  4. [Solved] Issue with Tasmota sensors and MQTTController later than 22024
22 Posts 3 Posters 7.4k Views 3 Watching
    Yes, sorry for not being persistent with my issue on this, we kind of touched it before here but obviously it worked for you and no one else had issues so I made it work for me.
    I first noticed my current issue in 22029 (mentioned in MantisBT #0000303, not related to this, as “other issues”) and haven’t had the time to mess with a stable setup to report the errors since. My apologies!
    Better late than never I’m doing my part now when life allows the time for fun stuff like this 🙂
    I believe openLuup MQTT broker supports the retain flag now and will configure my devices to apply it, if not I will move them to my Mosquitto broker when I have the time.
    Thank you for your patience and support!
    toggledbitsT Online
    toggledbitsT Online
    @crille I'm sorry you've had to live with it this long. Let's get it straightened out.
    New build 22092 of MQTTController is available for download/install. Let's see if that gets things rolling (your template or the included one, either way, but it will require json_payload: true where JSON is used).
    • CrilleC Online
      CrilleC Online
      OK, new tests done.
      This is done with 22092 with log level 6.
      reactor.yaml
      "pooltemp":
        topic: "Pooltemp"
        source: "DS18B20"
      as you can see it's using included default template
      tasmota_sensor_temperature:
        type: ValueSensor
        events:
          "tele/%topic%/SENSOR":
            "temperature_sensor.value":
              json_payload: true
              if_expr: '! isnull( payload?[ source ?? "Global" ] )'
            "temperature_sensor.units":
              json_payload: true
              if_expr: '! isnull( payload?.TempUnit )'
              expr: payload.TempUnit
      I've set SensorRetain 1 in Tasmota and the value is now retained in openLuup
      log after restart of MSR
      [latest-22080]2022-04-03T13:06:19.815Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.800
      [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Växthuset/SENSOR, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to esp32
      [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for esp32: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>esp32: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } }
      [latest-22080]2022-04-03T13:06:27.251Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to flora1
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for flora1: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>flora1: [Object]{ "temperature_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Temperature" }, "temperature_sensor.units": "C", "humidity_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Moisture" }, "humidity_sensor.units": "%", "light_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Illuminance" }, "light_sensor.units": "lux", "value_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Fertility" }, "value_sensor.units": "µS/cm" }
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Växthuset/SENSOR on flora1: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
          at _run (/home/homebridge/reactor/common/lexp.js:1431:31)
          at /home/homebridge/reactor/common/lexp.js:1512:33
          at _run (/home/homebridge/reactor/common/lexp.js:1511:28)
          at _run (/home/homebridge/reactor/common/lexp.js:1414:33)
          at /home/homebridge/reactor/common/lexp.js:1265:29
          at _run (/home/homebridge/reactor/common/lexp.js:1264:28)
          at Object.run (/home/homebridge/reactor/common/lexp.js:1645:22)
          at MQTTController.handle_event (/home/homebridge/reactor/ext/MQTTController/MQTTController.js:567:44)
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Växthuset/SENSOR to flora2
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Växthuset/SENSOR for flora2: {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>flora2: [Object]{ "temperature_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Temperature" }, "temperature_sensor.units": "C", "humidity_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Moisture" }, "humidity_sensor.units": "%", "light_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Illuminance" }, "light_sensor.units": "lux", "value_sensor.value": { "if_expr": "! isnull( payload?[ source ] )", "expr": "payload?[source]?.Fertility" }, "value_sensor.units": "µS/cm" }
      [latest-22080]2022-04-03T13:06:27.252Z <MQTTController:ERR> MQTTController#mqtt event handler failed for tele/Växthuset/SENSOR on flora2: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648991187
      [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/HaDevice1/LastUpdate, payload=[Buffer]1648991187
      [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Växthuset/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":10.5,"Illuminance":547,"Moisture":0,"Fertility":0,"RSSI":-97}}
      [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Växthuset/Time, payload=[Buffer]2022-04-03T15:06:27
      [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/Illuminance, payload=[Buffer]547
      [latest-22080]2022-04-03T13:06:27.253Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/RSSI, payload=[Buffer]-97
      [latest-22080]2022-04-03T13:06:27.254Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30005/Flora6cab88/Temperature, payload=[Buffer]10.5
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/STATE, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Uptime":"55T14:15:31","UptimeSec":4803331,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":93,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":4,"Downtime":"0T00:00:19"}}
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/35/HaDevice1/LastUpdate, payload=[Buffer]1648991188
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/HaDevice1/LastUpdate, payload=[Buffer]1648991188
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:27","Uptime":"55T14:15:31","UptimeSec":4803331,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":93,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Orion","BSSId":"E0:3F:49:06:F1:30","Channel":6,"Mode":"11n","RSSI":46,"Signal":-77,"LinkCount":4,"Downtime":"0T00:00:19"}}
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/UptimeSec, payload=[Buffer]4803331
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-03T15:06:27
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Uptime, payload=[Buffer]55T14:15:31
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=tele/Pooltemp/SENSOR, payload=[Buffer]{"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"}
      [latest-22080]2022-04-03T13:06:28.452Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching tele/Pooltemp/SENSOR to pooltemp
      [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling tele/Pooltemp/SENSOR for pooltemp: {"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"}
      [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>pooltemp: [Object]{ "temperature_sensor.value": { "json_payload": true, "if_expr": "! isnull( payload?[ source ?? \"Global\" ] )", "expr": "payload[ source ?? \"Global\" ]?.Temperature" }, "temperature_sensor.units": { "json_payload": true, "if_expr": "! isnull( payload?.TempUnit )", "expr": "payload.TempUnit" } }
      [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:5:MQTTController.js:604> MQTTController#mqtt setting Entity#mqtt>pooltemp temperature_sensor.units=C
      [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/tele, payload=[Buffer]{"Time":"2022-04-03T15:06:28","DS18B20":{"Id":"02049245CBF4","Temperature":8.8},"TempUnit":"C"}
      [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/DS18B20/Temperature, payload=[Buffer]8.8
      [latest-22080]2022-04-03T13:06:28.453Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/30003/Pooltemp/Time, payload=[Buffer]2022-04-03T15:06:28
      [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"Var1":"8.8"}
      [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching stat/Pooltemp/RESULT to dräneringspump
      [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling stat/Pooltemp/RESULT for dräneringspump: {"Var1":"8.8"}
      [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>dräneringspump: [Object]{ "power_switch.state": { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" } }
      [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"}
      [latest-22080]2022-04-03T13:06:28.458Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"Var1":"8.8"}
      [latest-22080]2022-04-03T13:06:28.733Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/10086/TemperatureSensor1/CurrentTemperature, payload=[Buffer]8.6
      [latest-22080]2022-04-03T13:06:28.733Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/5/VeraBridge1/LastUpdate, payload=[Buffer]1648991188
      [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=stat/Pooltemp/RESULT, payload=[Buffer]{"WebSend":"Done"}
      [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt dispatching stat/Pooltemp/RESULT to dräneringspump
      [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:5:MQTTController.js:508> MQTTController#mqtt handling stat/Pooltemp/RESULT for dräneringspump: {"WebSend":"Done"}
      [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:6:MQTTController.js:532> MQTTController#mqtt events for Entity#mqtt>dräneringspump: [Object]{ "power_switch.state": { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" } }
      [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:ERR> MQTTController#mqtt event handler failed for stat/Pooltemp/RESULT on dräneringspump: [ReferenceError]ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"}
      [latest-22080]2022-04-03T13:06:28.774Z <MQTTController:CRIT> ReferenceError: Invalid reference to member [object Object] of {"WebSend":"Done"}
      [latest-22080]2022-04-03T13:06:29.774Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_import/state, payload=[Buffer]40196.133
      [latest-22080]2022-04-03T13:06:29.804Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_active_export/state, payload=[Buffer]5955.417
      [latest-22080]2022-04-03T13:06:29.804Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_import/state, payload=[Buffer]325.054
      [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/cumulative_reactive_export/state, payload=[Buffer]3266.027
      [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import/state, payload=[Buffer]4.250
      [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import, payload=[Buffer]4.250
      [latest-22080]2022-04-03T13:06:29.805Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/Watts, payload=[Buffer]4250
      [latest-22080]2022-04-03T13:06:29.806Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_use, payload=[Buffer]7.933
      [latest-22080]2022-04-03T13:06:29.806Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export/state, payload=[Buffer]0.589
      [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export, payload=[Buffer]0.589
      [latest-22080]2022-04-03T13:06:29.807Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_1/state, payload=[Buffer]0.652
      [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_1, payload=[Buffer]0.652
      [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_1/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_2/state, payload=[Buffer]2.673
      [latest-22080]2022-04-03T13:06:29.808Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_2, payload=[Buffer]2.673
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_2/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_import_phase_3/state, payload=[Buffer]0.844
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_active_import_phase_3, payload=[Buffer]0.844
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_active_export_phase_3/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_1/state, payload=[Buffer]0.954
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_import_phase_1, payload=[Buffer]0.954
      [latest-22080]2022-04-03T13:06:29.810Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_1/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_2/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_2/state, payload=[Buffer]0.432
      [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_2, payload=[Buffer]0.432
      [latest-22080]2022-04-03T13:06:29.811Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_import_phase_3/state, payload=[Buffer]0.000
      [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/momentary_reactive_export_phase_3/state, payload=[Buffer]1.118
      [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/momentary_reactive_export_phase_3, payload=[Buffer]1.118
      [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_1/state, payload=[Buffer]232.900
      [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_1, payload=[Buffer]232.9
      [latest-22080]2022-04-03T13:06:29.812Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_2/state, payload=[Buffer]231.200
      [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_2, payload=[Buffer]231.2
      [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/voltage_phase_3/state, payload=[Buffer]233.800
      [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/voltage_phase_3, payload=[Buffer]233.8
      [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_1/state, payload=[Buffer]4.900
      [latest-22080]2022-04-03T13:06:29.813Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_1, payload=[Buffer]4.9
      [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_2/state, payload=[Buffer]11.700
      [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_2, payload=[Buffer]11.7
      [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=smartreader/sensor/current_phase_3/state, payload=[Buffer]5.900
      [latest-22080]2022-04-03T13:06:29.814Z <MQTTController:6:MQTTController.js:250> MQTTController#mqtt message topic=openLuup/update/56/EnergyMetering1/current_phase_3, payload=[Buffer]5.9
      [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:727> MQTTController#mqtt echo handling entity notification for Entity#hass>sensor_input_power
      [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:732> MQTTController#mqtt echo publishing capabilities for entity Entity#hass>sensor_input_power
      [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:775> MQTTController#mqtt echo cap x_hass rejected -- default reject extended x_hass
      [latest-22080]2022-04-03T13:06:30.477Z <MQTTController:6:MQTTController.js:793> MQTTController#mqtt echo publishing reactor/mqtt/hass/sensor_input_power/state/value_sensor {"value":3647,"units":"W"}
      Gui
      • toggledbitsT Online
        toggledbitsT Online
        Can you confirm in the startup messages that MQTTController is version 22092? The messages are not consistent with what should be seen in the new version.
        • CrilleC Online
          CrilleC Online
          This is from 22024
          [latest-22080]2022-04-03T14:52:25.150Z <SystemController:null> Module SystemController v22080
          [latest-22080]2022-04-03T14:52:25.151Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
          [latest-22080]2022-04-03T14:52:25.152Z <MQTTController:null> Module MQTTController v22009
          [latest-22080]2022-04-03T14:52:25.191Z <MQTTController:INFO> instance topic ident is mqtt
          and this is from 22092
          [latest-22080]2022-04-03T14:56:46.397Z <SystemController:null> Module SystemController v22080
          [latest-22080]2022-04-03T14:56:46.398Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
          [latest-22080]2022-04-03T14:56:46.400Z <MQTTController:null> Module MQTTController v22029
          [latest-22080]2022-04-03T14:56:46.437Z <MQTTController:INFO> instance topic ident is mqtt
            toggledbitsT Online
            Line 3 from 22092 says... 22029... dyslexia in version! That's a build error, and a strange coincidence at that.
            I just rebuilt the package. Re-download it and run the install again, then try. It should say 22092 at startup.
            • CrilleC Online
              CrilleC Online
              Yup, now I can confirm it's version 22092
              [latest-22080]2022-04-03T15:24:40.904Z <SystemController:null> Module SystemController v22080
              [latest-22080]2022-04-03T15:24:40.905Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
              [latest-22080]2022-04-03T15:24:40.906Z <MQTTController:null> Module MQTTController v22092
              [latest-22080]2022-04-03T15:24:40.943Z <MQTTController:INFO> instance topic ident is mqtt
              AND I now get the value for temperature on the next tele, but not the retained value at startup...?
              My custom template using init is also working when JSON payload is declared.
              Tell me what you need next.
                toggledbitsT Online
                OK. I can see on my Tasmota devices that it doesn't send the retain flag on... and I can't find that in Tasmota configuration... seems like a big hole, actually. I assumed that would be somewhere, and I'm disappointed that I'm apparently wrong.
                So, init will be required. However, your init should work with the included template (no need to copy the template to your local config, just put your init after uses_template). If that's not working, I'd like to know.
                EDIT: I found it... it's obscure. In the Tasmota console (it's not in the GUI), you need to type each of:
                PowerRetain on
                SensorRetain on
                StateRetain on
                SwitchRetain on
                For your temperature sensor, SensorRetain may be sufficient, but I don't see why you would not use it for other types as well.
                  OK, new tests done.
                  reactor.yaml
                  "pooltemp":
                    topic: "Pooltemp"
                    source: "DS18B20"
                    type: ValueSensor
                    events:
                          json_payload: true
                          json_payload: true
                  Gui
                  CrilleC Online
                  CrilleC Online
                  @crille said in Issue with Tasmota sensors and MQTTController later than 22024:
                  Yes, I've done that but the value does not get set when I restart MSR for some reason.
                    toggledbitsT Online
                    I had to restart my Tasmota device to get it to work, and of course, force state/value changes on the device to get it to send a first message with that flag set.
                    • CrilleC Online
                      CrilleC Online
                      This is from openLuup retained messages:
                        toggledbitsT Online
                        Here's what my log looks like with Mosquitto broker and the Tasmota device disconnected from power (so unable to publish -- anything Tasmota is therefore retained and sent from the broker):
                        [###BUILDVERSION###]2022-04-03T17:37:38.285Z <MQTTController:null> Module MQTTController v22092
                        [###BUILDVERSION###]2022-04-03T17:37:38.323Z <MQTTController:5:Controller.js:90> [MQTTController:constructor] created controller mqtt
                        [###BUILDVERSION###]2022-04-03T17:37:38.323Z <MQTTController:INFO> instance topic ident is mqtt
                        [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity blueiris_cam6_motion
                        [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity blueiris_cam13_motion
                        [###BUILDVERSION###]2022-04-03T17:37:38.376Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity "75e505_1"
                        [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:5:MQTTController.js:70> MQTTController#mqtt configuring entity "75e505_2"
                        [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.0.66:1883/
                        [###BUILDVERSION###]2022-04-03T17:37:38.377Z <MQTTController:5:MQTTController.js:241> MQTTController#mqtt connecting to mqtt://192.168.0.66:1883/ with options [Object]{ "reconnectPeriod": 15000, "clientId": "reactor_drupal_mqtt", "connectTimeout": 10000, "resubscribe": false, "will": { "topic": "reactor/mqtt/LWT", "payload": "offline", "qos": 1, "retain": true, "properties": { "willDelayInterval": 30 } } }
                        [###BUILDVERSION###]2022-04-03T17:37:38.474Z <MQTTController:INFO> connected; opening subscriptions
                        [###BUILDVERSION###]2022-04-03T17:37:38.477Z <MQTTController:INFO> Sending inits and going online!
                        [###BUILDVERSION###]2022-04-03T17:37:38.478Z <MQTTController:NOTICE> Controller MQTTController#mqtt is now online.
                        [###BUILDVERSION###]2022-04-03T17:37:38.488Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling tele/tasmota_75E505/STATE for "75e505_1": {"Time":"2022-04-03T18:32:34","Uptime":"0T00:10:10","UptimeSec":610,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SupremeGarden","BSSId":"44:D9:E7:03:C7:3A","Channel":6,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:04"}}
                        [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_1 power_switch.state=true
                        [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling tele/tasmota_75E505/STATE for "75e505_2": {"Time":"2022-04-03T18:32:34","Uptime":"0T00:10:10","UptimeSec":610,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"SupremeGarden","BSSId":"44:D9:E7:03:C7:3A","Channel":6,"Mode":"11n","RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:04"}}
                        [###BUILDVERSION###]2022-04-03T17:37:38.489Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_2 power_switch.state=true
                        [###BUILDVERSION###]2022-04-03T17:37:38.494Z <MQTTController:5:MQTTController.js:521> MQTTController#mqtt handling stat/tasmota_75E505/POWER1 for "75e505_1": ON
                        [###BUILDVERSION###]2022-04-03T17:37:38.494Z <MQTTController:5:MQTTController.js:626> MQTTController#mqtt setting Entity#mqtt>75e505_1 power_switch.state=true
                        You can see on line 10, it says connected; opening subscriptions, and then immediately thereafter it gets the retained messages from the broker. You should be able to confirm similar behavior at log level 5. Given that retain is a new feature for openLuup, I would suggest you confirm it's actually sending the messages; clearly it knows it should, but that doesn't prove it does.
                        • CrilleC Online
                          CrilleC Online
                          Yup, that's it. I moved the Tasmota device to Mosquitto and can replicate your log. So with openLuup I have to use init as it does not seem to respond with the retained messages at MSR startup.
                          I will consider moving all my devices to Mosquitto in the future, except for those I need to do Luup calculations and variable sets on virtual devices.
                          Oddly the rebuild seems to resolved most of my problems and I'm now up to date with the MQTTController, which was the main issue. Thank you very much for that!
                            toggledbitsT Online
                            No worries!
                            Paging @akbooer.... see the last couple of messages above. Apparently @Crille has some retained messages (they show as retained in the openLuup UI) that are not being sent by openLuup's broker when Reactor subscribes. FYI, Reactor uses a "catch-all" subscription (complete wildcard, i.e. # is the entire subscription request).
                              No worries!
                              Thanks for the heads up. Clearly something missing here that needs to be investigated.
                                @Crille
                                What topic(s) are you subscribing to which isn't sent? I have found a possible error if it contains a wildcard, but just wanted to check. Thanks.
                                  @Crille
                                  toggledbitsT Online
                                  toggledbitsT Online
                                  #21
                                  @akbooer It's Reactor that's subscribing, and as I posted earlier, Reactor subscribes with # alone, so it's 100% wildcard ("give me everything").
                                    Ah, OK, I wasn't clear. I am now. That's clearly a bug. Thanks.
                                      159.7k
