  3. iPhone Locator error
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
34 Posts 2 Posters 9.2k Views 2 Watching
    Evening. Not sure if we have an equivalent section here, but since 1730 June 2nd iPhone locators are spitting out 'Google has returned an error'
    Nothing changed at my end.
    APPId and code are still there.
    What have I broken, or have Google changed? Anyone know
    TIA
      In fact WTF are Google doing anyway. I was using Here....
        Hmmmm, so re-installed the Here version. It now gives the location, but whenever I try to change the settings on a phone, or access the map it throws a
        Error executing function iphone_Map():
        And I cannot delete the API key that I had. Looks like I may have a couple of messed up versions
          Ok that is weird. Are you using the Here map version? Maybe it is my fault for not having changed the error message text.
            No I think it auto updated....
              ahh yeah that would do it... have to uncheck the auto update...
                Done that now. I guess I need to re-create my phone instances as well?
                  best to restore from backup...If you have one from just before the autoupdate.
                    Nah, done a shed load of work since then.....
                    Migrated everything from scenes to Reactor today! Error started about a week ago 😞
                      Then yeah, recreate the instances of the plugin. It shouldn't be too bad. Get iCloud accounts logged in and the here map keys.
                        Sadly not. Brand new device and I can't access anything:
                        Error executing function iphone_Settings():
                        Any ideas? It's not like we're going anywhere 😄
                          Anything else in the error message? It's pointing to a JS function but not sure what the error could be.
                          It's been a long time since I fiddled with it... so I will need to refresh memory.
                            AltUI is somewhat more informative 🙂
                            an error occurred while displaying the javascript tab. devid: 0-261 err:iphone_Settings is not defined
                            stack:ReferenceError: iphone_Settings is not defined
                            at eval (eval at _deviceDrawControlPanelJSTab (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3022:17), :1:1)
                            at _deviceDrawControlPanelOneTabContent (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3717:8)
                            at _displayActiveDeviceTab (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:3744:4)
                            at HTMLAnchorElement. (http://192.168.70.6/port_3480/J_ALTUI_uimgr.js:7036:4)
                            at HTMLDivElement.dispatch (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:42571)
                            at HTMLDivElement.v.handle (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:40572)
                            at Object.trigger (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:70627)
                            at HTMLAnchorElement. (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:71222)
                            at Function.each (http://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js:2:2777)
                              Huh wait... looks like @amg0 did an update 10 days ago. I am not sure what caused that and if I need to do something to the other map versions.
                                OK Just FYI here's the error from the Map tab
                                an error occurred while displaying the javascript tab. devid: 0-261 err:iphone_Map is not defined
                                stack:ReferenceError: iphone_Map is not defined
                                  This looks like you are missing the J_IPhone.js file?
                                    ok the change is a minor bug fix. Let me apply it to the Here and Bing map versions
                                      I had the js file and uploaded another copy, but I'll wait for your fix.
                                        I just posted the update 2.52x on github... As for you errors, it is looking for functions which are in the J_IPhone.js file. It is either missing the file or the pointer to it. Make sure that all the files are present in the vera: Run the full update from the vera app store and then drop in the files from GitHub.
                                          Just the J_Iphone.js and the L_Iphone.lua
                                          Done that and no better.
                                          If I download from the 'develop Apps' I get a Here version.
                                          'Arse' I think is the word.
                                          Delete the plugin and try from scratch?
                                          Cheers
                                            117.4k
