  4. Constraints (no data) rule actions have never run
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
26 Posts 3 Posters 10.2k Views 3 Watching
  • MatohlM Matohl
    So it worked after the update?
    @matohl I've no idea what's going on.
    That rule that didn't run when it should of at 9am has now ran its action at 10.04am after I updated and restarted MSR etc, as it sent a notification to my phone in Telegram
    • MatohlM Offline
      MatohlM Offline
      Matohl
      Yes, it went true when you restarted (it's still after 09.00). Why it didn't run at 09.00 I can not tell, I have similar triggers that's works fine
        I have created a lot of other rules, some of them also with Constraints and none of those rules say null or no data in the Constraints in the rules summary card.
        I've gone through them all now again looking and it seems I only have two rules which I have highlighted above that don't run and they say or have said null or no data in Constraints.
        All my other garden lights have turned on and off OK, but they are using a sunset offset not a specific set time.
        But that rule to turn off the Festoon lights at 23:55pm has never run since I created it.
        I also have rules for the window coverings setup for specific times in the morning and generally they have all run at their set times OK.
        I will see what happens tomorrow at 9am with this "Lounge Blind Slats" one ?
          The 11:55pm rule that never worked since I created it, I deleted it. I then created it again exactly the same as I did before. Looking at its Summary card the Constraints stated no data / null etc. I then edited the rule and changed its time to 9:00am and saved. I then edited the rule again and set it back to 11:55pm and saved.
          The rule now runs and turns off my lights at 11:55pm or it did last night at least anyway. So assume it will work every night now.
          I created another new rule not related to run every night at 10:30pm and that one worked first time no problems, so not sure why I have had issues with a few rules.
          The 9am rule to open the Lounge Blind Slats didn't run this morning again, so I've deleted it and recreated it, see what happens with that tomorrow morning ?
          • toggledbitsT Online
            toggledbitsT Online
            Remember two things:
            1. Log files are pretty good at telling what's going on, and really good at help me determine what's going on;
            2. Open PRs are my highest priority.
              I emailed the logs to you as you asked above.
                toggledbitsT Online
                OK. Not seeing an email yet... you used the address in the "Support" section of the About page?
                    toggledbitsT Online
                    @cw-kid I removed your post just for my own anti-spam/scraping reduction, no other reason. The address you showed is fine. If you know how to reach me in my primary domain, that's fine too. I just point out the About page because it will always be there.
                      No worries.
                      Check your patrick@ primary domain I sent the logs there on the 26th
                        toggledbitsT Online
                        Logs from two days ago don't help when (a) you've update the software, (b) the condition that was a problem now isn't, and (c) a condition that wasn't a problem now is. 🙂 Too many changes. Need fresh logs.
                        The log does show that the rule "Heating turn ON Check Opened Windows" needs to be updated to use the hvac capability attribute (which didn't exist when you created the rule apparently, so you're using the device's extended attribute). You just need to go in and fix that rule. I don't have the "Trouble" system working yet, which will pick stuff like that up.
                          @toggledbits Thanks for the heads up. I've changed that rule to use hvac_heating_unit.setpoint instead then.
                          I'll do some more testing on these two problem rules with set start times. I believe one is working now after I recreated it and the other I need to see if its working now or not ?
                            toggledbitsT Online
                            If it's not working, don't recreate it yet. Save the JSON file with its ID from inside storage/rules and send that to me (you can just post it on a PR--should be small/short). After you've capture it, then you can go ahead and recreate. If there's anything broken in the rule itself, I should be able to see it.
                              163.4k
