Updated doco here.
Hope it works - YMMV.
Hey guys....
long time 😉
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
Hi akbooer,
tnks
donato
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
openLuup: Tasmota MQTT Bridge
@therealdb said in openLuup: Tasmota MQTT Bridge:
@archers no need to put ip or anything. Just push the mqtt message to the broker. In you case
I have tried this, but it seems not to work for some strange reason.
I put the Mqtt message in the "MQTT_PowerStatusOn" variable but I do not get any Mqtt message in either the Tasmota Console or in Mqtt Explorer when toggling the device, I assume that it should react when doing that.Any ideas on what could be wrong?
Just for comparison, when testing this in the Lua Code Test it works, so the messsage should be ok.
luup.openLuup.mqtt.publish ("cmnd/TasmotaIR/IRhvac","{\"Vendor\":\"FUJITSU_AC\",\"Model\":1,\"Mode\":\"Heat\",\"Power\":\"On\",\"Celsius\":\"On\",\"Temp\":20,\"FanSpeed\":\"Auto\",\"SwingV\":\"Off\",\"SwingH\":\"Off\",\"Quiet\":\"Off\",\"Turbo\":\"Off\",\"Econo\":\"Off\",\"Light\":\"Off\",\"Filter\":\"Off\",\"Clean\":\"Off\",\"Beep\":\"Off\",\"Sleep\":-1}")
@archers so, to execute something when you turn a device ON, just add this as the SetPowerURL variable's value:
mqtt://cmnd/TasmotaIR/IRhvac/=/{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Heat","Power":"On","Celsius":"On","Temp":20,"FanSpeed":"Auto","SwingV":"Off","SwingH":"Off","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}
(Notice the mqtt:// prefix that I omitted from the docs - my bad).
I've not implemented thermostats yet, but I could do it easily, grabbing some code from the heaters.
@archers said in openLuup: Tasmota MQTT Bridge:
Despite this I have historical data when looking at a graph
Yes, this works even if the Historian is not archiving to disk. It maintains an in-memory cache of the 1000, or so, latest values for numeric variables.
I assume that if the graph in Historian contains data so should a graph in Grafana.
Not so. This cache is not available to Grafana, which requires an on-disk archive. This behaviour is described in some detail on pp.12–13 of the User Guide.
@Buxton, you have two options:
- create the archive files manually (using the correct attributes.) Once they're there, the Historian will continue to write to them.
- Let me know the variable names (I'm assuming Temperature and Humidity?) and I will add them to the archive defaults.
#2 is obviously the better option.
I have the idea to control the temperature of my HVAC and looked at your VirtualHeater device.
For some reason it does not seem to keep the values I set when changing the temperature. Any ideas?My first thought is to keep things simple. A hetater or thermostat device for setting the temp and possibly something more. Maybe fan speed also later on.
@akbooer said in openLuup: Tasmota MQTT Bridge:
I had forgotten about setting that up on my main OpenLuup server, but that of course explains the difference with my test server.
Let me know the variable names (I'm assuming Temperature and Humidity?) and I will add them to the archive defaults.On my BLE Tasmota it is Temperature, Humidity and Battery (for my LYWSD03MMC Xiaomi BLE sensors).
@akbooer Yes, I'm starting to see what your up against here. MQTT, because of its flexibility, is not going fit into established serviceiDs. Developing a UI to manage this complexity will take some creative insight.....
Attached is a sample screenshot of the device file. Note the three sensors listed on the left with non-friendly names
And here is the actual device file as displayed in the console:
[{ "ControlURLs":[], "altid":"power_BedroomTV", "category_num":0, "device_file":"D_GenericTasmotaDevice.xml", "device_json":"D_GenericTasmotaDevice.json", "device_type":"GenericTasmotaDevice", "disabled":0, "id":30001, "id_parent":262, "invisible":"0", "ip":"", "local_udn":"uuid:d764c8cc-e932-55c4-478d-7aa05d83f3ea", "mac":"", "manufacturer":"could be anyone", "model":"", "name":"power_BedroomTV", "plugin":"", "room":"35", "states":[{ "id":0, "service":"urn:micasaverde-com:serviceId:HaDevice1", "value":"1620676905", "variable":"LastUpdate" },{ "id":1, "service":"power_BedroomTV", "value":"{\"Time\":\"2021-05-10T21:01:44\",\"Switch1\":\"ON\",\"Switch2\":\"ON\",\"ENERGY\":{\"TotalStartTime\":\"2021-04-04T05:29:11\",\"Total\":0.000,\"Yesterday\":0.000,\"Today\":0.000,\"Period\":0,\"Power\":[0,0],\"ApparentPower\":[0,0],\"ReactivePower\":[0,0],\"Factor\":[0.00,0.00],\"Frequency\":60,\"Voltage\":121,\"Current\":[0.000,0.000]}}", "variable":"tele" },{ "id":2, "service":"LYWSD03eb4f4f", "value":"a4c138eb4f4f", "variable":"mac" },{ "id":3, "service":"LYWSD03eb4f4f", "value":"21.7", "variable":"Temperature" },{ "id":4, "service":"LYWSD03eb4f4f", "value":"62", "variable":"Humidity" },{ "id":5, "service":"LYWSD03eb4f4f", "value":"-74", "variable":"RSSI" },{ "id":6, "service":"LYWSD03eb4f4f", "value":"14.1", "variable":"DewPoint" },{ "id":7, "service":"power_BedroomTV", "value":"2021-05-10T21:01:44", "variable":"Time" },{ "id":8, "service":"LYWSD0338eb2e", "value":"a4c13838eb2e", "variable":"mac" },{ "id":9, "service":"LYWSD0338eb2e", "value":"21.6", "variable":"Temperature" },{ "id":10, "service":"LYWSD0338eb2e", "value":"54", "variable":"Humidity" },{ "id":11, "service":"LYWSD0338eb2e", "value":"-85", "variable":"RSSI" },{ "id":12, "service":"LYWSD0338eb2e", "value":"11.9", "variable":"DewPoint" },{ "id":13, "service":"LYWSD03a59e0c", "value":"a4c138a59e0c", "variable":"mac" },{ "id":14, "service":"LYWSD03a59e0c", "value":"20.9", "variable":"Temperature" },{ "id":15, "service":"LYWSD03a59e0c", "value":"58", "variable":"Humidity" },{ "id":16, "service":"LYWSD03a59e0c", "value":"-91", "variable":"RSSI" },{ "id":17, "service":"LYWSD03a59e0c", "value":"12.3", "variable":"DewPoint" },{ "id":18, "service":"power_BedroomTV", "value":"ON", "variable":"Switch2" },{ "id":19, "service":"power_BedroomTV", "value":"ON", "variable":"Switch1" },{ "id":20, "service":"ENERGY", "value":"0", "variable":"Total" },{ "id":21, "service":"ENERGY", "value":"table: 0x556c23b0f060", "variable":"Power" },{ "id":22, "service":"ENERGY", "value":"table: 0x556c23b0f100", "variable":"ApparentPower" },{ "id":23, "service":"ENERGY", "value":"table: 0x556c237e4cd0", "variable":"Current" },{ "id":24, "service":"ENERGY", "value":"121", "variable":"Voltage" },{ "id":25, "service":"ENERGY", "value":"table: 0x556c237e48d0", "variable":"Factor" },{ "id":26, "service":"ENERGY", "value":"0", "variable":"Period" },{ "id":27, "service":"ENERGY", "value":"table: 0x556c23b0f1d0", "variable":"ReactivePower" },{ "id":28, "service":"ENERGY", "value":"0", "variable":"Yesterday" },{ "id":29, "service":"ENERGY", "value":"2021-04-04T05:29:11", "variable":"TotalStartTime" },{ "id":30, "service":"ENERGY", "value":"0", "variable":"Today" },{ "id":31, "service":"ENERGY", "value":"60", "variable":"Frequency" },{ "id":32, "service":"ENERGY", "value":"0", "variable":"Power/1" },{ "id":33, "service":"ENERGY", "value":"0", "variable":"Power/2" },{ "id":34, "service":"ENERGY", "value":"0", "variable":"ApparentPower/1" },{ "id":35, "service":"ENERGY", "value":"0", "variable":"ApparentPower/2" },{ "id":36, "service":"ENERGY", "value":"0", "variable":"Current/1" },{ "id":37, "service":"ENERGY", "value":"0", "variable":"Current/2" },{ "id":38, "service":"ENERGY", "value":"0", "variable":"Factor/1" },{ "id":39, "service":"ENERGY", "value":"0", "variable":"Factor/2" },{ "id":40, "service":"ENERGY", "value":"0", "variable":"ReactivePower/1" },{ "id":41, "service":"ENERGY", "value":"0", "variable":"ReactivePower/2" },{ "id":42, "service":"power_BedroomTV", "value":"50", "variable":"Sleep" },{ "id":43, "service":"power_BedroomTV", "value":"56414", "variable":"UptimeSec" },{ "id":44, "service":"power_BedroomTV", "value":"Dynamic", "variable":"SleepMode" },{ "id":45, "service":"power_BedroomTV", "value":"OFF", "variable":"POWER2" },{ "id":46, "service":"power_BedroomTV", "value":"OFF", "variable":"POWER1" },{ "id":47, "service":"power_BedroomTV", "value":"125", "variable":"Heap" },{ "id":48, "service":"Wifi", "value":"CD", "variable":"SSId" },{ "id":49, "service":"Wifi", "value":"FE:9F:DB:F5:A0:11", "variable":"BSSId" },{ "id":50, "service":"Wifi", "value":"0T00:00:26", "variable":"Downtime" },{ "id":51, "service":"Wifi", "value":"11", "variable":"Channel" },{ "id":52, "service":"Wifi", "value":"86", "variable":"RSSI" },{ "id":53, "service":"Wifi", "value":"2", "variable":"LinkCount" },{ "id":54, "service":"Wifi", "value":"-57", "variable":"Signal" },{ "id":55, "service":"Wifi", "value":"1", "variable":"AP" },{ "id":56, "service":"power_BedroomTV", "value":"2", "variable":"MqttCount" },{ "id":57, "service":"power_BedroomTV", "value":"0T15:40:14", "variable":"Uptime" },{ "id":58, "service":"power_BedroomTV", "value":"19", "variable":"LoadAvg" }], "status":-1, "subcategory_num":0, "time_created":1618456263 }]
@archers I need verbose logs. I have mine setup this way to control a dehumidifier and it’s working ok.
I set the debugmode variable to 1. In the ReadMe it says logs could be captured by navigating to http://VeraIP/cgi-bin/cmh/log.sh?Device=LuaUPnP but this does not seem to work, is it another url for OpenLuup? Or can I find the log somewhere in cmh-ludl?
Just to clarify, the device is still not connected to anything (no IP given) could that be the reason, or should it work anyway?
Latest openLuup development version (v21.5.10, and yes, we're back to that branch) includes fixes for Tasmota (and Shelly) Historian, including archive rules for Temperature / Humidity / Battery variable names.
Please Note: you should reload openLuup once more after updating, to get the Historian and Grafana to sync properly.
@archers it should work regardless. The openluup log page is under /console
Aha, I thought it ended up in a separate logfile.
This is what I get in the log when changing the temperature of the device (no 50):
2021-05-10 22:59:37.312 openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=50&serviceId=urn:upnp-org:serviceId:TemperatureSetpoint1_Heat&action=SetCurrentSetpoint&NewCurrentSetpoint=15 HTTP/1.1 tcp{client}: 0x1ec57b0 2021-05-10 22:59:37.313 luup.call_action:: 50.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.SetCurrentSetpoint 2021-05-10 22:59:37.314 luup_log:50: VirtualDevices[3.0-beta2@50](actionSetCurrentSetpoint@86):actionSetCurrentSetpoint(50,"15","Off","Heating") 2021-05-10 22:59:37.314 luup_log:50: VirtualDevices[3.0-beta2@50](actionSetCurrentSetpoint@90):actionSetCurrentSetpoint: skipped 2021-05-10 22:59:37.315 openLuup.server:: request completed (44 bytes, 1 chunks, 2 ms) tcp{client}: 0x1ec57b0 2021-05-10 22:59:50.043 openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x1ec57b0
@akbooer OK that worked. Thx
Edit: Humidity variables are back. Looks like about 4 hours passed
I still do not see the humidity variables on the cache page though. The humidity values have recently updated as a scene I run based on humidity trigger points, fired about an hour ago. -
@akbooer One small error creating the energy variables
2021-05-10 17:22:42.275 openLuup.context_switch:: ERROR: [dev #0] ./openLuup/whisper.lua:662: Cannot create file '%s' 2021-05-10 17:22:42.275 openLuup.scheduler:: 30001.ENERGY.Current/1 ERROR ./openLuup/whisper.lua:662: Cannot create file '%s' function: 0x5633603dd490 2021-05-10 17:22:42.276 openLuup.context_switch:: ERROR: [dev #0] ./openLuup/whisper.lua:662: Cannot create file '%s' 2021-05-10 17:22:42.276 openLuup.scheduler:: 30001.ENERGY.Current/2 ERROR ./openLuup/whisper.lua:662: Cannot create file '%s' function: 0x5633603dd490
Looking at the logs, you're setting the temperature while the heater is off, so it's skipped. Do you want to turn it on if the temperature is below the target?
@buxton said in openLuup: Tasmota MQTT Bridge:
Yes, that's not unexpected. In fact, it requires two variable updates before the variable appears on the historian list (because many, otherwise untinteresting, variables are updated once at startup.)
Ah yes, those pesky topic separators '/' in the variable name – I knew it would come back to bite me. They are, of course, in the Unix file world, directory path separators. Some work required on the HIstorian filename handling...
I created a new device just to start from fresh:
When I try to change the dropdown from "off" to "Heat" it reverts back after I e.g. change rooms or reload the browser. The same thing when changing the temperature. Should it not stay at the value I set? I may be missing something obvious here on how the heater controller works, since it is the first time I play around with one.
The current temp was at 2000 when the device was created, tried changing it to e.g. 20, but makes no difference.
Some log entries from when changing the values:
2021-05-11 16:04:04.239 openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=52&serviceId=urn:upnp-org:serviceId:TemperatureSetpoint1_Heat&action=SetCurrentSetpoint&NewCurrentSetpoint=21 HTTP/1.1 tcp{client}: 0x2697800 2021-05-11 16:04:04.242 luup.call_action:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.SetCurrentSetpoint 2021-05-11 16:04:04.243 openLuup.server:: request completed (44 bytes, 1 chunks, 2 ms) tcp{client}: 0x2697800 2021-05-11 16:04:09.775 openLuup.server:: GET /cmh/skins/default/img/devices/device_states/dimmable_light_30.png HTTP/1.1 tcp{client}: 0x2697800 2021-05-11 16:04:09.777 openLuup.server:: request completed (938 bytes, 0 chunks, 0 ms) tcp{client}: 0x2697800 2021-05-11 16:04:16.134 openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x2697800 2021-05-11 16:05:43.757 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=741810207&Timeout=60&MinimumDelay=1500&_=1620741805209 HTTP/1.1 tcp{client}: 0x2882ed8 2021-05-11 16:05:45.244 openLuup.server:: GET /data_request?id=action&output_format=json&DeviceNum=52&serviceId=urn:upnp-org:serviceId:HVAC_UserOperatingMode1&action=SetModeTarget&NewMode=HeatOn HTTP/1.1 tcp{client}: 0x2d32838 2021-05-11 16:05:45.246 luup.call_action:: 52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.SetModeTarget 2021-05-11 16:05:45.247 openLuup.server:: request completed (39 bytes, 1 chunks, 1 ms) tcp{client}: 0x2d32838 2021-05-11 16:05:53.818 openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x2d32838
Log from when the device was created:
2021-05-11 10:05:35.089 luup.create_device:: [52] D_VirtualHeater1.xml / I_VirtualHeater1.xml / D_Heater1.json (urn:schemas-upnp-org:device:Heater:1) 2021-05-11 10:05:35.099 openLuup.server:: request completed (6440 bytes, 0 chunks, 34 ms) tcp{client}: 0x1c6c030 2021-05-11 10:05:35.099 openLuup.scheduler:: [52] VirtualHeater2 device startup 2021-05-11 10:05:35.099 luup_log:52: VirtualHeater starting... 2021-05-11 10:05:35.100 luup_log:52: VirtualDevices[3.0-beta2@52]:Plugin starting 2021-05-11 10:05:35.100 luup.device_message:: device=52, status=4, message=Starting..., timeout=5, source=VirtualDevices 2021-05-11 10:05:35.100 luup_log:52: VirtualDevices[3.0-beta2@52]:Child #52 - "VirtualHeater2" 2021-05-11 10:05:35.101 luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.DebugMode was: EMPTY now: 0 #hooks:0 2021-05-11 10:05:35.101 luup.variable_set:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1.CurrentSetpoint was: EMPTY now: 18 #hooks:0 2021-05-11 10:05:35.102 luup.variable_set:: 52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint was: EMPTY now: 18 #hooks:0 2021-05-11 10:05:35.102 luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.TemperatureDevice was: EMPTY now: 0 #hooks:0 2021-05-11 10:05:35.103 luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.SetPowerURL was: EMPTY now: http:// #hooks:0 2021-05-11 10:05:35.103 luup.variable_set:: 52.urn:bochicchio-com:serviceId:VirtualHeater1.SetPowerOffURL was: EMPTY now: http:// #hooks:0 2021-05-11 10:05:35.103 luup.attr_set:: 52.subcategory_num = 2 2021-05-11 10:05:35.106 luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeTarget 2021-05-11 10:05:35.108 luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:HVAC_UserOperatingMode1.ModeStatus 2021-05-11 10:05:35.111 luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSetpoint1.CurrentSetpoint 2021-05-11 10:05:35.113 luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSetpoint1_Heat.CurrentSetpoint 2021-05-11 10:05:35.116 luup.variable_watch:: callback=virtualThermostatWatch, watching=52.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature 2021-05-11 10:05:35.116 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.Configured was: 0 now: 1 #hooks:0 2021-05-11 10:05:35.116 luup.set_failure:: status = 0 2021-05-11 10:05:35.117 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2021-05-11 10:05:35.117 luup.variable_set:: 52.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0 2021-05-11 10:05:35.117 openLuup.scheduler:: [52] VirtualHeater2 device startup completed: status=true, msg=Ready, name=VirtualDevices 2021-05-11 10:05:35.626 openLuup.server:: request completed (4456 bytes, 1 chunks, 8545 ms) tcp{client}: 0x20a2fc0 2021-05-11 10:05:35.714 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=679125970&_=1620678904534 HTTP/1.1 tcp{client}: 0x20a2fc0 2021-05-11 10:05:36.145 openLuup.server:: request completed (764639 bytes, 48 chunks, 429 ms) tcp{client}: 0x20a2fc0 2021-05-11 10:05:38.584 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=679159576&Timeout=60&MinimumDelay=1500&_=1620678904535 HTTP/1.1 tcp{client}: 0x20a2fc0 2021-05-11 10:05:41.932 openLuup.server:: GET /console?page=log HTTP/1.1 tcp{client}: 0x1c6c030
