Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Build 22069
Note: Only users of Hubitat hubs need to upgrade to this version, and then only if you previously upgraded to 22067.
- HubitatController: Fix a possible loss of attribute change across restarts of the hub (that is, when a value changes during a Hubitat restart but Reactor is not restarted).
Build 22080
- PR 0000311: Vera Scene controller entities missing attributes in new and exisitng rules
- PR 0000310: Dependent global variable may not update after editing parent.
- HubitatController: Because the HE events websocket passes all values as strings, the new fast-update process introduced in 22067 would change (for example) a previously-numeric attribute value to a string when updated by the hub. While this doesn't generally bother conditions or expressions, the type change affects InfluxFeed because InfluxDB cannot digest the type change. The data type declared by the hub during inventory is now stored and used to remap the events feed values to keep the data types consistent on the attributes. It must be noted, however, that the data types of extension attributes (
x_hubname_...
) are driven by the hub, and are therefore not guaranteed by Reactor (types are guaranteed for Reactor-defined capabilities, e.g.dimming
,value_sensor
, etc.). Users exporting extension attributes into InfluxDB are advised to always use explicit type setting for those attributes in their InfluxFeed configuration. This advisory has been added to the documentation for InfluxFeed. - HubitatController: An inconsistency in the (HE) attribute names between their MediaPlayer and MusicPlayer capabilities with respect to transport state is now handled correctly, so that Reactor's native
av_transport.state
attribute shows a correct value regardless of which the device uses. - SystemController: Will now issue system alerts unconditionally when disk space becomes critical (unless disk space monitoring has been disabled by user configuration), in addition to the (previously available) values and flags on the
reactor_system>system
(Reactor System) entity. It's also probably a good idea to add notifications (i.e. in your own rules) for such conditions raised by the system entity, if the user is not regularly looking at the Reactor UI. See the documentation for SystemController. - SystemController: A
dst
(boolean) attribute has been added to thereactor_system>sun
(Sun Information) entity; it will be true when Daylight Saving Time is in effect, false otherwise. - HassController: Fix
cover
capability handling on non-positionable covers (e.g. garage doors). - Dashboard: New display for cover entities.
Build 22118 (latest and zwavejs) — PLEASE READ ALL ADVISORIES BELOW
NODEJS VERSION REQUIREMENT: As previously announced, nodejs versions below 16 are no longer supported as of 2022-Mar-31. Bare-metal users (only) will need to upgrade their nodejs to version 16 (the current LTS version) or higher. Bare-metal RPi users can use the install script to do this. Docker image users needn't concern themselves; the image is built with an approved version of nodejs.
NOTE: This release includes changes to package dependencies. Bare-metal users please run
npm install --no-save --omit dev
to resolve.IMPORTANT: This update includes some significant enhancements for entity tracking. On your first startup after upgrading, you will get a lot of alerts about new devices being discovered (i.e. existing devices are being noted as new) as the enhanced tracking learns what is "normal" for your system. This is expected behavior for this version on its first startup. Just clear the alerts and go on about your day. After that, you should only receive notices when new devices are added to a hub, or new hubs are configured in Reactor.
Remember to hard-refresh all browsers after upgrading and restarting.
- PR 0000316: Variable Value condition with substitution in operand may replace expression with value in saved rule.
- PR 0000315: Improve alert message when a Rule-based reaction fails.
- PR 0000314: Fix "self-subscribe" exceptions logged after creating new Rule with local expressions and a Variable Value condition (exceptions clear after restart of Reactor).
- PR 0000312: Expressions
getEntity()
helper not listing or updating attributes correctly (fixed). - Raspberry Pi Install Script: Support for 64-bit installation on Raspbian Bullseye.
- Raspberry Pi Install Script: Can now be used to upgrade nodejs with a local (user-specific) install.
- UI: Faster core startup brings up the UI more quickly, and does not wait for controller startups, so a delay in a controller becoming ready (e.g. its associated hub is offline) will no longer delay the UI being available.
- UI: You can now add an SSL/TLS certificate and have the UI and API served over HTTPS (see How-To in documentation).
- New actions in
sys_system
capability to tell a Controller instance to purge unused entities (i.e. that no longer exist on the hub but are still present in Reactor), delete an entity (from Reactor only, not from the hub/mesh/etc.), and rename an entity (in Reactor, not at the hub/mesh/etc.). - UI/Entity Picker: You can now move the entity picker by dragging its title bar.
- UI/Entity Picker: The name search field will now also match on entity IDs.
- UI/Reaction editor: Changing from a group or while to another reaction type while editing would leave the conditions behind (they should be removed); fixed.
- Expressions: lexpjs updated, adds
yday
(day of year),isoweek
(ISO-8601 week number) anddst
(boolean) todateparts()
function result. - Status: Controller Status widget now sorts down/failed controllers first.
- Docs: Added How-Tos for serving media files from Reactor's built-in web server and set up HTTPS for the UI.
- HassController: Bless Hass version 2022.4.7.
REMINDER: If you need to post an issue related to this (or any) version, please follow the posting guidelines.
Build 22123 (latest and zwavejs)
This version primarily addresses a formatting problem in error messages when certain conditions (triggers and constraints) take an error (e.g. an Entity Attribute condition references an entity that no longer exists). This is cosmetic/display only and has no operational impact, but I thought it important to make a new release for the fix because of the difficulty of troubleshooting conditions with the broken messages.
If you are upgrading to this version from any version earlier than 22118, please read the release notes for 22118 in the prior post above.
Build 22136
NEW: This version adds the availability of 64-bit ARM docker images. This is recommended for Raspberry Pi 4 users on Raspbian Bullseye (only; Raspbian Buster users should continue to use the armv7l image). The 64-bit ARM images also work (and are tested) on the NVIDIA Jetson Nano (2GB model tested, but should work for all).
NOTE TO ALL USERS, ESP. CURRENT DOCKER USERS: Starting June 1, 2022, the naming of all deployed packages and docker images will be changed to remove the "raspbian" or "generic" component of the name. For example. the
latest-raspbian-armv7l
docker image will be named simplylatest-armv7l
, and thelatest-generic-amd64
ZIP archive will be namedlatest-amd64
. You will need to update your version upgrade procedures accordingly; users ofdocker-compose
will need to make this change in their compose files.- Additional localization updates;
- HassController: Bless Hass to 2022.5.4
Build 22140
NOTE TO DOCKER CONTAINER USERS: Starting with the first release in June 2022, docker images will be named only with the release branch and architecture. That is, the current
will becomelatest-amd64
, andlatest-raspbian-armv7l
will becomelatest-armv7l
. This will require changes to your upgrade procedure, or if you are using docker-compose, theimage
value in your compose file.- Additional localization updates;
- HassCOntroller: Bless Hass to 2022.5.5
Build 22142 (latest, zwavejs)
- PR 0000321: HTTP API
perform
action does not send response when it succeeds (clients then time out waiting for the response that never comes). - PR 0000320: API Docs: Fix
entity
API examples.
Build 22149 (latest, zwavejs)
- PR 0000322: EzloController: provide mapping for Xiaomi Mini Switch (a single-button remote).
- Rule: make sure clear of trouble state (on startup) is saved if necessary (so UI updates properly without need to refresh).
- VeraController: Hack for variables named
sl_
, which are the special Luup state variables that always send updates/call watches even when set to the same value they already have (all other state variables in Vera/Luup do not behave this way, they only trigger events when their values change). In particular, thesesl_
states are changed when lock codes on locks are entered, or buttons on scene controllers are pressed. For these uses, it is important that a repeated use of the same code or button signals an additional event, so Vera/Luup's uses these specialsl_
states for those. VeraController now inserts an extra_updated
attribute of the same name that can be used with the changes operator to detect when thesl_
states are updated. Refer to this forum post for more information.
Build 22168 (latest, zwavejs, stable)
REMINDER: As previously announced, all docker images are now named with the release branch and target architecture only. The
latest
branch docker image for all x86_64/amd64 systems is now namedlatest-amd64
(was previouslylatest-generic-amd64
). Thelatest
branch image for armv7l, which includes Raspberry Pi systems on Raspbian Buster, is now namedlatest-armv7l
(was previouslylatest-raspbian-armv7l
). Please adjust your upgrade procedures and, if used, docker-compose or Portainer configurations accordingly.- NUTController (for Network UPS Tools) is now available as an installable extra.
- Documentation updates to reflect updated installation archive and docker image names.
Build 22178 (latest, zwavejs)
NOTE: I will be on holiday for most of the month of July, and with limited Internet access. During this time, I will not be able to provide software support, fixes or builds, and likely will not have much time or means to read and answer questions. Please step up and provide support to your peers if questions come up!
- HassController: Set null state for switches and sensors when Hass reports them unavailable.
- HassController: Bless Hass to 2022.6.7.
- Docs: Improve details in Synology/Docker installation.
Build 22179 (latest, zwavejs)
- HassController: Fix an issue that may randomly affect/disable assignment of primary attributes (since 22118).
- Fix a problem in after...within (time-restricted) sequence conditions.
Build 22203 (latest, zwavejs)
- Expressions: the
time()
function has been extended to allow parsing of date/time values in strings in forms beyond ISO-8601; most simple date/time forms should work, particularly those that closely adhere to your locale's default. A string that contains only a time will be converted to that moment on the current date; a string that contains only a date will yield midnight on that date. If a given string cannot be converted, an error will be thrown. Refer to the documentation for Expressions for more information. - HassController: Bless Hass to 2022.7.6
- Docs: documentation for Reactions now includes additional information about rule-based reaction behaviors and action groups, and has been "modernized" to use the terminology of Multi-Hub Reactor rather than that of the Reactor for Vera plugin.
- Expressions: the
Build 22233 (latest, zwavejs)
BARE-METAL INSTALL USERS: When upgrading to this version, you must upgrade package dependencies after unpacking the archive file (delete any existing
package-lock.json
file and then runnpm install --no-save --omit dev
). The UI will not function properly if you fail to perform this upgrade.ALL USERS -- REMINDER: A hard refresh of your browser is necessary after upgrading to any new build.
- Upgraded the Bootstrap library to 5.2, which gave rise to a large number of required UI changes, and an opportunity for some useful cleanups. The Bootstrap Icons library was also upgraded to 1.9. All of this also means that Internet Explorer is no longer a supported browser (use its replacement, Edge).
- HassController: Bless Hass to 2022.8.6
Build 22240 (latest, zwavejs)
BARE-METAL USERS: If you are upgrading to this version from any version earlier than 22233, you need to update your package dependencies. Pleasee see the post for that build for instructions.
- PR 0000327: Reaction Entity Action layout for additional data fields is messy.
- VeraController: Ensure
x_vera_device.failed
and.configured
are null if Vera fails to provide state for these values. - EzloController: Dead-marking and automatic removal (after delay) of entities for Ezlo devices/rooms/scenes that no longer exist (functional parity with other hub Controller objects).
- HassController: Implement mappings for scenes, scripts, and automations. All of these can have their actions run via Reactor's
script.run
action. Automations also can be en-/disabled using thepower_switch
capability actions (and entity primary state is the automation's en-/disabled state). All appear as runnable scenes in the dashboard. - UI: Improve highlighting of containing groups when sort/drop changes to conditions are made in the rules editor.
- HassController: Bless Hass to 2022.8.7
Just a news item: the ZWaveJSController is now an official add-on, available for download from
extras
. Instructions for installing it are in the Reactor documentation.For (only) those users who have been using the zwavejs build series for testing ZWaveJSController, you will now need to go back to the latest build series, and install ZWaveJSController as referenced above. There will be no further builds on the zwavejs branch. Also, ZWaveJSController no longer requires an authentication key to use, so you can remove the
auth
entry from configuration (it will be ignored and is harmless if you leave it). -
Reactor build 22248
Docker Container Users: After upgrading to this build image, please check your
NODE_PATH
environment value in your container configuration; it should read/opt/reactor:/opt/reactor/node_modules
. If it does not, please correct it (some container managers, including Synology, do not automatically reapply/update values from newer images to existing containers).- Run Reaction action: New option "wait for completion" causes the current reaction to wait for the started reaction to finish. When unchecked (default), the started reaction runs concurrently with the reaction that starts it. This (concurrent) is the behavior of all prior versions of Reactor, and since unchecked is the default, the behavior of your existing reactions does not change (unless you go in and change it). docref
- Internal changes to support general release of ZWaveJSController.
ZWaveJSController build 22248
- Reduce default logging level to 5.
- Remove unused dependency.
Reactor build 22251
Bare-metal Install Users: If you are upgrading to this version from any version prior to 22233, you need to update your package dependencies. Please see the announcement for that build for instructions.
Docker Container Users: If you are upgrading to this build from any build earlier than 22248, you need to check that your
NODE_PATH
for your container is correctly updated. See the announcement for that build for details and instructions.ALL USERS -- REMINDER: A hard refresh of your browser is necessary after upgrading to any new build.
- PR 0000328: Rule Editor: editing condition options of parent of nested groups opens child's condition options panel (fixed).
- Entities list: fix name search parity with Entity Picker (ID matches).
- Change the way object arguments to actions in reactions are stored. Previously, they were stored in the reaction as native objects by converting the given string as JSON (the input was expected to be JSON) in the UI. This made expression substitution unavailable in those (object) arguments. Now, they are stored by the UI as given (i.e. a string), so substitutions are now available in those arguments. This specifically removes the limitation that
x_hass_system.call_service
could not perform substition in itsdata
argument. It now works as expected. A deprecation warning has been added to the Engine to detect argument values stored as native objects in actions that will cause an alert to be displayed notifying the user that the reaction/action needs to be edited. Any trivial edit to the field, followed by a save of the reaction, will update the form of the data and eliminate future alerts. - Dashboard: Fix stray "x" displayed on Sensor layout when source entity's units are null.
- HassController: Bless Hass to 2022.9.0
Reactor build 22252
NODE_PATH
- PR 0000329: Rule Editor: editing sunrise/sunset condition, if only sunrise/sunset selectors are modified last, the rule does not save as configured. If other condition fields are edited after, it saves correctly.
Reactor build 22256
NODE_PATH
ALL USERS -- IMPORTANT: As a result of entity storage changes in this build, existing entity storage (cache) is invalidated and rebuilt when this build is first run. That will cause all entities to be reported as newly-discovered, even though they were known before. However, this should be minimally disruptive to your logic, if at all. You may also safely ignore any warnings you see in the logs about "incompatible serialization data" on that first run; those are expected.
- PR 0000331: In the "Pulse" output condition options, the option to limit the number of pulses vanished from the editor during the upgrade to Bootstrap 5 (i.e. since 22233). It has been restored. This did not affect the operation of existing repeat count limits on conditions. If a pulsing condition was edited, that would have removed the limit, so if you use this feature, you might check those conditions that should use it. Opening the rule detail in the Rule Sets list of rules to see the condition descriptions is sufficient to see if it's there or not -- you don't need to go into the editor to see it. When present, the condition description will include "repeat after x seconds up to y times."
- Fix spurious data format warning for HTTP Request actions.
- Entities now have metadata (data about data) for each attribute that provides the time last modified, as well as the previous value and the effective time of the previous value. In addition, any data type and other definition information known for the attribute will also be present. The quickest way to see attribute metadata is to hover over the name of an attribute in the detail panel of an entity in the Entities list. The attribute metadata is accessible in expressions via each entity's
attribute_meta
property. The subkeys of this property are capability names, and within each capability are the attribute names, and within the attribute names are the metadata elements. For example, in the commonly used form of expressiongetEntity( entity_id ).attributes.power_switch.state
we would get the value of thestate
attribute in thepower_switch
capability of whatever entity was matched; this tells us if the switch is on or off. To get the time that value was set, we would usegetEntity( entity_id ).attribute_meta.power_switch.state.last_modified
. Those of you trying to use thelastupdate
property on an entity for various purposes (such as failed node detection) should particularly take note of this change and the capability it provides. - Docs: New page Expressions with Entities & Attributes in the How-To section.
- (Advisory) HubitatController: Hub variables are limited to 255 characters by the hub firmware. Attempts to set a hub variable to a longer string will fail. See the Limitations in the HubitatController docs for more details.
- VeraController: The
sys_system.reload
action was incorrectly reloading the remote Vera hub; that's not really its job, but rather the job ofx_vera_sys.reload
. If you have been usingsys_system.reload
to restart Luup, please switch tox_vera_sys.reload
. As of this build,sys_system.reload
will cause VeraController to resync all devices and entities (i.e. it's a restart of VeraController, not your Vera). - HassController: Bless Hass to 2022.9.2
ZWaveJSController build 22256
- Send notice (displays in Status widget) when a new node is discovered.
Reactor build 22257
NODE_PATH
ALL USERS -- IMPORTANT: If you are upgrading to this build from a build earlier than 22256, please read the advisories for that build prior to proceeding.
- VeraController: Specific support for iBlinds2 (Window Blind Controller mfg 647 prod 3,13) to handle its 50%=fully open way of doing business (since the covering is made up of slats/louvers, the 0 and 100 positions are closed fully tilted one direction or the other, with 50% being "flat" between the two).
- VeraController: The generic
cover.set
action was missing, and nativetoggled
capability support was added for window coverings (toggles between open and closed, as one might expect). - Dashboard: The Cover widget (window covering) was not changing its icon when the covering changed state.
- HubitatController: Tighten checking and handling around oddly-named attributes. Apparently at least one Hubitat user has a device that has a HE-native attribute with a space in its name, causing an exception to attribute naming tightened in 22256. This was causing a no-start on the controller. This build maps out non-alphanumeric characters from Hubitat to underscores, and also provides additional error handling to prevent a single attribute from stopping the controller startup.
