  4. Should MSR import this device type from an Ezlo controller?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
7 Posts 5 Posters 1.0k Views 5 Watching
    I have just connected a bunch of EzloPi controllers to MSR to import some ESP based devices etc.
    They all seemed to have worked and imported in to MSR apart from I have one missing device. It is a Digital Gas Sensor device.
    This is how that device looks in the Ezlo API.
    Devices Info:
    _id: "10696001"
    deviceTypeId: "ezlopi"
    parentDeviceId: "10696000"
    category: "level_sensor"
    subcategory: ""
    gatewayId: "457a5069"
    batteryPowered: false
    name: "Gas Sensor Digital"
    type: "sensor"
    reachable: true
    persistent: true
    serviceNotification: false
    armed: false
    roomId: ""
    security: "no"
    ready: true
    status: "idle"
    parentRoom: true
    protectConfig: "default"
    Items Info:
    _id: "20696001"
    deviceId: "10696001"
    hasGetter: true
    hasSetter: false
    show: true
    valueType: "substance_amount"
    scale: "parts_per_million"
    value: 2.7472610473632812
    valueFormatted: "2.75"
    status: "idle"
    There is also an Analog Gas sensor that one did import in to MSR OK.
    Devices Info:
    _id: "10696000"
    category: "security_sensor"
    subcategory: "gas"
    name: "Gas Sensor Analog"
    type: "sensor"
    reachable: true
    persistent: true
    armed: false
    roomId: ""
    security: "no"
    ready: true
    status: "idle"
    parentRoom: true
    Items Info:
    _id: "20696000"
    deviceId: "10696000"
    hasGetter: true
    hasSetter: false
    show: true
    valueType: "token"
    enum:
    0: "no_gas"
    1: "combustible_gas_detected"
    2: "toxic_gas_detected"
    3: "unknown"
    valueFormatted: "no_gas"
    value: "no_gas"
    status: "idle"
    And this is how this MQ2 Gas Sensor looks like on their dashboard:
    Digital
    Analog
    They have an EzloPi website here you can create your own sensor projects using ESP boards, which is very interesting stuff!
    And I just wrote on the Ezlo forum here, how to connect an EzloPi controller to MSR.
    THANKS.
      While I appreciate your faith, I'm genuinely wondering why ezlopi instead of tasmota or esphome. They're both more mature and easier to find help for, so my question.
      Back in track, it's probably missing a mapping somewhere and @toggledbits needs to collect all the attributes of the device from reactor in order to support it.
        Devices Info:
        _id: "10696001"
        subcategory: ""
        type: "sensor"
        reachable: true
        persistent: true
        armed: false
        roomId: ""
        security: "no"
        ready: true
        status: "idle"
        parentRoom: true
        Items Info:
        _id: "20696001"
        hasGetter: true
        hasSetter: false
        show: true
        status: "idle"
        Devices Info:
        _id: "10696000"
        subcategory: "gas"
        type: "sensor"
        reachable: true
        persistent: true
        armed: false
        roomId: ""
        security: "no"
        ready: true
        status: "idle"
        parentRoom: true
        Items Info:
        _id: "20696000"
        hasGetter: true
        hasSetter: false
        show: true
        valueType: "token"
        enum:
        0: "no_gas"
        3: "unknown"
        value: "no_gas"
        status: "idle"
        Digital
        Analog
        THANKS.
        @cw-kid said in Should MSR import this device type from an Ezlo controller?:
        According to their own API documentation, there's a reasonable value for subcategory that should be assigned here, but it's blank. Not sure if that's an error on their part, or just garden-variety laziness, but as we say here, not my circus, not my monkeys. I'm not working around their inability to follow their own specs. Make them fix their own bug.
        @therealdb said in Should MSR import this device type from an Ezlo controller?:
        So right, mate. Why get bogged down and more committed to their bloated cloud-dependency when great, lightweight solutions have existed for years, with far better support?
        @cw-kid, you do realize it's been over six years since the acquisition, right? I think it's safe to say, if they haven't muscled the core product up to well beyond Vera's capabilities at this point, they're not likely to ever get there. The Pi thing is a distraction. Or worse, in my view, it's a slap in the face to people like you who have been trying to help and waiting for the core product to come of age. I salute your dedication, but I'm not sure whatever reward you're seeking at the end is forthcoming.
        G cw-kidC 2 Replies Last reply
          @toggledbits six years? Damn. I had two years in the office pool.... how they've managed to last six is unbelievable.
          *Hubitat C-7 2.4.3.177
          Core 2026.1.1
          MSR: latest-26011-c621bbc7
            Utterly amazing. He must be burning money!
              @toggledbits said in Should MSR import this device type from an Ezlo controller?:
              Thanks, I didn't notice that. I will tell them to fix it.
              Cheers.
                As for your other comments Gentlemen, I don't disagree with them..
                  3.5k
                  3.1k
                  579
                • Self test
