  3. Plugins
  4. Homebridge to Openluup
Plugins
openweather plugin ?
Plugins
Openluup: Datayours
Plugins
Plugins
zigbee2mqtt and openLuup
Plugins
Plugins
Sonos system alerts truncated
Well pretty sure I didn't change or touch anything! I've turned everything on and off again as one might hope. Excepting a total reboot of the Pi3 that's running all my stuff very reliably in openLuup. It's all been working well for years and now all of sudden 6 second alerts are truncated to about 4 seconds. Occasionally it works as it should. I see this in the log - does it help? 2023-02-20 09:39:06.662 luup_log:0: My Lua ver 0.50 debug: executing scene 63: "Check windows doors" in room: "Watchers" 2023-02-20 09:39:06.663 luup.call_action:: 217.urn:micasaverde-com:serviceId:Sonos1.Alert 2023-02-20 09:39:06.663 luup.call_action:: action will be handled by parent: 214 2023-02-20 09:39:06.663 luup_log:0: My Lua ver 0.50 debug: rest of scene 63 was executed 2023-02-20 09:39:06.663 luup.scenes:: scene 63, Check windows doors, initiated by AltUI 2023-02-20 09:39:06.665 luup_log:214: Sonos: Alert action on device 217 URI "http://redacted:3480/www/sounds/AllClosed.mp3" duration "6" 2023-02-20 09:39:06.758 luup_log:214: Sonos: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>] 2023-02-20 09:39:06.759 luup_log:214: stack traceback: ./L_SonosSystem1.lua:265: in function 'error' ./L_SonosUPnP.lua:289: in function <./L_SonosUPnP.lua:169> (tail call): ? ./L_SonosSystem1.lua:3390: in function 'sayOrAlert' ./L_SonosSystem1.lua:3452: in function 'queueAlert' ./L_SonosSystem1.lua:3843: in function <./L_SonosSystem1.lua:3839> (tail call): ? [C]: in function 'pcall' ./openLuup/scheduler.lua:204: in function 'context_switch' ./openLuup/scheduler.lua:366: in function 'dispatch' ./openLuup/scheduler.lua:588: in function 'task_callbacks' ./openLuup/scheduler.lua:699: in function 'start' openLuup/init.lua:354: in main chunk [C]: ? 2023-02-20 09:39:06.888 luup.variable_set:: 214.urn:toggledbits-com:serviceId:SonosSystem1.zoneInfo was: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... now: {"zones":{"RINCON_000E58DC7BBE01400":{"Location":"http://redacted3:1400/xml/device_description.xml","Group":"RIN... #hooks:0 2023-02-20 09:39:06.895 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.TransportState was: STOPPED now: TRANSITIONING #hooks:0 2023-02-20 09:39:06.901 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentPlayMode was: SHUFFLE_NOREPEAT now: NORMAL #hooks:0 2023-02-20 09:39:06.913 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTransportActions was: Set, Stop, Pause, Play, X_DLNA_SeekTime, Next, X_DLNA_SeekTrackNr now: Set, Stop, Pause, Play, X_DLNA_SeekTime, X_DLNA_SeekTrackNr #hooks:0 2023-02-20 09:39:06.921 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.NumberOfTracks was: 10 now: 1 #hooks:0 2023-02-20 09:39:06.922 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.AVTransportURI was: x-rincon-queue:RINCON_000E58DC7BBE01400#0 now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.929 luup_log:214: Sonos: UPnP_request() "urn:schemas-upnp-org:service:AVTransport:1"#"GetPositionInfo" action took 5.0073010921478s (long) 2023-02-20 09:39:11.932 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackDuration was: 0:02:22 now: 0:00:00 #hooks:0 2023-02-20 09:39:11.933 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackURI was: x-file-cifs://ELEPHANT1/Multimedia/My%20Music/Music%20JP/The%20Smiths/The%20Queen%20Is%20Dead/08%20Vicar%20in%20a%2... now: http://redacted:3480/www/sounds/AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.934 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTrackMetaData was: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... now: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r... #hooks:0 2023-02-20 09:39:11.936 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentStatus was: Vicar in a Tutu: (The Smiths, The Queen Is Dead) now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentTitle was: Vicar in a Tutu now: AllClosed.mp3 #hooks:0 2023-02-20 09:39:11.937 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentArtist was: The Smiths now: #hooks:0 2023-02-20 09:39:11.938 luup.variable_set:: 217.urn:upnp-org:serviceId:AVTransport.CurrentAlbum was: The Queen Is Dead now: #hooks:0 Also see these: 2023-02-24 16:12:13.576 openLuup.server:: GET /www/sounds/YouRang.mp3 HTTP/1.1 tcp{client}: 0x17e96f0 2023-02-24 16:12:13.579 openLuup.server:: error 'closed' sending 43102 bytes to tcp{client}: 0x17e96f0 So any clues?
Plugins
Generic support for vacuums
Plugins
Switchboard plugin
Plugins
Plugins
Plugins
Reactor scope issues
B
Plugins
Plugins
This topic has come up before but I haven't seen an answer. Symptom: AltuUI says there is a new update available, so you tell it to do the update but the update does not happen. AltUI remains stuck on it's old version. On other occasions it works OK. So my version is: AltUI v2.49.2546, © 2019 AltUI says this: a newer version #2551 of ALTUI is available, do you want to upgrade ? add scrollable dialog for long boxes bugfix: clock display on safari remote url update ( @olov ) update jquery and bootstrap versions credential to camera device url ( @rafale77 ) ignore Ezlo hub ( @reneboer) Track through the JavaScript and find that this issues the update command: function _triggerAltUIUpgrade(newversion,newtracnum) { var url = '?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version={1}&TracRev={0}'.format(newversion,newtracnum); return _httpGet(url,{}).always( function() { PageMessage.message(_T("Upgrade Request succeeded, a Luup reload will happen"),"success"); }); }; And the url variable equals: url: "?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551" All looks good so far. I manually issue the same url complete with my openLuup ip_address in a local browser. Update fails - looks like AltUI is doing as it should: http://ip_address:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 In openLuup I see: 2021-12-06 13:56:14.821 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2021-12-06 13:56:14.838 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.49 now: v2.49 #hooks:0 And then later: 2021-12-06 13:55:58.256 openLuup.server:: GET /data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=8246&Version=40628&TracRev=2551 HTTP/1.1 tcp{client}: 0x25712a8 2021-12-06 13:55:58.257 luup.call_action:: 0.urn:micasaverde-com:serviceId:HomeAutomationGateway1.CreatePlugin 2021-12-06 13:55:58.259 luup.call_action:: 4.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2021-12-06 13:55:58.260 luup_log:4: AltAppStore : starting <run> phase... 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : downloading amg0/ALTUI [2551] to trash/AltAppStore/ 2021-12-06 13:55:58.262 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 2021-12-06 13:55:58.760 luup_log:4: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=2551 2021-12-06 13:55:59.543 luup_log:4: AltAppStore : getting contents of version: 2551 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2021-12-06 13:55:59.544 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2021-12-06 13:55:59.544 luup_log:4: AltAppStore : scheduling <job> phase... 2021-12-06 13:55:59.544 openLuup.requests:: 2021-12-06 13:55:59.545 openLuup.server:: request completed (148 bytes, 1 chunks, 1288 ms) tcp{client}: 0x25712a8 2021-12-06 13:55:59.554 openLuup.server:: request completed (6233 bytes, 1 chunks, 16442 ms) tcp{client}: 0x255e680 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : ...final <job> phase 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : Total size 0.000 (kB) 2021-12-06 13:55:59.555 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI 100% #hooks:0 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating icons in icons/ ... 2021-12-06 13:55:59.555 luup_log:4: AltAppStore : updating device files in ./ ... 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 icon files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : ... 0 device files 2021-12-06 13:55:59.556 luup_log:4: AltAppStore : Alternate UI update completed 2021-12-06 13:55:59.556 openLuup.luup:: device 4 'Alternate App Store' requesting reload 2021-12-06 13:55:59.556 luup.reload:: saving user_data 2021-12-06 13:56:00.262 openLuup.luup:: exiting with code 42 - after 0.3 hours All looks OK. Then I check GitHub. It shows the latest changes to the version 2551. However this page says the latest version is 2550. So I wondering what's going on. Seems the latest version number is not being picked by the installer? (not sure how it works.) Is it possible for openLuup to log a bit more about the version it's trying to install. As this call returns. https://api.github.com/repos/amg0/ALTUI/contents?ref=2551 message "No commit found for the ref 2551" documentation_url "https://docs.github.com/v3/repos/contents/" But this works fine: https://api.github.com/repos/amg0/ALTUI/contents?ref=2550 So it looks like AMG0 doesn't always update the repository with whatever is needed to get this to work (I imagine that's easy to forget). But could openLuup send back a fail result to AltUI and AltUI pick that up? Currently it looks like AltUI always assumes everything went OK. Or somehow; could openLuup log and/or notify the user what went wrong?
Plugins
Reactor: double click action
Plugins
Virtual Pronto Remote plugin
Plugins
openLuup: SmartSwitch plugin
Plugins
Reactor icons for local lan
B
Plugins
openLuup: Tasmota MQTT Bridge
Plugins
AltUi
Plugins
41 Posts 5 Posters 20.9k Views 5 Watching
    @ronluna I only mapped 2 devices with
    T:uuid,uuid
    also tried
    T:uuid,uuid;
    ronluna
    @crille I've been renaming renaming devices on my end without experiencing what you are describing. Are both Mitsubishi thermostat? Do you mind sharing an entire log output after an engine reload, additional 5 second log for the first device've value refresh and log output while rename a homebridge device from within openluup?
    • R ronluna
      @ronluna Yes, both are provisioned by the same plugin and is of same physical model.
      All those logs is too long to post or PM. My guess is that the luup.chdev.append overwrites the name.
      2021-03-25 12:04:20.863   openLuup.scheduler:: [23] Homebridge2openLuup device startup
      2021-03-25 12:04:20.863   luup_log:23: homebridge2openluup debug: luaStartUp running
      2021-03-25 12:04:20.863   luup_log:23: homebridge2openluup debug: 0 --> Connected
      2021-03-25 12:04:20.863   luup.variable_set:: 23.urn:ctrlable-com:serviceId:homebridge2openluup1.Connected was: 1 now: 0 #hooks:0
      2021-03-25 12:04:20.863   luup_log:23: homebridge2openluup debug: 0.1 --> PluginVersion
      2021-03-25 12:04:20.863   luup_log:23: homebridge2openluup debug: http://127.0.0.1:8581/ --> homebridgeURL
      2021-03-25 12:04:20.863   luup_log:23: homebridge2openluup debug: DeviceList Values = T:bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f,8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd;
      2021-03-25 12:04:20.863   luup.chdev.append:: [bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f] THERMOSTAT_bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f
      2021-03-25 12:04:20.863   luup.chdev.append:: [8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd] THERMOSTAT_8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd
      2021-03-25 12:04:20.863   luup.chdev.sync:: [23] Homebridge2openLuup, syncing children
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: URL request result: r = 1
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: URL request result: c = 201
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: URL request result: h = table: 0x55af4d7c10b0
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: response_body 1 = {"access_token":"XXXXX","token_type":"Bearer","expires_in":28800}
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: Returned web page data is : {"access_token":"XXXXX","token_type":"Bearer","expires_in":28800}
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: XXXXX --> access_token
      2021-03-25 12:04:20.866   luup.variable_set:: 23.urn:ctrlable-com:serviceId:homebridge2openluup1.access_token was: XXXXX now: XXXXX #hooks:0
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: Bearer --> token_type
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: response_body_parse access_token = XXXXX
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: response_body_parse token_type = Bearer
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: response_body_parse expires_in = 28800
      2021-03-25 12:04:20.866   luup_log:23: homebridge2openluup debug: 1 --> Connected
      R 1 Reply Last reply
        ronluna
        wrote on last edited by ronluna
        #32
        @crille said in Homebridge to Openluup:
        luup.chdev.append
        I'm really puzzled by this... Your logs looks just fine... The devices should not get renamed back when luup.chdev.append runs . if the devices where getting re-created the engine should be getting reloaded right away... What openluup version are you running?
        Wondering if @akbooer sees something weird in how the plugin is syncing the devices after the append runs that could be causing it... at line 601 of L_Homebridge2openllup1.lua as it is something I'm not experiencing on my end... and I'm not sure where else to look...😧
        CrilleC akbooerA 2 Replies Last reply
        • R ronluna
          luup.chdev.append
          @ronluna I'm running the openLuup version from development branch 2021.03.25b
          So your log says THERMOSTAT_uuid as well on the luup.chdev.append? If so I'm guessing wrong 🙂
          Is there any possibility to set the name from homebridge since it's picking up serviceName in startup?
          2021-03-26 13:47:13.306   luup_log:23: homebridge2openluup debug: homebridgeGetDevices91 = uniqueId bc2e86fa8031082fd9d44cd9baf66c5dfd56b96165eae2b7fc26f4314230bf7f Type : Thermostat serviceName : Källaren
          2021-03-26 13:47:13.306   luup_log:23: homebridge2openluup debug: homebridgeGetDevices92 = uniqueId 8f37721c51dc9fd6b15aad7024d6a8460038b1ee7e6fb23c732f1abc5bcfb8fd Type : Thermostat serviceName : Övervåningen
          Otherwise I can live with the default name, your great plugin is doing what I needed and is intended to operate in automations in the background for my implementation of it anyway.
          • R ronluna
            luup.chdev.append
            @ronluna said in Homebridge to Openluup:
            I've not been following this discussion (although I am about to install Homebridge in a Docker to give it a whirl.)
            Can you briefly summarize the issue?
              ronluna
              @crille currently the plugin relies on an initial manual configuration and the current mechanism creates the children in a very dumb way. It is possible to build a more sophisticated interface although the plugin still in a "proof of concept state".
              Yes, the devices are named DeviceType_UUID by default when they are created for the first time but after that I can rename them any way I want and the names remain persistent after engine reloads.
              My understanding is that once a device is renamed on your setup it will get renamed back to the default deviceType_uuid after the engine reloads right? and that's what I can't replicate on my end.
                ronluna
                @akbooer apparently on @Crille environment renaming plugin's children are not persistent after the engine reloads. although I can't replicate it on my end.
                  What versions of openLuup are you both running?
                    I'm always running the latest from development waiting to begin with MQTT. I implemented a workaround for this issue by setting my custom names in Lua startup.
                      @Crille, thanks.
                      @ronluna, if you're running an older system, then you may not have seen this change:
                      -- 2020.12.19  allow luup.chdev.append() to change device name (thanks @rigpapa)
                      This fixed an inconsistency with native Vera behaviour.
                        ronluna
                        @Crille I was using an older version. I have pushed a fixed to make device's name persistent after engine reload. please update the plugin and share the results when you get a chance.
                        Thanks @akbooer for the pointing this out.
                        • R ronluna
                          @ronluna Excellent work, the name is now persistent on reload, thank you!
                            152.6k
