Updated doco here.
Hope it works - YMMV.
Hey guys....
long time 😉
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
Hi akbooer,
tnks
donato
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
MQTT Plugin
@therealdb I tried to buid again from the new files, but I cannot get the Luup.MqttBridge to run the way it did before the update.
Unclear what is wrong, I think I did everything in the same was as before. I noticed that the icon on the Luup.MqttBridge file is different when looking at it in Ubuntu "Files".//ArcherS
@archers what's the output of
dotnet publish -c Release -r linux-x64
? You can do it under Windows and it will produce executables for Linux as well.If you want just a single file, go with
dotnet publish -c Release -r linux-x64 -p:PublishSingleFile=true --self-contained true
this will produce a single file with everything inside. I'm updating the doc as well.
@therealdb thanks for the build!
When using your latest build the Luup.MqttBridge file for some reason is a "shared library (application/x-sharedlib)" and not as when building from the older version "executable (application/x-executable)" despite having set permissions.
Really strange, I managed to get around this by creating a .sh file containing "./Luup.MqttBridge" and running this.
Over first hurdle...However when I launch the new built file I still only get this in the log file:
[19:17:23 INF] [MQTTServer] Broker is starting v 0.30.210109 on port 1883...
It is as if it hangs while trying to start/starting.
In the Tasmota console it says connected so the user/passwd seems ok:
19:17:21 MQT: Connected
So obviously not quite there yet.
Any ideas on what the pronlem could be?//ArcherS
So I did some more testing and found out that I had still "DVES_%06X" as client in the Tasmota device...
I am sure I had tripple checked everything, stupid...So I changed this to what it should be and now I get it to work , i.e. the device in OpenLuup gets the temp value. Success!
However the log does still not give more that the starting message for some reason.
Any ideas on this? Btw I still have this in the appsettings, not sure if that could be related:?/* remove comment when you're OK with less logs "Serilog": { "MinimumLevel": { "Default": "Information", "Override": { "Microsoft": "Fatal", "System": "Fatal" } } } */
I will do some more testing later on and see.
Thanks for the assistance!//ArcherS
@therealdb I noticed that the bridge had gone down over night. I restarted it and got the below error message after approx 10-15 minutes when it went down again. It ran for longer yesterday, maybe 1-2 hours before crashing.
I now started the old version (that works, it was of course my error on the Client in the Tasmota that was the problem), just to see if it also will go down.
//ArcherS
[08:55:53 INF] [MQTTServer] Broker is starting v 0.30.210109 on port 1883... Unhandled exception. System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 10 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.Http.HttpConnection.FillAsync(Boolean async) at System.Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync(Boolean async, Boolean foldedHeadersAllowed) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at Polly.Retry.AsyncRetryEngine.ImplementationAsync[TResult](Func`3 action, Context context, CancellationToken cancellationToken, ExceptionPredicates shouldRetryExceptionPredicates, ResultPredicates`1 shouldRetryResultPredicates, Func`5 onRetryAsync, Int32 permittedRetryCount, IEnumerable`1 sleepDurationsEnumerable, Func`4 sleepDurationProvider, Boolean continueOnCapturedContext) at Polly.AsyncPolicy`1.ExecuteAsync(Func`3 action, Context context, CancellationToken cancellationToken, Boolean continueOnCapturedContext) at Microsoft.Extensions.Http.PolicyHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at Polly.Bulkhead.AsyncBulkheadEngine.ImplementationAsync[TResult](Func`3 action, Context context, Func`2 onBulkheadRejectedAsync, SemaphoreSlim maxParallelizationSemaphore, SemaphoreSlim maxQueuedActionsSemaphore, CancellationToken cancellationToken, Boolean continueOnCapturedContext) at Polly.AsyncPolicy`1.ExecuteAsync(Func`3 action, Context context, CancellationToken cancellationToken, Boolean continueOnCapturedContext) at Microsoft.Extensions.Http.PolicyHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken) at System.Net.Http.HttpClient.GetStringAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) at Luup.MqttBridge.Services.LuupWrapper.RunCommandAsync(Int32 deviceID, String action, String actionCommand, String commandParameter, String command, String serviceID, String value) at Luup.MqttBridge.Services.LuupWrapper.UpdateVariablesAsync(Int32 deviceID, String serviceID, String variableName, String value) at Luup.MqttBridge.Services.Mqtt.MQTTServer.ProcessMessageAsync(MqttDevice device, MqttApplicationMessage applicationMessage) at Luup.MqttBridge.Services.Mqtt.MQTTServer.<>c__DisplayClass9_0.<<StartAsync>b__3>d.MoveNext() --- End of stack trace from previous location --- at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__140_1(Object state) at System.Threading.QueueUserWorkItemCallbackDefaultContext.Execute() at System.Threading.ThreadPoolWorkQueue.Dispatch() /home/user/mqttbridge/LuupMqttBridge.sh: line 1: 20380 Aborted (core dumped) ./Luup.MqttBridge
Yep, I noticed on my own version as well. It's because the HTTP endpoint crashed (are you using openLuup, right?) or timedout after 10 secs. I'll probably make it configurable in next version and be more aggressive towards crashes.
It's still very beta, even if I'm running a modified version in production for my own.New release coming up on GitHub in minutes
@archers are you able to compile it yourself, for an easy fix? I have a new version ready, but I'll need more debug in a real world scenario. But I'm ready to push it, if you can try. I also added support for alternate topic (useful if you want to intercept two mqtt messages with different topics and payload, but execute the same action) and wildcard support for clienid (useful if you have messages coming from other brokers and the original clientid is lost).
@therealdb I have now had the updated Mqtt Bridge running continuously for little more than 25 hours. So far it is still alive and kicking.
The log file is now working I get entries in the log, which I did not get before. This makes it easier to see what is happening of course.
So when the bridge starts I get:2021-01-30 11:24:16.055 +01:00 [INF] [MQTTServer] Broker is starting v 0.31.210130 on port 1883... 2021-01-30 11:28:40.877 +01:00 [INF] [MQTTServer] Updating #216 - urn:upnp-org:serviceId:TemperatureSensor1 / CurrentTemperature - 24.5 2021-01-30 11:33:40.770 +01:00 [INF] [MQTTServer] Updating #216 - urn:upnp-org:serviceId:TemperatureSensor1 / CurrentTemperature - 24.9 etc...
At times I get the following error, I assume it is related to the http issue:
2021-01-31 11:38:40.852 +01:00 [INF] [MQTTServer] Updating #216 - urn:upnp-org:serviceId:TemperatureSensor1 / CurrentTemperature - 25.5 2021-01-31 11:38:50.854 +01:00 [ERR] [LuupWrapper] RunCommandAsync: http://127.0.0.1:3480/data_request?id=variableset&output_format=json&DeviceNum=216&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature&Value=25.5&RunAsync=1 System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 10 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at void System.Net.Sockets.Socket+AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at int System.Net.Sockets.Socket+AwaitableSocketAsyncEventArgs.GetResult(short token) at async ValueTask System.Net.Http.HttpConnection.FillAsync(bool async) at async ValueTask<ArraySegment<byte>> System.Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync(bool async, bool foldedHeadersAllowed) at async Task<HttpResponseMessage> System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, bool async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at async Task<HttpResponseMessage> System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, bool async, CancellationToken cancellationToken) at async ValueTask<HttpResponseMessage> System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, bool async, bool doRequestAuth, CancellationToken cancellationToken) at async ValueTask<HttpResponseMessage> System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, bool async, CancellationToken cancellationToken) at async Task<HttpResponseMessage> Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at async Task<TResult> Polly.Retry.AsyncRetryEngine.ImplementationAsync<TResult>(Func<Context, CancellationToken, Task<TResult>> action, Context context, CancellationToken cancellationToken, ExceptionPredicates shouldRetryExceptionPredicates, ResultPredicates<TResult> shouldRetryResultPredicates, Func<DelegateResult<TResult>, TimeSpan, int, Context, Task> onRetryAsync, int permittedRetryCount, IEnumerable<TimeSpan> sleepDurationsEnumerable, Func<int, DelegateResult<TResult>, Context, TimeSpan> sleepDurationProvider, bool continueOnCapturedContext) at async Task<TResult> Polly.AsyncPolicy<TResult>.ExecuteAsync(Func<Context, CancellationToken, Task<TResult>> action, Context context, CancellationToken cancellationToken, bool continueOnCapturedContext) at async Task<HttpResponseMessage> Microsoft.Extensions.Http.PolicyHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at async Task<TResult> Polly.Bulkhead.AsyncBulkheadEngine.ImplementationAsync<TResult>(Func<Context, CancellationToken, Task<TResult>> action, Context context, Func<Context, Task> onBulkheadRejectedAsync, SemaphoreSlim maxParallelizationSemaphore, SemaphoreSlim maxQueuedActionsSemaphore, CancellationToken cancellationToken, bool continueOnCapturedContext) at async Task<TResult> Polly.AsyncPolicy<TResult>.ExecuteAsync(Func<Context, CancellationToken, Task<TResult>> action, Context context, CancellationToken cancellationToken, bool continueOnCapturedContext) at async Task<HttpResponseMessage> Microsoft.Extensions.Http.PolicyHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at async Task<HttpResponseMessage> Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at async ValueTask<HttpResponseMessage> System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, bool async, bool emitTelemetryStartStop, CancellationToken cancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at async ValueTask<HttpResponseMessage> System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, bool async, bool emitTelemetryStartStop, CancellationToken cancellationToken) at async Task<string> System.Net.Http.HttpClient.GetStringAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) at async Task Luup.MqttBridge.Services.LuupWrapper.RunCommandAsync(int deviceID, string action, string actionCommand, string commandParameter, string command, string serviceID, string value) 2021-01-31 11:43:40.851 +01:00 [INF] [MQTTServer] Updating #216 - urn:upnp-org:serviceId:TemperatureSensor1 / CurrentTemperature - 25.5 2021-01-31 11:48:40.836 +01:00 [INF] [MQTTServer] Updating #216 - urn:upnp-org:serviceId:TemperatureSensor1 / CurrentTemperature - 25.6 etc...
After the above error it goes back to reporting updates.
The error comes quite random, at times once every approx 20-30 minutes, and at times it can be a few hours between them.So far I have only one test device in OpenLuup getting values from the bridge, I do not know how adding some 50+ topics would affect the overall load and stability.
Edit: It could be worth mentioning that I today have some 50 devices in OpenLuup that are getting their values over http; some SiteSensors a bunch of virtual sensors getting data from Tasmota/Shelly devices etc. In other words there is a bit of activity already going on through the http interface today. Moving most of them to Mqtt would perhaps not increase the load at all, who knows.
Looking promising, thanks for the effort so far with the bridge!
I have mine running with almost 20 virtual devices and it's rock solid. It's pushing to vera as well.
My forked version has the ability to update the value only if a difference threshold is met (useful to avoid too many requests to the http interface). I'll try to backport it here in the coming days.
As I said, I'm using it to push things from a lot of different things (tasmota, shelly, my windows app, miflora).
I'll add an http endpoint soon to publish messages as well.
@therealdb that sounds reassuring, thanks!
As a side note to anyone venturing into the world of mqtt I found Mqtt Explorer which seems to be a pretty nice tool for looking at messages, topics etc.
It can even create graphs for values to track them over time. -
@archers said in MQTT Plugin:
is this still working for you?
