  4. Moving MSR from a QNAP container to RP 5 - some issues
5 Posts 4 Posters 1.7k Views 4 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    I have installed MSR on a RP5 bare metal and then copied the config and store files. Everything seems to be on the RP5 but I am missing all global expression and I don't see the controller time.
    My browser is Microsoft Edge Version 135.0.3179.54 (Official build) (64-bit)
    I have probably done something stupid or missed a step but I am stuck.
    Thanks for any help.
    latest-25082-3c348de6
      the clock problem is a know bug. update to latest.
      Please be 100% extra sure to copy everything under storage. this includes any file/directory under the path. do it while bot reactors are stopped for better accuracy.
        I know I sound like a broken record, but look at the logs. At startup, much is logged, and if there are problems with file permissions (which I suspect), you'll see it mentioned there in some form.
        • Tom_DT Offline
          Tom_DT Offline
          Tom_D
          Thank you all. After many false starts, I got a bit frustrated with the process and quit with the question here.
          After learning along the way, I created a new user on the RP and started fresh. Everything seems to be working now, and I can move on to something else.
          Thanks again.
          • Tom_DT Tom_D
            Thanks again.
            @Tom_D please mark issue thread as solved
            • Tom_DT Tom_D marked this topic as a question on
            • Tom_DT Tom_D has marked this topic as solved on
