  4. Access control - allowing anonymous user to dashboard
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 2 Posters 582 Views 2 Watching
    Using build 25328 and having the following users.yaml configuration:
    users:
      # This section defines your valid users.
      admin: *******
    groups:
      # This section defines your user groups. Optionally, it defines application
      # and API access restrictions (ACLs) for the group. Users may belong to
      # more than one group. Again, no required or special groups here.
      admin_group:
        users:
          - admin
        applications: true  # special form allows access to ALL applications
      guests:
        users: "*"
        applications:
          - dashboard
    api_acls:
      # This ACL allows users in the "admin" group to access the API
      - url: "/api"
        group: admin_group
        allow: true
        log: true
      # This ACL allows anyone/thing to access the /api/v1/alive API endpoint
      - url: "/api/v1/alive"
        allow: true
    session:
      timeout: 7200  # (seconds)
      rolling: true  # activity extends timeout when true
    # If log_acls is true, the selected ACL for every API access is logged.
    log_acls: true
    # If debug_acls is true, even more information about ACL selection is logged.
    debug_acls: true
    My goal is to allow anonymous user to dashboard, but MSR is still asking for a password when trying to access that. Nothing in the logs related to dashboard access. Probably an error in the configuration, but help needed to find that. Tried to put url: "/dashboard" under api_acls, but that was a long shot and didn't work.
    • toggledbitsT Online
      toggledbitsT Online
      Sorry, that's not possible in the current incarnation of access control... either everything is protected by user authentication (login), or its not. I use a trivial password on my guest account ("guest") to work around it.
        163.7k
