  4. VEC Virtual Switch Auto Off
2 Posts 1 Posters 723 Views 1 Watching
    I use Virtual Entity Controller virtual switches which I turn on via webhooks from other applications. Once a switch triggers and turns on, I can then activate associated rules.
    I would like each virtual switch to automatically turn off after a configurable time (e.g., 5 seconds, 10 seconds).
    Is there a better way to achieve this auto-off behavior instead of creating a separate rule for each switch that uses the 'Condition must be sustained for' option to turn it off?
    With a large number of these switches (and the associated turn-off rules), I'm checking to see if there is a simpler approach.If not, could this be a feature request to add an auto-off timer directly to the virtual switches.
    Reactor (Multi-hub) latest-26011-c621bbc7
    VirtualEntityController v25356
    Synology Docker
      Is this the proper place to ask for a feature request? I think it would be useful to have VEC Virtual switches to have an option for an Auto Off setting. Thanks
