  4. Should MSR import this device type from an Ezlo controller?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 5 Posters 1.5k Views 5 Watching
    Hi
    I have just connected a bunch of EzloPi controllers to MSR to import some ESP based devices etc.
    They all seemed to have worked and imported in to MSR apart from I have one missing device. It is a Digital Gas Sensor device.
    This is how that device looks in the Ezlo API.
    Devices Info:
    _id: "10696001"
    deviceTypeId: "ezlopi"
    parentDeviceId: "10696000"
    category: "level_sensor"
    subcategory: ""
    gatewayId: "457a5069"
    batteryPowered: false
    name: "Gas Sensor Digital"
    type: "sensor"
    reachable: true
    persistent: true
    serviceNotification: false
    armed: false
    roomId: ""
    security: "no"
    ready: true
    status: "idle"
    parentRoom: true
    protectConfig: "default"
    Items Info:
    _id: "20696001"
    deviceId: "10696001"
    hasGetter: true
    hasSetter: false
    show: true
    valueType: "substance_amount"
    scale: "parts_per_million"
    value: 2.7472610473632812
    valueFormatted: "2.75"
    status: "idle"
    There is also an Analog Gas sensor that one did import in to MSR OK.
    Devices Info:
    _id: "10696000"
    category: "security_sensor"
    subcategory: "gas"
    name: "Gas Sensor Analog"
    type: "sensor"
    reachable: true
    persistent: true
    armed: false
    roomId: ""
    security: "no"
    ready: true
    status: "idle"
    parentRoom: true
    Items Info:
    _id: "20696000"
    deviceId: "10696000"
    hasGetter: true
    hasSetter: false
    show: true
    valueType: "token"
    enum:
    0: "no_gas"
    1: "combustible_gas_detected"
    2: "toxic_gas_detected"
    3: "unknown"
    valueFormatted: "no_gas"
    value: "no_gas"
    status: "idle"
    And this is how this MQ2 Gas Sensor looks like on their dashboard:
    Digital
    Analog
    They have an EzloPi website here you can create your own sensor projects using ESP boards, which is very interesting stuff!
    And I just wrote on the Ezlo forum here, how to connect an EzloPi controller to MSR.
    THANKS.
      While I appreciate your faith, I'm genuinely wondering why ezlopi instead of tasmota or esphome. They're both more mature and easier to find help for, so my question.
      Back in track, it's probably missing a mapping somewhere and @toggledbits needs to collect all the attributes of the device from reactor in order to support it.
      • cw-kidC cw-kid
        Hi
        Devices Info:
        _id: "10696001"
        subcategory: ""
        type: "sensor"
        reachable: true
        persistent: true
        armed: false
        roomId: ""
        security: "no"
        ready: true
        status: "idle"
        parentRoom: true
        Items Info:
        _id: "20696001"
        hasGetter: true
        hasSetter: false
        show: true
        status: "idle"
        Devices Info:
        _id: "10696000"
        subcategory: "gas"
        type: "sensor"
        reachable: true
        persistent: true
        armed: false
        roomId: ""
        security: "no"
        ready: true
        status: "idle"
        parentRoom: true
        Items Info:
        _id: "20696000"
        hasGetter: true
        hasSetter: false
        show: true
        valueType: "token"
        enum:
        0: "no_gas"
        3: "unknown"
        value: "no_gas"
        status: "idle"
        Digital
        Analog
        THANKS.
        @cw-kid said in Should MSR import this device type from an Ezlo controller?:
        According to their own API documentation, there's a reasonable value for subcategory that should be assigned here, but it's blank. Not sure if that's an error on their part, or just garden-variety laziness, but as we say here, not my circus, not my monkeys. I'm not working around their inability to follow their own specs. Make them fix their own bug.
        @therealdb said in Should MSR import this device type from an Ezlo controller?:
        So right, mate. Why get bogged down and more committed to their bloated cloud-dependency when great, lightweight solutions have existed for years, with far better support?
        @cw-kid, you do realize it's been over six years since the acquisition, right? I think it's safe to say, if they haven't muscled the core product up to well beyond Vera's capabilities at this point, they're not likely to ever get there. The Pi thing is a distraction. Or worse, in my view, it's a slap in the face to people like you who have been trying to help and waiting for the core product to come of age. I salute your dedication, but I'm not sure whatever reward you're seeking at the end is forthcoming.
        G cw-kidC 2 Replies Last reply
          @toggledbits six years? Damn. I had two years in the office pool.... how they've managed to last six is unbelievable.
            Utterly amazing. He must be burning money!
              @toggledbits said in Should MSR import this device type from an Ezlo controller?:
              Thanks, I didn't notice that. I will tell them to fix it.
              Cheers.
                As for your other comments Gentlemen, I don't disagree with them..
                  164.2k
