  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
    #25
    I think we need a separate Tasmota thread, or this will get confusing.
    @therealdb for the Shelly input devices I see:
      for switch in "momentary" mode:
      input_event/n = {"event":"S","event_cnt":11}
    		S = shortpush
    		L = longpush
    		SS = double shortpush
    		SSS = triple shortpush
    		SL = shortpush + longpush
    		LS = longpush + shortpush
    and this can be for multiple inputs (eg. ix3 has three.)
    So we need to agree on how to map these to scene numbers. Perhaps the easiest thing is to repesent each one by increments of 10.
    For example:
        scene_no = {
    		S = 10,  -- shortpush
    		L = 20,  -- longpush
    		SS = 30, -- double shortpush
    		SSS = 40,  -- triple shortpush
    		SL = 50, -- shortpush + longpush
    		LS = 60, --longpush + shortpush
    so a short push on button 0 would be 10, a long push on button 1 would be 21.
      After an embarassing three attempts, v21.3.29c has this multi-push scene numbering implemented for shelly-ix3 (only, at the moment.)
        		S = shortpush
        		L = longpush
        For example:
            scene_no = {
        		L = 20,  -- longpush
        @akbooer yeah, I think the numbering is OK.
        What I was referring to detached mode is that when in this mode, you have input and switch not in sync, so imho we should map them as a BinarySwitch and a generic security sensor for the input. You'll get both \input and \relay mqtt message.
        I think it's OK to discuss Tasmota in this thread, since it's basically all dedicated to MQTT 😉
          #28
          Can't be a generic security sensor if you want to capture the different switch press modes, so I think just the sl_SceneActivated and time makes more sense.
            Just wanted to say big thanks to all for the great work!
            I've read all the progress with the broker and Tasmota bridge with joy and now managed to switch my Sonoffs from rules and Virtual HTTP Devices completely to MQTT using homebridge-mqttthing and Virtual Sensor plugin.
              @crille
              Excellent news. Yes, I am using homebridge-mqttthing too, for my few-remaining Zwave devices bridged to openLuup from Vera. The Homebridge-Shelly accessory is also very functional.
              All this means that the Apple Home app is my primary UI (well, actually secondary, since Siri on the HomePod takes care of most things.)
                #31
                Awesome to see the MQTT implementation. Only if I could get myself the motivation to migrate to homebridge and get everything (Z-way/openLuup/HomeAssistant/Homebridge) to talk through MQTT instead of http as they are at the moment... It seems to be a lot of work...
                For me too, the Apple Home app has become my primary (yet rarely used) UI.
                  @crille
                  I'm trying to get rid of the old Vera plugin for Homebridge.
                  What topics do I put in mqttthing to get/set bridged Vera devices?
                  I got the "getOn" to reflect the status when I had luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) in the Lua Startup Code, is that necessery for this purpose?
                  Do I need to write a handler for this?
                  I tried a generic handler but never got it to work.
                  Do you have an example of a handler if it's required?
                    Depends what you want to get/set. Currently, I'm just using this for on/off switches, so using the mqttthing type Light bulb - on/off. I'm sure you can be more sophisticated, but I haven't tried it.
                    As an example, I'll use a Vera-attached Zwave switch (device #30186 – it's actually a Fibaro relay, but it could be anything)
                    The first thing you need to ensure is that you have set the openLuup MQTT server to publish variable updates, using this line in Lua Startup:
                    luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true)   -- publish variable updates
                    So, then, in order to reflect the relevant variable in the mqttthing you need in MQTT Topics :
                    • Get on – openLuup/update/30186/SwitchPower1/Status
                    and in order to control it:
                    • Set on – relay/30186
                    The relay command above is just a convenient openLuup shortcut to turn devices on/off which works both in MQTT and as an HTTP request.
                    That should be all for basic control.
                      @akbooer Thank you, I never understood that the relay/ command was available to MQTT as well.
                      I guess there's no easy way to handle setBrightness?
                        I knew that was going to be the next question... I’ll add something modelled after the Shelly commands (like /relay,except that this takes 1 and 0 as arguments instead of turn=on, etc.)
                          @Crille
                          OK, latest development version (21.4.28c) has HTTP and MQTT requests to change a dimmer:
                          for device #51 to brightness level 42:
                          HTTP:
                          http://openLuupIP:3480/light/51?brightness=42
                          MQTT:
                          • topic: light/51
                          • message: 42
                          There's been some fairly drastic internal refactoring of the openLuup API, but you shouldn't notice anything changed...
                            @Crille
                            HTTP:
                            MQTT:
                            • topic: light/51
                            • message: 42
                            @akbooer Wow, that was fast! Thanks, works like a charm.
                            May I bother you with my next issue? Every time I restart Homebridge my sensor values and current state of bridged devices are lost to mqttthing and shows 0 or OFF until there is an update from the device. Is there a way to retain the values from openLuup/update?
                              As you’re probably aware, retain is the relevant word here. Currently. The MQTT server does not treat device variable updates as retained messages, so that when Homebridge subscribes it does not send the latest value. I need to consider that further...
                                In my own broker I have a Vera/VeraID/update message causing an update from the bridge on demand. I find it useful when subscribing from my windows app, so I get all the updates. It’s similar to what Shelly or tasmota is doing. Maybe it’s easier to implement than retained messages.
                                  @therealdb
                                  Thanks for that! I think the challenge in this case is that we are somewhat constrained by what the mqttthing is able to handle. It has some configurability, but I’m not sure whether we can use this approach. We will see.
                                    @therealdb
                                    @akbooer Perhaps an update of all or specified variables could be initiated by a topic in the startPub setting?
                                    • C Offline
                                      C Offline
                                      christian_fabre
                                      #42
                                      I have a Shelly plug and a Tasmota sensor.
                                      I installed the latest OpenLuup version (21.4.28c)
                                      I have the Shelly and Tasmota bridges that appear automatically, but I don't have the child devices.
                                      Error message in the logs:
                                      2021-04-29 15: 02: 20.795 openLuup.context_switch :: ERROR: [dev # 75] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 20.795 openLuup.mqtt :: ERROR publishing application message for mqtt: tele / piscine / SENSOR: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.216 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.217 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / power: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.219 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.219 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0 / energy: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.221 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.221 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / relay / 0: ./openLuup/api.lua:148: attempt to index field '? ' (a nil value)
                                      2021-04-29 15: 02: 21.223 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.223 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.225 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.225 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / temperature_f: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.227 openLuup.context_switch :: ERROR: [dev # 76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                      2021-04-29 15: 02: 21.227 openLuup.mqtt :: ERROR publishing application message for mqtt: shellies / shellyplug-s-20E453 / overtemperature: ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                        #43
                                        • What MQTT settings do you have in you Lua Startup?
                                        • What are devices #75 and #76?
                                        • Can you share more of the log than just the error – context is important
                                        • C Offline
                                          C Offline
                                          christian_fabre
                                          #44
                                          MQTT setting :
                                          luup.attr_set ("openLuup.MQTT.Port", 1885)
                                          luup.attr_set ("openLuup.MQTT.Username", "*******")
                                          luup.attr_set ("openLuup.MQTT.Password", "*******")
                                          luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", "0")
                                          luup.attr_set ("openLuup.MQTT.PublishVariableUpdates", true) -- publish every variable update
                                          luup.attr_set ("openLuup.MQTT.PublishDeviceStatus", 2)       -- publish a single device status every N seconds (0 = never)
                                          Devices 75 et 76
                                          21	2021-04-29 14:56:51.444	75		Done	0.000	21	plugin: Tasmota	OK
                                          22	2021-04-29 14:56:51.444	76		Done	0.000	22	plugin: Shelly	OK
                                          Context after StartLuup
                                          2021-04-29 16:53:44.403   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/command tcp{client}: 0x184a658
                                          2021-04-29 16:53:44.404   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/command tcp{client}: 0x184a658
                                          2021-04-29 16:53:44.404   openLuup.mqtt:: shellyplug-s-20E453 SUBSCRIBE to shellies/shellyplug-s-20E453/relay/0/command tcp{client}: 0x184a658
                                          2021-04-29 16:53:44.404   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.404   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/online : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.405   luup.shelly:76: New Shelly announced: shellyplug-s-20E453
                                          2021-04-29 16:53:44.405   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.405   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.405   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/announce : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.406   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/power : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0/energy : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.406   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/relay/0 : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.407   openLuup.context_switch::  ERROR: [dev #76] ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/temperature_f : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.407   openLuup.mqtt:: ERROR publishing application message for mqtt:shellies/shellyplug-s-20E453/overtemperature : ./openLuup/api.lua:148: attempt to index field '?' (a nil value)
                                          2021-04-29 16:53:44.661   openLuup.server:: request completed (515424 bytes, 33 chunks, 272 ms) tcp{client}: 0x22f6cf8
                                            164.9k
