Constraints (no data) rule actions have never run
OK. Not seeing an email yet... you used the address in the "Support" section of the About page?
@cw-kid I removed your post just for my own anti-spam/scraping reduction, no other reason. The address you showed is fine. If you know how to reach me in my primary domain, that's fine too. I just point out the About page because it will always be there.
Logs from two days ago don't help when (a) you've update the software, (b) the condition that was a problem now isn't, and (c) a condition that wasn't a problem now is.
Too many changes. Need fresh logs.The log does show that the rule "Heating turn ON Check Opened Windows" needs to be updated to use the hvac capability attribute (which didn't exist when you created the rule apparently, so you're using the device's extended attribute). You just need to go in and fix that rule. I don't have the "Trouble" system working yet, which will pick stuff like that up.
@toggledbits Thanks for the heads up. I've changed that rule to use hvac_heating_unit.setpoint instead then.
I'll do some more testing on these two problem rules with set start times. I believe one is working now after I recreated it and the other I need to see if its working now or not ?
If it's not working, don't recreate it yet. Save the JSON file with its ID from inside storage/rules and send that to me (you can just post it on a PR--should be small/short). After you've capture it, then you can go ahead and recreate. If there's anything broken in the rule itself, I should be able to see it.
