  4. [Reactor] Bug when sending MQTT boolean payloads
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 2 Posters 1.0k Views 2 Watching
    Hey @toggledbits.
    I found a strange bug while sending boolean MQTT payloads in actions. Latest MQTT/Reactor builds.
    Basically, if I send a true/false, it gets logged but it's not sent:
    [latest-25328]2025-12-31T11:36:23.958Z <MQTTController:INFO> MQTTController#mqtt x_mqtt.publish publishing foo/cmd/foo payload false
    If I change to ${{ str(1 == 1) }}, it goes thru. No apparent errors in logs.
    • toggledbitsT Online
      toggledbitsT Online
      All messages and payloads are text. You literally cannot send a boolean as a payload in MQTT. You have to convert all other types to a text representation.
      That said, I will look into why MQTTController isn't doing it automatically for this action. It should.
      Sorry for the reply delay... I was at a training event for a week.
      Edit/Update: found it. The x_mqtt.publish action is handled specially, and that code was missing the default case that would catch and convert non-string/non-object types. The underlying package handles other primitives like Number, but apparently not Booleans. Give me a day or two to settle back in and publish an updated MQTTController.
        Yes, thanks. I usually send json and numbers, so I assumed it would automatically convert to string anyway. Not a big deal, but it made me check my sanity for a couple of hours, until I realized it was not me.
          toggledbitsT Online
          Yeah, I think the underlying package has some kind of half-check somewhere, like if (payload) { ... } to see if a payload is being sent, and that would fail for boolean false and other falsy values, but it doesn't matter, I don't assume the proper conversion below me, and I missed it on the exception case in that action, so there's good permanent fix (for the code... my brain, maybe not so much).
            163.7k
