  4. Feature Requst: Filter Entities by Lost/removed
1 Posts 1 Posters 553 Views 1 Watching
    Good morning,
    Hopefully this is a simple request. I believe the title should be self explanatory, but just in case, I'll elaborate.
    On the status tab, we all get alerts if a device state has changed (i.e., been removed). This is great, but when I go into the entities tab, I have to either type the name (or a portion thereof) of the device that has been removed, or I need to scroll all the way through my list of devices. This is infrequent, however, yesterday I replaced a failed device in my HAAS environment. It was a Z-Wave switch that is added using the Smart Scan QR code, which normally makes it pretty easy. However, some devices don't get fully added the first time around, so it'll add multiple entries into HAAS until it get's the S2 authentication correct and the device fully included. It did this to me yesterday, and I had to delete the incomplete device from my installation. MSR still saw the entities of that failed/incomplete switch entity, and I was left with 8 alerts and entities that I needed to removed.
    It's not a huge problem, but this example was just one switch. If I were to add replace multiple devices at once, this could be a bit more annoying to remove. It would be helpful to be able to filter by removed entities, so I can find them all quickly and delete them. Continuing that train of thought, it would also be useful to have check boxes next to those lines, and perhaps do a select all type of thing so they could be deleted in one mouse click.
      157.7k
