  4. [Reactor] Problem with Global Reactions and groups
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 752 Views 2 Watching
    I have this Global Reaction doing some work around lights, based on the season:
    When I run it, both the lights in Summer and Winter groups are turned on. Very, very strange. I tried removing and adding the groups again, with no joy.
    I see these on the logs:
    [latest-25328]2026-01-11T18:23:11.847Z <Engine:CRIT> TypeError: this[_0x3c7c88(...)][_0x3c7c88(...)] is not a function [-]
        at GlobalReactionPredicateContext.toString (/opt/reactor/server/lib/PredicateContext.js:87:126)
        at Logger.getLogger (/opt/reactor/server/lib/Logger.js:417:31)
        at new GlobalReactionPredicateContext (/opt/reactor/server/lib/GlobalReactionPredicateContext.js:62:93)
        at Engine._resume_reaction (/opt/reactor/server/lib/Engine.js:2136:55)
        at Engine._process_reaction_queue (/opt/reactor/server/lib/Engine.js:2031:133)
        at process.processTicksAndRejections (node:internal/process/task_queues:103:5)
    [latest-25328]2026-01-11T18:23:12.155Z <Engine:CRIT> Engine#1 alarm() context is rule Rule#rule-mf29005p condition condmf29005q Script; timer ID will be alarm:rule:rule-mf29005p:cond:condmf29005q
    [latest-25328]2026-01-11T18:23:13.159Z <Engine:CRIT> Engine#1 alarm() context is rule Rule#rule-mf29005p condition condmf29005q Script; timer ID will be alarm:rule:rule-mf29005p:cond:condmf29005q
    [latest-25328]2026-01-11T18:23:14.376Z <Engine:CRIT> TypeError: this[_0x3c7c88(...)][_0x3c7c88(...)] is not a function [-]
    Maybe some old format that was corrupted in the rule? @toggledbits
      Try 26011
        @toggledbits yes, fixed! thanks.
          162.9k
