  3. Openluup control of Alexa
openLuup email server
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup
openLuup: Version Log
openLuup
ZWaveJS and MQTT
openLuup
Awesome MQTT - GitHub list
openLuup
openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
openLuup
openLuup
openLuup and room names
openLuup
openLuup
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
openLuup
openLuup
AltUI access over VPN
openLuup
openLuup
OpenLuup installation
openLuup
Unexpected stop of openLuup
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
openLuup
23 Posts 3 Posters 8.3k Views 3 Watching
    Let's say you have two routines and VeraAlexa already installed. Install Virtual Devices from GitHub (or via AltAppStore) as well. Create a device for Virtual Device Plug-in, then go to the device you created, and insert into variables:
    • SetPowerURL: lua://luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine", {RoutineName="xzy_LightOn", GroupZones="Bedroom"}, 666)
    Repeat for SetPowerOffURL, but use your lightOff routine name. Change 666 to your VeraAlexa device's ID. Try to turn on, it should call Alexa to do it, same thing for turning off.
      You are a gent sir. This is what I have in my SetPowerURL variable:
      lua://luup.call_action("urn:bochicchio-com:serviceId:VeraAlexa1", "RunRoutine"{RoutineName="xzylight", GroupZones="Office"},22)
      The routine name is correct and works when accessed from the Alexa App
      The device in GroupZones works if I send speech to it
      The VeraAlexa device number is correct.
      Log entry seems sparse, even in debug:
      2021-04-22 08:54:40.023   luup.call_action:: 59.urn:upnp-org:serviceId:SwitchPower1.SetTarget
      2021-04-22 08:54:40.024   luup_log:59: VirtualDevices[3.0-beta2@59](actionPower@92):actionPower(59,"1")
      2021-04-22 08:54:40.024   luup_log:59: VirtualDevices[3.0-beta2@59](actionPowerInternal@45):actionPowerInternal(59,true,true)
      2021-04-22 08:54:40.024   luup_log:59: VirtualDevices[3.0-beta2@59](setVar@104):setVar("urn:upnp-org:serviceId:SwitchPower1","Target","1",59) old value "0"
      2021-04-22 08:54:40.025   luup.variable_set:: 59.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0
      2021-04-22 08:54:40.025   luup_log:59: VirtualDevices[3.0-beta2@59](sendDeviceCommand@279):sendDeviceCommand("SetPowerURL","on",59)
      2021-04-22 08:54:40.025   luup_log:59: VirtualDevices[3.0-beta2@59]:sendDeviceCommand: RunLua: "luup.call_action(\"urn:bochicchio-com:serviceId:VeraAlexa1\", \"RunRoutine\", {RoutineName=\"xzylight\", GroupZones=\"Office\"},22)"
      2021-04-22 08:54:40.025   luup.call_action:: 1.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
      2021-04-22 08:54:40.025   luup_log:59: VirtualDevices[3.0-beta2@59](setVar@104):setVar("urn:upnp-org:serviceId:SwitchPower1","Status","1",59) old value "0"
      2021-04-22 08:54:40.025   luup.variable_set:: 59.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0
      2021-04-22 08:54:40.026   luup_log:59: VirtualDevices[3.0-beta2@59](onSuccess@77):Auto off in 0 secs
      What have I done wrong?
      TIA
        TIA
        @catmanv2 maybe this is the same problem as @LibraSun already reported. I’ll investigate more. Could you please post variables minus username/password? Thanks!
          Of course:
          Variable		Value
          AlexaHost
          layla.amazon.co.uk
          AmazonHost
          amazon.co.uk
          AnnouncementVolume
          50
          CommFailure
          CommFailureTime
          Configured
          CurrentVersion
          0.2.13
          DebugMode
          DefaultBreak
          DefaultEcho
          Office
          DefaultVolume
          40
          Language
          en-GB
          LatestResponse
          sending cmd:speak:<s>There is movement at the front door</s><break time="0s" /> to dev:Office type:A32DOYMUN6DTXA serial:G090U50991550NLS customerid:A1CVTZEBJIUFJI
          OneTimePassCode
          Password
          UseAnnoucements
          Username
            Of course:
            Variable		Value
            AlexaHost
            layla.amazon.co.uk
            AmazonHost
            amazon.co.uk
            AnnouncementVolume
            50
            CommFailure
            CommFailureTime
            Configured
            CurrentVersion
            0.2.13
            DebugMode
            DefaultBreak
            DefaultEcho
            Office
            DefaultVolume
            40
            Language
            en-GB
            LatestResponse
            OneTimePassCode
            Password
            UseAnnoucements
            Username
            @CatmanV2 @LibraSun can you please send me more logs (see Patrick's guidance). Privately is OK, if you prefer. Remember to set DebugMode to 1 for Vera Alexa's device. It's almost week-end, so I'll have some spare time. Thanks!
              @therealdb said in Openluup control of Alexa:
              For sure! But given that I have no idea what (other than what posted) is relevant how long a chunk do you want?
                Hmm, PM limit is 1000 characters
                2021-04-23 17:52:38.268   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                2021-04-23 17:52:38.268   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                2021-04-23 17:52:38.269   luup_log:52: SiteSensor: Scheduling next activity in 60 seconds
                2021-04-23 17:52:38.778   openLuup.server:: request completed (10747 bytes, 1 chunks, 7579 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:38.784   openLuup.server:: request completed (10747 bytes, 1 chunks, 7026 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:52:39.287   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175518&Timeout=60&MinimumDelay=1500&_=1618778104503 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:39.984   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175518&Timeout=60&MinimumDelay=1500&_=1619187656551 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:52:42.859   openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=61&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1 HTTP/1.1 tcp{client}: 0x564e8c87b0f8
                2021-04-23 17:52:42.860   luup.call_action:: 61.urn:upnp-org:serviceId:SwitchPower1.SetTarget
                2021-04-23 17:52:42.860   luup.variable_set:: 61.urn:upnp-org:serviceId:SwitchPower1.Target was: 0 now: 1 #hooks:0
                2021-04-23 17:52:42.861   luup_log:61: VirtualDevices[3.0-beta2@61]:sendDeviceCommand: RunLua: "luup.call_action(\"urn:bochicchio-com:serviceId:VeraAlexa1\", \"RunRoutine\", {RoutineName=\"xzylight\", GroupZones=\"Office\"},22)"
                2021-04-23 17:52:42.861   luup.call_action:: 1.urn:micasaverde-com:serviceId:HomeAutomationGateway1.RunLua
                2021-04-23 17:52:42.861   luup.variable_set:: 61.urn:upnp-org:serviceId:SwitchPower1.Status was: 0 now: 1 #hooks:0
                2021-04-23 17:52:42.861   openLuup.server:: request completed (35 bytes, 1 chunks, 2 ms) tcp{client}: 0x564e8c87b0f8
                2021-04-23 17:52:43.067   openLuup.server:: request completed (6489 bytes, 1 chunks, 3779 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:43.078   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/binary_light_on.png HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:43.079   openLuup.server:: request completed (708 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:43.180   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175520&Timeout=60&MinimumDelay=1500&_=1618778104504 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:43.228   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656552 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:52:43.334   openLuup.server:: request completed (6489 bytes, 1 chunks, 3349 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:52:43.335   openLuup.server:: request completed (1 bytes, 1 chunks, 106 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:52:43.714   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175520&Timeout=60&MinimumDelay=1500&_=1619187656553 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:52:45.721   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0
                2021-04-23 17:52:45.930   openLuup.server:: request completed (7817 bytes, 1 chunks, 2215 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:52:46.036   openLuup.server:: request completed (7817 bytes, 1 chunks, 2855 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:46.163   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175521&Timeout=60&MinimumDelay=1500&_=1618778104505 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:46.913   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175521&Timeout=60&MinimumDelay=1500&_=1619187656554 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:52:48.927   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 23 now: 22 #hooks:0
                2021-04-23 17:52:49.135   openLuup.server:: request completed (7817 bytes, 1 chunks, 2221 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:52:49.442   openLuup.server:: request completed (7817 bytes, 1 chunks, 3278 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:49.786   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175522&Timeout=60&MinimumDelay=1500&_=1619187656555 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:52:50.160   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175522&Timeout=60&MinimumDelay=1500&_=1618778104506 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:53.217   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0
                2021-04-23 17:52:53.422   openLuup.server:: request completed (7817 bytes, 1 chunks, 3261 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:53.629   openLuup.server:: request completed (7817 bytes, 1 chunks, 3841 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:52:53.634   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656556 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:52:53.736   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:52:53.978   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175523&Timeout=60&MinimumDelay=1500&_=1618778104507 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:52:54.991   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175523&Timeout=60&MinimumDelay=1500&_=1619187656557 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:52:59.789   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/switch_on.png HTTP/1.1 tcp{client}: 0x564e8c87b0f8
                2021-04-23 17:52:59.790   openLuup.server:: request completed (1223 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e8c87b0f8
                2021-04-23 17:52:59.791   openLuup.server:: GET /cmh/skins/default/img/devices/device_states/switch_off.png HTTP/1.1 tcp{client}: 0x564e8cd027f8
                2021-04-23 17:52:59.792   openLuup.server:: request completed (1191 bytes, 0 chunks, 0 ms) tcp{client}: 0x564e8cd027f8
                2021-04-23 17:53:04.775   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656558 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:53:04.877   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:53:05.036   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 23 now: 22 #hooks:0
                2021-04-23 17:53:05.143   openLuup.server:: request completed (7817 bytes, 1 chunks, 10151 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:05.249   openLuup.server:: request completed (7817 bytes, 1 chunks, 11270 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:05.782   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175524&Timeout=60&MinimumDelay=1500&_=1619187656559 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:06.573   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175524&Timeout=60&MinimumDelay=1500&_=1618778104508 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:09.329   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 22 now: 23 #hooks:0
                2021-04-23 17:53:09.638   openLuup.server:: request completed (7817 bytes, 1 chunks, 3854 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:09.844   openLuup.server:: request completed (7817 bytes, 1 chunks, 3270 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:10.183   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175525&Timeout=60&MinimumDelay=1500&_=1618778104509 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:10.982   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175525&Timeout=60&MinimumDelay=1500&_=1619187656560 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:13.659   luup.variable_set:: 20380.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 23 now: 22 #hooks:0
                2021-04-23 17:53:13.766   openLuup.server:: request completed (7817 bytes, 1 chunks, 2782 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:14.073   openLuup.server:: request completed (7817 bytes, 1 chunks, 3888 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:14.978   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175526&Timeout=60&MinimumDelay=1500&_=1619187656561 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:14.979   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656562 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:53:15.081   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:53:15.548   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175526&Timeout=60&MinimumDelay=1500&_=1618778104510 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:26.088   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656563 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:53:26.190   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:53:29.500   luup.variable_set:: 25005.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 27.4 now: 26.6 #hooks:2
                2021-04-23 17:53:29.501   luup.watch_callback:: 25005.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature called [20]DataWatcherCallback() function: 0x564e8c4004e0
                2021-04-23 17:53:29.501   luup.watch_callback:: 25005.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature called [11]reactorWatch() function: 0x564e8ba75720
                2021-04-23 17:53:29.508   luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"condso4rr22":{"evaledge":{"f":1616784363},"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,... now: {"condso4rr22":{"evaledge":{"f":1616784363},"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,... #hooks:0
                2021-04-23 17:53:29.510   luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.Message was:  now:  #hooks:0
                2021-04-23 17:53:29.927   openLuup.server:: request completed (74198 bytes, 5 chunks, 14948 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:29.933   openLuup.server:: request completed (74198 bytes, 5 chunks, 14384 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:30.179   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175529&Timeout=60&MinimumDelay=1500&_=1618778104511 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:30.903   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175529&Timeout=60&MinimumDelay=1500&_=1619187656564 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:38.278   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastRun was: 1619196758 now: 1619196818 #hooks:0
                2021-04-23 17:53:38.278   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastQuery was: 1619196758 now: 1619196818 #hooks:0
                2021-04-23 17:53:38.279   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastEval was: 1619196758 now: 1619196818 #hooks:0
                2021-04-23 17:53:38.279   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Valid response; matched! now: Performing query... #hooks:0
                2021-04-23 17:53:38.280   luup_log:52: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  }
                2021-04-23 17:53:38.280   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:52:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  }|17:52:38: SiteSensor: Request succeeded, "wit... now: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  } #hooks:0
                2021-04-23 17:53:38.298   luup_log:52: SiteSensor: Request succeeded, "with" match: "Matched"
                2021-04-23 17:53:38.298   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  } now: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  }|17:53:38: SiteSensor: Request succeeded, "wit... #hooks:0
                2021-04-23 17:53:38.299   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Performing query... now: Valid response; matched! #hooks:0
                2021-04-23 17:53:38.299   luup.set_failure:: status = 0
                2021-04-23 17:53:38.300   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                2021-04-23 17:53:38.300   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                2021-04-23 17:53:38.301   luup_log:52: SiteSensor: Scheduling next activity in 60 seconds
                2021-04-23 17:53:38.407   openLuup.server:: request completed (10747 bytes, 1 chunks, 7504 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:38.413   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656565 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:38.515   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:38.617   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175538&Timeout=60&MinimumDelay=1500&_=1619187656566 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:38.825   openLuup.server:: request completed (10747 bytes, 1 chunks, 8644 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:39.243   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175538&Timeout=60&MinimumDelay=1500&_=1618778104512 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:53:49.600   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656567 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:53:49.702   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:53:59.552   luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"condso4rr22":{"evaledge":{"f":1616784363},"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,... now: {"condso4rr22":{"statestamp":1616784363,"stateedge":{"f":1616784363},"id":"condso4rr22","evalstamp":1616784363,"las... #hooks:0
                2021-04-23 17:53:59.553   luup.variable_set:: 23.urn:toggledbits-com:serviceId:ReactorSensor.Message was:  now:  #hooks:0
                2021-04-23 17:53:59.870   openLuup.server:: request completed (73276 bytes, 5 chunks, 21252 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:53:59.983   openLuup.server:: request completed (73276 bytes, 5 chunks, 20739 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:00.195   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175540&Timeout=60&MinimumDelay=1500&_=1618778104513 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:00.910   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656568 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:00.912   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175540&Timeout=60&MinimumDelay=1500&_=1619187656569 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:54:01.014   openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:02.941   luup_log:0: 13Mb, 2.1%cpu, 1.3days
                2021-04-23 17:54:03.046   openLuup.server:: request completed (4875 bytes, 1 chunks, 2850 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:03.151   openLuup.server:: request completed (4875 bytes, 1 chunks, 2238 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:54:03.658   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175547&Timeout=60&MinimumDelay=1500&_=1619187656570 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:54:04.463   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175547&Timeout=60&MinimumDelay=1500&_=1618778104514 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:14.604   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656571 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:14.706   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:29.889   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656572 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:29.992   openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:31.696   openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x564e8c87b0f8
                2021-04-23 17:54:33.054   luup_log:26: IPhoneLocator: Entering loop:26:1
                2021-04-23 17:54:34.257   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.PrevUpdate was: 1619195975.93 now: 1619196282.895 #hooks:0
                2021-04-23 17:54:34.258   luup.variable_set:: 26.urn:micasaverde-com:serviceId:HaDevice1.LastUpdate was: 1619196282.895 now: 1619196597.36 #hooks:0
                2021-04-23 17:54:34.258   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.PrevLat was: 51.762584709398 now: 51.762616462252 #hooks:0
                2021-04-23 17:54:34.258   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.PrevLong was: 0.13431196000302 now: 0.13432520872469 #hooks:0
                2021-04-23 17:54:34.258   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.CurLat was: 51.762616462252 now: 51.762606422089 #hooks:0
                2021-04-23 17:54:34.258   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.CurLong was: 0.13432520872469 now: 0.13428539975898 #hooks:0
                2021-04-23 17:54:34.258   luup_log:26: IPhoneLocator: ETA set to =>0
                2021-04-23 17:54:34.258   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.LocationExtraInfo was: GPS:9.9140666521856:false now: GPS:8.4249524283522:false #hooks:0
                2021-04-23 17:54:34.259   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText was: Poll: 2021-04-23 17:49 / 300 s now: Poll: 2021-04-23 17:54 #hooks:0
                2021-04-23 17:54:34.259   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText2 was: -0.00 Km @ 0.00 Km/h on 2021-04-23 17:44 now: -0.00 Km @ 0.00 Km/h on 2021-04-23 17:49 #hooks:0
                2021-04-23 17:54:34.259   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MapUrl was: https://dev.virtualearth.net/REST/v1/Imagery/Map/Road?pushpin=51.762616462252,0.13432520872469;;H&mapLayer=TrafficF... now: https://dev.virtualearth.net/REST/v1/Imagery/Map/Road?pushpin=51.762606422089,0.13428539975898;;H&mapLayer=TrafficF... #hooks:0
                2021-04-23 17:54:34.259   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.ICloudDevices was: iPhone,Chris’s MacBook Air (2),New Mail Server,iPad (7) now: iPhone,Chris’s MacBook Air (2),New Mail Server,iPad (7) #hooks:0
                2021-04-23 17:54:34.259   luup_log:26: IPhoneLocator: getPeriodForDevice(26) - Distance:-0 Auto:1 Base:300==>300
                2021-04-23 17:54:34.259   luup.variable_set:: 26.urn:upnp-org:serviceId:IPhoneLocator1.MsgText was: Poll: 2021-04-23 17:54 now: Poll: 2021-04-23 17:54 / 300 s #hooks:0
                2021-04-23 17:54:34.260   luup.call_timer:: interval: time=301, days={}
                2021-04-23 17:54:34.309   openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x564e8cd027f8
                2021-04-23 17:54:34.313   openLuup.server:: request completed (10211 bytes, 1 chunks, 30654 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:54:34.315   openLuup.server:: request completed (10211 bytes, 1 chunks, 29850 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:34.655   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175559&Timeout=60&MinimumDelay=1500&_=1619187656573 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:54:35.560   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175559&Timeout=60&MinimumDelay=1500&_=1618778104515 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:38.381   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastRun was: 1619196818 now: 1619196878 #hooks:0
                2021-04-23 17:54:38.381   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastQuery was: 1619196818 now: 1619196878 #hooks:0
                2021-04-23 17:54:38.382   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LastEval was: 1619196818 now: 1619196878 #hooks:0
                2021-04-23 17:54:38.382   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Valid response; matched! now: Performing query... #hooks:0
                2021-04-23 17:54:38.383   luup_log:52: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  }
                2021-04-23 17:54:38.383   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:53:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  }|17:53:38: SiteSensor: Request succeeded, "wit... now: 17:54:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  } #hooks:0
                2021-04-23 17:54:38.400   luup_log:52: SiteSensor: Request succeeded, "with" match: "Matched"
                2021-04-23 17:54:38.400   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.LogCapture was: 17:54:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  } now: 17:54:38: SiteSensor: HTTP "GET" "http://192.168.70.52", headers={  }|17:54:38: SiteSensor: Request succeeded, "wit... #hooks:0
                2021-04-23 17:54:38.401   luup.variable_set:: 52.urn:toggledbits-com:serviceId:SiteSensor1.Message was: Performing query... now: Valid response; matched! #hooks:0
                2021-04-23 17:54:38.401   luup.set_failure:: status = 0
                2021-04-23 17:54:38.401   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                2021-04-23 17:54:38.402   luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                2021-04-23 17:54:38.402   luup_log:52: SiteSensor: Scheduling next activity in 60 seconds
                2021-04-23 17:54:38.858   openLuup.server:: request completed (10747 bytes, 1 chunks, 3297 ms) tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:38.964   openLuup.server:: request completed (10747 bytes, 1 chunks, 4308 ms) tcp{client}: 0x564e8c234198
                2021-04-23 17:54:39.232   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175568&Timeout=60&MinimumDelay=1500&_=1618778104516 HTTP/1.1 tcp{client}: 0x564e8bf913d8
                2021-04-23 17:54:39.895   openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=82175568&Timeout=60&MinimumDelay=1500&_=1619187656574 HTTP/1.1 tcp{client}: 0x564e8c234198
                2021-04-23 17:54:40.607   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656575 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:40.709   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:52.893   openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1619187656576 HTTP/1.1 tcp{client}: 0x564e8c6b7358
                2021-04-23 17:54:52.995   openLuup.server:: request completed (1 bytes, 1 chunks, 101 ms) tcp{client}: 0x564e8c6b7358
                That's two minutes, let me know if you need more 🙂
                  @catmanv2 I just need a couple of logs around the invocation of run routine. Thanks!
                    OK, I'm being dumb. Is that not what I just posted?
                    17:52:42.860
                    Device 61 is the virtual device...
                      17:52:42.860
                      @catmanv2 you posted device #61 (Virtual Device), but I definitely need device #22 (VeraAlexa) to have DebugMode to 1 and its logs. Thanks!
                        @therealdb Cheers!
                        OK Debug is on on device 22, and has been for some time 🙂
                        Is there another log file for VeraAlexa? That's my LuaUPnP.log . Raw and un-adulterated. Simply copied from the terminal from
                        #tail -F LuaUPnP.log
                          @therealdb Cheers!
                          @catmanv2 nope, no other log files. So, it seems that RunLua is not executing correctly. I'll take a look at this, to start. What's your version of openLuup?
                            According to the panel:
                            20.6.20
                            I can't help but notice that the password stored in the VeraAlexa variables is not my password any longer.....
                            Could this have a bearing? Seems to make no difference to TTS.....
                            And updated, no difference
                              20.6.20
                              @catmanv2 I don't think it will make any difference. I'll try to replicate your setup later today or tomorrow. We'll definitely fix it 😉
                                20.6.20
                                @catmanv2
                                Any reason not to be using the latest openLuup version (from the development branch) ?
                                  For sure! I'm just glad I hadn't totally lost the plot ref log reporting 🙂
                                    @catmanv2
                                    #23
                                    @akbooer said in Openluup control of Alexa:
                                    @catmanv2
                                    None other than I wasn't keeping track of what was available!
                                    Now on 21.4.20 TYVM
                                      163.6k
