  4. 🎉 My very first MSR controller: OpenSprinkler
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
13 Posts 10 Posters 3.6k Views 10 Watching
    Since today is my birthday - and I still pretend to be unconventional - I'm giving away a present to this wonderful community and I'm releasing my first OpenSprinkler controller for MSR. It was real fun to code it - and while it's still WIP, it seems to work OK for me. It's polling-based at the moment, but I'll add support for updates via MQTT very soon (it's already partially coded).
    Get it at (install is similar to MQTTController and such):
    GitHub - dbochicchio/reactor-opensprinkler: OpenSprinkler controller for Reactor - Multi-Hub Automation
    OpenSprinkler controller for Reactor - Multi-Hub Automation - dbochicchio/reactor-opensprinkler
    Feel free to try it. It's beta software, but it's stable. I'll update it weekly until all the tasks from my todo list are empty.
    Since I've learnt a lot from this controller, I'll explore new controllers soon.
    wmarcolinW 1 Reply Last reply
      Happy birthday @therealdb !! Love your continued work with smart home! ☺️
        Happy birthday!
        Even though I don't use OpenSprinkler I'm excited to see a 3rd party controller for MSR
          Happy birthday!
            Happy birthday!
              RogerO
              Happy Birthday.
                Happy birthday!
                • MikeReadingtonM Offline
                  MikeReadington
                  Happy Birthday!
                  • B Offline
                    B Offline
                    basai
                    Happy Birthday !! Also, thanks for doing this. Take care, -b
                      @therealdb happy birthday !!
                        Version 221102 released on GitHub: https://github.com/dbochicchio/reactor-opensprinkler
                        New features:
                        • enable/disable programs
                        • set rain_delay programmatically (see Rain Delay entity)
                        • see more controller info
                        • MQTT support from the internal MQTT engine (to get push updates instead of polling ones - very fast and accurate to get station status and rain delay)
                        It's almost feature complete, it's running on my prod system very well and I'm looking forward to anyone trying it.
                          New features:
                          @therealdb If this only worked with Bhyve I'd be all over it 😧
                            Version 25154 on GitHub:
                            No release, just download the code.
                            Fix for station status and support for MQTT capabilities in OS 2.2.1. Still based on both HTTP/MQTT because the underline fw is still not 100% MQTT-ready.
                              163.6k
