  4. Need help reducing false positive notifications
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 3 Posters 2.5k Views 3 Watching
    Good day all,
    I have an notification set up for my washing machine to let me know when it's complete. I have a templete sensor set up in HAAS to let me know if it's Washing, in Standby, or off, based upon the power consumption (Shelly 1PM on outlets)
      - name: "Washing Machine"
        state: >
          {% if states("sensor.washer_switch_0_power")|float == 0  %}
            Off
          {% elif states("sensor.washer_switch_0_power")|float <= 2.9 %}
            Standby
          {% else %}
            Washing
          {% endif %}
        icon: >
          {% if states("sensor.washer_switch_0_power") == "off"  %}
          mdi:washing-machine-alert
          mdi:washing-machine-off
          {% else %}
          mdi:washing-machine
          {% endif %}
            minutes: 2
    The MSR code is relatively simple. I have a built in false positive attribute for if MSR gets rebooted, because I would suddenly get tons of notifications when I upgraded MSR.
    What I'm trying to introduce, is a way to verify that I just didn't bump the knob on the washing machine when transferring loads from the washer to the dryer, which turns on the display and brings the power above the Standby threshold.
    The power goes up to 3.7W for about 4 minutes if the selector knob is bumped/turned.
    What would the best way to do this be? I have most of my MSR code set up for a couple of years now, and my coding logic is struggling a bit.
    I think I need a power threshold to be substained for a minimum time period (say 2 or 3 minutes, above 10W), before the other triggers can act. What would the best way to do that be?
    Running: latest-25082-3c348de6
    Fedora 41 Server
    HAAS:
    Core
    2025.3.4
    Supervisor
    2025.03.4
    Operating System
    15.1
    Frontend
    20250306.0
      Any thoughts? I know I can set up a a condition to monitor the power sensor value, and make sure it is above 3.5 for 5 minutes, but the condition I need is for the power value to go to the standby value of under 2.9 after that condition is met. That's what I'm unclear how to do.
        I haven't moved this particular piece into MSR yet, but my logic is:
        • watch for idle: if watts<5 for at least 15 secs, that's done. If previous status is running, mark as completed. Otherwise, stays idle.
        • watch for watts. if idle and watts > 50 for at least 15 secs, that's running.
        I think the best way to achieve this is by having two different rules. I'll probably design it with a virtual device with a string_sensor, containing the current state. I've never moved this part of my system to MSR, because I want to write a controller doing exactly this, but the logic is not complex.
        • T tamorgen
          @tamorgen said in Need help reducing false positive notifications:
          Look at the condition options (for any condition). You'll see the ability to sequence conditions there -- set a condition so it can only go true after another condition has gone true.
          Your problem seems simpler to me, though. Maybe I just don't get the full scope from what you wrote, but what you asked for can be done without sequencing.
          If you just want to know if the machine is running, make a rule for power >5W (your 3.7W plus some headroom) sustained for at least 5 minutes (see condition options again). If you want to know if the machine is not running, make a rule for (guessing) power < 15W sustained for 5 minutes. I think you'll find these pretty effectively ignore the transitions between cycles and bumps at the controls or door left open (light on) if you get the power values right for your machine's behavior.
          Now you have two rules, one to tell you that it appears to be idle, and the other that it appears to be running. We could use one rule, but by using two rules with a gap between the power values, we create additional hysteresis to prevent those false positives. For you rules that need to react to the machine going idle, use a Rule State condition to check your idle rule; for rules that need to react to the machine running, check the running rule.
            @toggledbits ,
            Patrick,
            This is what I had come up with. I tried using latch:
            The problem I ran into, is the latch condition went true after 5 minutes, and it stayed true all the way until the first condition changed, then it went false. so the "and" of the 3 conditions never becomes true. It's like I need the latch condition to stay true for 5 seconds longer.
            I hadn't considered two rules, but I'll see if I can figure out what you mean. The sensor switch I have made within HAAS already is sort of a rule as you described, as it looks for the power to be above 2.9W, which is the minimum value I recorded over a wash cycle, as it pauses within the cycle. The 3.7W value comes from when the control panel is turned on by turning or pumping the cycle selector switch, so what happens is that it does set the sensor to Washing when the control panel is turned on, if you follow.
            • T tamorgen
              @toggledbits ,
              Patrick,
              @tamorgen Frankly, it looks like you've made an overly simplistic sensor that you're trying to improve on in the rule... you're taking a low-res image of the device and trying to make it back into something higher-res.
              I'd just look at the power directly in Reactor:
                @toggledbits,
                I tried to go about the way you mentioned, but I don't think it was quite suited for my purpose. The purpose of the rule is to send a notification through Home Assistant to my phone, and I didn't want a delay that I believe your method would have introduced. What I came up with was creating a global variable and a helper rule, that sets the global variable to true when the 300 seconds is exceeded of power being above 3.7.
                Then there is a Variable Value check in the Triggers of the Notification rule:
                The Reaction resets the Global rule back to false, after the cycle is completed.
                It may not be the most elegant method, but it reduces the false positives on my phone when the cycle selector is bumped. For the same reason, I have the reactor uptime checked, because I would get tons of notifications on my phone when I did an update to MSR, or when my server was rebooted. I know I could completely encapsulate the logic within MSR, but the overly simplistic sensor in HAAS serves it's own purpose in HAAS for my dashboard, and HAAS can't read rule states from MSR, so for my purpose, I already have the simple sensor in place, so why reinvent the wheel?
                  165.0k
