Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
Updated to latest MSR 21243 and no entities are being executed I Hubitat
hehe.... went exited/etc/systemd/system/reactor.service......
[Unit] Description=Multi System Reactor After=network.target [Service] Type=simple User=pi WorkingDirectory=/home/pi/reactor Environment=NODE_PATH=/home/pi/reactor ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node Restart=on-failure RestartSec=5s [Install] WantedBy=multi-user.target
Reactor log......
2021-09-06T20:07:08.063Z <app:null> Reactor "1.0.1-21243-ab6d917" starting on v14.15.4 2021-09-06T20:07:08.066Z <app:INFO> Process ID 3029; platform linux/arm #1408 SMP Mon Mar 22 12:49:24 GMT 2021; locale [ "sv-SE", "UTF-8" ] 2021-09-06T20:07:08.067Z <app:INFO> Basedir /home/pi/reactor; data in /home/pi/reactor/storage 2021-09-06T20:07:08.067Z <app:INFO> NODE_PATH /home/pi/reactor; module paths [ "/home/pi/reactor/node_modules", "/home/pi/node_modules", "/home/node_modules", "/node_modules" ] 2021-09-06T20:07:08.241Z <Plugin:null> Module Plugin v21173 2021-09-06T20:07:08.273Z <default:INFO> Module Entity v21177 2021-09-06T20:07:08.284Z <Controller:null> Module Controller v21226 2021-09-06T20:07:08.286Z <default:null> Module Structure v21229 2021-09-06T20:07:08.305Z <default:null> Module Ruleset v21096 2021-09-06T20:07:08.306Z <default:null> Module Rulesets v21096 2021-09-06T20:07:08.380Z <default:null> Module Rule v21224 2021-09-06T20:07:08.397Z <default:null> Module Engine v21213 2021-09-06T20:07:08.399Z <default:null> Module httpapi v21238 2021-09-06T20:07:08.406Z <default:null> Module httpproxy v21054 2021-09-06T20:07:08.450Z <default:null> Module wsapi v21196 2021-09-06T20:07:08.454Z <app:NOTICE> Starting Structure... 2021-09-06T20:07:08.463Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController) 2021-09-06T20:07:08.473Z <Structure:INFO> Structure#1 starting controller interface hubitat (HubitatController) 2021-09-06T20:07:08.480Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-09-06T20:07:08.622Z <default:null> Module VeraController v21236 2021-09-06T20:07:08.629Z <default:null> Module HubitatController v21243 2021-09-06T20:07:08.632Z <default:null> Module SystemController v21102 2021-09-06T20:07:08.642Z <VeraController:NOTICE> VeraController#vera starting 2021-09-06T20:07:08.765Z <VeraController:INFO> VeraController#vera loaded mapping ver 21236 rev 1 format 1 notice 2021-09-06T20:07:08.767Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state 2021-09-06T20:07:08.887Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-09-06T20:07:09.035Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-09-06T20:07:09.044Z <Controller:NOTICE> HubitatController#hubitat not ready; performing initial connect/query 2021-09-06T20:07:09.629Z <VeraController:NOTICE> Controller VeraController#vera is now online. 2021-09-06T20:07:10.118Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.158Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.274Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.281Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.287Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.289Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.318Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.326Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.331Z <Controller:ERR> HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation 2021-09-06T20:07:10.478Z <Controller:INFO> HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.68.145/eventsocket 2021-09-06T20:07:10.484Z <Controller:NOTICE> Controller HubitatController#hubitat is now online. 2021-09-06T20:07:10.489Z <app:NOTICE> Starting Reaction Engine... 2021-09-06T20:07:10.491Z <Engine:INFO> Reaction Engine starting 2021-09-06T20:07:10.492Z <Engine:INFO> Checking rule sets... 2021-09-06T20:07:10.504Z <Engine:INFO> Checking rules... 2021-09-06T20:07:10.506Z <Engine:INFO> Data check complete; no corrections.
OK. Looks good.
First, make sure your command line Reactor is stopped. This is important, obviously, as the systemd Reactor will not start and keep trying to start if your command line Reactor is still running. Also, let's remove the existing Reactor log file:
rm /home/pi/reactor/logs/reactor.log
Then,
sudo systemctl daemon-reload
Then,
sudo systemctl restart reactor
Then try to get into the Reactor UI. If you can't get into the UI, look at the
reactor.log
file for messages. In you still have the "common/util" exception, go up to the startup lines and look at what it reports for NODE_PATH and post that here. -
@toggledbits Could not reach thrue UI .
The reactor.log file is no missing since the rm command.....
OK. Then
/var/log/syslog
And tell me, how did you edit the service file? There are some excess blank lines in what you posted when I got it formatted as code on the forums... that's... odd... did you edit it on the system, or did you pull it up to a Mac or Windows, edit it, and then push it down? Or something else?
I edited them directly on the pie in the textfile.
this is what the var log file said:
Sep 6 22:17:23 raspberrypi dhcpcd[428]: wlan0: fe80::465:fde6:f33:2344 is reachable again
Sep 6 22:17:23 raspberrypi avahi-daemon[429]: Withdrawing address record for fe80::2598:15e9:620:fe7d on eth0.
Sep 6 22:17:26 raspberrypi dhcpcd[428]: eth0: leased 192.168.68.126 for 7200 seconds
Sep 6 22:17:26 raspberrypi avahi-daemon[429]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.68.126.
Sep 6 22:17:26 raspberrypi dhcpcd[428]: eth0: adding route to 192.168.68.0/24
Sep 6 22:17:26 raspberrypi dhcpcd[428]: eth0: adding default route via 192.168.68.1
Sep 6 22:17:26 raspberrypi avahi-daemon[429]: New relevant interface eth0.IPv4 for mDNS.
Sep 6 22:17:26 raspberrypi avahi-daemon[429]: Registering new address record for 192.168.68.126 on eth0.IPv4.
Sep 6 22:17:34 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
Sep 6 22:50:34 raspberrypi systemd-timesyncd[339]: Synchronized to time server for the first time 178.16.128.13:123 (2.debian.pool.ntp.org).
Sep 6 22:50:41 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
Sep 6 22:53:32 raspberrypi dbus-daemon[626]: [session uid=1000 pid=626] Activating service name='ca.desrt.dconf' requested by ':1.28' (uid=1000 pid=1084 comm="mousepad /var/log/syslog ")
Sep 6 22:53:32 raspberrypi dbus-daemon[626]: [session uid=1000 pid=626] Successfully activated service 'ca.desrt.dconf'
Sep 6 22:54:50 raspberrypi dbus-daemon[418]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.51' (uid=1000 pid=1100 comm="/usr/lib/chromium-browser/chromium-browser-v7 --fo")
Sep 6 22:54:50 raspberrypi systemd[1]: Starting Hostname Service...
Sep 6 22:54:50 raspberrypi dbus-daemon[418]: [system] Successfully activated service 'org.freedesktop.hostname1'
Sep 6 22:54:50 raspberrypi systemd[1]: Started Hostname Service.
Sep 6 22:54:50 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
Sep 6 22:54:51 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
Sep 6 22:54:52 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
Sep 6 22:54:53 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
Sep 6 22:54:54 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
Sep 6 22:54:55 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas
Sep 6 22:54:55 raspberrypi gvfsd[665]: mkdir failed on directory /var/cache/samba: Åtkomst nekas -
I just noticed, the
ExecStart
line in your edited service file is incomplete. It should read:ExecStart=/home/pi/.local/lib/nodejs/node-v14.15.4-linux-armv7l/bin/node app -p
Fix that. Then do:
sudo systemctl daemon-reload sudo systemctl restart reactor
@toggledbits said in Updated to latest MSR 21243 and no entities are being executed I Hubitat:
Changed it and now i can reach msr thrue UI!
Here is the reactor.log
2021-09-06T21:05:42.633Z app:null Reactor "1.0.1-21243-ab6d917" starting on v14.15.4
2021-09-06T21:05:42.636Z app:INFO Process ID 1780; platform linux/arm #1408 SMP Mon Mar 22 12:49:24 GMT 2021; locale [ "sv-SE", "UTF-8" ]
2021-09-06T21:05:42.637Z app:INFO Basedir /home/pi/reactor; data in /home/pi/reactor/storage
2021-09-06T21:05:42.637Z app:INFO NODE_PATH /home/pi/reactor; module paths [ "/home/pi/reactor/node_modules", "/home/pi/node_modules", "/home/node_modules", "/node_modules" ]
2021-09-06T21:05:42.781Z Plugin:null Module Plugin v21173
2021-09-06T21:05:42.797Z default:INFO Module Entity v21177
2021-09-06T21:05:42.805Z Controller:null Module Controller v21226
2021-09-06T21:05:42.806Z default:null Module Structure v21229
2021-09-06T21:05:42.822Z default:null Module Ruleset v21096
2021-09-06T21:05:42.823Z default:null Module Rulesets v21096
2021-09-06T21:05:42.869Z default:null Module Rule v21224
2021-09-06T21:05:42.880Z default:null Module Engine v21213
2021-09-06T21:05:42.881Z default:null Module httpapi v21238
2021-09-06T21:05:42.886Z default:null Module httpproxy v21054
2021-09-06T21:05:42.925Z default:null Module wsapi v21196
2021-09-06T21:05:42.928Z app:NOTICE Starting Structure...
2021-09-06T21:05:42.936Z Structure:INFO Structure#1 starting controller interface vera (VeraController)
2021-09-06T21:05:42.944Z Structure:INFO Structure#1 starting controller interface hubitat (HubitatController)
2021-09-06T21:05:42.947Z Structure:INFO Structure#1 starting controller interface reactor_system (SystemController)
2021-09-06T21:05:43.018Z default:null Module VeraController v21236
2021-09-06T21:05:43.026Z default:null Module HubitatController v21243
2021-09-06T21:05:43.029Z default:null Module SystemController v21102
2021-09-06T21:05:43.037Z VeraController:NOTICE VeraController#vera starting
2021-09-06T21:05:43.145Z VeraController:INFO VeraController#vera loaded mapping ver 21236 rev 1 format 1 notice
2021-09-06T21:05:43.148Z VeraController:INFO VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
2021-09-06T21:05:43.227Z Controller:NOTICE Controller SystemController#reactor_system is now online.
2021-09-06T21:05:43.339Z app:INFO Structure running; pausing for controllers' initial ready
2021-09-06T21:05:43.347Z Controller:NOTICE HubitatController#hubitat not ready; performing initial connect/query
2021-09-06T21:05:43.896Z VeraController:NOTICE Controller VeraController#vera is now online.
2021-09-06T21:05:45.291Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.322Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.383Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.387Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.391Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.394Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.409Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.414Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.418Z Controller:ERR HubitatController#hubitat mapped capability x_hubitat_healthcheck has no implementation
2021-09-06T21:05:45.510Z Controller:INFO HubitatController#hubitat connecting to hub's eventsocket WebSocket API at ws://192.168.68.145/eventsocket
2021-09-06T21:05:45.517Z Controller:NOTICE Controller HubitatController#hubitat is now online.
2021-09-06T21:05:45.522Z app:NOTICE Starting Reaction Engine...
2021-09-06T21:05:45.524Z Engine:INFO Reaction Engine starting
2021-09-06T21:05:45.525Z Engine:INFO Checking rule sets...
2021-09-06T21:05:45.542Z Engine:INFO Checking rules...
2021-09-06T21:05:45.544Z Engine:INFO Data check complete; no corrections. -
That's better. OK, no more command line. Do this as well:
sudo systemctl enable reactor
This will tell systemd to start Reactor at boot (which you should then test). If you have any other mechanism for starting Reactor at boot (e.g. modified .profile or bashrc files), then those will need to be removed/disabled.
ok.... I cut the power and restarted the pie and msr got up by it self!!Coool!
Noice! OK. You're on your way! NOW we're finished!
@tunnus said in Updated to latest MSR 21243 and no entities are being executed I Hubitat:
@matteburk could check this post, although you probably have some other issue
Well, it turned out you had the same issue
May I say to you all - thank you!
I undertook the mini-project of migrating MSR from SD card to SSD. Full transparency, I'm not a Linux guy in any way/shape/form so there was a good deal of feeling my way thru the dark. Once I got it moved and running (honestly, on the first try!) I wanted the next logical step of start/restart at boot. Was really fumbling until I found this thread - it was better than any tutorial I'd been using.
Success is mine: on the SSD and with everything starting at boot like desired.
Thanks @Matteburk for making mistakes similar to mine and to @toggledbits for his INFINITE patience and guidance. (The
app -p
thing was actually a question I had after seeing an earlier screenshot in the thread and having removed it only to meet failure nose-to-nose.) -
