Hey guys....
long time 😉
Hi akbooer,
tnks
donato
Updated doco here.
Hope it works - YMMV.
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
Telegram Plug-in to send text, images and video notifications
@therealdb
Sorry db, thanks PerH - 'nuff said, properly chastened
I have set this up for some text notifications and it is working as it should, thanks for a very nice plugin!
With the added support in Reactor it makes a nice pair!I also tested sending an image (in the format http://url/folder/image.jpg) and it works as specified in the users guide on github.
What I cannot get to work however is when the url to the image contains user and login, which is required to get an image from my cameras.
I.e. the url to the image is :http://user:passwd@192.168.x.y/jpg/image.jpg
I have tried encoding it withhttps://www.urlencoder.org/
, but it does not seem to work.Any ideas on how to solve this?
//ArcherS
@therealdb yes I think it should be basic authorisation to send credentials via http in the form of
http://username:password@example.com/
to retreive an image from an Axis IP Camera and send it via Telegram.Maybe there is a better way to do it?
I have used curl calling a .sh file from OpenLuup for sending a few commands to the camera (for enabling/disabling privacy mask) in the past.What I did try, but failed was to get the camera to send an image directly. It has support for sending images via http/https, but I didn't get that to work. So far I have done it via email instead since it supports that as well.
I think however that quite a few cameras do not support sending themselves, so getting it to work in the plugin with basic auth would hopefully be of use anyway.
//ArcherS
Edit: I tested to modify mu curl from
curl --digest -u daniel:secret...
tocurl --user daniel:secret...
and that does not seem to work. It seems as if the Axis cameras require Digest mode for auth.Original post:
@therealdb not sure how to test, I tried from the prompt on my OpenLuup PC running Ubuntu but it didn't seem to work, I got "This server could not verify that you are authorized...".But in the .sh file that I call from OpenLuup I have:
curl --digest -u daniel:secret "http://192.168.x.x/axis-cgi/admin/param.cgi?action=update&root_Image_I0_Overlay_MaskWindows_M0_Enabled=no"
(This is a cgi command to the camera.)
And that curl works.Let me know if I should test something else!
//ArcherS
@archers said in Telegram Plug-in to send text, images and video notifications:
And that curl works.@ArcherS I've pushed v0.22 to GitHub https://github.com/dbochicchio/vera-Telegram
I've not created a release, so just get the S_* and L_* files.
There's a new param, so you should use this
luup.call_action("urn:bochicchio-com:serviceId:VeraTelegram1", "Send", { Text="This is a protected endpoint!", VideoUrl="https://media.giphy.com/media/3o84sIqsVAJNfWyjy8/giphy.gif" UrlParams="--digest -u daniel:secret" -- <== curl parameters! }, 515)
Try it and let me know. I'll probably release it later as a packaged version.
@therealdb thank you for the update!
I have tried it and it does not quite work.
The Lua code is executed ok (with the added comma as below), and I get a message in Telegram.
The text is ok, however instead of getting an image I get "camsnapshot117439654.gif" (the number is different each time). The gif does not seem to contain anything.
The url I call generates a .jpg file, I do not know why arrives as an empty .gif.Any ideas?
(Btw, there is a small typo in the luup.call_action, the comma is missing after the VideoUrl line. It should be:)
luup.call_action("urn:bochicchio-com:serviceId:VeraTelegram1", "Send", { Text="This is a protected endpoint!", VideoUrl="https://media.giphy.com/media/3o84sIqsVAJNfWyjy8/giphy.gif", UrlParams="--digest -u daniel:secret" -- <== curl parameters! }, 515)
//ArcherS
@therealdb now it works!
For my Axis camera that seems to require Digest mode for curl authentication I use the following to send an image:
luup.call_action("urn:bochicchio-com:serviceId:VeraTelegram1", "Send", { Text = "Motion in garage", ImageUrl = "http://192.168.x.x/jpg/image.jpg", UrlParams = "--digest -u daniel:secret" }, 515)
Thanks for the addition to an already nice plugin!
//ArcherS
