Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
124 Posts 12 Posters 97.4k Views 14 Watching
  • MatohlM Offline
    MatohlM Offline
    Matohl
    Up and running on my my RPi 4 with SSD. Will continue tomorrow with adding my Veras
      Nice. Any issues with the install?
      MatohlM 1 Reply Last reply
        Ok system up and running under termux on android 8.
        Some error in start up console log
        Tried first reactor rule and reaction, seems fast.
        reaction to set dimming does not work but on and off do.
        Would you prefer this to be logged in bug tracker or here.
        • K Offline
          K Offline
          kfxo
          wrote on last edited by kfxo
          Got it up an running and connected both openluup and home assistant. Noticing that if category_num attribute is not set in openluup then it does not recognize supported commands for the device. I'm guessing Reactor relies on this attribute?
          edit. updated Z-way plugin to latest which now provides category_num and issue is resolved
            Ok the dimming is 0 to 1 , that threw me. So 5% is 0.05.
            • ElcidE Elcid
              @elcid said in Multi-System Reactor Developer Preview AVAILABLE:
              Known error, it already has a PR, and is already fixed for the next build. That's just the preloader that I use to pull in data for testing. I'm usually looking at the end of the log, not the beginning, so I missed it before packaging the release. 🙂
              • K Offline
                K Offline
                kfxo
                Some first impressions. Having all home assistant and openluup entities together in a Reactor interface is a game changer. Install was super easy and went smoothly following the directions. Installed on a Debian10 VM. Looks like just about every entity from both systems were discovered. Performed a couple test rules with a HA entity being controlled based the state of an openluup entity and it was very responsive. Having trouble with the import tool, keep getting a syntax error. Definitely going to miss Run_Lua actions. Is there plans for anything to replace that? All and all looking great.
                • Black CatB Offline
                  Black CatB Offline
                  Black Cat
                  I'm stuck...(surprised I made it this far..):)
                  Uploaded and expanded OK...but there is no config/reactor.yaml file to edit.
                  aka Zedrally
                  • Black CatB Black Cat
                    @black-cat said in Multi-System Reactor Developer Preview AVAILABLE:
                    If you're using a Pi, you should have run the install script in the tools directory, which copies the files from dist-config to config. If you are installing on other Linux, there's a step in the instructions to do the copy manually. But that's all you need to do: cp dist-config/* config/
                    • K kfxo
                      @kfxo said in Multi-System Reactor Developer Preview AVAILABLE:
                      Can you paste some output? Let's have a look at that...
                      K 1 Reply Last reply
                        K Offline
                        K Offline
                        kfxo
                        I posted an issue on MantisBT but maybe I did it wrong. Should I try there again?
                        • K kfxo
                          Good on ya! I see it...
                          OK. Easy enough. Not sure how that snuck by... Probably the easiest is to have you just open it in a text editor, find the line (192) that says case 'interval': { and just remove that curly brace from the end of it. Save, and try again.
                            MatohlM Offline
                            MatohlM Offline
                            Matohl
                            Yes, but only due to myself. Following your instructions it went well 🙂 Will continue the testing later today ...
                              Linux Neanderthal here, I tried to install it on my Raspberry Pi2.
                              I got this output not sure what it means, it says I need to commit some file?
                              The version of nodejs currently installed is v12.20.1 (compatible).
                              Checking dependencies...
                              > bufferutil@4.0.3 install /home/pi/Documents/reactor/node_modules/bufferutil
                              > node-gyp-build
                              > utf-8-validate@5.0.4 install /home/pi/Documents/reactor/node_modules/utf-8-validate
                              > node-gyp-build
                              > core-js@3.9.0 postinstall /home/pi/Documents/reactor/node_modules/core-js
                              > node -e "try{require('./postinstall')}catch(e){}"
                              Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                              The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                              > https://opencollective.com/core-js
                              > https://www.patreon.com/zloirock
                              Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                              npm notice created a lockfile as package-lock.json. You should commit this file.
                              npm WARN bootstrap@4.5.3 requires a peer of popper.js@^1.16.1 but none is installed. You must install peer dependencies yourself.
                              added 86 packages from 68 contributors and audited 87 packages in 46.342s
                              4 packages are looking for funding
                                run `npm fund` for details
                              found 0 vulnerabilities
                              OK. Now please LOG OUT, then log back in and continue the installation procedure
                              (see docs/markdown/Installation.md or docs/html/Installation/index.html).
                              The installation Guide here then says to:
                              "Edit the file config/reactor.yaml and, on the line beginning baseurl:, replace the IP address with the actual primary IP address of your system."
                              There is a "config" folder present but it is empty.
                              There is a folder called /home/pi/Documents/reactor/dist-config and the reactor.yaml file was in there, so I edited that one and added my Pi's IP address.
                              I actually didn't even have a "Documents" folder to begin with, I had to create that folder first in this path: /home/pi/Documents
                              It then says to:
                              "Start up Reactor: node app.js"
                              Looks like there were some errors during startup.
                              pi@raspberrypi:~/Documents/reactor $ node app.js
                              2021-02-19T09:18:37.424Z <app:null> Reactor application v21047 starting on v12.20.2
                              2021-02-19T09:18:37.641Z <Controller:null> Module Controller v21046
                              2021-02-19T09:18:37.643Z <default:null> Module Structure v21025
                              2021-02-19T09:18:37.692Z <default:null> Module Ruleset v21041
                              2021-02-19T09:18:37.694Z <default:null> Module Rulesets v21041
                              2021-02-19T09:18:37.825Z <default:null> Module Rule v21047
                              2021-02-19T09:18:37.868Z <default:null> Module Engine v21047
                              2021-02-19T09:18:37.910Z <default:null> Module httpapi v21041
                              2021-02-19T09:18:37.924Z <default:null> Module httpproxy v20350
                              2021-02-19T09:18:38.093Z <default:null> Module wsapi v21041
                              2021-02-19T09:18:38.246Z <default:CRIT> Error: ENOENT: no such file or directory, open './server/struct_data.json'
                                  at Object.openSync (fs.js:462:3)
                                  at Object.readFileSync (fs.js:364:35)
                                  at Structure.start (/home/pi/Documents/reactor/server/lib/Structure.js:184:49)
                                  at /home/pi/Documents/reactor/app.js:141:72
                                  at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                  at processTicksAndRejections (internal/process/task_queues.js:97:5) {
                                errno: -2,
                                syscall: 'open',
                                code: 'ENOENT',
                                path: './server/struct_data.json'
                              2021-02-19T09:18:38.479Z <default:null> Module SystemController v21025
                              2021-02-19T09:18:38.537Z <app:null> Waiting 10 seconds before starting Engine
                              Will Reactor be started automatically after you reboot the Pi ?
                              Answer = NO
                              "I haven't fully daemon-ized Reactor yet while still in test mode, but eventually it will, of course, be available for startup at boot time."
                              Anyway I have the Reactor up and running it seems, I can access it in the web browser.
                              I then edited the reactor.yaml file and added my location details and the IP for my Vera hub. However after restarting MSR I had nothing listed in Entities other than Reactor System.
                              I had to copy the reator.yaml file from this folder to this folder and then it worked.
                              to
                              /home/pi/Documents/reactor/config
                              I can now see my Vera device and scenes listed under Entities
                              cw
                                Will this work for Conditions ?
                                Vera is not in either Away mode (2) or in Vacation mode (4)
                                or like this ?
                                Or some other way?
                                  > node-gyp-build
                                  > node-gyp-build
                                  It then says to:
                                    errno: -2,
                                    syscall: 'open',
                                    code: 'ENOENT',
                                  Answer = NO
                                  to
                                  cw
                                  @cw-kid said in Multi-System Reactor Developer Preview AVAILABLE:
                                  Just copy the files from dist-config to config manually. Reactor won't read config files unless they are in config.
                                  The startup error can be ignored; it's for loading test data, which isn't present.
                                    or like this ?
                                    Or some other way?
                                    Reactor's "House Mode" entity uses words: home, away, night, vacation. Note what is showing for "Current value" underneath the condition. You can also see this in the Entities list.
                                    EDIT: Also, can we please start threading discussions in this category? It's going to get unruly fast if everyone is talking about everything as replies to one thread.
                                      Thanks for the reply.
                                      I have used the words "away" and "vacation". However when I see this summary it says null or no data for the house mode triggers (conditions).
                                      So don't think its working.
                                      EDIT:
                                      Using "Does not contain" rather than "not in" looks better ?
                                        That's an unexpected difference. Equals and not equals would also be applicable here.
                                          #21
                                          @toggledbits In PLEG not equals is != I'm assuming <> is not equals in MSR. I'll change it to that as its better than "does not contain".
                                            163.4k
