all of the possible ways, that people can and do are slim to non-existent. You're saying versions before 22024 are working for you, and today is 22092, 68 days later. That's a bummer.
          But back to the technical side, you don't need to make your own template just to have an init. You can just add your init to your entity configuration. All that uses_template does is merge the referenced template into the entity config, with priority given to config (that is, if you have init in your config and there's an init in the template, your config will prevail). I will make this more clear in the docs.
          And, that init really shouldn't be necessary if your Tasmota has the retain flag set for those messages -- MQTTController would get the message with last state when it subscribes after it connects. At least, that would be the case for a compliant broker (I have no idea what you're using as a broker).
          Log snippets are helpful. I think I spotted an issue. Let me set up a test case and run your messages through statically, and see if I'm right, and if I am, what I can do about it. Stay tuned!
            Yes, sorry for not being persistent with my issue on this, we kind of touched it before here but obviously it worked for you and no one else had issues so I made it work for me.
            I first noticed my current issue in 22029 (mentioned in MantisBT #0000303, not related to this, as “other issues”) and haven’t had the time to mess with a stable setup to report the errors since. My apologies!
            Better late than never I’m doing my part now when life allows the time for fun stuff like this 🙂
            I believe openLuup MQTT broker supports the retain flag now and will configure my devices to apply it, if not I will move them to my Mosquitto broker when I have the time.
            Thank you for your patience and support!
              @crille I'm sorry you've had to live with it this long. Let's get it straightened out.
              New build 22092 of MQTTController is available for download/install. Let's see if that gets things rolling (your template or the included one, either way, but it will require json_payload: true where JSON is used).
                OK, new tests done.
                This is done with 22092 with log level 6.
                reactor.yaml
                "pooltemp":
                  topic: "Pooltemp"
                  source: "DS18B20"
                as you can see it's using included default template
                  type: ValueSensor
                  events:
                        json_payload: true
                        if_expr: '! isnull( payload?[ source ?? "Global" ] )'
                        json_payload: true
                        if_expr: '! isnull( payload?.TempUnit )'
                I've set SensorRetain 1 in Tasmota and the value is now retained in openLuup
                log after restart of MSR
                [latest-22080]2022-04-03T13:06:19.815Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.800
                [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Växthuset/SENSOR, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to esp32
                [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for esp32: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>esp32: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } }
                [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to flora1
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for flora1: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>flora1: [Object]{ "temperature_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Temperature" }, "temperature_sensor.units": "C", "humidity_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Moisture" }, "humidity_sensor.units": "%", "light_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Illuminance" }, "light_sensor.units": "lux", "value_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Fertility" }, "value_sensor.units": "µS/cm" }
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Växthuset/SENSOR on flora1: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                    at _run (/home/homebridge/reactor/common/lexp.js:1431:31)
                    at /home/homebridge/reactor/common/lexp.js:1512:33
                    at _run (/home/homebridge/reactor/common/lexp.js:1511:28)
                    at _run (/home/homebridge/reactor/common/lexp.js:1414:33)
                    at /home/homebridge/reactor/common/lexp.js:1265:29
                    at _run (/home/homebridge/reactor/common/lexp.js:1264:28)
                    at Object.run (/home/homebridge/reactor/common/lexp.js:1645:22)
                    at MQTTController.handle_event (/home/homebridge/reactor/ext/MQTTController/MQTTController.js:567:44)
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to flora2
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for flora2: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>flora2: [Object]{ "temperature_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Temperature" }, "temperature_sensor.units": "C", "humidity_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Moisture" }, "humidity_sensor.units": "%", "light_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Illuminance" }, "light_sensor.units": "lux", "value_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Fertility" }, "value_sensor.units": "µS/cm" }
                [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Växthuset/SENSOR on flora2: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648991187
                [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/HaDevice1/LastUpdate, payload=[Buffer]1648991187
                [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Växthuset/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
                [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Växthuset/Time, payload=[Buffer]2022-04-03T15:06:27
                [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/Illuminance, payload=[Buffer]547
                [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/RSSI, payload=[Buffer]-97
                [latest-22080]2022-04-03T13:06:27.254Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/Temperature, payload=[Buffer]10.5
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/STATE, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Uptime":"55T14:15:31","UptimeSec":4803331,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":93,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":4,"Downtime":"0T00:00:19"}}
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648991188
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/HaDevice1/LastUpdate, payload=[Buffer]1648991188
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Uptime":"55T14:15:31","UptimeSec":4803331,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":93,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":4,"Downtime":"0T00:00:19"}}
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/UptimeSec, payload=[Buffer]4803331
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-03T15:06:27
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Uptime, payload=[Buffer]55T14:15:31
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"}
                [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp
                [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"}
                [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } }
                [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:5:MQTTController.js:604> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C
                [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"}
                [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/DS18B20/Temperature, payload=[Buffer]8.8
                [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-03T15:06:28
                [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"Var1":"8.8"}
                [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching stat/Pooltemp/RESULT to dräneringspump
                [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling stat/Pooltemp/RESULT for dräneringspump: {"Var1":"8.8"}
                [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>dräneringspump: [Object]{ "power_switch.state": { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" } }
                [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"}
                [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"}
                [latest-22080]2022-04-03T13:06:28.733Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/10086/TemperatureSensor1/CurrentTemperature, payload=[Buffer]8.6
                [latest-22080]2022-04-03T13:06:28.733Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/5/VeraBridge1/LastUpdate, payload=[Buffer]1648991188
                [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"WebSend":"Done"}
                [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching stat/Pooltemp/RESULT to dräneringspump
                [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling stat/Pooltemp/RESULT for dräneringspump: {"WebSend":"Done"}
                [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>dräneringspump: [Object]{ "power_switch.state": { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" } }
                [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"}
                [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"}
                [latest-22080]2022-04-03T13:06:29.774Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_import/state, payload=[Buffer]40196.133
                [latest-22080]2022-04-03T13:06:29.804Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_export/state, payload=[Buffer]5955.417
                [latest-22080]2022-04-03T13:06:29.804Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_import/state, payload=[Buffer]325.054
                [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_export/state, payload=[Buffer]3266.027
                [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import/state, payload=[Buffer]4.250
                [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import, payload=[Buffer]4.250
                [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/Watts, payload=[Buffer]4250
                [latest-22080]2022-04-03T13:06:29.806Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use, payload=[Buffer]7.933
                [latest-22080]2022-04-03T13:06:29.806Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export/state, payload=[Buffer]0.589
                [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export, payload=[Buffer]0.589
                [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_1/state, payload=[Buffer]0.652
                [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_1, payload=[Buffer]0.652
                [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_1/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_2/state, payload=[Buffer]2.673
                [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_2, payload=[Buffer]2.673
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_2/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_3/state, payload=[Buffer]0.844
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_3, payload=[Buffer]0.844
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_3/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_1/state, payload=[Buffer]0.954
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_import_phase_1, payload=[Buffer]0.954
                [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_1/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_2/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_2/state, payload=[Buffer]0.432
                [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_2, payload=[Buffer]0.432
                [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_3/state, payload=[Buffer]0.000
                [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_3/state, payload=[Buffer]1.118
                [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_3, payload=[Buffer]1.118
                [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_1/state, payload=[Buffer]232.900
                [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_1, payload=[Buffer]232.9
                [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_2/state, payload=[Buffer]231.200
                [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_2, payload=[Buffer]231.2
                [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_3/state, payload=[Buffer]233.800
                [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_3, payload=[Buffer]233.8
                [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_1/state, payload=[Buffer]4.900
                [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_1, payload=[Buffer]4.9
                [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_2/state, payload=[Buffer]11.700
                [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_2, payload=[Buffer]11.7
                [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.900
                [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_3, payload=[Buffer]5.9
                [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_input_power
                [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_input_power
                [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass
                [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_input_power/state/value_sensor {"value":3647,"units":"W"}
                Gui
                  Can you confirm in the startup messages that MQTTController is version 22092? The messages are not consistent with what should be seen in the new version.
                    This is from 22024
                    [latest-22080]2022-04-03T14:52:25.150Z <SystemController:null> Module SystemController v22080
                    [latest-22080]2022-04-03T14:52:25.151Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
                    [latest-22080]2022-04-03T14:52:25.152Z <MQTTController:null> Module MQTTController v22009
                    [latest-22080]2022-04-03T14:52:25.191Z <MQTTController:INFO> instance topic ident is mqtt
                    and this is from 22092
                    [latest-22080]2022-04-03T14:56:46.397Z <SystemController:null> Module SystemController v22080
                    [latest-22080]2022-04-03T14:56:46.398Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
                    [latest-22080]2022-04-03T14:56:46.400Z <MQTTController:null> Module MQTTController v22029
                    [latest-22080]2022-04-03T14:56:46.437Z <MQTTController:INFO> instance topic ident is mqtt
                      Line 3 from 22092 says... 22029... dyslexia in version! That's a build error, and a strange coincidence at that.
                      I just rebuilt the package. Re-download it and run the install again, then try. It should say 22092 at startup.
                        Yup, now I can confirm it's version 22092
                        [latest-22080]2022-04-03T15:24:40.904Z <SystemController:null> Module SystemController v22080
                        [latest-22080]2022-04-03T15:24:40.905Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
                        [latest-22080]2022-04-03T15:24:40.906Z <MQTTController:null> Module MQTTController v22092
                        [latest-22080]2022-04-03T15:24:40.943Z <MQTTController:INFO> instance topic ident is mqtt
                        AND I now get the value for temperature on the next tele, but not the retained value at startup...?
                        My custom template using init is also working when JSON payload is declared.
                        Tell me what you need next.
                          OK. I can see on my Tasmota devices that it doesn't send the retain flag on... and I can't find that in Tasmota configuration... seems like a big hole, actually. I assumed that would be somewhere, and I'm disappointed that I'm apparently wrong.
                          So, init will be required. However, your init should work with the included template (no need to copy the template to your local config, just put your init after uses_template). If that's not working, I'd like to know.
                          EDIT: I found it... it's obscure. In the Tasmota console (it's not in the GUI), you need to type each of:
                          PowerRetain on
                          SensorRetain on
                          StateRetain on
                          SwitchRetain on
                          For your temperature sensor, SensorRetain may be sufficient, but I don't see why you would not use it for other types as well.
                            OK, new tests done.
                            reactor.yaml
                            "pooltemp":
                              topic: "Pooltemp"
                              source: "DS18B20"
                              type: ValueSensor
                              events:
                                    json_payload: true
                                    json_payload: true
                            Gui
                            Yes, I've done that but the value does not get set when I restart MSR for some reason.
                              I had to restart my Tasmota device to get it to work, and of course, force state/value changes on the device to get it to send a first message with that flag set.
                                This is from openLuup retained messages:
                                  Here's what my log looks like with Mosquitto broker and the Tasmota device disconnected from power (so unable to publish -- anything Tasmota is therefore retained and sent from the broker):
                                  [###BUILDVERSION###]2022-04-03T17:37:38.285Z <MQTTController:null> Module MQTTController v22092
                                  [###BUILDVERSION###]2022-04-03T17:37:38.323Z <MQTTController:5:Controller.js:90> [MQTTController:constructor] created controller mqtt
                                  [###BUILDVERSION###]2022-04-03T17:37:38.323Z <MQTTController:INFO> instance topic ident is mqtt
                                  [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity blueiris_cam6_motion
                                  [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity blueiris_cam13_motion
                                  [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity "75e505_1"
                                  [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity "75e505_2"
                                  [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.0.66:1883/
                                  [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:5:MQTTController.js:241> MQTTController#mqtt connecting to mqtt://192.168.0.66:1883/ with options [Object]{ "reconnectPeriod": 15000, "clientId": "reactor_drupal_mqtt", "connectTimeout": 10000, "resubscribe": false, "will": { "topic": "reactor/mqtt/LWT", "payload": "offline", "qos": 1, "retain": true, "properties": { "willDelayInterval": 30 } } }
                                  [###BUILDVERSION###]2022-04-03T17:37:38.474Z <MQTTController:INFO> connected; opening subscriptions
                                  [###BUILDVERSION###]2022-04-03T17:37:38.477Z <MQTTController:INFO> Sending inits and going online!
                                  [###BUILDVERSION###]2022-04-03T17:37:38.478Z <MQTTController:NOTICE> Controller MQTTController#mqtt is now online.
                                  [###BUILDVERSION###]2022-04-03T17:37:38.488Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling tele/tasmota_75E505/STATE for "75e505_1": {"Time":"2022-04-03T18:32:34","Uptime":"0T00:10:10","UptimeSec":610,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SupremeGarden","BSSId":"44:D9:E7:03:C7:3A","Channel":6,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:04"}}
                                  [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_1 power_switch.state=true
                                  [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling tele/tasmota_75E505/STATE for "75e505_2": {"Time":"2022-04-03T18:32:34","Uptime":"0T00:10:10","UptimeSec":610,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SupremeGarden","BSSId":"44:D9:E7:03:C7:3A","Channel":6,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:04"}}
                                  [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_2 power_switch.state=true
                                  [###BUILDVERSION###]2022-04-03T17:37:38.494Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling stat/tasmota_75E505/POWER1 for "75e505_1": ON
                                  [###BUILDVERSION###]2022-04-03T17:37:38.494Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_1 power_switch.state=true
                                  You can see on line 10, it says connected; opening subscriptions, and then immediately thereafter it gets the retained messages from the broker. You should be able to confirm similar behavior at log level 5. Given that retain is a new feature for openLuup, I would suggest you confirm it's actually sending the messages; clearly it knows it should, but that doesn't prove it does.
                                    Yup, that's it. I moved the Tasmota device to Mosquitto and can replicate your log. So with openLuup I have to use init as it does not seem to respond with the retained messages at MSR startup.
                                    I will consider moving all my devices to Mosquitto in the future, except for those I need to do Luup calculations and variable sets on virtual devices.
                                    Oddly the rebuild seems to resolved most of my problems and I'm now up to date with the MQTTController, which was the main issue. Thank you very much for that!
                                      No worries!
                                      Paging @akbooer.... see the last couple of messages above. Apparently @Crille has some retained messages (they show as retained in the openLuup UI) that are not being sent by openLuup's broker when Reactor subscribes. FYI, Reactor uses a "catch-all" subscription (complete wildcard, i.e. # is the entire subscription request).
                                        No worries!
                                        Thanks for the heads up. Clearly something missing here that needs to be investigated.
                                          @Crille
                                          What topic(s) are you subscribing to which isn't sent? I have found a possible error if it contains a wildcard, but just wanted to check. Thanks.
                                          • Possible feature request?
                                          • Copying a global reaction
                                          • Time series documentation
                                          • Tuya Wifi to Tasmota flashing
                                          • Reset a delay
                                          • Single protocol?
