  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
107 Posts 10 Posters 72.9k Views 7 Watching
    for my few-remaining Zwave devices bridged to openLuup from Vera
    I'm trying to get rid of the old Vera plugin for Homebridge.
    What topics do I put in mqttthing to get/set bridged Vera devices?
    I got the "getOn" to reflect the status when I had luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) in the Lua Startup Code, is that necessery for this purpose?
    Do I need to write a handler for this?
    I tried a generic handler but never got it to work.
    Do you have an example of a handler if it's required?
    Depends what you want to get/set. Currently, I'm just using this for on/off switches, so using the mqttthing type Light bulb - on/off. I'm sure you can be more sophisticated, but I haven't tried it.
    As an example, I'll use a Vera-attached Zwave switch (device #30186 – it's actually a Fibaro relay, but it could be anything)
    The first thing you need to ensure is that you have set the openLuup MQTT server to publish variable updates, using this line in Lua Startup:
    luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true)   -- publish variable updates
    So, then, in order to reflect the relevant variable in the mqttthing you need in MQTT Topics :
    • Get on – openLuup/update/30186/SwitchPower1/Status
    and in order to control it:
    • Set on – relay/30186
    The relay command above is just a convenient openLuup shortcut to turn devices on/off which works both in MQTT and as an HTTP request.
    That should be all for basic control.
      CrilleC Online
      CrilleC Online
      @akbooer Thank you, I never understood that the relay/ command was available to MQTT as well.
      I guess there's no easy way to handle setBrightness?
        I knew that was going to be the next question... I’ll add something modelled after the Shelly commands (like /relay,except that this takes 1 and 0 as arguments instead of turn=on, etc.)
          @Crille
          OK, latest development version (21.4.28c) has HTTP and MQTT requests to change a dimmer:
          for device #51 to brightness level 42:
          HTTP:
          http://openLuupIP:3480/light/51?brightness=42
          MQTT:
          • topic: light/51
          • message: 42
          There's been some fairly drastic internal refactoring of the openLuup API, but you shouldn't notice anything changed...
            @Crille
            HTTP:
            MQTT:
            • topic: light/51
            • message: 42
            CrilleC Online
            CrilleC Online
            @akbooer Wow, that was fast! Thanks, works like a charm.
            May I bother you with my next issue? Every time I restart Homebridge my sensor values and current state of bridged devices are lost to mqttthing and shows 0 or OFF until there is an update from the device. Is there a way to retain the values from openLuup/update?
              As you’re probably aware, retain is the relevant word here. Currently. The MQTT server does not treat device variable updates as retained messages, so that when Homebridge subscribes it does not send the latest value. I need to consider that further...
                In my own broker I have a Vera/VeraID/update message causing an update from the bridge on demand. I find it useful when subscribing from my windows app, so I get all the updates. It’s similar to what Shelly or tasmota is doing. Maybe it’s easier to implement than retained messages.
                  @therealdb
                  Thanks for that! I think the challenge in this case is that we are somewhat constrained by what the mqttthing is able to handle. It has some configurability, but I’m not sure whether we can use this approach. We will see.
                    @therealdb
                    CrilleC Online
                    CrilleC Online
                    @akbooer Perhaps an update of all or specified variables could be initiated by a topic in the startPub setting?
                    • C Offline
                      C Offline
                      christian_fabre
                      #42
                      I have a Shelly plug and a Tasmota sensor.
                      I installed the latest OpenLuup version (21.4.28c)
                      I have the Shelly and Tasmota bridges that appear automatically, but I don't have the child devices.
                      Error message in the logs:
                      2021-04-29 15: 02: 20.795 openLuup.context_switch :: ERROR: [dev # 75] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 20.795 openLuup.mqtt :: ERROR publishing application message for mqtt: tele / piscine / SENSOR: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.216 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.217 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / power: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.219 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.219 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / energy: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.221 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.221 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0: ./openLuup/api.lua:148: attempt to index field '? ' (a nil value)
                      2021-04-29 15: 02: 21.223 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.223 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.225 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.225 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature_f: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.227 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                      2021-04-29 15: 02: 21.227 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / overtemperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                        #43
                        • What MQTT settings do you have in you Lua Startup?
                        • What are devices #75 and #76?
                        • Can you share more of the log than just the error – context is important
                        • C Offline
                          C Offline
                          christian_fabre
                          #44
                          MQTT setting :
                          luup.attr_set ("openLuup.MQTT.Port", 1885)
                          luup.attr_set ("openLuup.MQTT.Username", "*******")
                          luup.attr_set ("openLuup.MQTT.Password", "*******")
                          luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", "0")
                          luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) -- publish every variable update
                          luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", 2)       -- publish a single device status every N seconds (0 = never)
                          Devices 75 et 76
                          21	2021-04-29 14:56:51.444	75		Done	0.000	21	plugin: Tasmota	OK
                          22	2021-04-29 14:56:51.444	76		Done	0.000	22	plugin: Shelly	OK
                          Context after StartLuup
                          2021-04-29 16:53:44.403   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x184a658
                          2021-04-29 16:53:44.404   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x184a658
                          2021-04-29 16:53:44.404   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x184a658
                          2021-04-29 16:53:44.404   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.404   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.405   luup.shelly:76: New Shelly announced: shellyplug-s-20E453
                          2021-04-29 16:53:44.405   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.405   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.405   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.406   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.407   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                          2021-04-29 16:53:44.661   openLuup.server:: request completed (515424 bytes, 33 chunks, 272 ms) tcp{client}: 0x22f6cf8
                            Thanks – that shows exactly what I needed to see. The first incoming message from the Shelly is not an announcement, so the device doesn't yet exist. I knew this happened, but thought I had handled the condition. A recent change has made it appear again. I'll work on it...
                            • C Offline
                              C Offline
                              christian_fabre
                              Okay
                              Thank you for your work that I am with interest
                              • C christian_fabre
                                Okay
                                @christian_fabre
                                Can you tell me what Shelly devices you are using here? Thanks.
                                  @christian_fabre
                                  Could you try the latest development version (21.4.29b) and see if that fixes the issue? Thanks.
                                  • C Offline
                                    C Offline
                                    christian_fabre
                                    #49
                                    Shelly Plug
                                    I installed the last version but still the same problem
                                    2021-04-29 20:31:35.495   openLuup.io.server:: MQTT:1885 connection from 192.168.1.149 tcp{client}: 0x1808020
                                    2021-04-29 20:31:35.500   openLuup.server:: request completed (1304 bytes, 1 chunks, 6470 ms) tcp{client}: 0x1a2dc08
                                    2021-04-29 20:31:35.515   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x1808020
                                    2021-04-29 20:31:35.516   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x1808020
                                    2021-04-29 20:31:35.517   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x1808020
                                    2021-04-29 20:31:35.518   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.518   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.519   luup.shelly:76: New Shelly announced: shellyplug-s-20E453
                                    2021-04-29 20:31:35.520   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                    2021-04-29 20:31:35.520   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./L_ShellyBridge.lua:226: attempt to index field '?' (a nil value)
                                    2021-04-29 20:31:35.521   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.521   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.522   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.522   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.523   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.524   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.525   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.525   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.526   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.526   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.527   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.527   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.528   openLuup.context_switch::  ERROR: [dev #76] ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                    2021-04-29 20:31:35.528   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./L_ShellyBridge.lua:343: attempt to index field 'hadevice' (a nil value)
                                      Sorry to hear.
                                      Can you send me that startup log? Something is not right here.
                                      • C Offline
                                        C Offline
                                        christian_fabre
                                        #51
                                        logs/LuaUPnP_startup.log
                                        178 lines, 1 error, max gap 0s @ 2021-04-30 08:45:58.936
                                        2021-04-30 08:45:57.409   :: openLuup STARTUP :: /etc/cmh-ludl
                                        2021-04-30 08:45:57.409   openLuup.init::        version 2021.04.08  @akbooer
                                        2021-04-30 08:45:57.437   openLuup.scheduler::   version 2021.03.19  @akbooer
                                        2021-04-30 08:45:57.462   openLuup.io::          version 2021.03.27  @akbooer
                                        2021-04-30 08:45:57.462   openLuup.mqtt::        version 2021.04.28b  @akbooer
                                        2021-04-30 08:45:57.464   openLuup.wsapi::       version 2019.08.12  @akbooer
                                        2021-04-30 08:45:57.464   openLuup.servlet::     version 2021.04.28c  @akbooer
                                        2021-04-30 08:45:57.464   openLuup.client::      version 2019.10.14  @akbooer
                                        2021-04-30 08:45:57.465   openLuup.server::      version 2020.03.26  @akbooer
                                        2021-04-30 08:45:57.473   openLuup.scenes::      version 2021.04.28  @akbooer
                                        2021-04-30 08:45:57.477   openLuup.chdev::       version 2020.21.27  @akbooer
                                        2021-04-30 08:45:57.477   openLuup.userdata::    version 2021.03.14  @akbooer
                                        2021-04-30 08:45:57.477   openLuup.requests::    version 2021.02.20  @akbooer
                                        2021-04-30 08:45:57.478   openLuup.gateway::     version 2020.03.08  @akbooer
                                        2021-04-30 08:45:57.481   openLuup.smtp::        version 2018.04.12  @akbooer
                                        2021-04-30 08:45:57.485   openLuup.historian::   version 2021.02.03  @akbooer
                                        2021-04-30 08:45:57.486   openLuup.luup::        version 2021.04.27  @akbooer
                                        2021-04-30 08:45:57.487   openLuup.pop3::        version 2018.04.23  @akbooer
                                        2021-04-30 08:45:57.488   openLuup.compression:: version 2016.06.30  @akbooer
                                        2021-04-30 08:45:57.488   openLuup.timers::      version 2019.05.03  @akbooer
                                        2021-04-30 08:45:57.488   openLuup.logs::        version 2018.03.25  @akbooer
                                        2021-04-30 08:45:57.488   openLuup.json::        version 2020.05.20  @akbooer
                                        2021-04-30 08:45:57.488   openLuup.init:: using openLuup.json.Lua.decode() for JSON decoding (Cjson not installed)
                                        2021-04-30 08:45:57.545   luup.create_device:: [1] D_ZWaveNetwork.xml / I_ZWave.xml /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                                        2021-04-30 08:45:57.561   luup.create_device:: [2] D_openLuup.xml / I_openLuup.xml / D_openLuup.json   (openLuup)
                                        2021-04-30 08:45:57.561   openLuup.init:: loading configuration user_data.json
                                        2021-04-30 08:45:57.571   openLuup.userdata:: loading user_data json...
                                        2021-04-30 08:45:57.846   luup.variable_set:: 2.openLuup.HouseMode was: EMPTY now: 1 #hooks:0
                                        2021-04-30 08:45:57.846   openLuup.userdata:: loading rooms...
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#1 'MiOS-45003471'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#2 'VeraEdge_Exterieur'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#3 'VeraEdge_Essai'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#4 'VeraEdge_Température'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#5 'VeraEdge_Piscine'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#6 'VeraEdge_System'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#7 'VeraEdge_Securité'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#8 'ZWay-31415926'
                                        2021-04-30 08:45:57.846   openLuup.userdata:: room#9 'OpenLuup'
                                        2021-04-30 08:45:57.847   openLuup.userdata:: ...room loading completed
                                        2021-04-30 08:45:57.847   openLuup.userdata:: loading devices...
                                        2021-04-30 08:45:57.850   luup.create_device:: [1] D_ZWaveNetwork.xml / X /    (urn:schemas-micasaverde-com:device:ZWaveNetwork:1)
                                        2021-04-30 08:45:57.859   luup.create_device:: [4] D_AltAppStore.xml / I_AltAppStore.xml / D_AltAppStore.json   (urn:schemas-upnp-org:device:AltAppStore:1)
                                        2021-04-30 08:45:57.868   luup.create_device:: [5] D_VeraBridge.xml / I_VeraBridge.xml / D_VeraBridge.json   (VeraBridge)
                                        2021-04-30 08:45:57.903   luup.create_device:: [15] D_Switchboard1.xml / I_Switchboard1.xml / D_Switchboard1_UI7.json   (urn:schemas-toggledbits-com:device:Switchboard:1)
                                        2021-04-30 08:45:57.957   luup.create_device:: [18] D_Reactor.xml / I_Reactor.xml / D_Reactor_UI7.json   (urn:schemas-toggledbits-com:device:Reactor:1)
                                        2021-04-30 08:45:57.994   luup.create_device:: [19] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:57.999   luup.create_device:: [20] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.004   luup.create_device:: [25] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.110   openLuup.scheduler.sandbox:: device 26 defined 'string.starts' (a function value)
                                        2021-04-30 08:45:58.110   openLuup.scheduler.sandbox:: device 26 defined 'string.altui_split' (a function value)
                                        2021-04-30 08:45:58.110   openLuup.scheduler.sandbox:: device 26 defined 'string.template' (a function value)
                                        2021-04-30 08:45:58.111   openLuup.scheduler.sandbox:: device 26 defined 'string.trim' (a function value)
                                        2021-04-30 08:45:58.111   luup.create_device:: [26] D_ALTUI.xml / I_ALTUI.xml / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                                        2021-04-30 08:45:58.158   luup.create_device:: [27] D_VirtualSensor1.xml / I_VirtualSensor1.xml / D_VirtualSensor1.json   (urn:schemas-toggledbits-com:device:VirtualSensor:1)
                                        2021-04-30 08:45:58.165   luup.create_device:: [28] D_GenericSensor1.xml /  / D_GenericSensor1.json   (urn:schemas-micasaverde-com:device:GenericSensor:1)
                                        2021-04-30 08:45:58.210   luup.create_device:: [29] D_MString.xml / I_MString.xml / D_MString.json   (urn:schemas-upnp-org:device:VContainer:1)
                                        2021-04-30 08:45:58.214   luup.create_device:: [32] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.219   luup.create_device:: [33] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.281   luup.create_device:: [35] D_ZWay.xml / I_ZWay2.xml / D_ZWay.json   (ZWay)
                                        2021-04-30 08:45:58.300   openLuup.scheduler.sandbox:: device 36 defined 'string.fliprsplit' (a function value)
                                        2021-04-30 08:45:58.300   openLuup.scheduler.sandbox:: device 36 defined 'string.template' (a function value)
                                        2021-04-30 08:45:58.300   openLuup.scheduler.sandbox:: device 36 defined 'string.trim' (a function value)
                                        2021-04-30 08:45:58.301   luup.create_device:: [36] D_FLIPR.xml / I_FLIPR.xml / D_FLIPR_UI7.json   (urn:schemas-upnp-org:device:flipr:1)
                                        2021-04-30 08:45:58.319   luup.create_device:: [40] D_MString.xml / I_MString.xml / D_GenericSensor1_Ph.json   (urn:schemas-upnp-org:device:VContainer:1)
                                        2021-04-30 08:45:58.338   luup.create_device:: [41] D_MString.xml / I_MString.xml / D_GenericSensor1_mVolts.json   (urn:schemas-upnp-org:device:VContainer:1)
                                        2021-04-30 08:45:58.356   luup.create_device:: [42] D_MString.xml / I_MString.xml / D_GenericSensor1_Tpiscine.json   (urn:schemas-upnp-org:device:VContainer:1)
                                        2021-04-30 08:45:58.385   luup.create_device:: [46] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.407   luup.create_device:: [49] D_BinaryLight1.xml / I_VirtualBinaryLight1.xml / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.411   luup.create_device:: [50] D_ReactorSensor.xml /  / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.425   luup.create_device:: [51] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.437   luup.create_device:: [54] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.450   luup.create_device:: [55] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.463   luup.create_device:: [56] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.480   luup.create_device:: [57] D_VeraAlexa1.xml / I_VeraAlexa1.xml / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.489   luup.register_handler:: global_function_name=Tasmota_MQTT_Handler, request=mqtt:tele/#
                                        2021-04-30 08:45:58.489   luup.register_handler:: global_function_name=Tasmota_MQTT_Handler, request=mqtt:tasmota/tele/#
                                        2021-04-30 08:45:58.490   luup.create_device:: [75] D_TasmotaBridge.xml / I_TasmotaBridge.xml / D_TasmotaBridge.json   (TasmotaBridge)
                                        2021-04-30 08:45:58.494   luup.register_handler:: global_function_name=Shelly_MQTT_Handler, request=mqtt:shellies/#
                                        2021-04-30 08:45:58.494   luup.create_device:: [76] D_ShellyBridge.xml / I_ShellyBridge.xml / D_ShellyBridge.json   (ShellyBridge)
                                        2021-04-30 08:45:58.501   luup.create_device:: [10002] D_SceneController1.xml / X / D_SceneController1.json   (urn:schemas-micasaverde-com:device:SceneController:1)
                                        2021-04-30 08:45:58.505   luup.create_device:: [10003] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.509   luup.create_device:: [10006] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.513   luup.create_device:: [10012] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.522   luup.create_device:: [10016] D_InfoViewer1.xml / X / D_InfoViewer1.json   (urn:schemas-a-lurker-com:device:InfoViewer:1)
                                        2021-04-30 08:45:58.544   luup.create_device:: [10034] D_DeusExMachinaII1.xml / X / D_DeusExMachinaII1_UI7.json   (urn:schemas-toggledbits-com:device:DeusExMachinaII:1)
                                        2021-04-30 08:45:58.606   luup.create_device:: [10040] D_MiLightRGBWBOX2.xml / X / D_MiLightRGBW.json   (urn:schemas-dcineco-com:device:DimmableLightRGBW:1)
                                        2021-04-30 08:45:58.610   luup.create_device:: [10046] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.614   luup.create_device:: [10047] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.617   luup.create_device:: [10048] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.625   luup.create_device:: [10059] D_LuaView1.xml / X / D_LuaView1.json   (urn:schemas-toggledbits-com:device:LuaView:1)
                                        2021-04-30 08:45:58.643   luup.create_device:: [10060] D_ZiBlueGateway1.xml / X / D_ZiBlueGateway1.json   (urn:schemas-upnp-org:device:ZiBlueGateway:1)
                                        2021-04-30 08:45:58.644   luup.create_device:: [10061] D_SerialPortRoot1.xml / X /    (urn:micasaverde-org:device:SerialPortRoot:1)
                                        2021-04-30 08:45:58.654   luup.create_device:: [10062] D_SerialPort1.xml / X /    (urn:micasaverde-org:device:SerialPort:1)
                                        2021-04-30 08:45:58.659   luup.create_device:: [10069] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.664   luup.create_device:: [10070] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.667   luup.create_device:: [10071] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.669   luup.create_device:: [10072] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.672   luup.create_device:: [10075] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.675   luup.create_device:: [10076] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.683   luup.create_device:: [10082] D_DelayLight.xml / X / D_DelayLight_UI7.json   (urn:schemas-toggledbits-com:device:DelayLight:1)
                                        2021-04-30 08:45:58.695   luup.create_device:: [10089] D_WindSensor1.xml / X / D_WindSensor1.json   (urn:schemas-micasaverde-com:device:WindSensor:1)
                                        2021-04-30 08:45:58.698   luup.create_device:: [10095] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.718   luup.create_device:: [10097] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
                                        2021-04-30 08:45:58.723   luup.create_device:: [10099] D_VSwitch.xml / X / D_VSwitch_UI7.json   (urn:schemas-upnp-org:device:VSwitch:1)
                                        2021-04-30 08:45:58.726   luup.create_device:: [10102] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.730   luup.create_device:: [10103] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.733   luup.create_device:: [10104] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.735   luup.create_device:: [10105] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.738   luup.create_device:: [10106] D_Reactor.xml / X / D_Reactor_UI7.json   (urn:schemas-toggledbits-com:device:Reactor:1)
                                        2021-04-30 08:45:58.743   luup.create_device:: [10107] D_Switchboard1.xml / X / D_Switchboard1_UI7.json   (urn:schemas-toggledbits-com:device:Switchboard:1)
                                        2021-04-30 08:45:58.747   luup.create_device:: [10110] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.751   luup.create_device:: [10114] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.753   luup.create_device:: [10115] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.759   luup.create_device:: [10118] D_DoorSensor1.xml / X / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
                                        2021-04-30 08:45:58.761   luup.create_device:: [10124] D_SmartHomeHelper.xml / X /    (urn:schemas-upnp-org:device:GoogleHome:1)
                                        2021-04-30 08:45:58.767   luup.create_device:: [10131] D_MotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                                        2021-04-30 08:45:58.774   luup.create_device:: [10132] D_LightSensor1.xml / X / D_LightSensor1.json   (urn:schemas-micasaverde-com:device:LightSensor:1)
                                        2021-04-30 08:45:58.778   luup.create_device:: [10133] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.784   luup.create_device:: [10138] D_GenericIO1.xml / X / D_GenericIO1.json   (urn:schemas-micasaverde-com:device:GenericIO:1)
                                        2021-04-30 08:45:58.788   luup.create_device:: [10139] D_MotionSensor1.xml / X / D_MotionSensor1.json   (urn:schemas-micasaverde-com:device:MotionSensor:1)
                                        2021-04-30 08:45:58.792   luup.create_device:: [10143] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.796   luup.create_device:: [10145] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.799   luup.create_device:: [10146] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.802   luup.create_device:: [10147] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.808   luup.create_device:: [10165] D_SmokeSensor1.xml / X / D_COSensor1NoTamper.json   (urn:schemas-micasaverde-com:device:SmokeSensor:1)
                                        2021-04-30 08:45:58.815   luup.create_device:: [10166] D_FloodSensor1.xml / X / D_FloodSensor1.json   (urn:schemas-micasaverde-com:device:FloodSensor:1)
                                        2021-04-30 08:45:58.820   luup.create_device:: [10172] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.825   luup.create_device:: [10173] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.831   luup.create_device:: [10177] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.836   luup.create_device:: [10178] D_ALTUI.xml / X / D_ALTUI_UI7.json   (urn:schemas-upnp-org:device:altui:1)
                                        2021-04-30 08:45:58.841   luup.create_device:: [10181] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.848   luup.create_device:: [10182] D_VirtualSensor1.xml / X / D_VirtualSensor1.json   (urn:schemas-toggledbits-com:device:VirtualSensor:1)
                                        2021-04-30 08:45:58.852   luup.create_device:: [10183] D_TemperatureSensor1.xml / X / D_GenericSensor1_Tpiscine.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.857   luup.create_device:: [10184] D_GenericSensor1.xml / X / D_GenericSensor1_mVolts.json   (urn:schemas-micasaverde-com:device:GenericSensor:1)
                                        2021-04-30 08:45:58.861   luup.create_device:: [10185] D_GenericSensor1.xml / X / D_GenericSensor1_Ph.json   (urn:schemas-micasaverde-com:device:GenericSensor:1)
                                        2021-04-30 08:45:58.865   luup.create_device:: [10186] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.871   luup.create_device:: [10187] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.875   luup.create_device:: [10189] D_MString.xml / X / D_MString.json   (urn:schemas-upnp-org:device:VContainer:1)
                                        2021-04-30 08:45:58.880   luup.create_device:: [10190] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.882   luup.create_device:: [10192] D_VeraAlert.xml /  /    ()
                                        2021-04-30 08:45:58.882   openLuup.chdev:: ERROR: unable to read XML file D_VeraAlert.xml
                                        2021-04-30 08:45:58.886   luup.create_device:: [10193] D_ReactorSensor.xml / X / D_ReactorSensor_UI7.json   (urn:schemas-toggledbits-com:device:ReactorSensor:1)
                                        2021-04-30 08:45:58.894   luup.create_device:: [10195] D_FloodSensor1.xml / X / D_FloodSensorWithTamper1.json   (urn:schemas-micasaverde-com:device:FloodSensor:1)
                                        2021-04-30 08:45:58.898   luup.create_device:: [10196] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.902   luup.create_device:: [10197] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.906   luup.create_device:: [10198] D_VeraAlexa1.xml / X / D_ComboDevice1.json   (urn:bochicchio-com:device:VeraAlexa:1)
                                        2021-04-30 08:45:58.909   luup.create_device:: [10199] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.913   luup.create_device:: [10200] D_BinaryLight1.xml / X / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.916   luup.create_device:: [10201] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.919   luup.create_device:: [10202] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.922   luup.create_device:: [10203] D_TemperatureSensor1.xml / X / D_TemperatureSensor1.json   (urn:schemas-micasaverde-com:device:TemperatureSensor:1)
                                        2021-04-30 08:45:58.925   luup.create_device:: [10204] D_HumiditySensor1.xml / X / D_HumiditySensor1.json   (urn:schemas-micasaverde-com:device:HumiditySensor:1)
                                        2021-04-30 08:45:58.928   luup.create_device:: [30040] D_BinaryLight1.xml /  / D_BinaryLight1.json   (urn:schemas-upnp-org:device:BinaryLight:1)
                                        2021-04-30 08:45:58.932   luup.create_device:: [30070] D_DoorSensor1.xml /  / D_DoorSensor1.json   (urn:schemas-micasaverde-com:device:DoorSensor:1)
                                        2021-04-30 08:45:58.933   openLuup.userdata:: loading scenes...
                                        2021-04-30 08:45:58.933   openLuup.userdata:: [10014] Alarme Température Congel/frigo
                                        2021-04-30 08:45:58.933   openLuup.userdata:: [10010] Gestion_SmartLed
                                        2021-04-30 08:45:58.933   openLuup.userdata:: [10009] essai_clavier
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [10001] Eclairage_Allee(Manu)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: number of scenes = 4
                                        2021-04-30 08:45:58.934   openLuup.userdata:: ...scene loading completed
                                        2021-04-30 08:45:58.934   openLuup.userdata:: loading installed plugin info...
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [openLuup] openLuup (21.4.29b)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [AltAppStore] Alternate App Store (20.3.30)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [VeraBridge] VeraBridge (21.1.3)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [8246] ALTUI (2.53b.)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [Z-Way] Z-Way (21.1.19)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [Arduino] MySensors (not.installed)
                                        2021-04-30 08:45:58.934   openLuup.userdata:: [9194] Switchboard (GitHub.GitHub.stable)
                                        2021-04-30 08:45:58.935   openLuup.userdata:: [9086] Reactor (GitHub.stable)
                                        2021-04-30 08:45:58.935   openLuup.userdata:: [9031] Virtual Sensor (1.11)
                                        2021-04-30 08:45:58.935   openLuup.userdata:: [9281] Virtual HTTP Devices (GitHub.master)
                                        2021-04-30 08:45:58.935   openLuup.userdata:: [AlexaTTS] VeraAlexa (GitHub.master)
                                        2021-04-30 08:45:58.935   openLuup.userdata:: ...user_data loading completed
                                        2021-04-30 08:45:58.935   openLuup.init:: running _openLuup_STARTUP_
                                        2021-04-30 08:45:58.936   luup_log:0: startup code completed
                                        2021-04-30 08:45:58.936   openLuup.init:: init phase completed
                                        2021-04-30 08:45:58.936   :: openLuup LOG ROTATION :: (runtime 0.0 days)
                                          In the latest testing branch release (v21.4.30) the MQTT server now subscribes to the topic openLuup/query. If you publish a message with the format: devNo.serviceId.variable, for example,
                                          • topic: openLuup/query
                                          • message: 2.openLuup.Memory_Mb
                                          it will force an immediate update message:
                                          • topic: openLuup/update/2/openLuup/Memory_Mb
                                          • message: 8.7 (or whatever)
                                          You should be able to use this to get an initial value for any mqttthing.
                                          Notice the formatting difference between the message and the returned topic ('.' instead of '/') this is intentional because it is in line with openLuup's existing dev.srv.var notation and it reminds you that it's not a part of the query topic, but it goes in the message, and avoids the need for openLuup to use a wildcard subscription.
                                            154.1k
