  4. Controller Z-Wave JS UI: "Location" attribute not visible in Reactor entities
2 Posts 2 Posters 636 Views 2 Watching
  • N Offline
    N Offline
    I'm on Docker/NAs (latest-26011-c621bbc7) with Zwave js ui (last version).
    I have set the 'Location' for each device in the Z-Wave JS UI dashboard, I cannot find this information among the Entity Attributes in the Reactor. I tried and the result is an empty array []. It seems the 'Location' metadata from Z-Wave JS is not being mapped to a standard attribute in Reactor. Location is equale to Rooms for me. When comparing this to the Vera or Ezlo Controller, Reactor automatically creates Room Icons also in the Reactor Dashboard and places the various devices under those room categories.
    This is a very convenient way to keep the dashboard organized and quickly find lights to turn off with a click (especially when something isn't switched off as expected for me:) ).
    Is there a way to map the Z-Wave JS UI 'Location' attribute and a dashboard organization, just like it does with Vera/Ezlo?
    Thanks in advance for all the great tips you've shared
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
      Grab ZWaveJSController build 26048. It will publish the location in zwave_device.location. It will not create groups automatically (yet), so you'll need to use DynamicGroupController to make your own.
      Rooms are going to be handled very differently in future. Right now, controllers great groups they own for rooms, and that prevents sharing of rooms between controllers (they can't modify another's groups), so you have to use DGC to manually create unified groups across controllers. That will be more automated in future.
