Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Multi-System Reactor Developer Preview AVAILABLE
OK, people, here we go! At long last, Multi-System Reactor developer preview is available!
The package can be downloaded from the Reactor bug tracker, a MantisBT system (at https://reactor.toggledbits.com/mantisbt/). There is a download button in the left margin, as well as links to the documentation, which you will need for installation.
UPDATE 2021-02-24 -- To keep spammers off, I've locked down registration on the Bug Tracker. To get access to the Bug Tracker and preview downloads, please PM me (not reply here) your full name and email address and I will set up an account for you.
This version of MSR will run on Linux systems, including RPi's under Raspios Buster, running node.js version 12.10 or higher (v14.15.1). For RPi users, there is an installation script that will install a local copy of node.js (for the logged-in user).
Bugs reports will be handled through the bug tracker only. Discussion and questions in this forum are fine, though (if that leads to a bug report, we'll transition).
This version supports Vera (and openLuup to the degree it's compatible with Vera Luup), Hubitat, and Home Assistant. Some of the device support on the H platforms is still a bit basic, but it is largely controlled by configuration and progress can be made quickly.
The documentation beyond installation is a mess. Of course, I started with the existing documentation and have been massaging into MSR's particulars, but it still has a long way to go on the detail.
I know I don't have to say this, but I will anyway... let me know how it goes!
Nice. Any issues with the install?
Got it up an running and connected both openluup and home assistant. Noticing that if category_num attribute is not set in openluup then it does not recognize supported commands for the device. I'm guessing Reactor relies on this attribute?
edit. updated Z-way plugin to latest which now provides category_num and issue is resolved
@elcid said in Multi-System Reactor Developer Preview AVAILABLE:
Some error in start up console log
Known error, it already has a PR, and is already fixed for the next build. That's just the preloader that I use to pull in data for testing. I'm usually looking at the end of the log, not the beginning, so I missed it before packaging the release.
Some first impressions. Having all home assistant and openluup entities together in a Reactor interface is a game changer. Install was super easy and went smoothly following the directions. Installed on a Debian10 VM. Looks like just about every entity from both systems were discovered. Performed a couple test rules with a HA entity being controlled based the state of an openluup entity and it was very responsive. Having trouble with the import tool, keep getting a syntax error. Definitely going to miss Run_Lua actions. Is there plans for anything to replace that? All and all looking great.
@black-cat said in Multi-System Reactor Developer Preview AVAILABLE:
Uploaded and expanded OK...but there is no config/reactor.yaml file to edit.
If you're using a Pi, you should have run the install script in the tools directory, which copies the files from dist-config to config. If you are installing on other Linux, there's a step in the instructions to do the copy manually. But that's all you need to do:
cp dist-config/* config/
@kfxo said in Multi-System Reactor Developer Preview AVAILABLE:
Can you paste some output? Let's have a look at that...
I posted an issue on MantisBT but maybe I did it wrong. Should I try there again?
Good on ya! I see it...
OK. Easy enough. Not sure how that snuck by... Probably the easiest is to have you just open it in a text editor, find the line (192) that says
case 'interval': {
and just remove that curly brace from the end of it. Save, and try again. -
Yes, but only due to myself. Following your instructions it went well Will continue the testing later today ...
Linux Neanderthal here, I tried to install it on my Raspberry Pi2.
I got this output not sure what it means, it says I need to commit some file?
The version of nodejs currently installed is v12.20.1 (compatible). Checking dependencies... > bufferutil@4.0.3 install /home/pi/Documents/reactor/node_modules/bufferutil > node-gyp-build > utf-8-validate@5.0.4 install /home/pi/Documents/reactor/node_modules/utf-8-validate > node-gyp-build > core-js@3.9.0 postinstall /home/pi/Documents/reactor/node_modules/core-js > node -e "try{require('./postinstall')}catch(e){}" Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library! The project needs your help! Please consider supporting of core-js on Open Collective or Patreon: > https://opencollective.com/core-js > https://www.patreon.com/zloirock Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -) npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN bootstrap@4.5.3 requires a peer of popper.js@^1.16.1 but none is installed. You must install peer dependencies yourself. added 86 packages from 68 contributors and audited 87 packages in 46.342s 4 packages are looking for funding run `npm fund` for details found 0 vulnerabilities OK. Now please LOG OUT, then log back in and continue the installation procedure (see docs/markdown/Installation.md or docs/html/Installation/index.html).
The installation Guide here then says to:
"Edit the file config/reactor.yaml and, on the line beginning baseurl:, replace the IP address with the actual primary IP address of your system."
There is a "config" folder present but it is empty.
There is a folder called /home/pi/Documents/reactor/dist-config and the reactor.yaml file was in there, so I edited that one and added my Pi's IP address.
I actually didn't even have a "Documents" folder to begin with, I had to create that folder first in this path: /home/pi/Documents
It then says to:
"Start up Reactor: node app.js"
Looks like there were some errors during startup.
pi@raspberrypi:~/Documents/reactor $ node app.js 2021-02-19T09:18:37.424Z <app:null> Reactor application v21047 starting on v12.20.2 2021-02-19T09:18:37.641Z <Controller:null> Module Controller v21046 2021-02-19T09:18:37.643Z <default:null> Module Structure v21025 2021-02-19T09:18:37.692Z <default:null> Module Ruleset v21041 2021-02-19T09:18:37.694Z <default:null> Module Rulesets v21041 2021-02-19T09:18:37.825Z <default:null> Module Rule v21047 2021-02-19T09:18:37.868Z <default:null> Module Engine v21047 2021-02-19T09:18:37.910Z <default:null> Module httpapi v21041 2021-02-19T09:18:37.924Z <default:null> Module httpproxy v20350 2021-02-19T09:18:38.093Z <default:null> Module wsapi v21041 2021-02-19T09:18:38.246Z <default:CRIT> Error: ENOENT: no such file or directory, open './server/struct_data.json' Error: ENOENT: no such file or directory, open './server/struct_data.json' at Object.openSync (fs.js:462:3) at Object.readFileSync (fs.js:364:35) at Structure.start (/home/pi/Documents/reactor/server/lib/Structure.js:184:49) at /home/pi/Documents/reactor/app.js:141:72 at processTicksAndRejections (internal/process/task_queues.js:97:5) Error: ENOENT: no such file or directory, open './server/struct_data.json' at Object.openSync (fs.js:462:3) at Object.readFileSync (fs.js:364:35) at Structure.start (/home/pi/Documents/reactor/server/lib/Structure.js:184:49) at /home/pi/Documents/reactor/app.js:141:72 at processTicksAndRejections (internal/process/task_queues.js:97:5) { errno: -2, syscall: 'open', code: 'ENOENT', path: './server/struct_data.json' } 2021-02-19T09:18:38.479Z <default:null> Module SystemController v21025 2021-02-19T09:18:38.537Z <app:null> Waiting 10 seconds before starting Engine
Will Reactor be started automatically after you reboot the Pi ?
Answer = NO
"I haven't fully daemon-ized Reactor yet while still in test mode, but eventually it will, of course, be available for startup at boot time."
Anyway I have the Reactor up and running it seems, I can access it in the web browser.
I then edited the reactor.yaml file and added my location details and the IP for my Vera hub. However after restarting MSR I had nothing listed in Entities other than Reactor System.
I had to copy the reator.yaml file from this folder to this folder and then it worked.
to
/home/pi/Documents/reactor/config
I can now see my Vera device and scenes listed under Entities
cw
@cw-kid said in Multi-System Reactor Developer Preview AVAILABLE:
Just copy the files from
dist-config
toconfig
manually. Reactor won't read config files unless they are inconfig
.The startup error can be ignored; it's for loading test data, which isn't present.
Vera is not in either Away mode (2) or in Vacation mode (4)
Reactor's "House Mode" entity uses words:
home
,away
,night
,vacation
. Note what is showing for "Current value" underneath the condition. You can also see this in the Entities list.EDIT: Also, can we please start threading discussions in this category? It's going to get unruly fast if everyone is talking about everything as replies to one thread.
Thanks for the reply.
I have used the words "away" and "vacation". However when I see this summary it says null or no data for the house mode triggers (conditions).
So don't think its working.
EDIT:
Using "Does not contain" rather than "not in" looks better ?
That's an unexpected difference. Equals and not equals would also be applicable here.
