  4. Host time is wrong
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Host time is wrong
14 Posts 3 Posters 3.0k Views 3 Watching
  • wmarcolinW Offline
    After a prolonged power cut, the UPS was unable to cope with the weather and shut down the entire system.
    When I returned, I had the problem that the host time displayed in the browser and automatically used in the rules was not correct.
    I searched for a topic here on this forum that talked about it, but it referred to a container installation. There was a recommendation to go into the storage/states directory and delete the files and restart MSR, I did it and it didn't solve the problem.
    There was also a recommendation to go directly to the browser to check the time, and I did so and I see that the time is correct.
    As you can see on the screen above:
    • MSR browser shows the correct browser time 21:23, but host time 13:02;
    • In the browser below the direct query and the host time is correct 9:22:54 PM;
    • Setting the VM date command on the third screen, the time is 9:23:00 PM.
    I've opened the entire reactor.log file and searched for any errors, and there aren't any.
    ^L
    [latest-23242]2023-09-15T02:11:12.928Z <app:null> Reactor build latest-23242-5ee8e1d4 starting on v18.12.0
    [latest-23242]2023-09-15T02:11:12.929Z <app:null> Process ID 1807 user/group 1000/1000; bare-metal; platform linux/x64 #179-Ubuntu SMP Mo>
    [latest-23242]2023-09-15T02:11:12.929Z <app:null> Basedir /home/leonardo/reactor; data in /home/leonardo/reactor/storage
    [latest-23242]2023-09-15T02:11:12.929Z <app:null> NODE_PATH=/home/leonardo/reactor
    [latest-23242]2023-09-15T02:11:12.933Z <app:INFO> Configured locale (undefined); selected locale(s) en_US.UTF-8
    [latest-23242]2023-09-15T02:11:12.955Z <app:INFO> Loaded locale en-US for en-US
    [latest-23242]2023-09-15T02:11:12.958Z <Structure:null> Module Structure v23172
    [latest-23242]2023-09-15T02:11:12.959Z <Capabilities:null> Module Capabilities v22356
    [latest-23242]2023-09-15T02:11:12.969Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 23914 revisi>
    [latest-23242]2023-09-15T02:11:12.978Z <Plugin:null> Module Plugin v22300
    [latest-23242]2023-09-15T02:11:12.981Z <TimerBroker:null> Module TimerBroker v22283
    [latest-23242]2023-09-15T02:11:12.983Z <Entity:null> Module Entity v22353
    [latest-23242]2023-09-15T02:11:12.986Z <Controller:null> Module Controller v23069
    [latest-23242]2023-09-15T02:11:12.992Z <default:null> Module Ruleset v22293
    [latest-23242]2023-09-15T02:11:12.992Z <default:null> Module Rulesets v22146
    [latest-23242]2023-09-15T02:11:12.996Z <GlobalExpression:null> Module GlobalExpression v23211
    [latest-23242]2023-09-15T02:11:13.003Z <Predicate:null> Module Predicate v23093
    [latest-23242]2023-09-15T02:11:13.005Z <AlertManager:null> Module AlertManager v22283
    [latest-23242]2023-09-15T02:11:13.007Z <Rule:null> Module Rule v23107
    [latest-23242]2023-09-15T02:11:13.009Z <GlobalReaction:null> Module GlobalReaction v22324
    [latest-23242]2023-09-15T02:11:13.010Z <Engine:null> Module Engine v23231
    [latest-23242]2023-09-15T02:11:13.012Z <httpapi:null> Module httpapi v23058
    [latest-23242]2023-09-15T02:11:13.019Z <wsapi:null> Module wsapi v23172
    [latest-23242]2023-09-15T02:11:13.019Z <app:NOTICE> Starting Structure...
    As you can see, the time in the log is 02:11, which is correct, because I'm in time zone -5, which means it's 09:11PM for me.
    I've restarted the VM, the computer hosting the VM, and the MSR a few times and the same difference remains. What do you recommend for the next step in understanding and solving the problem?
      Hi @toggledbits , any recommendations on how to align the two schedules? Thanks!
        No idea. I assume you hard-reloaded the browser? Is the TZ being set for some reason in your service configuration file?
          It really is rare.
          I haven't changed anything in the TZ configuration I had before, I compared the two installations I have in different environments, and they are identical. The rules even operate at the correct time. I've downloaded and restarted the VM, the computer, I've cleared the cash from the browser, and I'm still seeing this strange time.
            The strangest thing is that if I use the command
            http://192.168.50.8:8111/diag/sun
            shows the correct host time.
            Look at this screen to see the difference of 55 minutes, but note that the rules have the correct time.
              So what's the odd wrapper around the browser?
              wmarcolinW 1 Reply Last reply
                @toggledbits said in Host time is wrong:
                The time difference that indicates that you have the browser, and the time that indicates the host.
                All the queries in the VM, on my computer that opens the browse, using the diag/sun query have a different time to the one that MSR points to as the host time.
                  Not what I'm asking. Are you using some kind of remote access gateway?
                    @toggledbits Appears OP is using AnyDesk, a remote desktop application like Teamviewer, VNC, etc.
                      @gwp1 So it seems.
                      And if that's the case, then there are THREE computers involved here: the host/server on which MSR is running, the host on which the browser to running (i.e. the remote target of the AnyDesk connection), and the computer on which the AnyDesk client is being run.
                      I would venture to guess that the date/time is incorrect on the remote target (the system AnyDesk is connecting to, actually running the browser). I'm guessing the time displayed in the lower right corner is the time of the AnyDesk client machine, not the remote browser/host, and the client's time is irrelevant here. The browser is actually running on a remote target system, and it's the time on that remote target system that's in question here.
                      Beyond that, my suggestion is to connect to MSR locally from a local browser/computer, not using AnyDesk. But in all, this doesn't seem like an MSR issue, it seems like a (one of the many) host configuration issue.
                      G wmarcolinW 2 Replies Last reply
                        @gwp1 So it seems.
                        @wmarcolin see above response.
                          @gwp1 So it seems.
                          Hi, let's to align.
                          In my house, where everything works normally, or in my neighbor's house, which worked normally until two weeks ago, we have a separate computer, on which a Linux VM is mounted, where MSR is installed. This local computer is where I open the browser and we see in my friend's case the time difference from the host.
                          For ease of work, I have the AnyDesk application installed on the VM machine and on the computer I use to access it (not by browser), i.e. this application only opens a remote operating terminal, it would not be influencing this situation.
                          Anyway, I'm going to ask my friend to open MSR in browse at home and send me a picture of the screen, so we can resolve this doubt.
                          • wmarcolinW wmarcolin
                            Hi, let's to align.
                            @wmarcolin Have you checked that the host machine for MSR is properly syncing the date/time? This would not be MSR's job but the OS itself.
                              Screen shot simultaneo:
                                165.5k
