  4. Copying configuraiton and rules from QNAP install to Raspberry PI 4 install
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
13 Posts 3 Posters 2.0k Views 3 Watching
    Talisker
    I have made good progress setting up a new Raspberry PI 4 with the latest OS (64bit) and latest Reactor images in Docker. However I am not able to copy my configuraiton files (.yml) and reactor reactions over. I am not yet that confident with linux commands, so I have tired to drag and drop the files from a USB drive to the working folders in my new Raspberry PI. I am getting a popup in the GUI stating 'The file operation was completed with errors.' and Errors occured: "rule-xxxxxx.json: Error opening file "/home/pi/reactor/....................................json":Permission denied.
    I suspect it's something to do with permissions?
    Is there an easier way to copy my configuration over??
    Vera plus user. MSR user on Raspberry PI 4. Running MSR version 23049 in Docker
      Where are the files currently?
      What user are you logging on as when you're copying the files?
      There's sort of a million ways to solve this.
      You can SCP them over
      SFTP them over
      Copy them as the correct user (which is the fundamental issue.
      So what user are you working as and what user owns the /home/pi/reactor folder?
      ls -l /home/pi
      Will be a good start
      Do you have SSH access to the Pi?
        I suspect the files on the QNAP have root as the owner. That often happens with docker containers, and if you're just logged in as the pi user trying to copy the files, you'll get those messages. Drag and drop isn't going to get you there. I don't have a QNAP NAS, but if you can ssh into it, do that (log in as yourself). Then...
        • Bring yourself up to root sudo su -.
        • Navigate (using cd) to the directory above your config, storage, and logs on the QNAP NAS.
        • Make an archive file: tar cvf ../reactorconfig.tar .
          This will create the archive file in the directory above your current directory.
        • Copy the archive file to the Pi (e.g. into /home/pi)
        • Log in on the Pi as pi
        • Become root on the Pi: sudo su -
        • Go to the directory you created for the Reactor work files (using cd)
        • Untar the archive file: tar xvf /home/pi/reactorconfig.tar
        • Make your future life easier by making pi the owner of the files (esp. the config files): chown -R pi .
        • Exit the root privilege level: exit (you are now user pi again)
        • Try starting the docker container (using docker-compose is highly recommended, see install instructions).
          Talisker
          Thanks for the prompt responses guys. I might have to concede on this one and start my reactions again!
          On another note. I have installed / configured docker-compose (or at least I thought I had). I don't seem to be able to use it to stop reactor:
          pi@raspberrypi:~ $ docker stop reactor
          Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/reactor/stop": dial unix /var/run/docker.sock: connect: permission denied
          pi@raspberrypi:~ $ cd reactor
          pi@raspberrypi:~/reactor $ docker stop reactor
          pi@raspberrypi:~/reactor $ dir
          config docker-compose.yml logs storage
          pi@raspberrypi:~/reactor $ ^C
          pi@raspberrypi:~/reactor $ sudo docker stop reactor
          reactor
          pi@raspberrypi:~/reactor $ docker-compose down
          ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
          If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
            I should probably leave this to @toggledbits but what does
            su docker stop reactor
            do?
              Talisker
              pi@raspberrypi:~/reactor $ su docker stop reactor
              su: user docker does not exist or the user entry does not contain all the required fields
                Oh sorry!
                DOH
                  Oh sorry!
                  DOH
                  Talisker
                  @catmanv2 I tried that thanks and it works:
                  sudo docker stop reactor #stops reactor
                  sudo service docker restart #starts reactor
                  Cheers!
                    Talisker
                    @toggledbits thanks for the methodology. I manged to copy the files from a usb stick to the relevant folders using the sudo cp command. Feeling pretty pleased as I am now up an running on my raspberry pi.
                      Just add the pi user to the docker group on the Pi, and you won't have to sudo to use the docker or docker-compose commands.
                      # Run this command as user `pi`:
                      sudo usermod -a -G docker pi
                      Going forward, you should do everything related to the process (container) via docker-compose. You should rarely need or use the docker command itself.
                        Talisker
                        @toggledbits something is not working quite right with my docker install (docker-compose). Not sure where to start!
                          Can you post your compose file? Also, I assume you ran the docker-compose command while in the same directory as the compose file? Did you start it with docker-compose? If not, you're probably going to get errors like this trying to stop it with docker-compose... the two commands are not interchangeable (for start/stop).
                            Talisker
                            Sorry @toggledbits . I tied it again after a good break and it appears to work fine. I honestly don't know what was going wrong but things seem to now be in order:
                            pi@raspberrypi:~/reactor $ ls
                            Stopping reactor ... done
                            Removing reactor ... done
                            Removing network reactor_default
                            pi@raspberrypi:~/reactor $ docker-compose pull
                            Pulling reactor ... done
                            pi@raspberrypi:~/reactor $ docker-compose up -d
                            Creating network "reactor_default" with the default driver
                            Creating reactor ... done
                            docker-compose.yml below FYI:
                            Multi-System Reactor template docker-compose.yml (version 22160)
                            Change the lines indicated by "DO"...
                            version: '3'
                            services:
                            reactor:
                            container_name: reactor
                            environment:
                            TZ: GB
                            restart: "always"
                            expose:
                              - 8111
                            ports:
                              - 8111:8111
                            volumes:
                              - /home/pi/reactor:/var/reactor
                            tmpfs: /tmp
                              307
                              100.3k
                            • Next Release?
