  4. Constraints (no data) rule actions have never run
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
26 Posts 3 Posters 10.2k Views 3 Watching
    I have other Schedules in MSR for certain times in the morning to open window coverings they are now all working fine and open on the time I set in their triggers.
    If I use the command "date" on the Pi in putty it does say the correct time as of now:
    Fri 26 Feb 13:15:22 GMT 2021
    I'll have a look in the Reactor logs
      Looking in reactor.log I searched this rules ID code kljc5802:
      2021-02-25T19:00:05.003Z <Engine:INFO> Engine#1 master timer tick, local time "2/25/2021, 19:00:05" (TZ offset 0 mins from UTC)
      false
      false2021-02-25T19:34:00.006Z <Rule:5:Rule.js:635> Rule#rule-kljc5802 launching eval from timer-trigger notification by Timer#cond57lqecd
      false
      false2021-02-25T19:34:00.009Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      false
      false2021-02-25T19:34:00.012Z <Rule:5:Rule.js:635> Rule#rule-kljbrk9g launching eval from timer-trigger notification by Timer#cond57lqecd
      false
      false2021-02-25T19:34:00.014Z <Rule:5:Rule.js:697> Rule#rule-kljbrk9g (Schedule - Lawn Lights OFF) evaluate() acquiring mutex
      false
      false2021-02-25T19:34:00.017Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      false
      false2021-02-25T19:34:00.021Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 0/min limit 60/min
      false
      false2021-02-25T19:34:00.023Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      false
      false2021-02-25T19:34:00.025Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/25/2021, 23:55:00 edt=2/25/2021, 19:34:00 now=2/25/2021, 19:34:00
      false
      false2021-02-25T19:34:00.028Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/25/2021, 23:55:00, 15659 secs from now
      false
      false2021-02-25T19:34:00.030Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      false
      false
      2021-02-25T20:13:27.338Z <Engine:5:Engine.js:550> Engine#1 (re-)starting rule Rule#rule-kljc5802 (Schedule - Festoon Lights OFF)
      2021-02-25T20:13:27.340Z <Rule:5:Rule.js:555> Rule#rule-kljc5802 start(), awaiting mutex
      2021-02-25T20:13:27.513Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 restored states: trig=false, rule=false
      2021-02-25T20:13:27.515Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 subscribing to dependencies
      2021-02-25T20:13:27.517Z <Rule:INFO> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) started
      2021-02-25T20:13:27.761Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-25T20:13:27.762Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 0/min limit 60/min
      2021-02-25T20:13:27.765Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-25T20:13:27.767Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/25/2021, 23:55:00 edt=2/25/2021, 20:13:00 now=2/25/2021, 20:13:27
      2021-02-25T20:13:27.771Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/25/2021, 23:55:00, 13292 secs from now
      2021-02-25T20:13:27.774Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T00:00:00.129Z <Rule:5:Rule.js:635> Rule#rule-kljc5802 launching eval from timer-trigger notification by Timer#cond57lqecd
      2021-02-26T00:00:00.131Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      2021-02-26T00:00:00.136Z <Rule:5:Rule.js:635> Rule#rule-kljbrk9g launching eval from timer-trigger notification by Timer#cond57lqecd
      2021-02-26T00:00:00.139Z <Rule:5:Rule.js:697> Rule#rule-kljbrk9g (Schedule - Lawn Lights OFF) evaluate() acquiring mutex
      2021-02-26T00:00:00.141Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T00:00:00.145Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 0/min limit 60/min
      2021-02-26T00:00:00.147Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T00:00:00.150Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 00:00:00 now=2/26/2021, 00:00:00
      2021-02-26T00:00:00.152Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 86099 secs from now
      2021-02-26T00:00:00.154Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:02:14.128Z <Rule:NOTICE> Rule#rule-kljc5802 configuration changed; reloading
      2021-02-26T11:02:14.147Z <Rule:5:Rule.js:600> Rule#rule-kljc5802 reloading with new data
      2021-02-26T11:02:14.150Z <Rule:NOTICE> Rule#rule-kljc5802 stopping rule
      2021-02-26T11:02:14.152Z <Rule:5:Rule.js:581> Rule#rule-kljc5802 acquiring mutex
      2021-02-26T11:02:14.157Z <Rule:5:Rule.js:584> Rule#rule-kljc5802 mutex acquired; unsubscribing from condition dependencies
      2021-02-26T11:02:14.169Z <Rule:5:Rule.js:586> Rule#rule-kljc5802 saving states
      2021-02-26T11:02:14.176Z <Rule:5:Rule.js:590> Rule#rule-kljc5802 stopped
      2021-02-26T11:02:14.178Z <Rule:NOTICE> Rule Rule#rule-kljc5802 stopped
      2021-02-26T11:02:14.180Z <Rule:5:Rule.js:555> Rule#rule-kljc5802 start(), awaiting mutex
      2021-02-26T11:02:14.183Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 restored states: trig=false, rule=false
      2021-02-26T11:02:14.185Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 subscribing to dependencies
      2021-02-26T11:02:14.378Z <Rule:INFO> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) started
      2021-02-26T11:02:14.381Z <Rule:5:Rule.js:567> Rule#rule-kljc5802 start() dependencies resolved, performing initial evaluation
      2021-02-26T11:02:14.509Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      2021-02-26T11:02:14.511Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:02:14.518Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 0/min limit 60/min
      2021-02-26T11:02:14.520Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:02:14.523Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:02:00 now=2/26/2021, 11:02:14
      2021-02-26T11:02:14.527Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 46365 secs from now
      2021-02-26T11:02:14.529Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:02:52.786Z <Rule:NOTICE> Rule#rule-kljc5802 configuration changed; reloading
      2021-02-26T11:02:52.792Z <Rule:5:Rule.js:600> Rule#rule-kljc5802 reloading with new data
      2021-02-26T11:02:52.794Z <Rule:NOTICE> Rule#rule-kljc5802 stopping rule
      2021-02-26T11:02:52.797Z <Rule:5:Rule.js:581> Rule#rule-kljc5802 acquiring mutex
      2021-02-26T11:02:52.803Z <Rule:5:Rule.js:584> Rule#rule-kljc5802 mutex acquired; unsubscribing from condition dependencies
      2021-02-26T11:02:52.816Z <Rule:5:Rule.js:586> Rule#rule-kljc5802 saving states
      2021-02-26T11:02:52.823Z <Rule:5:Rule.js:590> Rule#rule-kljc5802 stopped
      2021-02-26T11:02:52.824Z <Rule:NOTICE> Rule Rule#rule-kljc5802 stopped
      2021-02-26T11:02:52.828Z <Rule:5:Rule.js:555> Rule#rule-kljc5802 start(), awaiting mutex
      2021-02-26T11:02:52.831Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 restored states: trig=false, rule=false
      2021-02-26T11:02:52.833Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 subscribing to dependencies
      2021-02-26T11:02:52.835Z <Rule:INFO> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) started
      2021-02-26T11:02:52.838Z <Rule:5:Rule.js:567> Rule#rule-kljc5802 start() dependencies resolved, performing initial evaluation
      2021-02-26T11:02:52.840Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      2021-02-26T11:02:52.844Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:02:52.846Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 1/min limit 60/min
      2021-02-26T11:02:52.848Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:02:52.850Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:02:00 now=2/26/2021, 11:02:52
      2021-02-26T11:02:52.852Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 46327 secs from now
      2021-02-26T11:02:52.854Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:03:25.898Z <Rule:NOTICE> Rule#rule-kljc5802 configuration changed; reloading
      2021-02-26T11:03:25.904Z <Rule:5:Rule.js:600> Rule#rule-kljc5802 reloading with new data
      2021-02-26T11:03:25.905Z <Rule:NOTICE> Rule#rule-kljc5802 stopping rule
      2021-02-26T11:03:25.908Z <Rule:5:Rule.js:581> Rule#rule-kljc5802 acquiring mutex
      2021-02-26T11:03:25.913Z <Rule:5:Rule.js:584> Rule#rule-kljc5802 mutex acquired; unsubscribing from condition dependencies
      2021-02-26T11:03:25.922Z <Rule:5:Rule.js:586> Rule#rule-kljc5802 saving states
      2021-02-26T11:03:25.929Z <Rule:5:Rule.js:590> Rule#rule-kljc5802 stopped
      2021-02-26T11:03:25.930Z <Rule:NOTICE> Rule Rule#rule-kljc5802 stopped
      2021-02-26T11:03:25.933Z <Rule:5:Rule.js:555> Rule#rule-kljc5802 start(), awaiting mutex
      2021-02-26T11:03:25.935Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 restored states: trig=false, rule=false
      2021-02-26T11:03:25.937Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 subscribing to dependencies
      2021-02-26T11:03:25.938Z <Rule:INFO> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) started
      2021-02-26T11:03:25.940Z <Rule:5:Rule.js:567> Rule#rule-kljc5802 start() dependencies resolved, performing initial evaluation
      2021-02-26T11:03:25.942Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      2021-02-26T11:03:25.944Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:03:25.945Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 1/min limit 60/min
      2021-02-26T11:03:25.948Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:03:25.950Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:03:00 now=2/26/2021, 11:03:25
      2021-02-26T11:03:25.952Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 46294 secs from now
      2021-02-26T11:03:25.954Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:03:52.673Z <Rule:NOTICE> Rule#rule-kljc5802 configuration changed; reloading
      2021-02-26T11:03:52.677Z <Rule:5:Rule.js:600> Rule#rule-kljc5802 reloading with new data
      2021-02-26T11:03:52.693Z <Rule:NOTICE> Rule#rule-kljc5802 stopping rule
      2021-02-26T11:03:52.695Z <Rule:5:Rule.js:581> Rule#rule-kljc5802 acquiring mutex
      2021-02-26T11:03:52.701Z <Rule:5:Rule.js:584> Rule#rule-kljc5802 mutex acquired; unsubscribing from condition dependencies
      2021-02-26T11:03:52.721Z <Rule:5:Rule.js:586> Rule#rule-kljc5802 saving states
      2021-02-26T11:03:52.729Z <Rule:5:Rule.js:590> Rule#rule-kljc5802 stopped
      2021-02-26T11:03:52.731Z <Rule:NOTICE> Rule Rule#rule-kljc5802 stopped
      2021-02-26T11:03:52.733Z <Rule:5:Rule.js:555> Rule#rule-kljc5802 start(), awaiting mutex
      2021-02-26T11:03:52.736Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 restored states: trig=false, rule=false
      2021-02-26T11:03:52.738Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 subscribing to dependencies
      2021-02-26T11:03:52.740Z <Rule:INFO> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) started
      2021-02-26T11:03:52.742Z <Rule:5:Rule.js:567> Rule#rule-kljc5802 start() dependencies resolved, performing initial evaluation
      2021-02-26T11:03:52.744Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      2021-02-26T11:03:52.747Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:03:52.749Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 1/min limit 60/min
      2021-02-26T11:03:52.754Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:03:52.757Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:03:00 now=2/26/2021, 11:03:52
      2021-02-26T11:03:52.759Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 46267 secs from now
      2021-02-26T11:03:52.761Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:04:13.259Z <Rule:NOTICE> Rule#rule-kljc5802 configuration changed; reloading
      2021-02-26T11:04:13.264Z <Rule:5:Rule.js:600> Rule#rule-kljc5802 reloading with new data
      2021-02-26T11:04:13.265Z <Rule:NOTICE> Rule#rule-kljc5802 stopping rule
      2021-02-26T11:04:13.266Z <Rule:5:Rule.js:581> Rule#rule-kljc5802 acquiring mutex
      2021-02-26T11:04:13.271Z <Rule:5:Rule.js:584> Rule#rule-kljc5802 mutex acquired; unsubscribing from condition dependencies
      2021-02-26T11:04:13.274Z <Rule:5:Rule.js:586> Rule#rule-kljc5802 saving states
      2021-02-26T11:04:13.281Z <Rule:5:Rule.js:590> Rule#rule-kljc5802 stopped
      2021-02-26T11:04:13.282Z <Rule:NOTICE> Rule Rule#rule-kljc5802 stopped
      2021-02-26T11:04:13.284Z <Rule:5:Rule.js:555> Rule#rule-kljc5802 start(), awaiting mutex
      2021-02-26T11:04:13.286Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 restored states: trig=false, rule=false
      2021-02-26T11:04:13.287Z <Rule:5:Rule.js:563> Rule#rule-kljc5802 subscribing to dependencies
      2021-02-26T11:04:13.289Z <Rule:INFO> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) started
      2021-02-26T11:04:13.290Z <Rule:5:Rule.js:567> Rule#rule-kljc5802 start() dependencies resolved, performing initial evaluation
      2021-02-26T11:04:13.292Z <Rule:5:Rule.js:697> Rule#rule-kljc5802 (Schedule - Festoon Lights OFF) evaluate() acquiring mutex
      2021-02-26T11:04:13.293Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:04:13.295Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 2/min limit 60/min
      2021-02-26T11:04:13.297Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:04:13.299Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:04:00 now=2/26/2021, 11:04:13
      2021-02-26T11:04:13.300Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 46246 secs from now
      2021-02-26T11:04:13.302Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:04:15.369Z <Rule:5:Rule.js:700> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:04:15.371Z <Rule:5:Rule.js:704> Rule#rule-kljc5802 update rate is 3/min limit 60/min
      2021-02-26T11:04:15.373Z <Rule:5:Rule.js:654> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:04:15.375Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:04:00 now=2/26/2021, 11:04:15
      2021-02-26T11:04:15.377Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 46244 secs from now
      2021-02-26T11:04:15.379Z <Rule:5:Rule.js:714> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      2021-02-26T11:18:29.114Z <Rule:5:Rule.js:680> Rule#rule-kljc5802.evaluate() mutex acquired, evaluating
      2021-02-26T11:18:29.117Z <Rule:5:Rule.js:684> Rule#rule-kljc5802 update rate is 1/min limit 60/min
      2021-02-26T11:18:29.119Z <Rule:5:Rule.js:634> Rule#rule-kljc5802 evaluateExpressions() with 0 expressions
      2021-02-26T11:18:29.124Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd trange after sdt=2/26/2021, 23:55:00 edt=2/26/2021, 11:18:00 now=2/26/2021, 11:18:29
      2021-02-26T11:18:29.127Z <Rule:null> Rule#rule-kljc5802 cond cond57lqecd timer now scheduled for 2/26/2021, 23:55:00, 45390 secs from now
      2021-02-26T11:18:29.130Z <Rule:5:Rule.js:694> Rule#rule-kljc5802.evaluate() trigger state false (was false)
      • toggledbitsT Online
        toggledbitsT Online
        Grep'ing out specific lines of the log isn't really a productive thing to do, as there are other lines surrounding in context that may not contain the search string but are needed to show the full activity. It would not, for example, show an exception thrown. Just gzip the log and email it to me at the address given in the "SUPPORT" section of the about page; I'll take a look later this morning.
          Not related but I am seeing these errors in the log:
          Expression compilation error for deviceclass heatonly_thermostat hvac_control.mode: Error: Parse error on line 1:
          ...tochangeover:'auto'}[lower(value)] ?? va
          Device 190 is the Secure Boiler Relay Switch related to the Secure Thermostat device.
          2021-02-25T18:03:47.240Z <VeraController:ERR> Exception/error while updating Entity#vera>device_190
          2021-02-25T18:03:47.242Z <VeraController:CRIT> ReferenceError: expr is not defined
            OK emailed them.
            Thank you
              24:04 am here now, the lights scheduled to turn off at 23:55pm haven't turned off again.
              Here is a screen shot of the rules summary card.
              I don't know why they aren't turning off ?
                toggledbitsT Online
                Are you in 21056?
                  Are you in 21056?
                  @toggledbits Yes
                  Two more rules here both are set to run at 9am
                  One worked this morning OK and did its action, the other rule the bottom one in the screen shot, that didn't run its action.
                  This is the rule that didn't run, have I done something wrong ?
                  I've just updated to the latest version of MSR (reactor-0.1.21057-f143fd3-generic.tar) and now that rule that didn't run this morning looks like this:
                  • MatohlM Offline
                    MatohlM Offline
                    Matohl
                    So it worked after the update?
                    • MatohlM Matohl
                      @matohl I've no idea what's going on.
                      That rule that didn't run when it should of at 9am has now ran its action at 10.04am after I updated and restarted MSR etc, as it sent a notification to my phone in Telegram
                      • MatohlM Offline
                        MatohlM Offline
                        Matohl
                        Yes, it went true when you restarted (it's still after 09.00). Why it didn't run at 09.00 I can not tell, I have similar triggers that's works fine
                          I have created a lot of other rules, some of them also with Constraints and none of those rules say null or no data in the Constraints in the rules summary card.
                          I've gone through them all now again looking and it seems I only have two rules which I have highlighted above that don't run and they say or have said null or no data in Constraints.
                          All my other garden lights have turned on and off OK, but they are using a sunset offset not a specific set time.
                          But that rule to turn off the Festoon lights at 23:55pm has never run since I created it.
                          I also have rules for the window coverings setup for specific times in the morning and generally they have all run at their set times OK.
                          I will see what happens tomorrow at 9am with this "Lounge Blind Slats" one ?
                            The 11:55pm rule that never worked since I created it, I deleted it. I then created it again exactly the same as I did before. Looking at its Summary card the Constraints stated no data / null etc. I then edited the rule and changed its time to 9:00am and saved. I then edited the rule again and set it back to 11:55pm and saved.
                            The rule now runs and turns off my lights at 11:55pm or it did last night at least anyway. So assume it will work every night now.
                            I created another new rule not related to run every night at 10:30pm and that one worked first time no problems, so not sure why I have had issues with a few rules.
                            The 9am rule to open the Lounge Blind Slats didn't run this morning again, so I've deleted it and recreated it, see what happens with that tomorrow morning ?
                              toggledbitsT Online
                              Remember two things:
                              1. Log files are pretty good at telling what's going on, and really good at help me determine what's going on;
                              2. Open PRs are my highest priority.
                                I emailed the logs to you as you asked above.
                                  toggledbitsT Online
                                  OK. Not seeing an email yet... you used the address in the "Support" section of the About page?
                                      toggledbitsT Online
                                      @cw-kid I removed your post just for my own anti-spam/scraping reduction, no other reason. The address you showed is fine. If you know how to reach me in my primary domain, that's fine too. I just point out the About page because it will always be there.
                                        No worries.
                                        Check your patrick@ primary domain I sent the logs there on the 26th
                                          toggledbitsT Online
                                          Logs from two days ago don't help when (a) you've update the software, (b) the condition that was a problem now isn't, and (c) a condition that wasn't a problem now is. 🙂 Too many changes. Need fresh logs.
                                          The log does show that the rule "Heating turn ON Check Opened Windows" needs to be updated to use the hvac capability attribute (which didn't exist when you created the rule apparently, so you're using the device's extended attribute). You just need to go in and fix that rule. I don't have the "Trouble" system working yet, which will pick stuff like that up.
                                            163.4k
