  4. MQTT action & expressions
6 Posts 3 Posters 2.2k Views 3 Watching
    I have a case where I'm trying to send a MQTT message similar to the example below:
    Topic: pool/set
      "command": 4,
      "value": 1,
      "time": 0,
      "interval": 0
    But I need to set "value" so that it is an integer between 20-30. I thought I could use "dimming" capability here, but there's probably a better way. @therealdb ?
      Topic: pool/set
        "command": 4,
        "value": 1,
        "time": 0,
        "interval": 0
      @tunnus yep, dimming is probably fine, but if you're sending a temperature, I'll go with hvac_heating_unit.set_setpoint.
      I truly love the ability to map things to "virtual devices", it's so refreshing when compared to the old vera way and I built a custom dashboard that's mapping things directly from MSR APIs and reusing standard capabilities is my favorite thing.
        @therealdb so something like below?
        template:
          pool_set_temp:
            type: hvac_heating_unit ???
            capabilities: ["hvac_heating"]
            primary_attribute: hvac_heating_unit.setpoint ???
            actions:
              hvac_heating:
                set_setpoint:
                  topic: "pool/set"
                  payload:
                    type: json
                    expr: "{ 'command': 4, 'value': set_setpoint, 'time': 0, 'interval': 0 }"
        Also, there would need to be a check for value range of 20-30, so adding that, maybe something like below could work?
        expr: "{ 'command': 4, 'value': min( 30, max( 20, int( set_setpoint ) ) ), 'time': 0, 'interval': 0 }"
          @tunnus Small correction to the capability name in the array:
              capabilities: [ hvac_heating_unit ]
          Also, you don't need the single quotes in the expression, because none of the key names in the object contains any special characters.
          The type would not apply with this entity, because I have no yet provided widget that works with HVAC capabilities in the dashboard (type is a dashboard hint).
          Edit: I whipped up superficial support for hvac_heating/cooling_unit in the Dashboard, in build 24137. It will get embellishments later.
            template:
              pool_set_temp:
                actions:
                  hvac_heating:
                    set_setpoint:
                      topic: "pool/set"
                      payload:
                        type: json
            @tunnus almost there. expression should get the value from setpoint attribute via parameters.
            so:
              pool_set_temp:
                capabilities: [hvac_heating]
                actions:
                  hvac_heating:
                    set_setpoint:
                      topic: "pool/set"
                      payload:
                        type: json
                        expr: { 'command': 4, 'value': min( 30, max( 20, int( parameters.setpoint ) ) ), 'time': 0, 'interval': 0 }
            EDIT: I don't know if you're controlling this device only via MQTT and/or you want to update its status via MQTT, but in this case look at events. Best example from https://github.com/dbochicchio/reactor-mqtt-contrib is imho shelly_relay_power.yaml
              so:
                pool_set_temp:
                  actions:
                    hvac_heating:
                      set_setpoint:
                        topic: "pool/set"
                        payload:
                          type: json
              @therealdb & @toggledbits it wasn't that easy... I finally got this working, but it took a couple of iterations. Correct version below:
              pool_set_temp:
                  actions:
                    hvac_heating_unit:
                      set_setpoint:
                        topic: "pool/set"
                        payload:
                          type: json
                          expr: '{ "command": 4, "value": min( 30, max( 20, int( parameters.setpoint ) ) ), "time": 0, "interval": 0 }'
              Devil is in the details I guess.
              • tunnusT tunnus marked this topic as a question on
              • tunnusT tunnus has marked this topic as solved on
                160.0k
