  4. Darker Reactor style
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
11 Posts 4 Posters 3.9k Views 4 Watching
    Thanks to @toggledbits for adding a custom CSS. I've started doing a darker Reactor style.
    Here's the file: https://gist.github.com/dbochicchio/825098ac13b7f8cac22012eae37ff7ce
    A couple of things are still too bright and I'll eventually catch-up. Just place it under your /config directory, naming the file as customstyles.css. Hard refresh your browser.
      Hm tried this and Reactor didnt seem to change after restarting and hard refresh.. mind sharing a screeshot of what your Reactor looks like. Maybe I havent noticed the changes
        Darker Theme:
        Standard Dark Theme:
        PablaP 1 Reply Last reply
          Darker Theme:
            @therealdb I like it. Understated, not radically different from @toggledbits - subtle. Well done.
            toggledbitsT therealdbT 2 Replies Last reply
              @gwp1 said in Darker Reactor style:
              Ha! Don't give me any credit, here! The included dark theme you see is native to Bootstrap, I just had to wire it in.
              I foresee I may have to have more options than just "light" and "dark" at some point...
                @gwp1 thanks.
                I'll fix other things along the way and balance some other contrasts. I usually thinker when it's dark, so less light is definitely better for me.
                @toggledbits I'll send a couple of notes for suggestions regarding color animations that are apparently hard-coded in Javascript. Don't hate me 🤣
                  Darker Theme:
                  @therealdb Ahh i see then it worked for me, now I notice the changes
                    @gwp1 thanks.
                    @therealdb said in Darker Reactor style:
                    OK. I've already found and fixed a few of those for the next build.
                      I just released a new update. I'll eventually move to a dedicated repo when it's stable. This update will specifically address a couple of too bright colors on rule editor. Just replace the file and remember to hard refresh the browser.
                        small update to align to 24343. https://gist.github.com/dbochicchio/825098ac13b7f8cac22012eae37ff7ce
                          164.0k
