Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Having issues with a shell command
Actually I have five MSR rules for the Playstation. I have another one that is also monitoring for the Harmony Activity starting, this rule closes the lounge blind and curtains if its daytime.
Would having two rules monitoring for the same trigger event, the Harmony Activity starting, have any affect on things?
Maybe one rule hi-jacks the other from triggering sometimes ?
@cw-kid said in Having issues with a shell command:
I'm not sure, I will look out for when it happens again.
The goal I propose is to write a script that runs
ps4-waker
itself, and retries if it fails to connect. MSR would then run that script instead of runningps4-waker
directly. If, for example, theps4-waker
script simply returns no data (empty) result, then something like this would work:#!/bin/sh while true; do # Run command and capture its output and exit status output=`ps4-waker $*` status=$? # If output was produced, stop looping. if [ -n "$output" ]; then break; fi sleep 1 # slow retries down a little done # Echo back the command output and exit with its exit status. echo "$output" exit $status
Save this as
ps4-wrapper.sh
in the Reactor install directory (or somewhere along the path, like whereps4-waker
currently is), and give it execute permissions (chmod 755 ps4-wrapper.sh
).The wrapper script can be run in place of
ps4-waker
, with the same arguments (e.g.ps4-wrapper.sh status
). If a request fails and produces no output, it is simply re-run until output is produced (or until the command times out in Reactor, when it is killed). -
No, each rule has its own supervision of its entities of interest, etc. You'd be able to quickly confirm this by looking in the logs and seeing that the SET reactions for both rules run.
Great thanks I will try this approach instead then.
But first I will leave things as is and see what happens? when it doesn't turn on the PS4 on first attempt.
It might just return no data in the response as you suggest, or it may as I seem to think, return something else, which I haven't documented here in this thread yet. But I can't remember off the top of my head what it was doing.
This isn't related to when the PS4 doesn't turn on.
When the PS4 is OFF / sleep mode, I am seeing this error alert appearing, to do with the parsing of the output to JSON.
I assume this alert occurs if the "ps4-waker check" command hasn't worked and initially pulled in the data ?
Maybe I need two wrapper scripts then, one for turning on the power and one for the check command also.
Regarding the power on issue and maybe using a wrapper script.
When I manually run the "ps4-waker" command in terminal this is the output I get back:
WAKEUP sent to device... 192.168.0.201
I don't see any alert in MSR gui when it fails to turn on the PS4 on its first and currently only attempt to do so.
Looking in the log I can't see anything there either as to why the command didn't turn on the PS4 ?
2021-08-04T13:08:32.530Z <Rule:5:Rule.js:660> Rule#rule-krpft5eh rule set variable ps4waker = (string) 2021-08-04T13:08:32.533Z <Engine:5:Engine.js:945> Engine#1 set variable rule rule-krpft5eh ps4waker=, requesting re-eval 2021-08-04T13:08:32.534Z <Rule:5:Rule.js:956> Rule#rule-krpft5eh (Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command) evaluate() acquiring mutex 2021-08-04T13:08:32.535Z <Engine:5:Engine.js:1145> _process_reaction_queue() wake-up! 2021-08-04T13:08:32.536Z <Rule:5:Rule.js:960> Rule#rule-krpft5eh._evaluate() mutex acquired, evaluating 2021-08-04T13:08:32.537Z <Rule:5:Rule.js:964> Rule#rule-krpft5eh update rate is 6/min limit 60/min 2021-08-04T13:08:32.537Z <Rule:5:Rule.js:887> Rule#rule-krpft5eh evaluateExpressions() with 1 expressions 2021-08-04T13:08:32.538Z <Rule:5:Rule.js:976> Rule#rule-krpft5eh._evaluate() trigger state now true (was true) 2021-08-04T13:08:32.539Z <Rule:5:Rule.js:978> Rule#rule-krpft5eh._evaluate() constraints state true 2021-08-04T13:08:32.540Z <Rule:5:Rule.js:987> Rule#rule-krpft5eh rule state now true, changed no 2021-08-04T13:08:32.541Z <Engine:5:Engine.js:1106> _process_reaction_queue() running task 2261 { "tid": 2261, "id": "rule-krpft5eh:S", "rule": "rule-krpft5eh", "__reaction": [RuleReaction#rule-krpft5eh:S], "next_step": 3, "status": 1, "ts": 1628082499978, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 2 } 2021-08-04T13:08:32.542Z <Engine:NOTICE> Resuming reaction Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command<SET> (rule-krpft5eh:S) from step 3 2021-08-04T13:08:32.542Z <Engine:INFO> Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command<SET> all actions completed. 2021-08-04T13:08:32.543Z <Engine:5:Engine.js:1110> _process_reaction_queue() task returned, new status -1; task 2261 2021-08-04T13:08:32.545Z <Engine:5:Engine.js:1145> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting 2021-08-04T13:08:32.832Z <Rule:5:Rule.js:748> Rule#rule-knn2os0h dependency notification entity-changed Entity#vera>device_184 from Entity#vera>device_184 2021-08-04T13:08:32.834Z <Rule:5:Rule.js:754> Rule#rule-knn2os0h requesting eval; entity-changed Entity#vera>device_184 2021-08-04T13:08:32.836Z <Rule:5:Rule.js:748> Rule#rule-klkppx0h dependency notification entity-changed Entity#vera>device_184 from Entity#vera>device_184 2021-08-04T13:08:32.837Z <Rule:5:Rule.js:754> Rule#rule-klkppx0h requesting eval; entity-changed Entity#vera>device_184 2021-08-04T13:08:32.838Z <Rule:5:Rule.js:748> Rule#rule-krpft5eh dependency notification entity-changed Entity#vera>device_184 from Entity#vera>device_184 2021-08-04T13:08:32.839Z <Rule:5:Rule.js:754> Rule#rule-krpft5eh requesting eval; entity-changed Entity#vera>device_184 2021-08-04T13:08:32.839Z <Rule:5:Rule.js:956> Rule#rule-knn2os0h (Lounge - Harmony XBOX Activity Start - Close Window Coverings (Day)) evaluate() acquiring mutex 2021-08-04T13:08:32.840Z <Rule:5:Rule.js:956> Rule#rule-klkppx0h (Lounge - Harmony Powered OFF - Turn OFF LED strips) evaluate() acquiring mutex 2021-08-04T13:08:32.841Z <Rule:5:Rule.js:956> Rule#rule-krpft5eh (Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command) evaluate() acquiring mutex 2021-08-04T13:08:32.841Z <Rule:5:Rule.js:960> Rule#rule-knn2os0h._evaluate() mutex acquired, evaluating 2021-08-04T13:08:32.842Z <Rule:5:Rule.js:964> Rule#rule-knn2os0h update rate is 6/min limit 60/min 2021-08-04T13:08:32.843Z <Rule:5:Rule.js:887> Rule#rule-knn2os0h evaluateExpressions() with 0 expressions 2021-08-04T13:08:32.844Z <Rule:5:Rule.js:976> Rule#rule-knn2os0h._evaluate() trigger state now false (was false) 2021-08-04T13:08:32.846Z <Rule:5:Rule.js:978> Rule#rule-knn2os0h._evaluate() constraints state false 2021-08-04T13:08:32.847Z <Rule:5:Rule.js:987> Rule#rule-knn2os0h rule state now false, changed no 2021-08-04T13:08:32.847Z <Rule:5:Rule.js:960> Rule#rule-klkppx0h._evaluate() mutex acquired, evaluating 2021-08-04T13:08:32.848Z <Rule:5:Rule.js:964> Rule#rule-klkppx0h update rate is 6/min limit 60/min 2021-08-04T13:08:32.848Z <Rule:5:Rule.js:887> Rule#rule-klkppx0h evaluateExpressions() with 0 expressions 2021-08-04T13:08:32.849Z <Rule:5:Rule.js:976> Rule#rule-klkppx0h._evaluate() trigger state now true (was true) 2021-08-04T13:08:32.850Z <Rule:5:Rule.js:978> Rule#rule-klkppx0h._evaluate() constraints state false 2021-08-04T13:08:32.851Z <Rule:5:Rule.js:987> Rule#rule-klkppx0h rule state now false, changed no 2021-08-04T13:08:32.851Z <Rule:5:Rule.js:960> Rule#rule-krpft5eh._evaluate() mutex acquired, evaluating 2021-08-04T13:08:32.852Z <Rule:5:Rule.js:964> Rule#rule-krpft5eh update rate is 7/min limit 60/min 2021-08-04T13:08:32.853Z <Rule:5:Rule.js:887> Rule#rule-krpft5eh evaluateExpressions() with 1 expressions 2021-08-04T13:08:32.854Z <Rule:5:Rule.js:976> Rule#rule-krpft5eh._evaluate() trigger state now true (was true) 2021-08-04T13:08:32.854Z <Rule:5:Rule.js:978> Rule#rule-krpft5eh._evaluate() constraints state true 2021-08-04T13:08:32.856Z <Rule:5:Rule.js:987> Rule#rule-krpft5eh rule state now true, changed no 2021-08-04T13:08:33.082Z <Rule:5:Rule.js:748> Rule#rule-knn2os0h dependency notification entity-changed Entity#vera>device_184 from Entity#vera>device_184 2021-08-04T13:08:33.083Z <Rule:5:Rule.js:754> Rule#rule-knn2os0h requesting eval; entity-changed Entity#vera>device_184 2021-08-04T13:08:33.084Z <Rule:5:Rule.js:748> Rule#rule-klkppx0h dependency notification entity-changed Entity#vera>device_184 from Entity#vera>device_184 2021-08-04T13:08:33.085Z <Rule:5:Rule.js:754> Rule#rule-klkppx0h requesting eval; entity-changed Entity#vera>device_184 2021-08-04T13:08:33.086Z <Rule:5:Rule.js:748> Rule#rule-krpft5eh dependency notification entity-changed Entity#vera>device_184 from Entity#vera>device_184 2021-08-04T13:08:33.087Z <Rule:5:Rule.js:754> Rule#rule-krpft5eh requesting eval; entity-changed Entity#vera>device_184 2021-08-04T13:08:33.088Z <Rule:5:Rule.js:956> Rule#rule-knn2os0h (Lounge - Harmony XBOX Activity Start - Close Window Coverings (Day)) evaluate() acquiring mutex 2021-08-04T13:08:33.089Z <Rule:5:Rule.js:956> Rule#rule-klkppx0h (Lounge - Harmony Powered OFF - Turn OFF LED strips) evaluate() acquiring mutex 2021-08-04T13:08:33.090Z <Rule:5:Rule.js:956> Rule#rule-krpft5eh (Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command) evaluate() acquiring mutex 2021-08-04T13:08:33.090Z <Rule:5:Rule.js:960> Rule#rule-knn2os0h._evaluate() mutex acquired, evaluating 2021-08-04T13:08:33.091Z <Rule:5:Rule.js:964> Rule#rule-knn2os0h update rate is 7/min limit 60/min 2021-08-04T13:08:33.091Z <Rule:5:Rule.js:887> Rule#rule-knn2os0h evaluateExpressions() with 0 expressions 2021-08-04T13:08:33.092Z <Rule:5:Rule.js:976> Rule#rule-knn2os0h._evaluate() trigger state now false (was false) 2021-08-04T13:08:33.093Z <Rule:5:Rule.js:978> Rule#rule-knn2os0h._evaluate() constraints state false 2021-08-04T13:08:33.094Z <Rule:5:Rule.js:987> Rule#rule-knn2os0h rule state now false, changed no 2021-08-04T13:08:33.095Z <Rule:5:Rule.js:960> Rule#rule-klkppx0h._evaluate() mutex acquired, evaluating 2021-08-04T13:08:33.095Z <Rule:5:Rule.js:964> Rule#rule-klkppx0h update rate is 7/min limit 60/min 2021-08-04T13:08:33.096Z <Rule:5:Rule.js:887> Rule#rule-klkppx0h evaluateExpressions() with 0 expressions 2021-08-04T13:08:33.097Z <Rule:5:Rule.js:1595> cond cond58zlosr evaluation state true->false 2021-08-04T13:08:33.098Z <Rule:5:Rule.js:1595> cond trig evaluation state true->false 2021-08-04T13:08:33.098Z <Rule:5:Rule.js:976> Rule#rule-klkppx0h._evaluate() trigger state now false (was true) 2021-08-04T13:08:33.099Z <Rule:5:Rule.js:978> Rule#rule-klkppx0h._evaluate() constraints state false 2021-08-04T13:08:33.100Z <Rule:5:Rule.js:984> Rule#rule-klkppx0h trigger conditions not met 2021-08-04T13:08:33.100Z <Rule:5:Rule.js:987> Rule#rule-klkppx0h rule state now false, changed no 2021-08-04T13:08:33.102Z <Rule:5:Rule.js:960> Rule#rule-krpft5eh._evaluate() mutex acquired, evaluating 2021-08-04T13:08:33.103Z <Rule:5:Rule.js:964> Rule#rule-krpft5eh update rate is 8/min limit 60/min 2021-08-04T13:08:33.103Z <Rule:5:Rule.js:887> Rule#rule-krpft5eh evaluateExpressions() with 1 expressions 2021-08-04T13:08:33.104Z <Rule:5:Rule.js:976> Rule#rule-krpft5eh._evaluate() trigger state now true (was true) 2021-08-04T13:08:33.105Z <Rule:5:Rule.js:978> Rule#rule-krpft5eh._evaluate() constraints state true 2021-08-04T13:08:33.105Z <Rule:5:Rule.js:987> Rule#rule-krpft5eh rule state now true, changed no
I will try and implement the script now.
I've created the ps4-wrapper.sh file and made it executable and placed it in to the Reactor root directory as I cannot find where the actual ps4-waker utility is installed / located on the system.
When I try to run the script in terminal I get errors:
root@HP-Thin01:/home/stuart/reactor# bash ps4-wrapper.sh ps4-wrapper.sh: line 15: syntax error: unexpected end of file root@HP-Thin01:/home/stuart/reactor# sh ps4-wrapper.sh ps4-wrapper.sh: 14: ps4-wrapper.sh: Syntax error: end of file unexpected (expecting "then") root@HP-Thin01:/home/stuart/reactor#
Also how do I modify the MSR rules to run the script instead of the command directly ?
I tried this:
EDIT:
Seems it didn't like me creating the script in Notepad++ on Windows and copying it over to the Debian machine.
So I deleted the script and created it again using nano editor on Debian and now I can run the script OK from the terminal window and the PS4 did turn ON.
However I cannot run the script from the MSR rule still, nothing seems to happen when I play the reaction.
I can't see any errors related to ps4-wrapper.sh
2021-08-04T14:14:30.725Z <Engine:5:Engine.js:1145> _process_reaction_queue() wake-up! 2021-08-04T14:14:30.731Z <Engine:5:Engine.js:1106> _process_reaction_queue() running task 2373 { "tid": 2373, "id": "rule-krpft5eh:S", "rule": "rule-krpft5eh", "__reaction": [RuleReaction#rule-krpft5eh:S], "next_step": 1, "status": 0, "ts": 1628086468720, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 } 2021-08-04T14:14:30.731Z <Engine:NOTICE> Resuming reaction Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command<SET> (rule-krpft5eh:S) from step 1 2021-08-04T14:14:30.732Z <Engine:INFO> Engine#1 reaction Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command<SET> (rule-krpft5eh:S) step 2 shell command: ps4-wrapper.sh 2021-08-04T14:14:30.733Z <Engine:5:Engine.js:1382> Engine#1 action data { "command": "ps4-wrapper.sh", "rule": "rule-krpft5eh", "rvar": "ps4waker", "ignore_exit": true } 2021-08-04T14:14:30.749Z <Engine:5:Engine.js:1110> _process_reaction_queue() task returned, new status 3; task 2373 2021-08-04T14:14:30.751Z <Engine:5:Engine.js:1145> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting 2021-08-04T14:14:30.755Z <Rule:5:Rule.js:660> Rule#rule-krpft5eh rule set variable ps4waker = (string) 2021-08-04T14:14:30.755Z <Engine:5:Engine.js:945> Engine#1 set variable rule rule-krpft5eh ps4waker=, requesting re-eval 2021-08-04T14:14:30.756Z <Rule:5:Rule.js:956> Rule#rule-krpft5eh (Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command) evaluate() acquiring mutex 2021-08-04T14:14:30.757Z <Engine:5:Engine.js:1145> _process_reaction_queue() wake-up! 2021-08-04T14:14:30.758Z <Rule:5:Rule.js:960> Rule#rule-krpft5eh._evaluate() mutex acquired, evaluating 2021-08-04T14:14:30.758Z <Rule:5:Rule.js:964> Rule#rule-krpft5eh update rate is 1/min limit 60/min 2021-08-04T14:14:30.759Z <Rule:5:Rule.js:887> Rule#rule-krpft5eh evaluateExpressions() with 1 expressions 2021-08-04T14:14:30.760Z <Rule:5:Rule.js:976> Rule#rule-krpft5eh._evaluate() trigger state now true (was true) 2021-08-04T14:14:30.761Z <Rule:5:Rule.js:978> Rule#rule-krpft5eh._evaluate() constraints state true 2021-08-04T14:14:30.762Z <Rule:5:Rule.js:987> Rule#rule-krpft5eh rule state now true, changed no 2021-08-04T14:14:30.763Z <Engine:5:Engine.js:1106> _process_reaction_queue() running task 2373 { "tid": 2373, "id": "rule-krpft5eh:S", "rule": "rule-krpft5eh", "__reaction": [RuleReaction#rule-krpft5eh:S], "next_step": 3, "status": 1, "ts": 1628086468720, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 2 } 2021-08-04T14:14:30.764Z <Engine:NOTICE> Resuming reaction Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command<SET> (rule-krpft5eh:S) from step 3 2021-08-04T14:14:30.764Z <Engine:INFO> Lounge - Harmony PS4 Activity Start - Wake PS4 Shell Command<SET> all actions completed. 2021-08-04T14:14:30.765Z <Engine:5:Engine.js:1110> _process_reaction_queue() task returned, new status -1; task 2373 2021-08-04T14:14:30.767Z <Engine:5:Engine.js:1145> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting 2021-08-04T14:14:34.579Z <EzloController:5:EzloController.js:1069> EzloController#ezlo-plus received message 485 bytes
Just seen an unrelated error in the logs
<EzloController:ERR> EzloController#ezlo-plus no implementation mapping for attributes from match * cap x_ezlo_object
When you create the file on Windows in Notepad++, it will get Windows line endings (CR+LF) instead of Unix line endings (LF alone) and that confuses the shell. You can select the right line endings under the Edit > EOL Conversion in Notepad++.
If you modified the
ps4-waker
command to be anything other thanps4-waker $*
put it back the way I gave it to you. That lets you run the wrapper script with arguments on the command line that will get passed through, like this:./ps4-wrapper.sh status
or./ps4-wrapper.sh somethingelse
In the MSR rule, you should use
/full/path/to/ps4-wrapper.sh arguments
Top tip thanks, I have changed that setting now in Notepad++
If you modified the ps4-waker command to be anything other than ps4-waker $* put it back the way I gave it to you. That lets you run the wrapper script with arguments on the command line that will get passed through, like this: ./ps4-wrapper.sh status or ./ps4-wrapper.sh somethingelse
I haven't change the script, that line still says
In the terminal I can use this command and it works and outputs the response
sh ps4-wrapper.sh check
So the argument is passed OK.
I can also just run this command which turns on the PS4
sh ps4-wrapper.sh
There is no argument for the command for turning on the PS4 as the command is just
ps4-waker
So maybe this is the problem?
However I am unsure how to run the .sh file from my MSR rules?
Best way is to use
, but you may also get away with./ps4-wrapper.sh arguments
if it's in the Reactor install directory. Remember to set the file permissions for read and execute. -
./ps4-wrapper.sh
Seems to do the trick, the PS4 now turns on when this rules trigger happens, which is the Harmony Activity Starting.
I will modify the other rules now to use the wrapper script instead of issuing the commands directly.
Thanks again.
Excellent. If you've got a backup script running that takes care of just your
config
andstorage
, remember to add your wrapper script to its list of things to copy, since it's not in one of those directories. -
If you've got a backup script running that takes care of just your config and storage
I haven't got one, but I could really do with having a backup script running to copy those folders off the HP Thin Client to maybe my Windows file server or something. Or maybe even to a USB stick in the Thin Client if I can find a spare one big enough.
Those directories don't get very large, so a network copy is fine and will go fast. I distrust USB sticks, especially when left in devices, as they often have poor thermal management (not built to be left inserted full time) and degrade quickly like that, with little or no warning. Your backup media should be as reliable as possible.
Ezlo error is benign. I'll quiet it down.
I've just checked:
Storage = 1.08MB
Config = 20.4KB
So yeah pretty small.
I will have to do some Googling how to create a script and schedule it to run, to copy the folders and files to my Windows server, as I have no idea how to do it under Debian terminal.
There is no desktop on that HP Thin Client running MSR.
in fact an inbuilt backup feature in MSR would be nice to have.
I'll think about it, but my thoughts on it so far aren't leaning towards it.
It would have to be cross-platform (Windows, any flavor of Linux you can imagine including Macs, etc.), and to be at all effective, be able to store the backup somewhere other than the place it's backing up... a separate local volume? Windows server? NAS? An NFS share on a Linux server? SCP? FTP? RSYNC? HTTP PUT/POST?... so many options. Reliable backup depends on the local environment quite heavily, and your local knowledge of it and the risks you identify. Unlike Vera, this isn't a contained problem for a canned solution on proprietary hardware and software supported by a controlled cloud. And then, of course, people are going to want a one-click restore, and maybe even partial restore.
Maybe someday there will be backup, but for the moment, it's not a priority and anything I do is all but guaranteed to be a large effort that yields an inadequate result.
Yes I understand what you are saying and there could be many different ways to skin that cat.
But how about a more universal option? Most people will have a Google Drive or Microsoft One Drive cloud storage with their user accounts.
Could a backup option be added to upload to those types of cloud storage services?
Everything appears to all be working nicely now.
The only issue is sometimes I see this error alert
I assume it happens when the "ps4wakercheck" variable hasn't been populated with any data and therefore the "ps4wakerparse" variable has nothing to parse.
The ps4waker check rule is now using the wrapper script also, so if for whatever reason it didn't get data returned on its first attempt, it does on the second or subsequent attempts.
