Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
MQTT – setup and use
@akbooer Wow, that was fast! Thanks, works like a charm.
May I bother you with my next issue? Every time I restart Homebridge my sensor values and current state of bridged devices are lost to mqttthing and shows 0 or OFF until there is an update from the device. Is there a way to retain the values from openLuup/update? -
In my own broker I have a Vera/VeraID/update message causing an update from the bridge on demand. I find it useful when subscribing from my windows app, so I get all the updates. It’s similar to what Shelly or tasmota is doing. Maybe it’s easier to implement than retained messages.
Thanks for that! I think the challenge in this case is that we are somewhat constrained by what the mqttthing is able to handle. It has some configurability, but I’m not sure whether we can use this approach. We will see.
I have a Shelly plug and a Tasmota sensor.
I installed the latest OpenLuup version (21.4.28c)
I have the Shelly and Tasmota bridges that appear automatically, but I don't have the child devices.
Error message in the logs:2021-04-29 15: 02: 20.795 openLuup.context_switch :: ERROR: [dev # 75] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 20.795 openLuup.mqtt :: ERROR publishing application message for mqtt: tele / piscine / SENSOR: ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.216 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.217 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / power: ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.219 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.219 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / energy: ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.221 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.221 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0: ./openLuup/api.lua:148: attempt to index field '? ' (a nil value) 2021-04-29 15: 02: 21.223 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.223 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.225 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.225 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature_f: ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.227 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 15: 02: 21.227 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / overtemperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
MQTT setting :
luup.attr_set ("openLuup.MQTT.Port", 1885) luup.attr_set ("openLuup.MQTT.Username", "*******") luup.attr_set ("openLuup.MQTT.Password", "*******") luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", "0") luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) -- publish every variable update luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", 2) -- publish a single device status every N seconds (0 = never)
Devices 75 et 76
21 2021-04-29 14:56:51.444 75 Done 0.000 21 plugin: Tasmota OK 22 2021-04-29 14:56:51.444 76 Done 0.000 22 plugin: Shelly OK
Context after StartLuup
2021-04-29 16:53:44.403 openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x184a658 2021-04-29 16:53:44.404 openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x184a658 2021-04-29 16:53:44.404 openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x184a658 2021-04-29 16:53:44.404 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.404 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.405 luup.shelly:76: New Shelly announced: shellyplug-s-20E453 2021-04-29 16:53:44.405 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.405 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.405 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.405 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.406 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.406 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.406 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.406 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.406 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.406 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.407 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.407 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.407 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.407 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.407 openLuup.context_switch:: ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.407 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value) 2021-04-29 16:53:44.661 openLuup.server:: request completed (515424 bytes, 33 chunks, 272 ms) tcp{client}: 0x22f6cf8
Thanks – that shows exactly what I needed to see. The first incoming message from the Shelly is not an announcement, so the device doesn't yet exist. I knew this happened, but thought I had handled the condition. A recent change has made it appear again. I'll work on it...
Okay
Thank you for your work that I am with interest -
Can you tell me what Shelly devices you are using here? Thanks.
Could you try the latest development version (21.4.29b) and see if that fixes the issue? Thanks.
Shelly Plug
I installed the last version but still the same problem
2021-04-29 20:31:35.495 openLuup.io.server:: MQTT:1885 connection from 192.168.1.149 tcp{client}: 0x1808020 2021-04-29 20:31:35.500 openLuup.server:: request completed (1304 bytes, 1 chunks, 6470 ms) tcp{client}: 0x1a2dc08 2021-04-29 20:31:35.515 openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x1808020 2021-04-29 20:31:35.516 openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x1808020 2021-04-29 20:31:35.517 openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x1808020 2021-04-29 20:31:35.518 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.518 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.519 luup.shelly:76: New Shelly announced: shellyplug-s-20E453 2021-04-29 20:31:35.520 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value) 2021-04-29 20:31:35.520 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value) 2021-04-29 20:31:35.521 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.521 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.522 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.522 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.523 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.524 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.525 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.525 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.526 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.526 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.527 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.527 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.528 openLuup.context_switch:: ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value) 2021-04-29 20:31:35.528 openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
logs/LuaUPnP_startup.log
178 lines, 1 error, max gap 0s @ 2021-04-30 08:45:58.9362021-04-30 08:45:57.409 :: openLuup STARTUP :: /etc/cmh-ludl 2021-04-30 08:45:57.409 openLuup.init:: version 2021.04.08 @akbooer 2021-04-30 08:45:57.437 openLuup.scheduler:: version 2021.03.19 @akbooer 2021-04-30 08:45:57.462 openLuup.io:: version 2021.03.27 @akbooer 2021-04-30 08:45:57.462 openLuup.mqtt:: version 2021.04.28b @akbooer 2021-04-30 08:45:57.464 openLuup.wsapi:: version 2019.08.12 @akbooer 2021-04-30 08:45:57.464 openLuup.servlet:: version 2021.04.28c @akbooer 2021-04-30 08:45:57.464 openLuup.client:: version 2019.10.14 @akbooer 2021-04-30 08:45:57.465 openLuup.server:: version 2020.03.26 @akbooer 2021-04-30 08:45:57.473 openLuup.scenes:: version 2021.04.28 @akbooer 2021-04-30 08:45:57.477 openLuup.chdev:: version 2020.21.27 @akbooer 2021-04-30 08:45:57.477 openLuup.userdata:: version 2021.03.14 @akbooer 2021-04-30 08:45:57.477 openLuup.requests:: version 2021.02.20 @akbooer 2021-04-30 08:45:57.478 openLuup.gateway:: version 2020.03.08 @akbooer 2021-04-30 08:45:57.481 openLuup.smtp:: version 2018.04.12 @akbooer 2021-04-30 08:45:57.485 openLuup.historian:: version 2021.02.03 @akbooer 2021-04-30 08:45:57.486 openLuup.luup:: version 2021.04.27 @akbooer 2021-04-30 08:45:57.487 openLuup.pop3:: version 2018.04.23 @akbooer 2021-04-30 08:45:57.488 openLuup.compression:: version 2016.06.30 @akbooer 2021-04-30 08:45:57.488 openLuup.timers:: version 2019.05.03 @akbooer 2021-04-30 08:45:57.488 openLuup.logs:: version 2018.03.25 @akbooer 2021-04-30 08:45:57.488 openLuup.json:: version 2020.05.20 @akbooer 2021-04-30 08:45:57.488 openLuup.init:: using openLuup.json.Lua.decode() for JSON decoding (Cjson not installed) 2021-04-30 08:45:57.545 luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1) 2021-04-30 08:45:57.561 luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json (openLuup) 2021-04-30 08:45:57.561 openLuup.init:: loading configuration user_data.json 2021-04-30 08:45:57.571 openLuup.userdata:: loading user_data json... 2021-04-30 08:45:57.846 luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0 2021-04-30 08:45:57.846 openLuup.userdata:: loading rooms... 2021-04-30 08:45:57.846 openLuup.userdata:: room#1 'MiOS-45003471' 2021-04-30 08:45:57.846 openLuup.userdata:: room#2 'VeraEdge_Exterieur' 2021-04-30 08:45:57.846 openLuup.userdata:: room#3 'VeraEdge_Essai' 2021-04-30 08:45:57.846 openLuup.userdata:: room#4 'VeraEdge_Température' 2021-04-30 08:45:57.846 openLuup.userdata:: room#5 'VeraEdge_Piscine' 2021-04-30 08:45:57.846 openLuup.userdata:: room#6 'VeraEdge_System' 2021-04-30 08:45:57.846 openLuup.userdata:: room#7 'VeraEdge_Securité' 2021-04-30 08:45:57.846 openLuup.userdata:: room#8 'ZWay-31415926' 2021-04-30 08:45:57.846 openLuup.userdata:: room#9 'OpenLuup' 2021-04-30 08:45:57.847 openLuup.userdata:: ...room loading completed 2021-04-30 08:45:57.847 openLuup.userdata:: loading devices... 2021-04-30 08:45:57.850 luup.create_device:: [1] D_ZWaveNetwork.xml / X / (urn:schemas-micasaverde-com:device:ZWaveNetwork:1) 2021-04-30 08:45:57.859 luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json (urn:schemas-upnp-org:device:AltAppStore:1) 2021-04-30 08:45:57.868 luup.create_device:: [5] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json (VeraBridge) 2021-04-30 08:45:57.903 luup.create_device:: [15] D_Switchboard1.xml / I_Switchboard1.xml / D_Switchboard1_UI7.json (urn:schemas-toggledbits-com:device:Switchboard:1) 2021-04-30 08:45:57.957 luup.create_device:: [18] D_Reactor.xml / I_Reactor.xml / D_Reactor_UI7.json (urn:schemas-toggledbits-com:device:Reactor:1) 2021-04-30 08:45:57.994 luup.create_device:: [19] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:57.999 luup.create_device:: [20] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.004 luup.create_device:: [25] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.110 openLuup.scheduler.sandbox:: device 26 defined 'string.starts' (a function value) 2021-04-30 08:45:58.110 openLuup.scheduler.sandbox:: device 26 defined 'string.altui_split' (a function value) 2021-04-30 08:45:58.110 openLuup.scheduler.sandbox:: device 26 defined 'string.template' (a function value) 2021-04-30 08:45:58.111 openLuup.scheduler.sandbox:: device 26 defined 'string.trim' (a function value) 2021-04-30 08:45:58.111 luup.create_device:: [26] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1) 2021-04-30 08:45:58.158 luup.create_device:: [27] D_VirtualSensor1.xml / I_VirtualSensor1.xml / D_VirtualSensor1.json (urn:schemas-toggledbits-com:device:VirtualSensor:1) 2021-04-30 08:45:58.165 luup.create_device:: [28] D_GenericSensor1.xml / / D_GenericSensor1.json (urn:schemas-micasaverde-com:device:GenericSensor:1) 2021-04-30 08:45:58.210 luup.create_device:: [29] D_MString.xml / I_MString.xml / D_MString.json (urn:schemas-upnp-org:device:VContainer:1) 2021-04-30 08:45:58.214 luup.create_device:: [32] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.219 luup.create_device:: [33] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.281 luup.create_device:: [35] D_ZWay.xml / I_ZWay2.xml / D_ZWay.json (ZWay) 2021-04-30 08:45:58.300 openLuup.scheduler.sandbox:: device 36 defined 'string.fliprsplit' (a function value) 2021-04-30 08:45:58.300 openLuup.scheduler.sandbox:: device 36 defined 'string.template' (a function value) 2021-04-30 08:45:58.300 openLuup.scheduler.sandbox:: device 36 defined 'string.trim' (a function value) 2021-04-30 08:45:58.301 luup.create_device:: [36] D_FLIPR.xml / I_FLIPR.xml / D_FLIPR_UI7.json (urn:schemas-upnp-org:device:flipr:1) 2021-04-30 08:45:58.319 luup.create_device:: [40] D_MString.xml / I_MString.xml / D_GenericSensor1_Ph.json (urn:schemas-upnp-org:device:VContainer:1) 2021-04-30 08:45:58.338 luup.create_device:: [41] D_MString.xml / I_MString.xml / D_GenericSensor1_mVolts.json (urn:schemas-upnp-org:device:VContainer:1) 2021-04-30 08:45:58.356 luup.create_device:: [42] D_MString.xml / I_MString.xml / D_GenericSensor1_Tpiscine.json (urn:schemas-upnp-org:device:VContainer:1) 2021-04-30 08:45:58.385 luup.create_device:: [46] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.407 luup.create_device:: [49] D_BinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.411 luup.create_device:: [50] D_ReactorSensor.xml / / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.425 luup.create_device:: [51] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.437 luup.create_device:: [54] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.450 luup.create_device:: [55] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.463 luup.create_device:: [56] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.480 luup.create_device:: [57] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.489 luup.register_handler:: global_function_name=Tasmota_MQTT_Handler, request=mqtt:tele/# 2021-04-30 08:45:58.489 luup.register_handler:: global_function_name=Tasmota_MQTT_Handler, request=mqtt:tasmota/tele/# 2021-04-30 08:45:58.490 luup.create_device:: [75] D_TasmotaBridge.xml / I_TasmotaBridge.xml / D_TasmotaBridge.json (TasmotaBridge) 2021-04-30 08:45:58.494 luup.register_handler:: global_function_name=Shelly_MQTT_Handler, request=mqtt:shellies/# 2021-04-30 08:45:58.494 luup.create_device:: [76] D_ShellyBridge.xml / I_ShellyBridge.xml / D_ShellyBridge.json (ShellyBridge) 2021-04-30 08:45:58.501 luup.create_device:: [10002] D_SceneController1.xml / X / D_SceneController1.json (urn:schemas-micasaverde-com:device:SceneController:1) 2021-04-30 08:45:58.505 luup.create_device:: [10003] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.509 luup.create_device:: [10006] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.513 luup.create_device:: [10012] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.522 luup.create_device:: [10016] D_InfoViewer1.xml / X / D_InfoViewer1.json (urn:schemas-a-lurker-com:device:InfoViewer:1) 2021-04-30 08:45:58.544 luup.create_device:: [10034] D_DeusExMachinaII1.xml / X / D_DeusExMachinaII1_UI7.json (urn:schemas-toggledbits-com:device:DeusExMachinaII:1) 2021-04-30 08:45:58.606 luup.create_device:: [10040] D_MiLightRGBWBOX2.xml / X / D_MiLightRGBW.json (urn:schemas-dcineco-com:device:DimmableLightRGBW:1) 2021-04-30 08:45:58.610 luup.create_device:: [10046] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.614 luup.create_device:: [10047] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.617 luup.create_device:: [10048] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.625 luup.create_device:: [10059] D_LuaView1.xml / X / D_LuaView1.json (urn:schemas-toggledbits-com:device:LuaView:1) 2021-04-30 08:45:58.643 luup.create_device:: [10060] D_ZiBlueGateway1.xml / X / D_ZiBlueGateway1.json (urn:schemas-upnp-org:device:ZiBlueGateway:1) 2021-04-30 08:45:58.644 luup.create_device:: [10061] D_SerialPortRoot1.xml / X / (urn:micasaverde-org:device:SerialPortRoot:1) 2021-04-30 08:45:58.654 luup.create_device:: [10062] D_SerialPort1.xml / X / (urn:micasaverde-org:device:SerialPort:1) 2021-04-30 08:45:58.659 luup.create_device:: [10069] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.664 luup.create_device:: [10070] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.667 luup.create_device:: [10071] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.669 luup.create_device:: [10072] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.672 luup.create_device:: [10075] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.675 luup.create_device:: [10076] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.683 luup.create_device:: [10082] D_DelayLight.xml / X / D_DelayLight_UI7.json (urn:schemas-toggledbits-com:device:DelayLight:1) 2021-04-30 08:45:58.695 luup.create_device:: [10089] D_WindSensor1.xml / X / D_WindSensor1.json (urn:schemas-micasaverde-com:device:WindSensor:1) 2021-04-30 08:45:58.698 luup.create_device:: [10095] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.718 luup.create_device:: [10097] D_VSwitch.xml / X / D_VSwitch_UI7.json (urn:schemas-upnp-org:device:VSwitch:1) 2021-04-30 08:45:58.723 luup.create_device:: [10099] D_VSwitch.xml / X / D_VSwitch_UI7.json (urn:schemas-upnp-org:device:VSwitch:1) 2021-04-30 08:45:58.726 luup.create_device:: [10102] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.730 luup.create_device:: [10103] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.733 luup.create_device:: [10104] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.735 luup.create_device:: [10105] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.738 luup.create_device:: [10106] D_Reactor.xml / X / D_Reactor_UI7.json (urn:schemas-toggledbits-com:device:Reactor:1) 2021-04-30 08:45:58.743 luup.create_device:: [10107] D_Switchboard1.xml / X / D_Switchboard1_UI7.json (urn:schemas-toggledbits-com:device:Switchboard:1) 2021-04-30 08:45:58.747 luup.create_device:: [10110] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.751 luup.create_device:: [10114] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.753 luup.create_device:: [10115] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.759 luup.create_device:: [10118] D_DoorSensor1.xml / X / D_DoorSensor1.json (urn:schemas-micasaverde-com:device:DoorSensor:1) 2021-04-30 08:45:58.761 luup.create_device:: [10124] D_SmartHomeHelper.xml / X / (urn:schemas-upnp-org:device:GoogleHome:1) 2021-04-30 08:45:58.767 luup.create_device:: [10131] D_MotionSensor1.xml / X / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1) 2021-04-30 08:45:58.774 luup.create_device:: [10132] D_LightSensor1.xml / X / D_LightSensor1.json (urn:schemas-micasaverde-com:device:LightSensor:1) 2021-04-30 08:45:58.778 luup.create_device:: [10133] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.784 luup.create_device:: [10138] D_GenericIO1.xml / X / D_GenericIO1.json (urn:schemas-micasaverde-com:device:GenericIO:1) 2021-04-30 08:45:58.788 luup.create_device:: [10139] D_MotionSensor1.xml / X / D_MotionSensor1.json (urn:schemas-micasaverde-com:device:MotionSensor:1) 2021-04-30 08:45:58.792 luup.create_device:: [10143] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.796 luup.create_device:: [10145] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.799 luup.create_device:: [10146] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.802 luup.create_device:: [10147] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.808 luup.create_device:: [10165] D_SmokeSensor1.xml / X / D_COSensor1NoTamper.json (urn:schemas-micasaverde-com:device:SmokeSensor:1) 2021-04-30 08:45:58.815 luup.create_device:: [10166] D_FloodSensor1.xml / X / D_FloodSensor1.json (urn:schemas-micasaverde-com:device:FloodSensor:1) 2021-04-30 08:45:58.820 luup.create_device:: [10172] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.825 luup.create_device:: [10173] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.831 luup.create_device:: [10177] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.836 luup.create_device:: [10178] D_ALTUI.xml / X / D_ALTUI_UI7.json (urn:schemas-upnp-org:device:altui:1) 2021-04-30 08:45:58.841 luup.create_device:: [10181] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.848 luup.create_device:: [10182] D_VirtualSensor1.xml / X / D_VirtualSensor1.json (urn:schemas-toggledbits-com:device:VirtualSensor:1) 2021-04-30 08:45:58.852 luup.create_device:: [10183] D_TemperatureSensor1.xml / X / D_GenericSensor1_Tpiscine.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.857 luup.create_device:: [10184] D_GenericSensor1.xml / X / D_GenericSensor1_mVolts.json (urn:schemas-micasaverde-com:device:GenericSensor:1) 2021-04-30 08:45:58.861 luup.create_device:: [10185] D_GenericSensor1.xml / X / D_GenericSensor1_Ph.json (urn:schemas-micasaverde-com:device:GenericSensor:1) 2021-04-30 08:45:58.865 luup.create_device:: [10186] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.871 luup.create_device:: [10187] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.875 luup.create_device:: [10189] D_MString.xml / X / D_MString.json (urn:schemas-upnp-org:device:VContainer:1) 2021-04-30 08:45:58.880 luup.create_device:: [10190] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.882 luup.create_device:: [10192] D_VeraAlert.xml / / () 2021-04-30 08:45:58.882 openLuup.chdev:: ERROR: unable to read XML file D_VeraAlert.xml 2021-04-30 08:45:58.886 luup.create_device:: [10193] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json (urn:schemas-toggledbits-com:device:ReactorSensor:1) 2021-04-30 08:45:58.894 luup.create_device:: [10195] D_FloodSensor1.xml / X / D_FloodSensorWithTamper1.json (urn:schemas-micasaverde-com:device:FloodSensor:1) 2021-04-30 08:45:58.898 luup.create_device:: [10196] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.902 luup.create_device:: [10197] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.906 luup.create_device:: [10198] D_VeraAlexa1.xml / X / D_ComboDevice1.json (urn:bochicchio-com:device:VeraAlexa:1) 2021-04-30 08:45:58.909 luup.create_device:: [10199] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.913 luup.create_device:: [10200] D_BinaryLight1.xml / X / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.916 luup.create_device:: [10201] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.919 luup.create_device:: [10202] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.922 luup.create_device:: [10203] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json (urn:schemas-micasaverde-com:device:TemperatureSensor:1) 2021-04-30 08:45:58.925 luup.create_device:: [10204] D_HumiditySensor1.xml / X / D_HumiditySensor1.json (urn:schemas-micasaverde-com:device:HumiditySensor:1) 2021-04-30 08:45:58.928 luup.create_device:: [30040] D_BinaryLight1.xml / / D_BinaryLight1.json (urn:schemas-upnp-org:device:BinaryLight:1) 2021-04-30 08:45:58.932 luup.create_device:: [30070] D_DoorSensor1.xml / / D_DoorSensor1.json (urn:schemas-micasaverde-com:device:DoorSensor:1) 2021-04-30 08:45:58.933 openLuup.userdata:: loading scenes... 2021-04-30 08:45:58.933 openLuup.userdata:: [10014] Alarme Température Congel/frigo 2021-04-30 08:45:58.933 openLuup.userdata:: [10010] Gestion_SmartLed 2021-04-30 08:45:58.933 openLuup.userdata:: [10009] essai_clavier 2021-04-30 08:45:58.934 openLuup.userdata:: [10001] Eclairage_Allee(Manu) 2021-04-30 08:45:58.934 openLuup.userdata:: number of scenes = 4 2021-04-30 08:45:58.934 openLuup.userdata:: ...scene loading completed 2021-04-30 08:45:58.934 openLuup.userdata:: loading installed plugin info... 2021-04-30 08:45:58.934 openLuup.userdata:: [openLuup] openLuup (21.4.29b) 2021-04-30 08:45:58.934 openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30) 2021-04-30 08:45:58.934 openLuup.userdata:: [VeraBridge] VeraBridge (21.1.3) 2021-04-30 08:45:58.934 openLuup.userdata:: [8246] ALTUI (2.53b.) 2021-04-30 08:45:58.934 openLuup.userdata:: [Z-Way] Z-Way (21.1.19) 2021-04-30 08:45:58.934 openLuup.userdata:: [Arduino] MySensors (not.installed) 2021-04-30 08:45:58.934 openLuup.userdata:: [9194] Switchboard (GitHub.GitHub.stable) 2021-04-30 08:45:58.935 openLuup.userdata:: [9086] Reactor (GitHub.stable) 2021-04-30 08:45:58.935 openLuup.userdata:: [9031] Virtual Sensor (1.11) 2021-04-30 08:45:58.935 openLuup.userdata:: [9281] Virtual HTTP Devices (GitHub.master) 2021-04-30 08:45:58.935 openLuup.userdata:: [AlexaTTS] VeraAlexa (GitHub.master) 2021-04-30 08:45:58.935 openLuup.userdata:: ...user_data loading completed 2021-04-30 08:45:58.935 openLuup.init:: running _openLuup_STARTUP_ 2021-04-30 08:45:58.936 luup_log:0: startup code completed 2021-04-30 08:45:58.936 openLuup.init:: init phase completed 2021-04-30 08:45:58.936 :: openLuup LOG ROTATION :: (runtime 0.0 days)
In the latest testing branch release (v21.4.30) the MQTT server now subscribes to the topic
openLuup/query
. If you publish a message with the format:devNo.serviceId.variable
, for example,- topic: openLuup/query
- message: 2.openLuup.Memory_Mb
it will force an immediate update message:
- topic: openLuup/update/2/openLuup/Memory_Mb
- message: 8.7 (or whatever)
You should be able to use this to get an initial value for any mqttthing.
Notice the formatting difference between the message and the returned topic ('.' instead of '/') this is intentional because it is in line with openLuup's existing dev.srv.var notation and it reminds you that it's not a part of the query topic, but it goes in the message, and avoids the need for openLuup to use a wildcard subscription.
If you have blocked the Shelly in your router from Internet access you probably have to open it temporary for the downgrade.I also added my Shelly Button to OpenLuup and for some reason I could not downgrade it, but I managed to get it working anyway after a few attempts.
(A bit strange since the post I found on the forum was on problems with the Button and v1.10.3.)Another tip is to use MqttExplorer if you do not already use it and see if the Shelly shows up there. If it does, then at least the Mqtt part of the Shelly most likely works.
Excellent diagnosis. Let's hope that's the root cause.
Entirely exaplins why I couldn't reproduce this ... my Shelly 2.5s are on 1.9.4, but telling me there's a 1.10.3, so I'll be sure NOT to do that!
I don't follow the Shelly forum much, so please pass on when it's safe again to upgrade.
@rafale77 Shellies are manual update... a good choice, as I'm sure you'll agree!
Ha! Indeed, There is an ongoing train wreck on the QNAP forum with people humorously (to me at least, maybe not to them) finding out the firmware autoupdate being enabled on the new firmware which itself has a lot of connectivity problems forcing many to downgrade... sounds familiar? No one is immune to a problematic upgrade or a use case where something breaks. And this came as a knee jerk reaction to a security breach for which the firmware upgrade itself does nothing because the exposure comes from an app.
@akbooer I routinely updated the two new Shellies and then I got v1.10.3, bad decision as it turnes out.
My two older Shellies are on v1.9.0 and worked directly when I enabled Mqtt.Manual update is better, automatic is a pain, Win 10 is a good example on that. I assume I will get it on my Qnap when I update it.
I have also blocked the Shellies and Tasmotas in the the router
