Updated doco here.
Hope it works - YMMV.
Hey guys....
long time 😉
2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0Also see these:
Hi akbooer,
tnks
donato
tnks donato
Hi @akbooer,
Hi Patrick/AK Booer
And other plugins are fine:
What's new in version 1.5:
2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hoursAll looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550.
Hi @toggledbits and others,
What does it do?
Plugin details in:
Install via AltUI:
Version 0.51
Initial release.
Version 0.52
Homebridge to Openluup
@crille I've been renaming renaming devices on my end without experiencing what you are describing. Are both Mitsubishi thermostat? Do you mind sharing an entire log output after an engine reload, additional 5 second log for the first device've value refresh and log output while rename a homebridge device from within openluup?
@ronluna Yes, both are provisioned by the same plugin and is of same physical model.
All those logs is too long to post or PM. My guess is that the luup.chdev.append overwrites the name.
2021-03-25 12:04:20.863 openLuup.scheduler:: [23] Homebridge2openLuup device startup 2021-03-25 12:04:20.863 luup_log:23: homebridge2openluup debug: luaStartUp running 2021-03-25 12:04:20.863 luup_log:23: homebridge2openluup debug: 0 --> Connected 2021-03-25 12:04:20.863 luup.variable_set:: 23.urn:ctrlable-com:serviceId:homebridge2openluup1.Connected was: 1 now: 0 #hooks:0 2021-03-25 12:04:20.863 luup_log:23: homebridge2openluup debug: 0.1 --> PluginVersion 2021-03-25 12:04:20.863 luup_log:23: homebridge2openluup debug: http://127.0.0.1:8581/ --> homebridgeURL 2021-03-25 12:04:20.863 luup_log:23: homebridge2openluup debug: DeviceList Values = T:bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f,8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd; 2021-03-25 12:04:20.863 luup.chdev.append:: [bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f] THERMOSTAT_bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f 2021-03-25 12:04:20.863 luup.chdev.append:: [8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd] THERMOSTAT_8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd 2021-03-25 12:04:20.863 luup.chdev.sync:: [23] Homebridge2openLuup, syncing children 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: URL request result: r = 1 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: URL request result: c = 201 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: URL request result: h = table: 0x55af4d7c10b0 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: response_body 1 = {"access_token":"XXXXX","token_type":"Bearer","expires_in":28800} 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: Returned web page data is : {"access_token":"XXXXX","token_type":"Bearer","expires_in":28800} 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: XXXXX --> access_token 2021-03-25 12:04:20.866 luup.variable_set:: 23.urn:ctrlable-com:serviceId:homebridge2openluup1.access_token was: XXXXX now: XXXXX #hooks:0 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: Bearer --> token_type 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: response_body_parse access_token = XXXXX 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: response_body_parse token_type = Bearer 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: response_body_parse expires_in = 28800 2021-03-25 12:04:20.866 luup_log:23: homebridge2openluup debug: 1 --> Connected
@crille said in Homebridge to Openluup:
luup.chdev.append
I'm really puzzled by this... Your logs looks just fine... The devices should not get renamed back when luup.chdev.append runs . if the devices where getting re-created the engine should be getting reloaded right away... What openluup version are you running?
Wondering if @akbooer sees something weird in how the plugin is syncing the devices after the append runs that could be causing it... at line 601 of L_Homebridge2openllup1.lua as it is something I'm not experiencing on my end... and I'm not sure where else to look...
@ronluna I'm running the openLuup version from development branch 2021.03.25b
So your log says THERMOSTAT_uuid as well on the luup.chdev.append? If so I'm guessing wrong
Is there any possibility to set the name from homebridge since it's picking up serviceName in startup?2021-03-26 13:47:13.306 luup_log:23: homebridge2openluup debug: homebridgeGetDevices91 = uniqueId bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f Type : Thermostat serviceName : Källaren 2021-03-26 13:47:13.306 luup_log:23: homebridge2openluup debug: homebridgeGetDevices92 = uniqueId 8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd Type : Thermostat serviceName : Övervåningen
Otherwise I can live with the default name, your great plugin is doing what I needed and is intended to operate in automations in the background for my implementation of it anyway.
@ronluna said in Homebridge to Openluup:
I've not been following this discussion (although I am about to install Homebridge in a Docker to give it a whirl.)
Can you briefly summarize the issue?
@crille currently the plugin relies on an initial manual configuration and the current mechanism creates the children in a very dumb way. It is possible to build a more sophisticated interface although the plugin still in a "proof of concept state".
Yes, the devices are named DeviceType_UUID by default when they are created for the first time but after that I can rename them any way I want and the names remain persistent after engine reloads.
My understanding is that once a device is renamed on your setup it will get renamed back to the default deviceType_uuid after the engine reloads right? and that's what I can't replicate on my end.
