  4. Copying configuraiton and rules from QNAP install to Raspberry PI 4 install
13 Posts 3 Posters 2.7k Views 3 Watching
    Where are the files currently?
    What user are you logging on as when you're copying the files?
    There's sort of a million ways to solve this.
    You can SCP them over
    SFTP them over
    Copy them as the correct user (which is the fundamental issue.
    So what user are you working as and what user owns the /home/pi/reactor folder?
    ls -l /home/pi
    Will be a good start
    Do you have SSH access to the Pi?
      I suspect the files on the QNAP have root as the owner. That often happens with docker containers, and if you're just logged in as the pi user trying to copy the files, you'll get those messages. Drag and drop isn't going to get you there. I don't have a QNAP NAS, but if you can ssh into it, do that (log in as yourself). Then...
      • Bring yourself up to root sudo su -.
      • Navigate (using cd) to the directory above your config, storage, and logs on the QNAP NAS.
      • Make an archive file: tar cvf ../reactorconfig.tar .
        This will create the archive file in the directory above your current directory.
      • Copy the archive file to the Pi (e.g. into /home/pi)
      • Log in on the Pi as pi
      • Become root on the Pi: sudo su -
      • Go to the directory you created for the Reactor work files (using cd)
      • Untar the archive file: tar xvf /home/pi/reactorconfig.tar
      • Make your future life easier by making pi the owner of the files (esp. the config files): chown -R pi .
      • Exit the root privilege level: exit (you are now user pi again)
      • Try starting the docker container (using docker-compose is highly recommended, see install instructions).
        Talisker
        Thanks for the prompt responses guys. I might have to concede on this one and start my reactions again!
        On another note. I have installed / configured docker-compose (or at least I thought I had). I don't seem to be able to use it to stop reactor:
        pi@raspberrypi:~ $ docker stop reactor
        Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/reactor/stop": dial unix /var/run/docker.sock: connect: permission denied
        pi@raspberrypi:~ $ cd reactor
        pi@raspberrypi:~/reactor $ docker stop reactor
        pi@raspberrypi:~/reactor $ dir
        config docker-compose.yml logs storage
        pi@raspberrypi:~/reactor $ ^C
        pi@raspberrypi:~/reactor $ sudo docker stop reactor
        reactor
        pi@raspberrypi:~/reactor $ docker-compose down
        ERROR: Couldn't connect to Docker daemon at http+docker://localhost - is it running?
        If it's at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
          I should probably leave this to @toggledbits but what does
          su docker stop reactor
          do?
            Talisker
            pi@raspberrypi:~/reactor $ su docker stop reactor
            su: user docker does not exist or the user entry does not contain all the required fields
              Oh sorry!
              DOH
                Oh sorry!
                DOH
                Talisker
                @catmanv2 I tried that thanks and it works:
                sudo docker stop reactor #stops reactor
                sudo service docker restart #starts reactor
                Cheers!
                  Talisker
                  @toggledbits thanks for the methodology. I manged to copy the files from a usb stick to the relevant folders using the sudo cp command. Feeling pretty pleased as I am now up an running on my raspberry pi.
                    Just add the pi user to the docker group on the Pi, and you won't have to sudo to use the docker or docker-compose commands.
                    # Run this command as user `pi`:
                    sudo usermod -a -G docker pi
                    Going forward, you should do everything related to the process (container) via docker-compose. You should rarely need or use the docker command itself.
                      Talisker
                      @toggledbits something is not working quite right with my docker install (docker-compose). Not sure where to start!
                        Can you post your compose file? Also, I assume you ran the docker-compose command while in the same directory as the compose file? Did you start it with docker-compose? If not, you're probably going to get errors like this trying to stop it with docker-compose... the two commands are not interchangeable (for start/stop).
                          Talisker
                          Sorry @toggledbits . I tied it again after a good break and it appears to work fine. I honestly don't know what was going wrong but things seem to now be in order:
                          pi@raspberrypi:~/reactor $ ls
                          Stopping reactor ... done
                          Removing reactor ... done
                          Removing network reactor_default
                          pi@raspberrypi:~/reactor $ docker-compose pull
                          Pulling reactor ... done
                          pi@raspberrypi:~/reactor $ docker-compose up -d
                          Creating network "reactor_default" with the default driver
                          Creating reactor ... done
                          docker-compose.yml below FYI:
                          Multi-System Reactor template docker-compose.yml (version 22160)
                          Change the lines indicated by "DO"...
                          version: '3'
                          services:
                          reactor:
                          container_name: reactor
                          environment:
                          TZ: GB
                          restart: "always"
                          expose:
                            - 8111
                          ports:
                            - 8111:8111
                          volumes:
                            - /home/pi/reactor:/var/reactor
                          tmpfs: /tmp
                            1.0k
                            157.5k
