  3. Unexpected stop of openLuup
Set up: a) Many many many many kms from home: laptop connected to modem router. Router running wireguard client to create a virtual network. b) Home: modem router running wireguard server. openLuup pi4 connect to router and also a PC and other stuff, etc. The problem: When accessing charts, AltUI or the openLupp console the web pages are returned OK up to the point where they are truncated and therefore fail to display anything useful. Note this all works fine over short distances eg around a major city (I tested it) but not seemingly at world wide distances. ie network delays seem to be the issue here? Windows TeamViewer works fine overy the exact same network/wireguard set up. That's how I was able to get the openLuup logs shown below. Here is any example of openLuup trying to return a chart: 2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88 Re: socket.select() not ready to send Is there some sort of timeout I change; to see if this can make this work? Note that openLuup is still running everything flawlessly for ages now, including the more recent addtions of ZigBee stuff. Much appreciated.
Currently I have a Vera and Hue hub all reliably controlled by openLuup with AltUI, plus any number of plugins. Been working really well for a few years now. However would like to head for a more MQTT based set up. Eliminate the Hue hub and hopefully eliminate Vera by using ZWAVE JS UI. Noting that Zwavejs2mqtt has been renamed to Z-Wave JS UI. Probably also run the stuff using Docker. Just because. Everything would end up on the one computer for easier management. Erhhh that's the hope. Some of the new Zigbee Aqara stuff is very good and inexpensive plus it fits in with HomeKit. Also the Aqara battery powered stuff looks to have a good battery lifetime: ie suggested up to five years. The battery operated Hue buttons I have; have lasted for ages. Would like to use zigbee2mqtt with a SonOff dongle, which would allow access to the over two and half thousand devices zigbee2mqtt now supports: https://www.zigbee2mqtt.io/supported-devices/ AK has the MQTT stuff working in openLuup. Have played around with it and it works well, as one would expect. Love the UDP to MQTT code. Shellys are great and also very inexpensive and they spit out & accept MQTT but I would prefer to stay away from WiFi. Not meshed and higher power consumption. Horses for courses. Now here's the query: Got about forty or more ZWave twin light switches, plus a few other ZWave bits & pieces such as blind controllers. Then there are the Hue devices on top of that. That's a lot of virtual devices to set up in openLuup. What's an appropriate way to do this? It seems there is no "auto magic bridge set up". Do I need to use say @therealdb's Virtual Devices plugin that supports MQTT or is there some other approach? I have to confess I still don't understand the master child approach in that plugin. Seems one light switch would have all the other light switches hanging off it? Helps Vera but not a problem with openLuup - why is that? Suspect AK's good coding beats Vera's? https://github.com/dbochicchio/vera-VirtualDevices Setting up manually say 100 virtual devices is a bit much to ask. I had a look at hacking the user_data.json file. Good approach till you see all the UIDs and the individually numbered ControlURL and EventURLs that need to be set up. I need some way of say of creating about 80 light switches in "No room" or in say the "ZWave upgrade" room. Or say some sort of code that could go through all my existing bridged ZWAVE devices in openLuup and create virtual devices for each one. I caould then use the openLuup console to name them and place them in their rooms: openLuup_IP_address:3480/console?page=devices_table At that point I could hack the user_data.json file to insert the MQTT topics fairly easily for each? Plus any other fine tuning needed. Then the old ZWave stuff could be swapped over to ZWAVE JS UI and all the virtual MQTT devices would be ready to go or am I dreaming? Then delete all the old Vera bridged stuff. I'm not too fussed about scene code and the like, as a I have all my code in one block, that is set up in the openLuup start up. It seems that with ZWay you can create all the ZWave device by doing some sort of interrogation of ZWay's API? Seems also to be the case with the Shelleys? So any ideas, suggestions or code snippets are welcome on how to move towards MQTT and in particular ZWAVE JS UI and zigbee2mqtt. I'm in no hurry as openLuup is performing nicely, with the old Vera handling all my ZWave devices.
Every now and then my openLuup stops responding. This is the LuaUPnP.log when it happens: 2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548 And then in syslog: Aug 20 15:00:11 username systemd[1]: openluup.service: Control process exited, code=exited status=7 Aug 20 15:00:11 username systemd[1]: openluup.service: Failed with result 'exit-code'.
21 Posts 5 Posters 12.3k Views 5 Watching
  • CrilleC Online
    CrilleC Online
    And then in syslog:
      I'm wonder if the first error messages you shown are simply the fact that you have MQTT Inspector running on an, essentially, unattended machine, and it just goes to sleep for a while... I know that this is exactly what mine does.
      I've become fairly convinced that these errors are something deep within the LuaSocket library. I've always have something like this from time to time, be it the HTTP server, or MQTT now, or other things. I doubt that this is directly related to your 'crash' (freeze?) but I wouldn't rule out a network issue.
      I've just reloaded my main openLuup instance (running on Synology Docker) for a system updata, and that's been rock solid for the last 50 days, which is not unusual for all the openLuup systems I used to run.
      CrilleC Online
      CrilleC Online
      @akbooer I'm having openLuup crashes too with similar log errors. The only thing I have noticed is that at 2 occasions when I rebooted my Ezlo Plus connected by Ezlo Bridge, openLuup have crashed shortly after. It does not do that every time but it's the only thing I've managed to correlate to the hangs. I've captured the logs before restarting openLuup, if they are of interest.
        Are you using VeraBridge in asynchronous mode?
        This doesn't sound like an MQTT issue, perhaps we should move this to a new thread.
        CrilleC 1 Reply Last reply
          CrilleC Online
          CrilleC Online
          @akbooer Perhaps the only thing related to MQTT is a lot of UNSUBSCRIBE before it crashes. I've created a new thread here
          I don't know if VeraBridge is running asynchronous, is that relevant too? You can answer in the new thread. Thank you.
            That rather looks as though it has run out of file handles (which are used for sockets as well.)
            • what machine is this running on?
            • can I see the complete Startup Log?
            • also, when running, the openLuup console Servers page.
              CrilleC Online
              CrilleC Online
              @akbooer It's running on a virtual Ubuntu 18.04 LTS server that also run Homebridge and MSR, therefore a lot of calls from 127.0.0.1.
              Startup log:
              2021-08-03 13:01:53.798   :: openLuup STARTUP :: /home/username/cmh-ludl
              2021-08-03 13:01:53.798   openLuup.init::        version 2021.06.14  @akbooer
              2021-08-03 13:01:53.822   openLuup.scheduler::   version 2021.03.19  @akbooer
              2021-08-03 13:01:53.852   openLuup.io::          version 2021.03.27  @akbooer
              2021-08-03 13:01:53.852   openLuup.mqtt::        version 2021.06.08  @akbooer
              2021-08-03 13:01:53.853   openLuup.wsapi::       version 2019.08.12  @akbooer
              2021-08-03 13:01:53.854   openLuup.servlet::     version 2021.04.30  @akbooer
              2021-08-03 13:01:53.854   openLuup.client::      version 2019.10.14  @akbooer
              2021-08-03 13:01:53.854   openLuup.server::      version 2020.03.26  @akbooer
              2021-08-03 13:01:53.857   openLuup.scenes::      version 2021.06.02  @akbooer
              2021-08-03 13:01:53.863   openLuup.chdev::       version 2021.05.04  @akbooer
              2021-08-03 13:01:53.863   openLuup.userdata::    version 2021.04.30  @akbooer
              2021-08-03 13:01:53.863   openLuup.requests::    version 2021.02.20  @akbooer
              2021-08-03 13:01:53.863   openLuup.gateway::     version 2021.05.08  @akbooer
              2021-08-03 13:01:53.866   openLuup.smtp::        version 2018.04.12  @akbooer
              2021-08-03 13:01:53.893   openLuup.historian::   version 2021.06.12  @akbooer
              2021-08-03 13:01:53.893   openLuup.luup::        version 2021.05.14  @akbooer
              2021-08-03 13:01:53.894   openLuup.pop3::        version 2018.04.23  @akbooer
              2021-08-03 13:01:53.895   openLuup.compression:: version 2016.06.30  @akbooer
              2021-08-03 13:01:53.895   openLuup.timers::      version 2021.05.23  @akbooer
              2021-08-03 13:01:53.895   openLuup.logs::        version 2018.03.25  @akbooer
              2021-08-03 13:01:53.895   openLuup.json::        version Cjson (2.1.0) + openLuup (2021.05.01)  @akbooer
              2021-08-03 13:01:53.929   luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
              2021-08-03 13:01:53.935   luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json   (openLuup)
              2021-08-03 13:01:53.935   openLuup.init:: loading configuration user_data.json
              2021-08-03 13:01:53.942   openLuup.userdata:: loading user_data json...
              2021-08-03 13:01:53.951   luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
              2021-08-03 13:01:53.951   openLuup.userdata:: loading rooms...
              2021-08-03 13:01:53.951   openLuup.userdata:: room#1 'MiOS-XXXXXX'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#4 'Källaren'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#5 'Sovrummet'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#6 'Vera sensorer'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#7 'Datarummet'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#8 'Z - Virtual'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#9 'Hela huset'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#10 'Köket'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#11 'Vardagsrummet'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#12 'Milias rum'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#13 'Hallen'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#14 'Ezlo-90000XXX'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#15 'Baksidan (Ute)'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#16 'Tasmota'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#101 'Room 101'
              2021-08-03 13:01:53.951   openLuup.userdata:: room#17 'Växthuset'
              2021-08-03 13:01:53.951   openLuup.userdata:: ...room loading completed
              2021-08-03 13:01:53.951   openLuup.userdata:: loading devices...
              2021-08-03 13:01:53.952   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
              2021-08-03 13:01:54.100   openLuup.scheduler.sandbox:: device 3 defined 'string.starts' (a function value)
              2021-08-03 13:01:54.100   openLuup.scheduler.sandbox:: device 3 defined 'string.altui_split' (a function value)
              2021-08-03 13:01:54.100   openLuup.scheduler.sandbox:: device 3 defined 'string.template' (a function value)
              2021-08-03 13:01:54.100   openLuup.scheduler.sandbox:: device 3 defined 'string.trim' (a function value)
              2021-08-03 13:01:54.100   luup.create_device:: [3] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
              2021-08-03 13:01:54.104   luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json   (urn:schemas-upnp-org:device:AltAppStore:1)
              2021-08-03 13:01:54.110   luup.create_device:: [5] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json   (VeraBridge)
              2021-08-03 13:01:54.119   luup.create_device:: [9] D_EzloBridge.xml / I_EzloBridge.xml / D_EzloBridge.json   (urn:schemas-rboer-com:device:EzloBridge:1)
              2021-08-03 13:01:54.130   luup.create_device:: [10] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.221   luup.create_device:: [23] D_Homebridge2openluup1.xml / I_Homebridge2openluup1.xml / D_Homebridge2openluup1.json   (urn:schemas-ctrlable-com:device:Homebridge2openluup1:1)
              2021-08-03 13:01:54.223   luup.create_device:: [28] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.225   luup.create_device:: [29] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.310   luup.create_device:: [33] D_HVAC_ZoneThermostat1.xml /  / D_HVAC_ZoneThermostat1.json   (urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1)
              2021-08-03 13:01:54.312   luup.create_device:: [34] D_HVAC_ZoneThermostat1.xml /  / D_HVAC_ZoneThermostat1.json   (urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1)
              2021-08-03 13:01:54.315   luup.create_device:: [35] D_TasmotaBridge.xml / I_TasmotaBridge.xml / D_TasmotaBridge.json   (TasmotaBridge)
              2021-08-03 13:01:54.332   luup.create_device:: [37] D_VirtualSensor1.xml / I_VirtualSensor1.xml / D_VirtualSensor1.json   (urn:schemas-toggledbits-com:device:VirtualSensor:1)
              2021-08-03 13:01:54.334   luup.create_device:: [38] D_TemperatureSensor1.xml /  / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.335   luup.create_device:: [39] D_TemperatureSensor1.xml /  / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.336   luup.create_device:: [40] D_HumiditySensor1.xml /  / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.338   luup.create_device:: [42] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.340   luup.create_device:: [43] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.342   luup.create_device:: [44] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.344   luup.create_device:: [45] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.346   luup.create_device:: [46] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.348   luup.create_device:: [47] D_VirtualBinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.374   luup.create_device:: [51] D_SiteSensor1.xml / I_SiteSensor1.xml / D_SiteSensor1.json   (urn:schemas-toggledbits-com:device:SiteSensor:1)
              2021-08-03 13:01:54.375   luup.create_device:: [52] D_HumiditySensor1.xml /  / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.381   luup.create_device:: [10002] D_ZigbeeNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZigbeeNetwork:1)
              2021-08-03 13:01:54.384   luup.create_device:: [10003] D_BluetoothNetwork.xml / X /    (urn:schemas-micasaverde-com:device:BluetoothNetwork:1)
              2021-08-03 13:01:54.388   luup.create_device:: [10004] D_LPRFNetwork.xml / X /    (urn:schemas-micasaverde-com:device:LPRFNetwork:1)
              2021-08-03 13:01:54.391   luup.create_device:: [10005] D_SceneController1.xml / X / D_SceneController1.json   (urn:schemas-micasaverde-com:device:SceneController:1)
              2021-08-03 13:01:54.395   luup.create_device:: [10006] D_G550Siren.xml / X / D_G550Siren1.json   (urn:schemas-micasaverde-com:device:G550Siren:1)
              2021-08-03 13:01:54.406   luup.create_device:: [10016] D_GarageDoorLock.xml / X / D_DoorLock1.json   (urn:schemas-micasaverde-com:device:DoorLock:1)
              2021-08-03 13:01:54.413   luup.create_device:: [10027] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.415   luup.create_device:: [10028] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.415   luup.create_device:: [10032] D_GarageDoorLock.xml / X / D_DoorLock1.json   (urn:schemas-micasaverde-com:device:DoorLock:1)
              2021-08-03 13:01:54.416   luup.create_device:: [10046] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.417   luup.create_device:: [10047] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.418   luup.create_device:: [10048] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.584   luup.create_device:: [10050] D_HouseModes.xml / X / D_HouseModes.json   (urn:schemas-micasaverde-com:device:HouseModes:1)
              2021-08-03 13:01:54.584   luup.create_device:: [10064] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.585   luup.create_device:: [10065] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.586   luup.create_device:: [10068] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.588   luup.create_device:: [10069] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.589   luup.create_device:: [10070] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.590   luup.create_device:: [10071] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.591   luup.create_device:: [10076] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.592   luup.create_device:: [10086] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.676   luup.create_device:: [10093] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.678   luup.create_device:: [10094] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
              2021-08-03 13:01:54.680   luup.create_device:: [10095] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
              2021-08-03 13:01:54.681   luup.create_device:: [10096] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
              2021-08-03 13:01:54.682   luup.create_device:: [10097] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
              2021-08-03 13:01:54.683   luup.create_device:: [10098] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
              2021-08-03 13:01:54.684   luup.create_device:: [10099] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
              2021-08-03 13:01:54.685   luup.create_device:: [10100] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.686   luup.create_device:: [10104] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
              2021-08-03 13:01:54.687   luup.create_device:: [10105] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
              2021-08-03 13:01:54.688   luup.create_device:: [10106] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
              2021-08-03 13:01:54.689   luup.create_device:: [10107] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
              2021-08-03 13:01:54.690   luup.create_device:: [10109] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
              2021-08-03 13:01:54.691   luup.create_device:: [10110] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
              2021-08-03 13:01:54.692   luup.create_device:: [10111] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.766   luup.create_device:: [10112] D_Keypad1.xml / X / D_Keypad_Wintop.json   (urn:schemas-micasaverde-com:device:Keypad:1)
              2021-08-03 13:01:54.768   luup.create_device:: [10113] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.770   luup.create_device:: [10115] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.771   luup.create_device:: [10116] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.772   luup.create_device:: [10127] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.773   luup.create_device:: [10129] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.774   luup.create_device:: [10130] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.864   luup.create_device:: [10131] D_MotionSensor1.xml / X / D_GlassBreakSensorWithTamper.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
              2021-08-03 13:01:54.865   luup.create_device:: [10132] D_MotionSensor1.xml / X / D_GlassBreakSensorWithTamper.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
              2021-08-03 13:01:54.865   luup.create_device:: [10133] D_MotionSensor1.xml / X / D_GlassBreakSensorWithTamper.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
              2021-08-03 13:01:54.866   luup.create_device:: [10149] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.868   luup.create_device:: [10162] D_PowerMeter1.xml / X / D_PowerMeter1.json   (urn:schemas-micasaverde-com:device:PowerMeter:1)
              2021-08-03 13:01:54.870   luup.create_device:: [10163] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
              2021-08-03 13:01:54.872   luup.create_device:: [10165] D_SmokeSensor1.xml / X / D_SmokeSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:SmokeSensor:1)
              2021-08-03 13:01:54.874   luup.create_device:: [10166] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.960   luup.create_device:: [10167] D_DimmableLight1.xml / X / D_DimmableLightQD1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.962   luup.create_device:: [10168] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.963   luup.create_device:: [10184] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.964   luup.create_device:: [10185] D_VirtualBinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
              2021-08-03 13:01:54.965   luup.create_device:: [10187] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.967   luup.create_device:: [10188] D_ComboDevice1.xml / X / D_ComboDevice1.json   (urn:schemas-micasaverde-com:device:ComboDevice:1)
              2021-08-03 13:01:54.968   luup.create_device:: [10189] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.969   luup.create_device:: [10190] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.970   luup.create_device:: [10191] D_Siren1.xml / X / D_Siren1.json   (urn:schemas-micasaverde-com:device:Siren:1)
              2021-08-03 13:01:54.971   luup.create_device:: [10192] D_Siren1.xml / X / D_Siren1.json   (urn:schemas-micasaverde-com:device:Siren:1)
              2021-08-03 13:01:54.973   luup.create_device:: [10199] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.974   luup.create_device:: [10200] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.975   luup.create_device:: [10215] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.976   luup.create_device:: [10216] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.977   luup.create_device:: [10217] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
              2021-08-03 13:01:54.979   luup.create_device:: [10218] D_VirtualMotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:SmokeSensor:1)
              2021-08-03 13:01:54.980   luup.create_device:: [10219] D_VirtualMotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:SmokeSensor:1)
              2021-08-03 13:01:54.981   luup.create_device:: [10220] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.981   luup.create_device:: [10221] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.982   luup.create_device:: [10222] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
              2021-08-03 13:01:54.983   luup.create_device:: [10223] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
              2021-08-03 13:01:54.984   luup.create_device:: [20004] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
              2021-08-03 13:01:54.985   luup.create_device:: [20005] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.986   luup.create_device:: [20006] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
              2021-08-03 13:01:54.987   luup.create_device:: [20007] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.988   luup.create_device:: [20008] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.989   luup.create_device:: [20009] D_DimmableLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.990   luup.create_device:: [20010] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
              2021-08-03 13:01:54.991   luup.create_device:: [20011] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.992   luup.create_device:: [20012] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.993   luup.create_device:: [20013] D_MotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
              2021-08-03 13:01:54.994   luup.create_device:: [20014] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.995   luup.create_device:: [20015] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:54.996   luup.create_device:: [20016] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.997   luup.create_device:: [20018] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:54.999   luup.create_device:: [20019] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.000   luup.create_device:: [20020] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.000   luup.create_device:: [20021] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
              2021-08-03 13:01:55.002   luup.create_device:: [20022] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.003   luup.create_device:: [20024] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.005   luup.create_device:: [20025] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.006   luup.create_device:: [20026] D_MotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
              2021-08-03 13:01:55.007   luup.create_device:: [20029] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.008   luup.create_device:: [20030] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.009   luup.create_device:: [20031] D_DimmableLight1.xml / X / D_DimmableLight1.json   (urn:schemas-upnp-org:device:DimmableLight:1)
              2021-08-03 13:01:55.010   luup.create_device:: [30001] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.010   luup.create_device:: [30003] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.010   luup.create_device:: [30004] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.011   luup.create_device:: [30005] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.011   luup.create_device:: [30006] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.011   luup.create_device:: [30007] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.012   luup.create_device:: [30008] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.012   luup.create_device:: [30009] D_GenericTasmotaDevice.xml /  / D_GenericTasmotaDevice.json   (GenericTasmotaDevice)
              2021-08-03 13:01:55.012   openLuup.userdata:: loading scenes...
              2021-08-03 13:01:55.012   openLuup.userdata:: [11] Dimma upp Sovrum Taklampa
              2021-08-03 13:01:55.012   openLuup.userdata:: [10] Dimma ned Sovrummet
              2021-08-03 13:01:55.012   openLuup.userdata:: [9] Dimma upp Milias  rum
              2021-08-03 13:01:55.012   openLuup.userdata:: number of scenes = 3
              2021-08-03 13:01:55.012   openLuup.userdata:: ...scene loading completed
              2021-08-03 13:01:55.012   openLuup.userdata:: loading installed plugin info...
              2021-08-03 13:01:55.013   openLuup.userdata:: [openLuup] openLuup (21.7.25)
              2021-08-03 13:01:55.013   openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
              2021-08-03 13:01:55.013   openLuup.userdata:: [VeraBridge] VeraBridge (21.1.3)
              2021-08-03 13:01:55.013   openLuup.userdata:: [8246] Alternate UI (2.53c.)
              2021-08-03 13:01:55.013   openLuup.userdata:: [Z-Way] Z-Way (not.installed)
              2021-08-03 13:01:55.013   openLuup.userdata:: [Arduino] MySensors (not.installed)
              2021-08-03 13:01:55.013   openLuup.userdata:: [9314] Ezlo Bridge (GitHub.master)
              2021-08-03 13:01:55.013   openLuup.userdata:: [9281] Virtual HTTP Devices (GitHub.master)
              2021-08-03 13:01:55.013   openLuup.userdata:: [9031] Virtual Sensor (1.11)
              2021-08-03 13:01:55.013   openLuup.userdata:: [8942] SiteSensor (1.15)
              2021-08-03 13:01:55.013   openLuup.userdata:: ...user_data loading completed
              2021-08-03 13:01:55.013   openLuup.init:: running _openLuup_STARTUP_
              2021-08-03 13:01:55.013   luup_log:0: MagicShowerFan: Function loaded successfully.
              2021-08-03 13:01:55.013   luup_log:0: MagicShowerFan: Starting to monitor showers...
              2021-08-03 13:01:55.013   luup.variable_watch:: callback=MagicShowerFan, watching=10190.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel
              2021-08-03 13:01:55.013   luup.variable_watch:: callback=MagicShowerFan, watching=20008.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel
              2021-08-03 13:01:55.013   openLuup.init:: init phase completed
              2021-08-03 13:01:55.013   :: openLuup LOG ROTATION :: (runtime 0.0 days)
              Server console page:
              Server sockets watched for incoming connections
              #	date / time	device	socket
              1	2021-08-20 20:15:52	0	HTTP:3480 tcp{client}: 0x55bab90e01a8
              2	2021-08-20 20:15:52	0	HTTP:3480 tcp{client}: 0x55bab9d0b718
              3	2021-08-20 20:15:52	0	HTTP:3480 tcp{client}: 0x55bab8de9968
              4	2021-08-20 20:15:52	0	HTTP:3480 tcp{client}: 0x55bab9cce768
              5	2021-08-20 20:15:52	0	HTTP:3480 tcp{client}: 0x55bab9dda538
              6	2021-08-20 20:15:52	0	HTTP:3480 tcp{client}: 0x55bab9856bb8
              7	2021-08-20 20:15:43	0	HTTP:3480 tcp{client}: 0x55bab9ecaa58
              8	2021-08-20 20:15:21	0	HTTP:3480 tcp{client}: 0x55bab8d74018
              9	2021-08-20 20:04:16	0	HTTP:3480 tcp{client}: 0x55bab9aaf008
              10	2021-08-20 20:00:15	0	HTTP:3480 tcp{client}: 0x55bab9863d48
              11	2021-08-20 17:59:58	0	MQTT:1888 tcp{client}: 0x55bab8c24e48
              12	2021-08-20 17:25:37	0	HTTP:3480 tcp{client}: 0x55bab8c3b128
              13	2021-08-20 15:13:23	0	MQTT:1888 tcp{client}: 0x55bab90d5438
              14	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8bdb198
              15	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f9d898
              16	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab86e7f58
              17	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8e87328
              18	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8c69918
              19	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8839b78
              20	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f0fa38
              21	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8bc3808
              22	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8df8c48
              23	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fe2c88
              24	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fc8938
              25	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fc0fe8
              26	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8d39d68
              27	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fd0288
              28	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f20f68
              29	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f52ee8
              30	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f3b908
              31	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab7fd7868
              32	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab7fdbf88
              33	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8d5eb58
              34	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8ee8998
              35	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8c31438
              36	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fd72b8
              37	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fe6558
              38	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fdec08
              39	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8647ca8
              40	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f1da88
              41	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8c0a7d8
              42	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8d3e718
              43	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f33728
              44	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8ec3eb8
              45	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8bc9118
              46	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8ebc6c8
              47	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f03d38
              48	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f0ad28
              49	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8f087d8
              50	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8efcd78
              51	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8efa858
              52	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fdb8f8
              53	2021-08-20 15:12:18	0	MQTT:1888 tcp{client}: 0x55bab8fff8f8
              54	2021-08-20 15:12:10	0	MQTT:1888 tcp{server}: 0x55bab8a09878
              55	2021-08-20 15:12:10	0	POP3 tcp{server}: 0x55bab89f0b58
              56	2021-08-20 15:12:10	0	SMTP tcp{server}: 0x55bab89edbf8
              57	2021-08-20 15:12:10	0	HTTP:3480 tcp{server}: 0x55bab89eb0b8
              Received connections
              server	date / time	#connects	from IP
              HTTP	2021-08-20 20:15:52	22187	127.0.0.1
              HTTP	2021-08-20 20:15:21	19	192.168.1.240
              HTTP	2021-08-20 20:04:16	4	192.168.1.3
              SMTP		0
              POP3		0
              UDP		0
              MQTT	2021-08-20 15:12:18	1	192.168.1.63
              MQTT	2021-08-20 15:12:18	1	192.168.1.62
              MQTT	2021-08-20 17:59:58	4	192.168.1.66
              MQTT	2021-08-20 15:12:18	1	192.168.1.61
              MQTT	2021-08-20 15:12:18	35	127.0.0.1
              MQTT	2021-08-20 15:13:23	1	192.168.1.65
              MQTT	2021-08-20 15:12:18	1	192.168.1.64
              MQTT	2021-08-20 15:12:18	1	192.168.1.59
              • CrilleC Crille
                @crille said in Unexpected stop of openLuup:
                Yes, it's relevant. Synchronous polling takes a lot of time out from other things.
                Check the VeraBridge variable AsyncPoll, if it's not set to true then you should try doing so (and reloading.)
                CrilleC A 3 Replies Last reply
                  CrilleC Online
                  CrilleC Online
                  @akbooer Ok. Thanks ,I changed it to true (was at, I guess default, false) and reloaded. Let’s hope that do good to the system.
                  I still always get errors after a reload though.
                  2021-08-20 23:44:09.048   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b0530b79b8
                  2021-08-20 23:44:09.049   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b0533b7bc8
                  2021-08-20 23:44:09.300   openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55b0526b00d8' sending 2 bytes to tcp{client}: 0x55b0526b00d8
                    ArcherS
                    @akbooer I join in here since I have had some similar problems.
                    My Zway bridge has been running in asyc mode for long, however I checked my Vera bridge and it was not. I have changed it, but since I have no devices left on the Vera I thought that I just as well should remove it from OpenLuup to unload it a bit.
                    What is the best way of doing that? Just to delete the brigde device in OpenLuup and reload?
                      Yup, just that.
                        Yup, just that.
                        ArcherS
                        Today I got a new crash. This time in the middle of the day. OpenLuup was not doing anything specific, I was not doing anything with it, no irregular cpu load (approx 3.6%). No errors in the log before what is shown below. Mqtt Explorer was not on either, so regular load there as well. (This was also before I tried with Mqtt from Home Assistant to OpenLuup, as described in another thread.)
                        I discovered a few hours later that the server had crashed. When checking the logs this is what I could see:
                        2021-09-17 11:04:36.136   openLuup.io.server:: MQTT:1883 connection from 192.168.1.144 tcp{client}: 0x29b5f80
                        2021-09-17 11:04:36.136   openLuup.io.server:: MQTT:1883 connection from 192.168.1.66 tcp{client}: 0x3136a28
                        2021-09-17 11:04:36.136   openLuup.io.server:: MQTT:1883 connection from 192.168.1.59 tcp{client}: 0x30932b0
                        2021-09-17 11:04:36.137   openLuup.io.server:: MQTT:1883 connection from 192.168.1.52 tcp{client}: 0x3671eb8
                        2021-09-17 11:04:36.137   openLuup.io.server:: MQTT:1883 connection from 192.168.1.51 tcp{client}: 0x3506688
                        2021-09-17 11:04:36.137   openLuup.io.server:: MQTT:1883 connection from 192.168.1.58 tcp{client}: 0x3005fa8
                        2021-09-17 11:04:36.182   luup.variable_set:: 144.urn:toggledbits-com:serviceId:ReactorValues.SpabadCut was: 349 now: 345 #hooks:1
                        2021-09-17 11:04:36.190   luup.variable_set:: 144.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"cond0":{"evaledge":[],"stateedge":[],"valuestamp":1631631832,"id":"cond0","statestamp":0,"lastvalue":0},"root":{"... now: {"cond0":{"evaledge":[],"stateedge":[],"valuestamp":1631631832,"id":"cond0","statestamp":0,"lastvalue":0},"root":{"... #hooks:0
                        2021-09-17 11:04:36.191   luup.variable_set:: 144.urn:toggledbits-com:serviceId:ReactorSensor.lastacc was: 1631869442 now: 1631869476 #hooks:0
                        2021-09-17 11:04:36.191   luup.variable_set:: 144.urn:toggledbits-com:serviceId:ReactorGroup.GroupStatus_grp1b0eboj1 was: 1 now: 0 #hooks:0
                        2021-09-17 11:04:36.191   luup.variable_set:: 144.urn:toggledbits-com:serviceId:ReactorSensor.Message was: Not tripped now: Not tripped #hooks:0
                        2021-09-17 11:04:36.194   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x2a6a020
                        2021-09-17 11:04:36.195   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x2a6a020
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaFriggebod UNSUBSCRIBE from cmnd/TasmotaFriggebod_fb/# tcp{client}: 0x2a6a020
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaFriggebod UNSUBSCRIBE from cmnd/TasmotaFriggebod/# tcp{client}: 0x2a6a020
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaFriggebod UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x2a6a020
                        2021-09-17 11:04:36.195   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x2978900
                        2021-09-17 11:04:36.195   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x2978900
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaSjo UNSUBSCRIBE from cmnd/TasmotaSjo_fb/# tcp{client}: 0x2978900
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaSjo UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x2978900
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaSjo UNSUBSCRIBE from cmnd/Tasmota_Sjo/# tcp{client}: 0x2978900
                        2021-09-17 11:04:36.195   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x2c12be0
                        2021-09-17 11:04:36.195   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x2c12be0
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaIR UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x2c12be0
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaIR UNSUBSCRIBE from cmnd/TasmotaIR_fb/# tcp{client}: 0x2c12be0
                        2021-09-17 11:04:36.195   openLuup.mqtt:: TasmotaIR UNSUBSCRIBE from cmnd/TasmotaIR/# tcp{client}: 0x2c12be0
                        2021-09-17 11:04:36.210   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x30c6558
                        2021-09-17 11:04:36.210   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x30c6558
                        2021-09-17 11:04:36.210   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x395fb70
                        2021-09-17 11:04:36.210   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x395fb70
                        2021-09-17 11:04:36.210   openLuup.mqtt:: TasmotaGarage UNSUBSCRIBE from cmnd/TasmotaGarage_fb/# tcp{client}: 0x395fb70
                        2021-09-17 11:04:36.210   openLuup.mqtt:: TasmotaGarage UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x395fb70
                        2021-09-17 11:04:36.210   openLuup.mqtt:: TasmotaGarage UNSUBSCRIBE from cmnd/TasmotaGarage/# tcp{client}: 0x395fb70
                        2021-09-17 11:04:36.219   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x29b5f80
                        2021-09-17 11:04:36.219   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x29b5f80
                        2021-09-17 11:04:36.219   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x3136a28
                        2021-09-17 11:04:36.219   openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x3136a28
                        2021-09-17 11:04:36.223   luup.watch_callback:: 20013.MHZ19B.CarbonDioxide called [9]virtualSensorWatchCallback() function: 0x263bea8
                        2021-09-17 11:04:36.243   openLuup.io.server:: MQTT:1883 connection closed  tcp{client}: 0x2b7aff8
                        2021-09-17 11:04:36.243   openLuup.mqtt:: closed tcp{client}: 0x2b7aff8
                        2021-09-17 11:04:36.243   openLuup.mqtt:: TasmotaCO2Brandv UNSUBSCRIBE from cmnd/TasmotaCO2Brandv/# tcp{client}: 0x2b7aff8
                        2021-09-17 11:04:36.243   openLuup.mqtt:: TasmotaCO2Brandv UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x2b7aff8
                        2021-09-17 11:04:36.243   openLuup.mqtt:: TasmotaCO2Brandv UNSUBSCRIBE from cmnd/TasmotaCO2Brandv_fb/# tcp{client}: 0x2b7aff8
                        2021-09-17 11:04:36.243   openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/TasmotaCO2Brandv/POWER : closed
                        I am seeing a number of Mqtt connections almost at the same time and then some unsubscribe and receive errors and then just a crash.
                        I have had not crashes for >25 days, so a bit strange.
                        The only change I can think of that I made a day ago was that I added a Reactor that fetches data from a site parses it and sends it to Thingspeak by making two "http get" actions to get data from energyhive.com and then two:
                        os.execute( "curl -s -i -H 'Accept:application/json' 'https://api.thingspeak.com/update?api_key=key&field1='" .. result)
                        Both actions were running every minute. I have now removed one of the "http get" and curl commands, and also run this every second minute instead. The Reactor is what is shown in the beginning of the log btw.
                        Maybe this is something that puts a lot of load on the Lua sockets of something? I will disable it and see.
                        Any ideas around this would be welcome. 🙂
                          CrilleC Online
                          CrilleC Online
                          @akbooer I'm still having a lot of crashes but since I added an autorestart of the service it's not really a major problem anymore.
                          Even though openLuup is rock solid for most people, may I suggest you add
                          [Service]
                          Restart=on-failure
                          RestartSec=5s
                          To the documentation for openLuup in the appendix for systemd?
                          At least it helped me not coming home to a dead house 🙂
                          • CrilleC Crille
                            [Service]
                            Restart=on-failure
                            RestartSec=5s
                            ArcherS
                            @crille thanks for the suggestion! I have added this on my system.
                            • D Offline
                              D Offline
                              Donato
                              wrote on last edited by Donato
                              Hi akbooer,
                              randomly openluup hangs but today I noticed in the log (attached) something strange :
                              2022-08-13 12:54:35.283 openLuup.server:: GET /data_request?id=lr_render&target=Vera-45108342.024.urn:upnp-org:serviceId:VContainer1.Variable3&from=2022-08-13T00:00&format=json HTTP/1.1 tcp{client}: 0x556c471741f8
                              2022-08-13 12:54:35.286 luup_log:4: DataGraph: Whisper query: CPU = 2.068 mS for 775 points
                              2022-08-13 12:54:35.289 openLuup.server:: request completed (20282 bytes, 2 chunks, 6 ms) tcp{client}: 0x556c471741f8
                              2022-08-13 12:54:35.290 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x556c471741f8
                              2022-08-13 12:54:57.889 openLuup.io.server:: HTTP:3480 connection from 92.255.85.183 tcp{client}: 0x556c482cf138
                              2022-08-13 12:54:57.889 openLuup.server:: /*: mstshash=Administr tcp{client}: 0x556c482cf138
                              2022-08-13 12:54:57.889 openLuup.context_switch:: ERROR: [dev #0] ./openLuup/server.lua:238: attempt to concatenate local 'method' (a nil value)
                              2022-08-13 12:54:57.889 luup.incoming_callback:: function: 0x556c4753ff20 ERROR: ./openLuup/server.lua:238: attempt to concatenate local 'method' (a nil value)
                              at 12:54 openluup stopped to write and read the datayours files
                              Is a possible attack ?
                                Looks like an attack, from what I read online.
                                • D Offline
                                  D Offline
                                  Donato
                                  Hi akbooer,
                                  in order to set firewall rules can you give me some info on the openluup log records ? Following there are few normal log lines of datayours read/write :
                                  2022-08-13 12:52:21.921 luup.variable_set:: 4.urn:akbooer-com:serviceId:DataYours1.AppMemoryUsed was: 6568 now: 6871 #hooks:0
                                  2022-08-13 12:52:26.570 openLuup.io.server:: HTTP:3480 connection from xx.xx.xx.xx tcp{client}: 0x556c474b0348
                                  2022-08-13 12:52:26.571 openLuup.server:: GET /data_request?id=lr_render&target=Vera-yyyyyyyy.024.urn:upnp-org:serviceId:VContainer1.Variable3&from=-2h&format=json HTTP/1.1 tcp{client}: 0x556c474b0348
                                  2022-08-13 12:52:26.571 luup_log:4: DataGraph: Whisper query: CPU = 0.405 mS for 121 points
                                  2022-08-13 12:52:26.572 openLuup.server:: request completed (3359 bytes, 1 chunks, 1 ms) tcp{client}: 0x556c474b0348
                                  2022-08-13 12:52:26.572 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x556c474b0348
                                  2022-08-13 12:52:26.574 openLuup.io.server:: HTTP:3480 connection from xx.xx.xx.xx tcp{client}: 0x556c47810548
                                  2022-08-13 12:52:26.574 openLuup.server:: GET /data_request?id=lr_render&target=Vera-yyyyyyyy.024.urn:upnp-org:serviceId:VContainer1.Variable3&from=2022-08-13T00:00&format=json HTTP/1.1 tcp{client}: 0x556c47810548
                                  2022-08-13 12:52:26.576 luup_log:4: DataGraph: Whisper query: CPU = 2.085 mS for 773 points
                                  2022-08-13 12:52:26.580 openLuup.server:: request completed (20228 bytes, 2 chunks, 6 ms) tcp{client}: 0x556c47810548
                                  2022-08-13 12:52:26.581 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x556c47810548
                                  2022-08-13 12:52:35.363 openLuup.io.server:: HTTP:3480 connection from xx.xx.xx.xx tcp{client}: 0x556c4756a4b8
                                  2022-08-13 12:52:35.364 openLuup.server:: GET /data_request?id=lr_render&target=Vera-yyyyyyyy.024.urn:upnp-org:serviceId:VContainer1.Variable3&from=-2h&format=json HTTP/1.1 tcp{client}: 0x556c4756a4b8
                                  2022-08-13 12:52:35.364 luup_log:4: DataGraph: Whisper query: CPU = 0.418 mS for 121 points
                                  2022-08-13 12:52:35.366 openLuup.server:: request completed (3359 bytes, 1 chunks, 1 ms) tcp{client}: 0x556c4756a4b8
                                  2022-08-13 12:52:35.366 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x556c4756a4b8
                                  2022-08-13 12:52:35.368 openLuup.io.server:: HTTP:3480 connection from xx.xx.xx.xx tcp{client}: 0x556c47294958
                                  2022-08-13 12:52:35.368 openLuup.server:: GET /data_request?id=lr_render&target=Vera-yyyyyyyy.024.urn:upnp-org:serviceId:VContainer1.kwdaily3&from=2016-07-01&format=json HTTP/1.1 tcp{client}: 0x556c47294958
                                  2022-08-13 12:52:35.375 luup_log:4: DataGraph: Whisper query: CPU = 6.521 mS for 2235 points
                                  2022-08-13 12:52:35.392 openLuup.server:: request completed (62445 bytes, 4 chunks, 23 ms) tcp{client}: 0x556c47294958
                                  2022-08-13 12:52:35.397 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x556c47294958
                                  2022-08-13 12:52:35.398 openLuup.io.server:: HTTP:3480 connection from xx.xx.xx.xx tcp{client}: 0x556c47158248
                                  2022-08-13 12:52:35.398 openLuup.server:: GET /data_request?id=lr_render&target=Vera-yyyyyyyy.024.urn:upnp-org:serviceId:VContainer1.Variable3&from=2022-08-13T00:00&format=json HTTP/1.1 tcp{client}: 0x556c47158248
                                  2022-08-13 12:52:35.401 luup_log:4: DataGraph: Whisper query: CPU = 2.409 mS for 773 points
                                  2022-08-13 12:52:35.406 openLuup.server:: request completed (20228 bytes, 2 chunks, 7 ms) tcp{client}: 0x556c47158248
                                  2022-08-13 12:52:35.406 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x556c47158248
                                  2022-08-13 12:53:26.581 openLuup.io.server:: HTTP:3480 connection from xx.xx.xx.xx tcp{client}: 0x556c4877f9d8
                                  2022-08-13 12:53:26.581 openLuup.server:: GET /data_request?id=lr_render&target=Vera-yyyyyyyy.024.urn:upnp-org:serviceId:VContainer1.Variable3&from=-2h&format=json HTTP/1.1 tcp{client}: 0x556c4877f9d8
                                  2022-08-13 12:53:26.582 luup_log:4: DataGraph: Whisper query: CPU = 0.735 mS for 121 points
                                  The read commands of whisper files are all of kind "http://server-ip:3480......."
                                  the following log record :
                                  is from a http read ?
                                  Can I see UDP write log record ?
                                  The write commands come from remote datayours through UDP to "server-ip" .
                                  All consolidated whisper files I read/write are on "server-ip".
                                  Is it correct in this scenario that all the regular and normal commands (read/write) must come from "server-ip" ?
                                  tnks
                                    If your system is exposed to the internet (which I assume it must be, given that IP address is in HK) have you considered either setting up some port forwarding, or, a VPN and locking it down to internal access only? Would seem simpler than trying to set up firewall rules, assuming your Datayours server is on the same LAN?
                                    I'm sure you have a good reason for your set up, just my $0.0002 worth 😉
                                      Yes, the server logs the initial HTTP connection, and the hex number at the end of the log line is an internal reference for the client socket. That same socket reference occurs at the end of the actual HTTP request line.
                                      IIRC, DataYours by default does not log UDP writes (because in many instances they would flood the log. I’d have to refer back to the source code to see if debug logging enables that.
                                      Agree with the comment on VPNs.
                                        @Donato
                                        This error:
                                        …is an error in my error reporting! I can fix this easily. The message should just report an unsupported HTTP request and then carry on as usual. I’ll post an update shortly.
                                        It still doesn’t address the issue that you’re receiving a request from someone/somewhere that you shouldn’t.
                                          OK, latest development version (v220814) should fix the error message.
                                            164.0k
