Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
iPhone Locator error
Evening. Not sure if we have an equivalent section here, but since 1730 June 2nd iPhone locators are spitting out 'Google has returned an error'
Nothing changed at my end.
APPId and code are still there.What have I broken, or have Google changed? Anyone know
TIA
Hmmmm, so re-installed the Here version. It now gives the location, but whenever I try to change the settings on a phone, or access the map it throws a
Error executing function iphone_Map():And I cannot delete the API key that I had. Looks like I may have a couple of messed up versions
AltUI is somewhat more informative
an error occurred while displaying the javascript tab. devid: 0-261 err:iphone_Settings is not defined
stack:ReferenceError: iphone_Settings is not defined
at eval (eval at _deviceDrawControlPanelJSTab (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3022:17), :1:1)
at _deviceDrawControlPanelOneTabContent (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3717:8)
at _displayActiveDeviceTab (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3744:4)
at HTMLAnchorElement. (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:7036:4)
at HTMLDivElement.dispatch (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:42571)
at HTMLDivElement.v.handle (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:40572)
at Object.trigger (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:70627)
at HTMLAnchorElement. (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:71222)
at Function.each (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:2777)C
OK Just FYI here's the error from the Map tab
an error occurred while displaying the javascript tab. devid: 0-261 err:iphone_Map is not defined
stack:ReferenceError: iphone_Map is not defined
I just posted the update 2.52x on github... As for you errors, it is looking for functions which are in the J_IPhone.js file. It is either missing the file or the pointer to it. Make sure that all the files are present in the vera: Run the full update from the vera app store and then drop in the files from GitHub.
