Error: Command timeout
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
HA 2025.9.4 Supported Yet?
124 Posts 12 Posters 50.3k Views 14 Watching
    OK, people, here we go! At long last, Multi-System Reactor developer preview is available!
    The package can be downloaded from the Reactor bug tracker, a MantisBT system (at https://reactor.toggledbits.com/mantisbt/). There is a download button in the left margin, as well as links to the documentation, which you will need for installation.
    UPDATE 2021-02-24 -- To keep spammers off, I've locked down registration on the Bug Tracker. To get access to the Bug Tracker and preview downloads, please PM me (not reply here) your full name and email address and I will set up an account for you.
    This version of MSR will run on Linux systems, including RPi's under Raspios Buster, running node.js version 12.10 or higher (v14.15.1). For RPi users, there is an installation script that will install a local copy of node.js (for the logged-in user).
    Bugs reports will be handled through the bug tracker only. Discussion and questions in this forum are fine, though (if that leads to a bug report, we'll transition).
    This version supports Vera (and openLuup to the degree it's compatible with Vera Luup), Hubitat, and Home Assistant. Some of the device support on the H platforms is still a bit basic, but it is largely controlled by configuration and progress can be made quickly.
    The documentation beyond installation is a mess. Of course, I started with the existing documentation and have been massaging into MSR's particulars, but it still has a long way to go on the detail.
    I know I don't have to say this, but I will anyway... let me know how it goes!
    • MatohlM Offline
      MatohlM Offline
      Matohl
      Up and running on my my RPi 4 with SSD. Will continue tomorrow with adding my Veras
        Nice. Any issues with the install?
        MatohlM 1 Reply Last reply
          Ok system up and running under termux on android 8.
          Some error in start up console log
          Tried first reactor rule and reaction, seems fast.
          reaction to set dimming does not work but on and off do.
          Would you prefer this to be logged in bug tracker or here.
          • K Offline
            K Offline
            kfxo
            wrote on last edited by kfxo
            Got it up an running and connected both openluup and home assistant. Noticing that if category_num attribute is not set in openluup then it does not recognize supported commands for the device. I'm guessing Reactor relies on this attribute?
            edit. updated Z-way plugin to latest which now provides category_num and issue is resolved
              Ok the dimming is 0 to 1 , that threw me. So 5% is 0.05.
              • ElcidE Elcid
                @elcid said in Multi-System Reactor Developer Preview AVAILABLE:
                Known error, it already has a PR, and is already fixed for the next build. That's just the preloader that I use to pull in data for testing. I'm usually looking at the end of the log, not the beginning, so I missed it before packaging the release. 🙂
                • K Offline
                  K Offline
                  kfxo
                  Some first impressions. Having all home assistant and openluup entities together in a Reactor interface is a game changer. Install was super easy and went smoothly following the directions. Installed on a Debian10 VM. Looks like just about every entity from both systems were discovered. Performed a couple test rules with a HA entity being controlled based the state of an openluup entity and it was very responsive. Having trouble with the import tool, keep getting a syntax error. Definitely going to miss Run_Lua actions. Is there plans for anything to replace that? All and all looking great.
                  • Black CatB Offline
                    Black CatB Offline
                    Black Cat
                    I'm stuck...(surprised I made it this far..):)
                    Uploaded and expanded OK...but there is no config/reactor.yaml file to edit.
                    aka Zedrally
                    • Black CatB Black Cat
                      @black-cat said in Multi-System Reactor Developer Preview AVAILABLE:
                      If you're using a Pi, you should have run the install script in the tools directory, which copies the files from dist-config to config. If you are installing on other Linux, there's a step in the instructions to do the copy manually. But that's all you need to do: cp dist-config/* config/
                      • K kfxo
                        @kfxo said in Multi-System Reactor Developer Preview AVAILABLE:
                        Can you paste some output? Let's have a look at that...
                        K 1 Reply Last reply
                          K Offline
                          K Offline
                          kfxo
                          I posted an issue on MantisBT but maybe I did it wrong. Should I try there again?
                          • K kfxo
                            Good on ya! I see it...
                            OK. Easy enough. Not sure how that snuck by... Probably the easiest is to have you just open it in a text editor, find the line (192) that says case 'interval': { and just remove that curly brace from the end of it. Save, and try again.
                              MatohlM Offline
                              MatohlM Offline
                              Matohl
                              Yes, but only due to myself. Following your instructions it went well 🙂 Will continue the testing later today ...
                                Linux Neanderthal here, I tried to install it on my Raspberry Pi2.
                                I got this output not sure what it means, it says I need to commit some file?
                                The version of nodejs currently installed is v12.20.1 (compatible).
                                Checking dependencies...
                                > bufferutil@4.0.3 install /home/pi/Documents/reactor/node_modules/bufferutil
                                > node-gyp-build
                                > utf-8-validate@5.0.4 install /home/pi/Documents/reactor/node_modules/utf-8-validate
                                > node-gyp-build
                                > core-js@3.9.0 postinstall /home/pi/Documents/reactor/node_modules/core-js
                                > node -e "try{require('./postinstall')}catch(e){}"
                                Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                                The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                                > https://opencollective.com/core-js
                                > https://www.patreon.com/zloirock
                                Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                npm WARN bootstrap@4.5.3 requires a peer of popper.js@^1.16.1 but none is installed. You must install peer dependencies yourself.
                                added 86 packages from 68 contributors and audited 87 packages in 46.342s
                                4 packages are looking for funding
                                  run `npm fund` for details
                                found 0 vulnerabilities
                                OK. Now please LOG OUT, then log back in and continue the installation procedure
                                (see docs/markdown/Installation.md or docs/html/Installation/index.html).
                                The installation Guide here then says to:
                                "Edit the file config/reactor.yaml and, on the line beginning baseurl:, replace the IP address with the actual primary IP address of your system."
                                There is a "config" folder present but it is empty.
                                There is a folder called /home/pi/Documents/reactor/dist-config and the reactor.yaml file was in there, so I edited that one and added my Pi's IP address.
                                I actually didn't even have a "Documents" folder to begin with, I had to create that folder first in this path: /home/pi/Documents
                                It then says to:
                                "Start up Reactor: node app.js"
                                Looks like there were some errors during startup.
                                pi@raspberrypi:~/Documents/reactor $ node app.js
                                2021-02-19T09:18:37.424Z <app:null> Reactor application v21047 starting on v12.20.2
                                2021-02-19T09:18:37.641Z <Controller:null> Module Controller v21046
                                2021-02-19T09:18:37.643Z <default:null> Module Structure v21025
                                2021-02-19T09:18:37.692Z <default:null> Module Ruleset v21041
                                2021-02-19T09:18:37.694Z <default:null> Module Rulesets v21041
                                2021-02-19T09:18:37.825Z <default:null> Module Rule v21047
                                2021-02-19T09:18:37.868Z <default:null> Module Engine v21047
                                2021-02-19T09:18:37.910Z <default:null> Module httpapi v21041
                                2021-02-19T09:18:37.924Z <default:null> Module httpproxy v20350
                                2021-02-19T09:18:38.093Z <default:null> Module wsapi v21041
                                2021-02-19T09:18:38.246Z <default:CRIT> Error: ENOENT: no such file or directory, open './server/struct_data.json'
                                    at Object.openSync (fs.js:462:3)
                                    at Object.readFileSync (fs.js:364:35)
                                    at Structure.start (/home/pi/Documents/reactor/server/lib/Structure.js:184:49)
                                    at /home/pi/Documents/reactor/app.js:141:72
                                    at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                    at processTicksAndRejections (internal/process/task_queues.js:97:5) {
                                  errno: -2,
                                  syscall: 'open',
                                  code: 'ENOENT',
                                  path: './server/struct_data.json'
                                2021-02-19T09:18:38.479Z <default:null> Module SystemController v21025
                                2021-02-19T09:18:38.537Z <app:null> Waiting 10 seconds before starting Engine
                                Will Reactor be started automatically after you reboot the Pi ?
                                Answer = NO
                                "I haven't fully daemon-ized Reactor yet while still in test mode, but eventually it will, of course, be available for startup at boot time."
                                Anyway I have the Reactor up and running it seems, I can access it in the web browser.
                                I then edited the reactor.yaml file and added my location details and the IP for my Vera hub. However after restarting MSR I had nothing listed in Entities other than Reactor System.
                                I had to copy the reator.yaml file from this folder to this folder and then it worked.
                                to
                                /home/pi/Documents/reactor/config
                                I can now see my Vera device and scenes listed under Entities
                                cw
                                  Will this work for Conditions ?
                                  Vera is not in either Away mode (2) or in Vacation mode (4)
                                  or like this ?
                                  Or some other way?
                                    > node-gyp-build
                                    > node-gyp-build
                                    It then says to:
                                      errno: -2,
                                      syscall: 'open',
                                      code: 'ENOENT',
                                    Answer = NO
                                    to
                                    cw
                                    @cw-kid said in Multi-System Reactor Developer Preview AVAILABLE:
                                    Just copy the files from dist-config to config manually. Reactor won't read config files unless they are in config.
                                    The startup error can be ignored; it's for loading test data, which isn't present.
                                      or like this ?
                                      Or some other way?
                                      Reactor's "House Mode" entity uses words: home, away, night, vacation. Note what is showing for "Current value" underneath the condition. You can also see this in the Entities list.
                                      EDIT: Also, can we please start threading discussions in this category? It's going to get unruly fast if everyone is talking about everything as replies to one thread.
                                        Thanks for the reply.
                                        I have used the words "away" and "vacation". However when I see this summary it says null or no data for the house mode triggers (conditions).
                                        So don't think its working.
                                        EDIT:
                                        Using "Does not contain" rather than "not in" looks better ?
                                          That's an unexpected difference. Equals and not equals would also be applicable here.
                                          • Error: Command timeout
                                          • [Solved] Local expression in Rule does not evaluate as they used to do
                                            74.3k
                                            599
                                          • Shelly Wall Display XL
