Here’s the gist of it:
1. UI
2. scheduler
3. web server
4. Luup compatible API
6. Zwave bridge to Vera
openLuup was the result.
Set up:
2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88Re: socket.select() not ready to send
Hi @akbooer
Hey guys...
Long time... 😉
For example..
AND
AND
AND
IF binary-light1 is OFF
AND
IF binary-light2 is OFF
THEN
execute LUA code
WAIT 2 minute
execute LUA code
Now here's the query:
Bit of an odd one this:
I can ssh into all my servers
TIA for any thoughts
Hi Ak,
This is in the init function:
Regards
Jan
no file ‘./socket/http.lua’
no file ‘./socket/http.so’
no file ‘./socket.so’
stack traceback:
[C]: in function ‘require’
2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548And then in syslog:
Openluup control of Alexa
@therealdb said in Openluup control of Alexa:
I’ve not used reactor, so I’m not sure. As I said, you can create a virtual device and run lua. Just use lua:// and the insert the lua code to run the routine
Thanks, but this is where I'm a bit stuck. I can't see anything in the doc to create a virtual device to map on an Alexa controlled device. Or should I be looking at a virtual http type device direct to the wifi bulb? That being the case I guess I'm going to need to know what the API commands are (which I've not seen being)
Or am I on totally the wrong track?Cheers
Let's say you have two routines and VeraAlexa already installed. Install Virtual Devices from GitHub (or via AltAppStore) as well. Create a device for Virtual Device Plug-in, then go to the device you created, and insert into variables:
- SetPowerURL: lua://luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine", {RoutineName="xzy_LightOn", GroupZones="Bedroom"}, 666)
Repeat for SetPowerOffURL, but use your lightOff routine name. Change 666 to your VeraAlexa device's ID. Try to turn on, it should call Alexa to do it, same thing for turning off.
You are a gent sir. This is what I have in my SetPowerURL variable:
lua://luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine"{RoutineName="xzylight", GroupZones="Office"},22)
The routine name is correct and works when accessed from the Alexa App
The device in GroupZones works if I send speech to it
The VeraAlexa device number is correct.Log entry seems sparse, even in debug:
2021-04-22 08:54:40.023 luup.call_action:: 59.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2021-04-22 08:54:40.024 luup_log:59: VirtualDevices[3.0-beta2@59](actionPower@92):actionPower(59,"1") 2021-04-22 08:54:40.024 luup_log:59: VirtualDevices[3.0-beta2@59](actionPowerInternal@45):actionPowerInternal(59,true,true) 2021-04-22 08:54:40.024 luup_log:59: VirtualDevices[3.0-beta2@59](setVar@104):setVar("urn:upnp-org:serviceId:SwitchPower1","Target","1",59) old value "0" 2021-04-22 08:54:40.025 luup.variable_set:: 59.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0 2021-04-22 08:54:40.025 luup_log:59: VirtualDevices[3.0-beta2@59](sendDeviceCommand@279):sendDeviceCommand("SetPowerURL","on",59) 2021-04-22 08:54:40.025 luup_log:59: VirtualDevices[3.0-beta2@59]:sendDeviceCommand: RunLua: "luup.call_action(\"urn:bochicchio-com:serviceId:VeraAlexa1\", \"RunRoutine\", {RoutineName=\"xzylight\", GroupZones=\"Office\"},22)" 2021-04-22 08:54:40.025 luup.call_action:: 1.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua 2021-04-22 08:54:40.025 luup_log:59: VirtualDevices[3.0-beta2@59](setVar@104):setVar("urn:upnp-org:serviceId:SwitchPower1","Status","1",59) old value "0" 2021-04-22 08:54:40.025 luup.variable_set:: 59.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0 2021-04-22 08:54:40.026 luup_log:59: VirtualDevices[3.0-beta2@59](onSuccess@77):Auto off in 0 secs
What have I done wrong?
TIA
Of course:
Variable Value AlexaHost layla.amazon.co.uk AmazonHost amazon.co.uk AnnouncementVolume 50 CommFailure 0 CommFailureTime 0 Configured 1 CurrentVersion 0.2.13 DebugMode 0 DefaultBreak 3 DefaultEcho Office DefaultVolume 40 Language en-GB LatestResponse sending cmd:speak:<s>There is movement at the front door</s><break time="0s" /> to dev:Office type:A32DOYMUN6DTXA serial:G090U50991550NLS customerid:A1CVTZEBJIUFJI OneTimePassCode Password **** UseAnnoucements 1 Username *****
@CatmanV2 @LibraSun can you please send me more logs (see Patrick's guidance). Privately is OK, if you prefer. Remember to set DebugMode to 1 for Vera Alexa's device. It's almost week-end, so I'll have some spare time. Thanks!
For sure! But given that I have no idea what (other than what posted) is relevant how long a chunk do you want?
Hmm, PM limit is 1000 characters
2021-04-23 17:52:38.268 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-23 17:52:38.268 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-23 17:52:38.269 luup_log:52: SiteSensor: Scheduling next activity in 60 seconds 2021-04-23 17:52:38.778 openLuup.server:: request completed (10747 bytes, 1 chunks, 7579 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:38.784 openLuup.server:: request completed (10747 bytes, 1 chunks, 7026 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:52:39.287 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175518&Timeout=60&MinimumDelay=1500&_=1618778104503 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:39.984 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175518&Timeout=60&MinimumDelay=1500&_=1619187656551 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:52:42.859 openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=61&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1 HTTP/1.1 tcp{client}: 0x564e8c87b0f8 2021-04-23 17:52:42.860 luup.call_action:: 61.urn:upnp-org:serviceId:SwitchPower1.SetTarget 2021-04-23 17:52:42.860 luup.variable_set:: 61.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0 2021-04-23 17:52:42.861 luup_log:61: VirtualDevices[3.0-beta2@61]:sendDeviceCommand: RunLua: "luup.call_action(\"urn:bochicchio-com:serviceId:VeraAlexa1\", \"RunRoutine\", {RoutineName=\"xzylight\", GroupZones=\"Office\"},22)" 2021-04-23 17:52:42.861 luup.call_action:: 1.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua 2021-04-23 17:52:42.861 luup.variable_set:: 61.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0 2021-04-23 17:52:42.861 openLuup.server:: request completed (35 bytes, 1 chunks, 2 ms) tcp{client}: 0x564e8c87b0f8 2021-04-23 17:52:43.067 openLuup.server:: request completed (6489 bytes, 1 chunks, 3779 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:43.078 openLuup.server:: GET /cmh/skins/default/img/devices/device_states/binary_light_on.png HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:43.079 openLuup.server:: request completed (708 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:43.180 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175520&Timeout=60&MinimumDelay=1500&_=1618778104504 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:43.228 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656552 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:52:43.334 openLuup.server:: request completed (6489 bytes, 1 chunks, 3349 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:52:43.335 openLuup.server:: request completed (1 bytes, 1 chunks, 106 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:52:43.714 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175520&Timeout=60&MinimumDelay=1500&_=1619187656553 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:52:45.721 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0 2021-04-23 17:52:45.930 openLuup.server:: request completed (7817 bytes, 1 chunks, 2215 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:52:46.036 openLuup.server:: request completed (7817 bytes, 1 chunks, 2855 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:46.163 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175521&Timeout=60&MinimumDelay=1500&_=1618778104505 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:46.913 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175521&Timeout=60&MinimumDelay=1500&_=1619187656554 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:52:48.927 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 23 now: 22 #hooks:0 2021-04-23 17:52:49.135 openLuup.server:: request completed (7817 bytes, 1 chunks, 2221 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:52:49.442 openLuup.server:: request completed (7817 bytes, 1 chunks, 3278 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:49.786 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175522&Timeout=60&MinimumDelay=1500&_=1619187656555 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:52:50.160 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175522&Timeout=60&MinimumDelay=1500&_=1618778104506 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:53.217 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0 2021-04-23 17:52:53.422 openLuup.server:: request completed (7817 bytes, 1 chunks, 3261 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:53.629 openLuup.server:: request completed (7817 bytes, 1 chunks, 3841 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:52:53.634 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656556 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:52:53.736 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:52:53.978 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175523&Timeout=60&MinimumDelay=1500&_=1618778104507 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:52:54.991 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175523&Timeout=60&MinimumDelay=1500&_=1619187656557 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:52:59.789 openLuup.server:: GET /cmh/skins/default/img/devices/device_states/switch_on.png HTTP/1.1 tcp{client}: 0x564e8c87b0f8 2021-04-23 17:52:59.790 openLuup.server:: request completed (1223 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e8c87b0f8 2021-04-23 17:52:59.791 openLuup.server:: GET /cmh/skins/default/img/devices/device_states/switch_off.png HTTP/1.1 tcp{client}: 0x564e8cd027f8 2021-04-23 17:52:59.792 openLuup.server:: request completed (1191 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e8cd027f8 2021-04-23 17:53:04.775 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656558 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:53:04.877 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:53:05.036 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 23 now: 22 #hooks:0 2021-04-23 17:53:05.143 openLuup.server:: request completed (7817 bytes, 1 chunks, 10151 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:05.249 openLuup.server:: request completed (7817 bytes, 1 chunks, 11270 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:05.782 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175524&Timeout=60&MinimumDelay=1500&_=1619187656559 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:06.573 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175524&Timeout=60&MinimumDelay=1500&_=1618778104508 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:09.329 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0 2021-04-23 17:53:09.638 openLuup.server:: request completed (7817 bytes, 1 chunks, 3854 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:09.844 openLuup.server:: request completed (7817 bytes, 1 chunks, 3270 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:10.183 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175525&Timeout=60&MinimumDelay=1500&_=1618778104509 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:10.982 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175525&Timeout=60&MinimumDelay=1500&_=1619187656560 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:13.659 luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 23 now: 22 #hooks:0 2021-04-23 17:53:13.766 openLuup.server:: request completed (7817 bytes, 1 chunks, 2782 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:14.073 openLuup.server:: request completed (7817 bytes, 1 chunks, 3888 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:14.978 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175526&Timeout=60&MinimumDelay=1500&_=1619187656561 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:14.979 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656562 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:53:15.081 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:53:15.548 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175526&Timeout=60&MinimumDelay=1500&_=1618778104510 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:26.088 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656563 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:53:26.190 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:53:29.500 luup.variable_set:: 25005.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 27.4 now: 26.6 #hooks:2 2021-04-23 17:53:29.501 luup.watch_callback:: 25005.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature called [20]DataWatcherCallback() function: 0x564e8c4004e0 2021-04-23 17:53:29.501 luup.watch_callback:: 25005.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature called [11]reactorWatch() function: 0x564e8ba75720 2021-04-23 17:53:29.508 luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"condso4rr22":{"evaledge":{"f":1616784363},"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,... now: {"condso4rr22":{"evaledge":{"f":1616784363},"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,... #hooks:0 2021-04-23 17:53:29.510 luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.Message was: now: #hooks:0 2021-04-23 17:53:29.927 openLuup.server:: request completed (74198 bytes, 5 chunks, 14948 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:29.933 openLuup.server:: request completed (74198 bytes, 5 chunks, 14384 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:30.179 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175529&Timeout=60&MinimumDelay=1500&_=1618778104511 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:30.903 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175529&Timeout=60&MinimumDelay=1500&_=1619187656564 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:38.278 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastRun was: 1619196758 now: 1619196818 #hooks:0 2021-04-23 17:53:38.278 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastQuery was: 1619196758 now: 1619196818 #hooks:0 2021-04-23 17:53:38.279 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastEval was: 1619196758 now: 1619196818 #hooks:0 2021-04-23 17:53:38.279 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Valid response; matched! now: Performing query... #hooks:0 2021-04-23 17:53:38.280 luup_log:52: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ } 2021-04-23 17:53:38.280 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:52:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ }|17:52:38: SiteSensor: Request succeeded, "wit... now: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ } #hooks:0 2021-04-23 17:53:38.298 luup_log:52: SiteSensor: Request succeeded, "with" match: "Matched" 2021-04-23 17:53:38.298 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ } now: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ }|17:53:38: SiteSensor: Request succeeded, "wit... #hooks:0 2021-04-23 17:53:38.299 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Performing query... now: Valid response; matched! #hooks:0 2021-04-23 17:53:38.299 luup.set_failure:: status = 0 2021-04-23 17:53:38.300 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-23 17:53:38.300 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-23 17:53:38.301 luup_log:52: SiteSensor: Scheduling next activity in 60 seconds 2021-04-23 17:53:38.407 openLuup.server:: request completed (10747 bytes, 1 chunks, 7504 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:38.413 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656565 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:38.515 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:38.617 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175538&Timeout=60&MinimumDelay=1500&_=1619187656566 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:38.825 openLuup.server:: request completed (10747 bytes, 1 chunks, 8644 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:39.243 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175538&Timeout=60&MinimumDelay=1500&_=1618778104512 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:53:49.600 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656567 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:53:49.702 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:53:59.552 luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"condso4rr22":{"evaledge":{"f":1616784363},"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,... now: {"condso4rr22":{"statestamp":1616784363,"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,"las... #hooks:0 2021-04-23 17:53:59.553 luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.Message was: now: #hooks:0 2021-04-23 17:53:59.870 openLuup.server:: request completed (73276 bytes, 5 chunks, 21252 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:53:59.983 openLuup.server:: request completed (73276 bytes, 5 chunks, 20739 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:00.195 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175540&Timeout=60&MinimumDelay=1500&_=1618778104513 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:00.910 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656568 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:00.912 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175540&Timeout=60&MinimumDelay=1500&_=1619187656569 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:54:01.014 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:02.941 luup_log:0: 13Mb, 2.1%cpu, 1.3days 2021-04-23 17:54:03.046 openLuup.server:: request completed (4875 bytes, 1 chunks, 2850 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:03.151 openLuup.server:: request completed (4875 bytes, 1 chunks, 2238 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:54:03.658 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175547&Timeout=60&MinimumDelay=1500&_=1619187656570 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:54:04.463 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175547&Timeout=60&MinimumDelay=1500&_=1618778104514 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:14.604 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656571 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:14.706 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:29.889 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656572 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:29.992 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:31.696 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x564e8c87b0f8 2021-04-23 17:54:33.054 luup_log:26: IPhoneLocator: Entering loop:26:1 2021-04-23 17:54:34.257 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.PrevUpdate was: 1619195975.93 now: 1619196282.895 #hooks:0 2021-04-23 17:54:34.258 luup.variable_set:: 26.urn:micasaverde-com:serviceId:HaDevice1.LastUpdate was: 1619196282.895 now: 1619196597.36 #hooks:0 2021-04-23 17:54:34.258 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.PrevLat was: 51.762584709398 now: 51.762616462252 #hooks:0 2021-04-23 17:54:34.258 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.PrevLong was: 0.13431196000302 now: 0.13432520872469 #hooks:0 2021-04-23 17:54:34.258 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.CurLat was: 51.762616462252 now: 51.762606422089 #hooks:0 2021-04-23 17:54:34.258 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.CurLong was: 0.13432520872469 now: 0.13428539975898 #hooks:0 2021-04-23 17:54:34.258 luup_log:26: IPhoneLocator: ETA set to =>0 2021-04-23 17:54:34.258 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.LocationExtraInfo was: GPS:9.9140666521856:false now: GPS:8.4249524283522:false #hooks:0 2021-04-23 17:54:34.259 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText was: Poll: 2021-04-23 17:49 / 300 s now: Poll: 2021-04-23 17:54 #hooks:0 2021-04-23 17:54:34.259 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText2 was: -0.00 Km @ 0.00 Km/h on 2021-04-23 17:44 now: -0.00 Km @ 0.00 Km/h on 2021-04-23 17:49 #hooks:0 2021-04-23 17:54:34.259 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MapUrl was: https://dev.virtualearth.net/REST/v1/Imagery/Map/Road?pushpin=51.762616462252,0.13432520872469;;H&mapLayer=TrafficF... now: https://dev.virtualearth.net/REST/v1/Imagery/Map/Road?pushpin=51.762606422089,0.13428539975898;;H&mapLayer=TrafficF... #hooks:0 2021-04-23 17:54:34.259 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.ICloudDevices was: iPhone,Chris’s MacBook Air (2),New Mail Server,iPad (7) now: iPhone,Chris’s MacBook Air (2),New Mail Server,iPad (7) #hooks:0 2021-04-23 17:54:34.259 luup_log:26: IPhoneLocator: getPeriodForDevice(26) - Distance:-0 Auto:1 Base:300==>300 2021-04-23 17:54:34.259 luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText was: Poll: 2021-04-23 17:54 now: Poll: 2021-04-23 17:54 / 300 s #hooks:0 2021-04-23 17:54:34.260 luup.call_timer:: interval: time=301, days={} 2021-04-23 17:54:34.309 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x564e8cd027f8 2021-04-23 17:54:34.313 openLuup.server:: request completed (10211 bytes, 1 chunks, 30654 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:54:34.315 openLuup.server:: request completed (10211 bytes, 1 chunks, 29850 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:34.655 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175559&Timeout=60&MinimumDelay=1500&_=1619187656573 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:54:35.560 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175559&Timeout=60&MinimumDelay=1500&_=1618778104515 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:38.381 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastRun was: 1619196818 now: 1619196878 #hooks:0 2021-04-23 17:54:38.381 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastQuery was: 1619196818 now: 1619196878 #hooks:0 2021-04-23 17:54:38.382 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastEval was: 1619196818 now: 1619196878 #hooks:0 2021-04-23 17:54:38.382 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Valid response; matched! now: Performing query... #hooks:0 2021-04-23 17:54:38.383 luup_log:52: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ } 2021-04-23 17:54:38.383 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ }|17:53:38: SiteSensor: Request succeeded, "wit... now: 17:54:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ } #hooks:0 2021-04-23 17:54:38.400 luup_log:52: SiteSensor: Request succeeded, "with" match: "Matched" 2021-04-23 17:54:38.400 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:54:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ } now: 17:54:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={ }|17:54:38: SiteSensor: Request succeeded, "wit... #hooks:0 2021-04-23 17:54:38.401 luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Performing query... now: Valid response; matched! #hooks:0 2021-04-23 17:54:38.401 luup.set_failure:: status = 0 2021-04-23 17:54:38.401 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-04-23 17:54:38.402 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2021-04-23 17:54:38.402 luup_log:52: SiteSensor: Scheduling next activity in 60 seconds 2021-04-23 17:54:38.858 openLuup.server:: request completed (10747 bytes, 1 chunks, 3297 ms) tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:38.964 openLuup.server:: request completed (10747 bytes, 1 chunks, 4308 ms) tcp{client}: 0x564e8c234198 2021-04-23 17:54:39.232 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175568&Timeout=60&MinimumDelay=1500&_=1618778104516 HTTP/1.1 tcp{client}: 0x564e8bf913d8 2021-04-23 17:54:39.895 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175568&Timeout=60&MinimumDelay=1500&_=1619187656574 HTTP/1.1 tcp{client}: 0x564e8c234198 2021-04-23 17:54:40.607 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656575 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:40.709 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:52.893 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656576 HTTP/1.1 tcp{client}: 0x564e8c6b7358 2021-04-23 17:54:52.995 openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358
That's two minutes, let me know if you need more
@catmanv2 I just need a couple of logs around the invocation of run routine. Thanks!
OK, I'm being dumb. Is that not what I just posted?
17:52:42.860Device 61 is the virtual device...
@therealdb Cheers!
OK Debug is on on device 22, and has been for some time
Is there another log file for VeraAlexa? That's my LuaUPnP.log . Raw and un-adulterated. Simply copied from the terminal from
#tail -F LuaUPnP.log
@catmanv2 nope, no other log files. So, it seems that RunLua is not executing correctly. I'll take a look at this, to start. What's your version of openLuup?
According to the panel:
20.6.20
I can't help but notice that the password stored in the VeraAlexa variables is not my password any longer.....
Could this have a bearing? Seems to make no difference to TTS.....
And updated, no difference
@catmanv2 I don't think it will make any difference. I'll try to replicate your setup later today or tomorrow. We'll definitely fix it
For sure! I'm just glad I hadn't totally lost the plot ref log reporting
