Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Alerts - (vera>device_699) does not have attribute ?attr?
@cw-kid said in Alerts - (vera>device_699) does not have attribute ?attr?:
On the Everspring Flood light parent device (Binary Light) I've just looked in Vera and there is no "Armed" variable.
It would have to have been there at some point or you could not have chosen it for your rule. The list in the rule editor only shows what exists on the device/entity, not what it thinks would normally be there. So it was there at one point, and disappeared later, and this is not that unusual in the Vera world, sadly.
You can try re-creating it. It would be educational to see if it "sticks" after a reload, and after changing house mode, which aside from user action are the principal ways that variable gets played with.
@toggledbits said in Alerts - (vera>device_699) does not have attribute ?attr?:
"Tripped" I was using "Tripped" as the trigger in the rule not "Armed".
Looking in the device dump .json file I did the other day I can't see "Armed" in there either. So maybe this device never had it in the first place.
An Entity Attribute condition in rule Deck Floodlight (Disarmed) - Tripped (Day) - Send Alert failed because the referenced entity Deck Floodlight (vera>device_699) does not have attribute x_vera_svc_micasaverde_com_SecuritySensor1.Armed
oh LOL that was a Constraint. So yes looks like I was using "Armed" also at some point.
So it has vanished as you suggested.
Whew! OK... that's good (no, really). So, I have the changes for the device def. I'll send that via PM. You can drop it into your reactor/server/lib directory and restart Reactor. It should give you the standard
arming
service, with a value report of null (if it's still missing at that point -- hope so, don't change anything on the Vera yet!). Even if you don't use it, I'd like to confirm this approach would work if it comes up for other devices. -
The other issue, found that, will be fixed in today's build (restart reporting system entity missing).
OK I have uploaded the vera_devices.yaml file and restarted MSR.
For the Everspring Flood light parent device this is what I am now seeing:
SecuritySensor1.Armed is the last item in the list in the drop down box.
So what does this mean ?
It can't see the actual "Armed" state if that variable has now vanished off Vera.
It seems to think its "false" not null.
Your other snip shows the variable is there now, at the bottom of the list, therefore it has appeared and has a value, and null is not to be expected. This is exactly why I am taking this approach: the
arming
capability will make sure that itsstate
attribute always exists with a value of true, false, or null, the first two following the value ofSecuritySensor1/Armed
when it is present on the device, or getting null if it is not. This is easier to handle in rules/conditions than getting an error thrown; you can treat null and false as equivalent, in all likelihood, which is exactly what a simple is TRUE condition operation would do.For the sake of clarity, the update did not make the
Armed
variable appear on the device. It can't do that. It only affects how it reads the device data that is available. So something createdArmed
on the Vera side in the interim, perhaps Vera itself. -
But I still can't see the "Armed" variable listed in Vera. I have hard refreshed the browser.
Well, it would not be listed if it hadn't come back in user_data. If, since the last MSR restart, the Vera reported that variable even once, MSR would have it. If it later is missing, there's actually no way for MSR to know it's missing, it thinks it's just not being updated/no updates for it, so it keeps it at the last value it got. The only way to reset that cached state is to restart MSR.
This is confusing.
This is the SDATA for this device, "armed" is indeed present:
{ "name": "Deck Floodlight", "altid": "133", "id": 699, "category": 3, "subcategory": 0, "room": 5, "parent": 1, "status": "0", "configured": "1", "armedtripped": "0", "lasttrip": "1617376314", "tripped": "0", "armed": "0" },
However I cannot see that variable in the Vera UI7 web GUI even after reloading the LUUP engine and hard refreshing the browser.
Change out
sdata
forstatus
and see what it reports. -
Status output:
{ "id": 699, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SensorMlType", "value": "1" }
{ "id": 699, "states": [ { "id": 466, "service": "urn:upnp-org:serviceId:SwitchPower1", "variable": "Status", "value": "0" }
The name of the device "Deck Floodlight" cannot be found, so I searched for its ID number 699 instead and that's all I could see.
I don't know what ID 466 is ? There is no device with that ID.
Its not its altid / node id that is 133
That does not look like a complete status output. Can you post the URL you used for that query? I assume you're doing that as an HTTP request?
I just ran it in Chrome browser.
Try adding
DeviceNum
parameter, and please don't edit any of the response when posting:http://vera-ip:3480/data_request?id=status&DeviceNum=699
The 466 you were asking about earlier is the state's ID number. It's not relevant to anything, just an internal value for Luup.
There's a lot of it:
{ "Device_Num_699": { "states": [ { "id": 583, "service": "urn:upnp-org:serviceId:SwitchPower1", "variable": "Status", "value": "0" }, { "id": 584, "service": "urn:upnp-org:serviceId:SwitchPower1", "variable": "Target", "value": "0" }, { "id": 585, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "Configured", "value": "1" }, { "id": 586, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "LastUpdate", "value": "1616525032" }, { "id": 587, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "FirstConfigured", "value": "1616524758" }, { "id": 588, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "ChildrenSameRoom", "value": "1" }, { "id": 589, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "PollRatings", "value": "5.00" }, { "id": 590, "service": "urn:micasaverde-com:serviceId:HaDevice1", "variable": "ModeSetting", "value": "1:;2:;3:;4:" }, { "id": 591, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "Capabilities", "value": "211,156,1,4,7,1,L,R,B,RS,|37S,49S:5,85,89S,90S,94,108S,112S,113S:4,114S,115S,122S,133S,134S,152,159," }, { "id": 592, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "NodeInfo", "value": "55,5e,98,9f," }, { "id": 593, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "Neighbors", "value": "1,12,28,31,32,33,40,44,45,47,52,56,58,67,70,72,79,85,87,112," }, { "id": 594, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastReset", "value": "1616524754" }, { "id": 595, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "VariablesSet", "value": "1-PIR Trigger Off period,2d,60,2-Lux sensor threshold,2d,30,3-Lux auto report,2d,1" }, { "id": 596, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SecurityFailed", "value": "0" }, { "id": 597, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "ManufacturerInfo", "value": "96,18,1" }, { "id": 598, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "VersionInfo", "value": "3,4,61,1,1" }, { "id": 599, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AlarmType", "value": "0x7,0x8," }, { "id": 600, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AlarmVersion", "value": "0,2" }, { "id": 601, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SubscribedAlarms", "value": ",0x7,0x8," }, { "id": 602, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "SensorMlType", "value": "3" }, { "id": 603, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "PlusInfo", "value": "1,5,0,12,7,12,7" }, { "id": 604, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "FirmwareInfo", "value": "96,4609,29529" }, { "id": 605, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AgiInfo", "value": "X" }, { "id": 606, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "ConfiguredAssoc", "value": "" }, { "id": 607, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "ConfiguredVariable", "value": "1-PIR Trigger Off period,2d,60,2-Lux sensor threshold,2d,30,3-Lux auto report,2d,1" }, { "id": 608, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "PollSettings", "value": "60" }, { "id": 609, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "VariablesGet", "value": "1,60,2,30,3,1," }, { "id": 610, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "PollOk", "value": "2" }, { "id": 611, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "AssociationNum", "value": "0" }, { "id": 612, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastRouteUpdate", "value": "1616525092" }, { "id": 613, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastNnu", "value": "1617238807,7" }, { "id": 614, "service": "urn:micasaverde-com:serviceId:ZWaveDevice1", "variable": "LastArr", "value": "1617238811,7" }, { "id": 615, "service": "urn:micasaverde-com:serviceId:ZWaveNetwork1", "variable": "LastPollSuccess", "value": "1616525034" }, { "id": 616, "service": "urn:micasaverde-com:serviceId:ZWaveNetwork1", "variable": "ConsecutivePollFails", "value": "0" }, { "id": 617, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "IgnoreTripTime", "value": "2" }, { "id": 618, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "ArmedTripped", "value": "0" }, { "id": 619, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "LastTrip", "value": "1617376314" }, { "id": 620, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "Tripped", "value": "0" }, { "id": 621, "service": "urn:micasaverde-com:serviceId:SecuritySensor1", "variable": "Armed", "value": "0" } ], "Jobs": [ ], "PendingJobs": 0, "tooltip": { "display": 0 }, "status": -1 }, "Using_2G": 0, "LoadTime": 1617383774, "DataVersion": 383787633, "UserData_DataVersion": 383774040, "TimeStamp": 1617390782, "lights_on": 13, "lights_off": 43, "doors_locked": 0, "doors_unlocked": 0, "sensors_tripped": 0, "sensors_not_tripped": 24, "failed_devices": 0, "visible_devices": 149, "partitions_active": 0, "partitions_notactive": 0, "alerts": [ { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "35995388862", "LocalDate": "2021-03-31 06:24:21", "EventType": 16, "SourceType": 5, "Argument": 1, "Filesize": 0, "Severity": 5, "LocalTimestamp": 1617168261, "Code": "offline", "NewValue": "1", "Description": "Device NOT responding", "Users": "", "Server_Storage": "", "Key": "", "Icon": "error.png", "PK_Store": "0" }, { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "35995486322", "LocalDate": "2021-03-31 07:30:55", "EventType": 16, "SourceType": 5, "Argument": 0, "Filesize": 0, "Severity": 5, "LocalTimestamp": 1617172255, "Code": "offline", "NewValue": "0", "Description": "Device responding again", "Users": "", "Server_Storage": "", "Key": "", "Icon": "error.png", "PK_Store": "0" }, { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36007081772", "LocalDate": "2021-03-31 23:15:25", "EventType": 3, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 1, "LocalTimestamp": 1617228925, "Code": "DL_ARMEDTRIPPED", "NewValue": "1", "Description": "Lounge Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "", "PK_Store": "0" }, { "PK_Device": 331, "Room": 1, "DeviceName": "Lounge Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36007090092", "LocalDate": "2021-03-31 23:15:58", "EventType": 4, "SourceType": 4, "Argument": 0, "Filesize": 0, "Severity": 1, "LocalTimestamp": 1617228958, "Code": "DL_ARMEDTRIPPED", "NewValue": "0", "Description": "Lounge Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034063812", "LocalDate": "2021-04-02 12:54:57", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617364497, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034387302", "LocalDate": "2021-04-02 13:23:04", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617366184, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 694, "Room": 3, "DeviceName": "Porch Motion Sensor", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034718782", "LocalDate": "2021-04-02 13:53:19", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617367999, "Code": "", "NewValue": "1", "Description": "Porch Motion Sensor", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034775722", "LocalDate": "2021-04-02 13:58:47", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617368327, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034882632", "LocalDate": "2021-04-02 14:08:12", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617368892, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" }, { "PK_Device": 290, "Room": 5, "DeviceName": "Deck Motion", "DeviceType": "urn:schemas-micasaverde-com:device:MotionSensor:1", "PK_Alert": "36034926972", "LocalDate": "2021-04-02 14:12:02", "EventType": 12, "SourceType": 3, "Argument": 0, "Filesize": 0, "Severity": 0, "LocalTimestamp": 1617369122, "Code": "", "NewValue": "1", "Description": "Deck Motion", "Users": "", "Server_Storage": "", "Key": "", "Icon": "burglar.png", "PK_Store": "0" } ], "ZWaveStatus": 1, "Mode": 1, "LocalTime": "2021-04-02 20:13:02 N" }
"Lounge Motion" not sure why that is referenced in there? That is a motion sensor in the lounge room.
"Deck Motion" is the virtual motion sensor I created to work with this Everspring Flood light parent device #699
Can see "Porch Motion Sensor" mentioned as well, that is an outdoor Everspring motion sensor not related.
